(PAGING internet auto martor whoever can help)oil leaking on bushing
Old Nov 17, 2005 | 09:45 AM
magicdonjohn's Avatar
oil is leaking on my bushing after i changed my motor. i though it was coming from the oil filter but its not. can u tell me what kinda seal i need and also do u sell it. thanx in advance
Old Nov 17, 2005 | 10:11 AM
NismoChi's Avatar
What bushing??Where?? Can you be more specific.
Also, (if possible) a pic worth a thousand words.
Old Nov 17, 2005 | 10:38 AM
sorry bout that. the lower control arm bushing by the passenger side tire
Old Nov 17, 2005 | 10:51 AM
Greeny's Avatar
¯\(°_o)/¯
There are 2 places you need to check for the leak..
1. Check your power steering pressure hose for a leak in the hose..It is on the passenger side behind the stut tower,it runs down behind the engine to the pump..
2. Check around the bottom engine pulley for oil leaking around it....
Old Nov 17, 2005 | 04:05 PM
its not the power steering pressure hose. is it a seal or sumthin for the engine pully?
Old Nov 17, 2005 | 04:54 PM
internetautomar's Avatar
mod or sell?
it's probably the front crank seal.
Very common to go bad and it took out 2 bushings on my old max
Old Nov 18, 2005 | 03:31 AM
CyMax's Avatar
....and as long as you have to pull the crank pully... excellant time for a UDP install!!! You should be happy you now have an excuse for an upgrade!!! There are a few excellant writeups on UDP installs, sure made mine a breeze.
Old Nov 18, 2005 | 06:58 AM
mod or sell?
that's when I did my old one.
I got the UDP and replaced the seal
Old Nov 18, 2005 | 09:45 AM
do u sell the seal and the UDP?
Old Nov 18, 2005 | 10:45 AM
mod or sell?
the seal yes, the UDP no
ASP sells it fairly cheaply
Old Nov 18, 2005 | 09:59 PM
fastflyingasian's Avatar
i have the same leak over the one bushing on the lower control arm. ever since i did the udp it has leaked and havnt the motivation to fix it . do an udp its worth it especially since your there.
Mar 12, 2020 12:06 AM
bbsitum
Sep 6, 2019 07:31 PM
Starrider
Dec 18, 2015 04:43 AM
seesole
Sep 14, 2015 12:38 PM
ag90fox
Sep 9, 2015 12:22 PM
