First ever Rear Mounted Turbo maxima
Old 02-10-2007, 08:25 PM
  #281
MDeezy's Avatar
you could unplug the VAFC and see if that resolves the problem, or just reset the VAFC and keep it configured for the car but no fuel corrections.
Test the injectors.
I dont think you upgraded your fuel setup for the rear mount did you?
MDeezy is offline
Old 02-10-2007, 08:29 PM
  #282
streetzlegend's Avatar
Test the injectors.
Right now the maf is not connected to the vafc2. the reason im taking off the vafc2 is because i have a loose connection somewhere on the ecu from when i installed the vafc.
yes i was having a similar problem before and i thought it was because i screwed up the stock injectors (the car would actually turn off when this happend) because of my timing advanced and extremely high fuel pressure that i was running. So i put in z32 injectors. and car ran fine, till now. Im going to try everything tomorrow.
streetzlegend is offline
Old 02-10-2007, 09:23 PM
  #283
nismology's Avatar
You forgot to mention what happens to the manifold vacuum when it starts acting up. ..............
nismology is offline
Old 02-10-2007, 11:50 PM
  #284
Bacon Lover
Tatanko's Avatar
Ugh, not another pioneering project gone wrong.
Craig Mack, anyone?
Tatanko is offline
Old 02-11-2007, 07:56 AM
  #285
95BLKMAX's Avatar
Craig Mack, anyone?
Nah not like that. Like he said, this isnt related to the turbo. RMT project was a success and worked like we expected it to. This is something not-related that's making the car undrivable. Obviously, lean+turbo is a bad idea. So when this started happening, turbo came off (see how easy it is to just remove your turbo on an RMT? ).
And also, what nismology was reffering to was that when this wacked out ubber lean a/f occurs, vaccum drops to about ~15in Hg. Idle also drops some. AS IF there was a vaccum leak. But Nismology, s0ber and streetz looked around for one with a bottle of starter fluid and nothing they sprayed caused a change. So we're down to electrical.
95BLKMAX is offline
Old 02-11-2007, 08:55 AM
  #286
SLOW
Nealoc187's Avatar
Originally Posted by choray911
If the AFR is in the 10s or 11s, and the EGTs are high, then you might be able to retard timing a bit to get the temps down. If the AFRs are right, timing has been retarded, and the EGTs are still up, an intercooler or aftercooler might help.
If you live in a place that has a hot summer, the EGT readings will let you know if it is a bad idea to get into boost for the day.
I also use mine as a way to tell if it is safe to turn off the car with out baking the bearings inside the turbo.
Almost any car can be tuned with a EGT and a WB02.
Choray
Retarding timing raises EGT typically. This is due largely to the fact that the burn is happening closer to the time that the exhaust valve opens, or in some cases the burn is still occurring when the exhaust valve is open. Advancing timing cools EGTs typically. This is why you don't want to tune with JUST an EGT. EGTs can be affected by too many things to use them as a sole tuning tool.
Nealoc187 is offline
Old 02-11-2007, 11:00 PM
  #287
mtcookson's Avatar
How's your EGR valve? I happened to have egr issues with a Maxima I used to own and it would go lean every time the thing would try to open. It always seemed random so I never figured it out till way later. For some reason it always seemed to be worse in the winter than the summer too.
mtcookson is offline
Old 02-11-2007, 11:07 PM
  #288
Geoff's Avatar
There are a lot of things in your setup that differ from successful rear mounted turbos. First of all, the turbo supply line and drain should NOT be at an angle...ever, on any turbo setup. Oil needs to be able to freely, and quickly drain from the turbo; turbos do not want oil pressure, just a steady stream to lubricate otherwise oil will bypass the seals, smoke, and or fill the intake with oil. Also, do you have any kind of restrictor on the supply line? I don't doubt that you are supplying wayyyy to much oil if there is no restrictor. You were right to think about a turbo timer for the pump; most kits use one to run the pump for 1 minute after shutdown. An intercooler would most likely be worthless at your boost level, especially since the long charge pipe will lower the charge air temp sufficiently. Hopefully when you get the fuel sorted out the turbo will also spool quicker otherwise you may want to look into a smaller turbo/ turbine housing. Good luck with the project
Geoff is offline
Old 02-12-2007, 06:05 AM
  #289
My problem was the front o2 sensor!!! I unpluged them both and car idled perfect obviously rich since it has not o2's at 11.7 a/f. I connected one of the sensors and a/f went crazy again to really lean. So im installing new o2's in couple days. I am back in business
Also I removed my VAFC2 because i cleaned up the wiring mess i had on my ECU and might install my emanage blue soon. so right now i dont have a working 00VI, low end is extremly slow and car does not even provide any power till about 4,000 RPM. Also being very rich below 3k does not help turbo spool up since EGT's are low at that richness. once i put the plugs in and im at near 14.7 that will really help turbo spool up sooner. I might be removing the power rod from the 00vi as well.
