Nitrous dissappeared??
Old Jan 30, 2003 | 12:29 PM
tornado019's Avatar
Ok help me out here. Maybe I'm missing something but I think my nitrous has dissappeared on me! Back in early november, I had my bottle filled up, a full 10 lbs. I put it in my car (in the trunk) and had it connected and open. Its been there ever since, and never used. Today, I finally got around to getting my pressure gauge installed on the bottle and it's only reading 200 psi of pressure! Shouldn't a full bottle have more pressure then that?? Its 51 degrees outside. I know the cold has an effect, but not this much right?
Old Jan 30, 2003 | 01:26 PM
BJJ's Avatar
BJJ
Re: Nitrous dissappeared??
Was the bottle open since November , if so it will leak out over time and you have yourself an empty bottle. If you want to be sure just weigh the bottle it should weigh roughly 16 lbs. when empty, so every pound over that is a pound of nitrous you still have.
Old Jan 30, 2003 | 01:31 PM
JAIMECBR900's Avatar
Re: Re: Nitrous dissappeared??
Very good advice. Weigh the bottle and calculate how much you have left. Also, temp plays a much bigger part than you think. I doubt that it would make you read 200 psi instead of maybe 500-600psi when cold, but it might for that length of time. Also as BJJ said, if you leave the valve open that long and never use it, it will slowly leak out.
Remember that there is only a line from the bottle to the solenoid. It is not going to be hermetically sealed. For this reason, you should always turn the valve off when not in use.
Old Jan 30, 2003 | 02:05 PM
1MAX2NV's Avatar
Never leave your bottle valve open. It's near impossible to have a leak proof system. I have a NOS remote bottle opener and I still turn off my bottle valve when I parked the car in the garage.
Old Jan 30, 2003 | 02:40 PM
tornado019's Avatar
Thats actually what I suspected. I just wasn't sure if it would in fact leak out or not. I always like to keep it open, you know, in case I come up on an opportunity to use it. I haven't done any racing though so far this winter, especially with the track being closed. I'll try weighing it and see what I have left, probably have to go get it refilled. Thanks for the advice.
About how much PSI can I expect to lose per degree of temp change? Isn't it 85 degrees optimal temp?
Old Jan 30, 2003 | 03:37 PM
CalsonicSE's Avatar
http://nosnitrous.com/HiOctn/ProdLin.../BttlHeat.html
Cumalot
Mar 15, 2001 06:25 PM
Jan 14, 2001 02:07 PM
Ramius83
Jan 5, 2001 03:31 PM
My 4DSC
Jan 4, 2001 07:21 PM
Cumalot
Nov 26, 2000 04:30 PM
