Problems Lock
Old Feb 15, 2019 | 08:11 PM
emilianonp's Avatar
Problems Lock
lock system,
How can I disconnect it?
electrical energy is blocked in the injectors
Old Feb 16, 2019 | 04:26 AM
Turbobink's Avatar
I have no idea what you just said ...
Old Feb 16, 2019 | 12:28 PM
Shrout1's Avatar
emilianonp are you referring to the issue referenced in the other thread?
https://maxima.org/forums/4th-genera...-door-key.html
On my 1999 maxima I have to have a transponder key present in the ignition for the fuel injectors to fire. If I don't have the transponder key then the car won't send fuel to the engine. Is this what you mean? Is it the same 1995 maxima as mentioned in the other thread?
Old Feb 16, 2019 | 12:35 PM
JvG's Avatar
JvG
I have a 96. My car wanted me to lock and unlock the drivers door by using the key.
Old Feb 25, 2019 | 09:05 AM
emilianonp's Avatar
I have a normal key, not a key fob. The current to the injectors, after running for a little bit, the current gets cut off and the car doesn't start. I have read that it may have something to do with the anti-theft system and I would like to know what exactly I need to check with regard to the anti-theft system? My car runs for about 6-7 miles and then shuts off. I have changed all of the electrical parts to rule out issues and there is no "check engine" code/light. When the car is stopped, I reset the computer, opening the two front doors and the trunk, and by doing this the car will turn on and go a little bit further.
What I really need to know is how do I do a thorough check of my anti-theft system.
Any suggestions would be greatly appreciated. Thank you!
Old Feb 26, 2019 | 05:32 AM
emilianonp's Avatar
Maxima 95
plaf713
Mar 9, 2009 03:18 PM
gregmaxin
Jan 30, 2009 01:48 PM
ustfdes
Dec 22, 2005 11:15 AM
ronal404
Sep 21, 2004 07:16 PM
kmb
Mar 13, 2002 10:07 AM