I dont think there is anything wrong with my oil setup. The feed line has a check valve that does not allow oil to flow into the turbo while the car is off, also I do have a restrictor on the turbos oil inlet, its a 1/16 size restrictor. My oil problem was not when the car was running but when the car was off. I have solved this problem by running the pump 2 minutes after engine is off. ever since iv been doing that, i have not had any oil on the charge pipe at all. I have a thick oil drain line coming out the turbo and into the pump so i seriously doubt there is any oil pressure on the return side of the turbo. There for I consider this project a success.
That is one of the things I wanted to check yesterday. But when I saw that the o2 sensor was causing the problem I didnt check the egr.
Old 02-12-2007, 12:46 PM
  #290
Bacon Lover
Tatanko's Avatar
Glad to hear you got it worked out. NOW for the real results
Tatanko is offline
Old 02-12-2007, 07:57 PM
  #291
Turiman's Avatar
nothing but good news, happy to hear your back in the game, so we can compare
Turiman is offline
Old 02-12-2007, 08:05 PM
  #292
thanx yall. hopefully if i dont have to travel for work this weekend i might install emanage and tune.
Old 02-19-2007, 06:14 PM
  #293
Doctor D I presume???
doc2278's Avatar
Originally Posted by streetzlegend
Thanx all for the input. I30mike, I am planning on very very soon doing water injection with a similar scavenge pump, since i rather not do FMIC because it will add even more distance to the charge pipe. Water injection should hopefully help keep detonation down if theres any at all. I might need some advice from you guys with this whole turbo project once a while since im new to it. I just put in mobil 1 synthetic (usually use castrol gtx, when i drained it it looked like water lol, maybe the turbos heat caused it to brake down too much or something).
What about going crazy, rear mount the intercooler ( long and thin type) and mount it just in front of the rear bumper? mount it to the frame.
OR
use two 300zx intercoolers, theyre small and you can mount them to the rear of the car and run custom piping.
http://cgi.ebay.com/ebaymotors/300ZX...spagenameZWDVW
doc2278 is offline
Old 02-19-2007, 09:09 PM
  #294
hmmm, i like the rear intercooler mounting idea. But will it work if its not getting direct air flow like in the front?
Old 02-19-2007, 09:21 PM
  #295
mtcookson's Avatar
Use an air scoop. I had a strange aftercooler setup idea a while back that involved and air scoop. Wouldn't likely be as efficient as a front mount but more efficient than none at all.
Old 02-19-2007, 09:49 PM
  #296
doc2278's Avatar
shouldnt be a problem, its not like the maxima is a twin turboed V12 LOL. it wont need as much cool air . But I digress, angled properly, the intercooler(s) will work properly.
its getting its air flow from under the car, the toyota Mr2 uses a similar design setup on an aftermarket turbo kit.
With the 300zx intercoolers, they become hidden and they serve their purpose. One recommendation I would make here is, use the ducts the intercoolers come with. and when mounting them, angle the intercoolers down about 15 degrees from a 90 degree set up and you will get more efficient airflow ( since the rear suspension will diffuse the airflow, the angling of the intercoolers will pick that flow back up).
it might actually be more efficient,.. here's why, since these intercoolers are not mounted in front of the radiator, so then air flow is reduced simply put, they may get better flow rear mounted since there will be nothing hindering them. the ducts added will direct the laminar flow into the intercoolers as designed front or rear mounted. STillen might have the HDPE ducts to fit these intercoolers, also there is always ebay. Happy hunting.
doc2278 is offline
Old 02-19-2007, 10:22 PM
  #297
doc2278's Avatar
Worse comes to worse, cut two holes in your rear bumper, ( doesnt have to be as big as the intercoolers, just enough to create some flow through) put some painted chicken wire behind the holes. and then you have proper flow through.
doc2278 is offline
Old 02-19-2007, 10:46 PM
  #298
mtcookson's Avatar
What a coincidence you mentioned a twin turbo V12... I saw an MB S65 AMG tonight... 6 liter V12 twin turbo. 604 hp, 738 lb. ft. torque @ 2,000 rpm. Damn did that thing sound and look awesome.
