safcII w/ nitrous??
Old Jan 12, 2007 | 07:54 PM
babymac's Avatar
BOOST 4 LIFE!
safcII w/ nitrous??
Is it worth it to get one dyno tunned for nitrous to squeeze out a few more ponnies?
Old Jan 13, 2007 | 06:47 AM
t6378tp's Avatar
Turbo 3.5
I thought about doing something like this. I would like to have a nitrous map and n/a map, but have not start doing any research yet still trying to makeup my mind on other things
Old Jan 13, 2007 | 11:41 AM
RA030726's Avatar
I'm nutty for Nissans
The SAFC2 has two map settings so its totally possible.
Old Jan 13, 2007 | 11:45 AM
babymac's Avatar
BOOST 4 LIFE!
How much hp do think could be gained from a nitrous map? I know you could see around 10hp n/a so I wonder what could be had on the juice???
Old Jan 13, 2007 | 11:48 AM
NmexMAX's Avatar
dot dot dot ...
Read about what A/F is suitable for your N2O shot, try it, find out, get back to us.
Old Jan 13, 2007 | 11:53 AM
babymac's Avatar
BOOST 4 LIFE!
Will do, but was just wondering if anybody else has done it and what results they had?
Old Jan 13, 2007 | 11:59 AM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/showthread.php?t=228702
Old Jan 13, 2007 | 12:30 PM
t6378tp's Avatar
Turbo 3.5
get a wideband or dyno time and a extra bottle. spray and tune then spray and tune again and again.
there are gains to be made but since no 2 setups or driving styles are excatly the same you will have to find out what best for your car some-1 else's setup may get you in the ballpark but the final tune is up to you
Old Jan 13, 2007 | 01:16 PM
NmexMAX's Avatar
dot dot dot ...
A wideband is almost if not should be necessary.
Old Jan 13, 2007 | 01:22 PM
babymac's Avatar
BOOST 4 LIFE!
Thats my plan after I get down some nice times first.
Old Jan 13, 2007 | 01:24 PM
NmexMAX's Avatar
dot dot dot ...
So, you're just going blindly into it?
Old Jan 13, 2007 | 01:27 PM
babymac's Avatar
BOOST 4 LIFE!
No , I am not getting a safcII until I get my best possible times on the spray first.
Old Jan 13, 2007 | 01:30 PM
NmexMAX's Avatar
dot dot dot ...
How are you setting things up and controlling & monitoring A/F?
How large of a shot?
Old Jan 13, 2007 | 01:57 PM
babymac's Avatar
BOOST 4 LIFE!
Right now I am just running a zex 55 wet shot(for now at least), So I really don't think I have to monitor things until I get into bigger shots. And I am only spraying at the track, which I go to probably once or twice a month.
oh and another thing after a few test runs I checked my plugs and they look great, so I would say everything is running perfect.
Old Jan 24, 2007 | 07:29 PM
platinum03SE
well theres no way to tell what ur a/f is so ude have to ether one, bring it to a dyno, or two, get a wideband in the exhaust.
Old Jan 25, 2007 | 11:35 AM
grey99max's Avatar
LandShark has Cosworth
Oh - maybe someday I should do that. Just a stock ECU here - no wideband, either.......
Actually, I really should, what with the present 150-shot dual-stage NX, and one more stage in the works...... after long-tube headers, a dyno tuning session or two is planned.
Old Jan 25, 2007 | 01:50 PM
NmexMAX's Avatar
dot dot dot ...
No EGT gauge either?
Old Jan 25, 2007 | 05:42 PM
grey99max's Avatar
No - what are those for ???
Old Jan 25, 2007 | 07:13 PM
absoundlab
exhaust gas temp
Old Jan 25, 2007 | 09:28 PM
grey99max's Avatar
Originally Posted by absoundlab
exhaust gas temp
I see.........
Old Jan 26, 2007 | 04:47 PM
streetzlegend's Avatar
when i did wideband i never got a chance to spray and try and tune it. but my goal was to tune it n/a to about 13.1ish or high 12's.
If you have the nitrous setup jetted properly, it SHOULD remain the same a/f ratio when you spray, thats the whole reason for picking the proper jets. To be honest, I dont suggest trying to squeeze a few hp from tuning a/f unless its really off. trying to lean it out a lil bit to get like few hp is probably a bit risky. If you wanna get more power out of your nitrous, get headers, and/or a cutout.
Old Feb 3, 2007 | 01:16 PM
BJSelden's Avatar
Wow
That looks awesome!
Old Feb 7, 2007 | 11:41 AM
NmexMAX's Avatar
dot dot dot ...
are you lookingat that is so awesome?
Old Feb 7, 2007 | 12:02 PM
vq356sp's Avatar
El Mas Noob Del Org.
Someone is trying to reach 15 posts
SmoothMax
Apr 16, 2001 06:53 PM
Cumalot
Mar 15, 2001 06:25 PM
Ramius83
Jan 5, 2001 03:31 PM
My 4DSC
Jan 4, 2001 07:21 PM
Cumalot
Nov 26, 2000 04:30 PM
