How to ground the starter? (making grounding kit)
Old Sep 28, 2008 | 11:56 AM
metalpiotr's Avatar
03 Maxima, 6spd
I'm making my own grounding kit. I already grounded the battery negative to chassis and alternator ground to chassis (and have noticed smoother revs). I've been hearing that grounding the starter can result in quicker starts so for those of you who had done it, I am wondering how you did it.
Somewhere I read that the starter is grounded through its case, so where would be the best place to attach the ground? Should I attach the ground cable to one of the screws/small bolts that go into the case, or one of the two big mounting bolts?
Old Sep 28, 2008 | 02:45 PM
johnnyd2k2's Avatar
On the case I think it's an 8mm long bolt it goes all the way through the starter then to the frame there should be a threaded hole close to it about 9" away you will see it when you start looking
Old Sep 28, 2008 | 10:25 PM
CMax03's Avatar
I would think with the bolts into the trans it should be suffient already! Check the resistance between the negative post and the starter with your volt ohmmeter!
Old Sep 29, 2008 | 01:02 AM
808MAX-SPEC's Avatar
Here's a pic of my grounding kit from the chasis to the 8mm bolt on the starter. Hope this helps.
Old Sep 29, 2008 | 08:34 AM
maxximaa's Avatar
theres an 8mm bolt on the starter based on the ^^ pic.
it's one long *** bolt, just take it out and attach the ground there.
Old Oct 4, 2008 | 02:52 PM
metalpiotr's Avatar
03 Maxima, 6spd
Thanks guys. I found the 8mm bolt and mounted the ground cable to it. Haven't noticed any difference in starting, but definitely doesn't hurt to have extra grounding.
The Frye
Sep 2, 2021 11:03 AM
Maxima30
Sep 7, 2015 06:13 PM
litch
Sep 5, 2015 11:29 AM
maximusrising
Sep 2, 2015 09:55 AM
A32goldylocks
Sep 2, 2015 06:39 AM
