some nitrous ??'s
Old May 19, 2003 | 04:15 PM
mayhemI30's Avatar
"I'm running with scissors!"
some nitrous ??'s
i gonna be getting nitrous here pretty soon and i was just wondering how i should set it up. i'll be using 75hp shot 20923 /nx kit. what gauges should i use? ands should i use a full throttle switch with a rpm window switch or would it be push button operated?
i'm nitrous
Old May 19, 2003 | 04:31 PM
xHypex's Avatar
My best advice is to read the FAQs and go through the older posts in this forum (there aren't too many anyway). The more you read the more comfortable you'll be with your own kit and nitrous in general. If you have a question chances are someone else did at some point as well. If you can't find an answer after doing some reading then post
-hype
Old May 20, 2003 | 02:01 PM
roastduck88's Avatar
I recommend a A/F guage (or exhaust temp would be better), Fuel pressure guage, upgraded fuel pump, and possibly a Fuel Pressure Regulator.
Old May 20, 2003 | 04:58 PM
elchino's Avatar
I would definitely also get an electronic nitrous pressure gauge. don't forget to change your plugs (not really necessary but it's peace of mind)
Old May 20, 2003 | 09:58 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
i would suggeest doing some reading, not trying to dog you, just want to keep your max healthy...
the switch is totally up to you. Most people prefer the WOT window switch but I just done like the idea of having the nitrous controlled electronically, id rather control it myself. I would use a switch is I was a 6 spd though..
I would go with an electric full sweep nitrous and fuel pressure guages (not mechanical) check out autometer and definetly an EGT, thats perhaps the gauge I monitor most
I would start off with a 35 shot if I were you and slowly bump is up, make sure your fuel pressure stays constant @ WOT, cuz I dont know how an I30's fuel pump is...
like the guys above mentioned, so some reading, youll be much mor comfortable..
Old May 21, 2003 | 10:22 AM
mayhemI30's Avatar
thanks
the guy that does my installs thinks that it would be the best to run wot switch with window switch and some fuel safety switch or something. i dont remeber what he he exactly i think i'll listen to him he's built some fast cars. 10.66@139.4 1993 supra auto for example
Old May 21, 2003 | 10:40 AM
SonicDust187's Avatar
I am goin to run a FPSS, wot and window switch.
Old May 21, 2003 | 11:00 AM
XXXL Cracker's Avatar
Old May 21, 2003 | 09:35 PM
Eat Naaawwwzzzzz
go for it
SmoothMax
Apr 16, 2001 06:53 PM
Cumalot
Mar 15, 2001 06:25 PM
Ramius83
Jan 5, 2001 03:31 PM
My 4DSC
Jan 4, 2001 07:21 PM
Cumalot
Nov 26, 2000 04:30 PM
