New to nitrous need some help
Old Mar 4, 2004 | 02:28 PM
maxGTRvq35de's Avatar
I have a 2002 maxima auto, i would like to buy a NX wet kit is that a good choice for my car also is it true that i can not run a Zex kit on my car because of the returnless fuel system? and can i run a wet kit at all? i would like to run a 75 shot it that safe? any info will greatly help me thank you.
Old Mar 5, 2004 | 07:42 AM
skandalouz's Avatar
u can run a wet kit.... u can actually run a dry kit also but that involves doing a bunch of extra work to the fuel system... not exactly sure on the details.. but someone on here has done that.... hopefully he'll chime in.... but IMO a wet kit is the best way to go
Old Mar 5, 2004 | 01:22 PM
thank you i think that is my plan
Old Mar 5, 2004 | 02:30 PM
Jime's Avatar
I believe NX is the best and they only make wet.
You will find it much easier than dry, especially on a 2k2 with the returnless system. You can run a 75 shot and possibly a 100 without any fuel system upgrades. Just make sure you have a fuel pressure gauge and watch it very closely to verify the pressure holds when spraying.
I haven't installed mine on the 2k2 yet but will be doing so soon. My setup is different from the norm in that I run a completely separate fuel system for the nitrous and use 114 Unleaded Race fuel to keep the detonation demons at bey.
Not sure about the WOT switch if you can hook up to the tps or if you have to put it under the gas pedal because of the drive by wire setup.
Start off with a 35 shot and move up, but the 35 will give you a real kick in the pants.
Follow the directions on the NX website, I found them better than the ones that came with the kit.
Don't forget the copper plugs, they don't make 2 steps colder that I can find so I am running LFR6A-11's.
Get a trans cooler as well.
Old Mar 5, 2004 | 02:54 PM
SkylineGTR's Avatar
What size tranny cooler are you running?
TK
Old Mar 5, 2004 | 03:12 PM
Jime's Avatar
Its a B&M 11x17 in, 24,000 gvw
Old Mar 5, 2004 | 07:00 PM
cool thanks for all the answer im going to get my trany cooler this weekend.
Old Mar 6, 2004 | 04:08 PM
thomasd cook's Avatar
Are you doing install yourself? If so is it possible you can do a write-up for the 5th gen.?
Old Mar 7, 2004 | 09:07 AM
i will do it my self and yes if i do it i will do a write up.
Old Mar 7, 2004 | 11:40 AM
That would be great and very helpful to all. I just did a write-up for LED swap out.
SmoothMax
Apr 16, 2001 06:53 PM
Cumalot
Mar 15, 2001 06:25 PM
Ramius83
Jan 5, 2001 03:31 PM
My 4DSC
Jan 4, 2001 07:21 PM
Cumalot
Nov 26, 2000 04:30 PM
