Problems Lock
Old 02-15-2019, 08:11 PM
emilianonp's Avatar
Problems Lock
lock system,
How can I disconnect it?
electrical energy is blocked in the injectors
emilianonp is offline
Old 02-16-2019, 04:26 AM
Turbobink's Avatar
I have no idea what you just said ...
Turbobink is offline
Old 02-16-2019, 12:28 PM
Shrout1's Avatar
emilianonp are you referring to the issue referenced in the other thread?
https://maxima.org/forums/4th-genera...-door-key.html
On my 1999 maxima I have to have a transponder key present in the ignition for the fuel injectors to fire. If I don't have the transponder key then the car won't send fuel to the engine. Is this what you mean? Is it the same 1995 maxima as mentioned in the other thread?
Shrout1 is offline
Old 02-16-2019, 12:35 PM
JvG
JvG's Avatar
I have a 96. My car wanted me to lock and unlock the drivers door by using the key.
JvG is offline
Old 02-25-2019, 09:05 AM
emilianonp's Avatar
I have a normal key, not a key fob. The current to the injectors, after running for a little bit, the current gets cut off and the car doesn't start. I have read that it may have something to do with the anti-theft system and I would like to know what exactly I need to check with regard to the anti-theft system? My car runs for about 6-7 miles and then shuts off. I have changed all of the electrical parts to rule out issues and there is no "check engine" code/light. When the car is stopped, I reset the computer, opening the two front doors and the trunk, and by doing this the car will turn on and go a little bit further.
What I really need to know is how do I do a thorough check of my anti-theft system.
Any suggestions would be greatly appreciated. Thank you!
Old 02-26-2019, 05:32 AM
emilianonp's Avatar
Maxima 95
plaf713
03-09-2009 03:18 PM
gregmaxin
01-30-2009 01:48 PM
ustfdes
12-22-2005 11:15 AM
ronal404
09-21-2004 07:16 PM
kmb
03-13-2002 10:07 AM
Quick Reply: Problems Lock