Old 02-20-2007, 05:44 AM
  #299
95BLKMAX's Avatar
Wow man this sounds like something I would say, lol
95BLKMAX is offline
Old 02-20-2007, 06:43 AM
  #300
hmmm very interesting. I might consider this rear mount intercooler option.
Old 02-20-2007, 10:11 AM
  #301
VQ30 DE T
accordingtou's Avatar
Sound Clips?
accordingtou is offline
Old 02-20-2007, 11:17 AM
  #302
Originally Posted by accordingtou
Sound Clips?
see if u can see this clip
http://vids.myspace.com/index.cfm?fu...oid=1751144300
Old 02-20-2007, 03:37 PM
  #303
Bacon Lover
Tatanko's Avatar
I think the original one (the one you took at night with no BOV) has better sound with it. You should post that one.
Tatanko is offline
Old 02-21-2007, 05:25 PM
  #304
happy4444's Avatar
And We Thought We Seen It All..
happy4444 is offline
Old 02-21-2007, 09:55 PM
  #305
Old 02-22-2007, 08:11 AM
  #306
VQ30 DE T
http://vids.myspace.com/index.cfm?fu...oid=1751144300NICEEEEEEEEEEEE
Old 02-22-2007, 08:13 AM
  #307
VQ30 DE T
Turbo
NICE AUTO?
Old 02-22-2007, 08:31 AM
  #308
yes thats auto.. that was 5psi untuned, now im at 7.5-8psi and tuned.
Old 02-22-2007, 08:45 AM
  #309
QUESTION FOR ALL:
Do you guys think if I put a muffler with 3" inlet and outlet after the turbo. Will this cause too much restriction? I am thinking of doing dynomax muffler.
The muffler fits fine at the location where I have the turbo exhaust outlet pipe right now. We can just route that same pipe into the muffler and then out. The exhaust is starting to bother me a little bit. Maybe because my trunk is completly gutted. But still from outside is pretty loud. I just wanna make sure if i put a muffler its not going to rob some air flow.
Old 02-22-2007, 08:49 AM
  #310
Alex_V
I hate them but what about a cannister muffler, a little inset? it might act like a resonator.
~Alex
Old 02-22-2007, 09:33 AM
  #311
~Alex
You mean like them straight thru maganaflows? I hate those things, just makes it deeper but dosnt bring noise down. if the drown i got already gets any deeper my windows are going to pop lol. i dont get any rasp at all, i just wanna get rid of the loud deep drown i got. sounds like a damn dumptruck with a turbo spooling noise in the background lol.
Old 02-22-2007, 12:14 PM
  #312
Bacon Lover
Tatanko's Avatar
A good 3" muffler shouldn't restrict you too much. Besides, if it bothers you that much, the tiny bit of restriction a muffler will add probably won't bother you as much.
Tatanko is offline
Old 02-22-2007, 01:28 PM
  #313
LandShark has Cosworth
grey99max's Avatar
QUESTION FOR ALL:
This one doesn't have much - if any - back pressure. You can feel each exhaust pulse at idle: It's what Warpspeed built into my '99 ...
grey99max is offline
Old 02-23-2007, 09:24 AM
  #314
95BLKMAX's Avatar
oh snap, nice muffler harold. I think streetz should give Dallas a call
95BLKMAX is offline
Old 02-23-2007, 09:34 AM
  #315
hacim105's Avatar
Good job on your accomplishment!
My only question is what value is it to have a rear mounted turbo as opposed to a front mounted turbo?
hacim105 is offline
Old 02-23-2007, 10:28 PM
  #316
It is half the price to spend. and if done properly almost as effective as front. (i said almost)
Old 02-23-2007, 10:29 PM
  #317
UPDATE!: FINALLY HAVE TRACK TIMES
http://forums.maxima.org/showthread.php?t=512116
Old 02-25-2007, 06:29 PM
  #318
Turbo 3.5
t6378tp's Avatar
just wondering do you think a 2 or 2-1/4 inch exhaust would help the turbo spool faster than your 2-1/2 exhaust
t6378tp is offline
Old 02-25-2007, 07:02 PM
  #319
SLOW
Nealoc187's Avatar
The larger your exhaust the faster you will spool... (watch out for diminishing returns).
Streetz to answer your question about the muffler, it won't hamper your performance to any significant extent.
Old 02-25-2007, 07:24 PM
  #320
ghostmax301's Avatar
11.76 and 123mph - stock VQ30
Inspiration. Keep it up man...
ghostmax301 is offline
Quick Reply: First ever Rear Mounted Turbo maxima
