going with nitrous
Old Feb 12, 2006 | 11:52 AM
DJ Technischer's Avatar
going with nitrous
Since the turbo swap , Would be out of the question for me right now , I am thinking about going with nitrous , Since my cars a 1988 with 145k Miles on it , i think im only going to go like 25 shot , And if i want to go higher , Witch injectors should i get ? What kit do you think would be best for me , Im deff thinking about wet , Because i have heard alot of problems with dry , Also before trying this I know im going to have to Do the 300zx ecu , And maf So i can do a cold air intake , doing that will allow me to run a higher shot right ? and any ways im sure it would be a much easy installation , what are your opinons on this?
Old Feb 12, 2006 | 12:01 PM
Jason R's Avatar
aka UNCDooD
please do not put a nitrous kit on your second gen. kthxbye.
Old Feb 12, 2006 | 12:10 PM
why not? really i dont understand why not?
Old Feb 12, 2006 | 12:12 PM
Jason R's Avatar
aka UNCDooD
because you are totally clueless about it and a 25 shot is a waste of nitrous.
Old Feb 12, 2006 | 12:25 PM
ok... Wow , Its funny how when you started out you knew nothing about it to? I dident say i was going to do it right this moment , and did i say i was going to STAY 25 for ever i was just going to do 25 to get the hang of using it , And how is 25 horsepower a waste ? .......
Old Feb 12, 2006 | 12:56 PM
Jason R's Avatar
aka UNCDooD
before the thought even crossed my mind to put a nitrous kit on my car i had already known plenty. 25 shot of nitrous doesn't necessarily mean it will give you 25 hp. do you plan on going for a wet or dry setup? you don't need all that other **** you were talking about in your first post if running such a small shot. I am running a 75 shot on my car and have changed nothing as far as the fuel system goes. do not waste your time or money on a nitrous kit. you had a hard enough time installing a throttlebody on your car.
Old Feb 12, 2006 | 01:10 PM
Donkeypunch's Avatar
You honestly won't feel anything with a "25".
Old Feb 12, 2006 | 01:42 PM
Umm i dident have a hard time installing it , Its just i cant get it to work correctly , When i push the gass in a the way it acts like i am only pressing it in half way.
Old Feb 12, 2006 | 01:49 PM
Jason R's Avatar
aka UNCDooD
if the car doesn't run properly after the install of a part then you must have done something wrong. If you can't get your car to run right with a bigger throttlebody then you have no reason to even think about installing a nitrous kit.
Old Feb 12, 2006 | 01:50 PM
i only tryed for like 30 mins , I havent messed with it since , Im sure its just the tps like card said. and i havent messed with it.
Old Feb 12, 2006 | 02:00 PM
Jason R's Avatar
aka UNCDooD
if you knew how to set it then it would've been done. especially since it only takes a few minutes to set. please give up on modifying your car. and his name is not 'Card'.
Old Feb 12, 2006 | 02:21 PM
C MAX's Avatar
if you really want to do it go with a dry shot 60, very simple and wont blow your motor. forget about going wet to much to worry about unless your mechanically inclined and know what to keep an eye out for. basically a dry kit is plug and play and no need to change anything. i dont know what you heard bad about a dry kit because i owned one for yrs with no problems unless you wanna spray more than a 70 shot dry would be perfect for you.
Old Feb 12, 2006 | 03:47 PM
Did i say i dident know how to set it , All you have to do is , Loosen the two screws , And then Move it to a SIDE , And then go and try it out , if it doesnt work , Come back , And move it to a diffrent posistion ... Just because Idont know much about nitrous , Means nothing Im learned you a$$hole , You where learning once to , You dident just know every thing like that , Atleast i can admit it.
Old Feb 12, 2006 | 04:27 PM
Jason R's Avatar
aka UNCDooD
that made no sense whatsoever. please go back to the 4th grade and learn how to form a sentence.
Old Feb 12, 2006 | 04:59 PM
MaxBoost925's Avatar
Drug Money
Houston, we have a war!
Anyways, wet is safer than dry. Only do this if you REALLY know what you're doing. Read up if you don't otherwise say bye to that VE or VG or whatever it is.
Old Feb 13, 2006 | 01:39 AM
Safer how?
Old Feb 13, 2006 | 04:01 AM
C MAX's Avatar
Originally Posted by Donkeypunch
Safer how?
wet is not safer period. fuel puddles and can cause detonation and can fail quicker due to failure of solenoids. with the dry kit you get two nitrous solenoid that controls your stock fpr to increase fuel supply, a lot less to worry about. the only thing is with dry, a heavy shot is dangerous because you tax the injectors. i had dry and sprayed forever all day long and soon as i converted to wet is when all my problems started. i suggest a dry kit if your not looking for a lot of power and are not mechanically inclined to monitor the system properly.
Old Feb 13, 2006 | 05:18 AM
What shot and psi should i run , And what kit , Do you think is the safest ? Some one was telling me zex , But what is your opinon?
also what Gaudges should i get , Fuel pressure , And what else?
Old Feb 16, 2006 | 04:45 PM
TAPOUT's Avatar
You will lose
I think you should go with a 50 shot dry, and put a window switch on it so it only sprays from 2500 rpm til boost is about 90%. That will help you spool faster, and should keep you within somewhat safe parameters.
Old Feb 18, 2006 | 08:45 AM
this guys selling his 75 dry kit from zex for like 190 should i take it?
Old Feb 18, 2006 | 11:17 AM
C MAX's Avatar
thats it, cant be put any better. then when you want more power and high shot then you convert to wet, by then you know what your doing. thats the safest way.
SmoothMax
Apr 16, 2001 06:53 PM
Cumalot
Mar 15, 2001 06:25 PM
Ramius83
Jan 5, 2001 03:31 PM
My 4DSC
Jan 4, 2001 07:21 PM
Cumalot
Nov 26, 2000 04:30 PM
