Dont Know Anything About Nos!!!
Old Apr 7, 2003 | 08:41 PM
danthediablo19's Avatar
I have a 95 max wit all the exhuast from ypipe etc.and cold air intake..I was thinking of buying a 70 shot or 100shot.But I dont know what i have to do to upgrade my car for it to handle the 70 or 100 shot..If someone can list me for the 70 and 100 shot parts that i would havet o upgrade in my car.if i have too.thatll be great.and thanks
Old Apr 8, 2003 | 04:32 AM
ToYLeT902's Avatar
JET Speed Lab
spark plugs, fuel pump... i think im forgetting something else.. cant think right now
Old Apr 9, 2003 | 12:17 PM
JAIMECBR900's Avatar
plugs, fuel pump, fuel pressure gauge, egt gauge, probably a FPR. If 5 spd, RPM switch and stronger clutch (ACT preferably). If auto, VB mod and cooler are not bad ideas.
I hate that the search function doesn't work anymore....
Old Apr 13, 2003 | 02:49 AM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
please.
do some reading.
Nitrous should NOT be used without knowldge.
Read tha faqs
Old Apr 13, 2003 | 03:20 PM
ToYLeT902's Avatar
JET Speed Lab
Originally posted by killer2002SE
please.
do some reading.
Read tha faqs
sorry
Old Apr 13, 2003 | 07:42 PM
Donkey®'s Avatar
wat
Nitrous bottle.
Old Apr 13, 2003 | 11:18 PM
ToYLeT902's Avatar
JET Speed Lab
Originally posted by look2me40
Nitrous bottle.
i knew i forgot something... o yea a switch might help too
Old Apr 13, 2003 | 11:38 PM
JDM4LIFE's Avatar
please.
do some reading.
Read tha faqs
exactly, nitrous is kinda like sex. you could, and definitely should, know what you're doing before hook it up. imagine if you had no idea how sex worked your first time, you woulda freaked even more, right? lol exactly.. i'm about to pick up my no2 setup here soon. i've read all kinds of stuff and dunno if i'm ready to have it in my car yet.
btw, you should go pick up the newest Sport Compact Car. it has an article dedicated to nothing but nitrous setups and precautions, etc. buy it and read it. the article's very informative. plus, read the faq's on this site!!
Old Apr 16, 2003 | 12:45 PM
XXXL Cracker's Avatar
The SCC article doen't tell you **** about installation, how to run everything etc. Other than that it has some good general knowledge for Honda drivers.
I would not run out an buy it... the Nitrous stickie has a lot more info
D
Old Apr 16, 2003 | 01:13 PM
Jime's Avatar
First time I had sex, it was really dark and I was totally scared, on top of that I was all alone.
Old Apr 17, 2003 | 03:23 AM
ToYLeT902's Avatar
JET Speed Lab
D
if only products would come with papers telling you what to do to set it up
Old Apr 17, 2003 | 09:05 AM
SonicDust187's Avatar
Why would I need an rpm switch if I am a 5 speed. I always let go of the gas pedal when shifting gears, wouldn't this cause the nitrous not to spray while changing gears?
Old Apr 17, 2003 | 09:21 AM
Jime's Avatar
It is probably more of a safety feature. What would happen if you shifted a bit too late and hit the limiter and also for really low RPM levels.
Old Apr 17, 2003 | 10:29 AM
What rpm level is considered too low to turn the nitrous on?
Old Apr 17, 2003 | 10:38 AM
Jime's Avatar
Well everyone has their own opinion on this, most say around 3k. The main thing not to do is switch it on at low rpm in higher gears.
I hit the spray right out of the hole at around 2k but before you can blink your eyes its at 6k so no danger of hurting anything. Its when you hit it at low rpm in a higher gear that all the pressure is exerted in the cylinder and no immediate place to release, thats what causes damage.
Old Apr 17, 2003 | 11:06 AM
I know what you mean, in first 2 gears the car's rpm just fly, once I hit 3rd and above they dont go up as fast.
Old Apr 17, 2003 | 11:40 AM
SR20DEN's Avatar
VQ Wizard
Jime is correct about peoples opinions. The best answer I can give is that it all depends upon the amount you use. The higher the shot, the higher the RPM you need to start. The VQ30 has been proven to handle 400 lb. ft. of torque for short periods so unless you're running a 125 shot or more (wet, DPI) you wont have to worry too much about a 2000 RPM start.
Old Apr 17, 2003 | 11:43 AM
SR20DEN's Avatar
VQ Wizard
Re: Dont Know Anything About Nos!!!
If you're using a Zex or NOS dry kit you can go upto a 70 shot without any real upgrades. But for safety reasons you should upgrade that old fuel pump before you spray with any kit. Most people here prefer the high pressure 255 lph Walbro pump. If you get that you can go to a 100+ dry shot but NEVER exceed 90psi fuel pressure on the injectors you have.
Old Apr 23, 2003 | 02:51 PM
wondering???Thinking???
the nos line that runs from the motor to the trunk to the nos tank..they put my nos tank on the passenger side of the trunk and was wondering if i move it my self to the driver side of the trunk will the line be longer enough to putit back towards the trunk also?RIght now its barely reaches so i think since it went across the car the line i think itll be long enough dont u all think????
Cumalot
Nov 28, 2000 09:38 AM
Cumalot
Nov 26, 2000 04:30 PM
ereet
Nov 26, 2000 03:44 PM
Slickismax
Nov 5, 2000 08:51 PM
MardiGrasMax
Oct 27, 2000 12:40 PM
