*NOOBIES* The "I am new here,but have a question" thread..(post your questions here)
Hi! I am about to get a 1992 Maxima GXE from a family member its not run in several years and i am needing to do some work to it. i have some Questions and have tried to look for the answers on past posts and doing a search also but i will ask these that i dont find at a later time.
My concern now is that reading the posts about the VTC's and all that has me worried for a car thats sat for a few years i dont even know what engine i have
Vin decoding programs just say its a 3.0L V6 so my Question is what engine do i have?
Do i have the VE30De? or VG30De?? or?
what i do know is the car has the red umm cam covers on it?
Here is the Vin if that helps : JN1HJ01F5NT000989
I have never owned a Nissan and i am looking forward to it
i am sorry in advance for what is probably such a "noob" Question
All GXE 3rd gens had the VG no matter what year, and the 89-91 SE also had it. Only the 92-94 SE got the special VE motor.
Thanks that helps! I am really excited about this car and looking forward to it, So on this Engine thats in my '92 GXE i dont have to worry about VTC's?? just wanting to make sure..
good news is, no VTC's to worry about.
bad news is, you do have a timing belt to worry about. if you go ahead and replace it (and the water pump and belt tensioner) now (with oem parts, not autozone stuff) then you're good for 60k miles. If not, you're sitting on a ticking time bomb unless you have service records stating it was done recently.
I was looking up on ebay and saw the body kits i want for my car. My question is why are the price different because they look the same, same materials (Poly-Fiber Reinforced Plastic (PFRP) and just different names....one is made from AIT($480) and other is EX BXE($415)included S+H , does anyone know what the difference between the names or of their products?
I was looking up on ebay and saw the body kit i want for my car. my question is why are the price different because they look the same, same materials and just different names....one is made from AIT and other is EX BXE, does anyone know what the difference between the names or of the products?
but women still pay for the brand name
well it's good news/bad news.
ok thanks i appreciate the info, i will check the my local nissan dealer 1st of the week i have bought some autoparts from RockAuto before they seem to be pretty good on things, Has any one else bought these parts from Rock Auto? i wonder if a NAPA or CarQuest would be a notch up from the autozones of the world!
Speaking of which, I just installed that TPS and chunked the other "new" one and it seems that my earlier described problems have disappeared. Hopefully it will be a lasting solution. Let's see if my gas mileage improves. Thanks everyone!
P.S. This is my 15th post! Took 2.5 years to do it. Now, if I can just find something productive to add to conversations around here.
Last edited by ImAlive1459; Mar 13, 2010 at 01:38 PM. Reason: Just noticed that this is my 15th post!
'94 Maxima GXE Brake Conversion/ABS
My father-in-law gave my son a 1994 Maxima GXE for his first car. So....let the work begin. I brought the car back to life today with a new battery and fresh gas. As I was looking over the car, I noticed it didn't have ABS and had the dreaded rear drum brakes (noisy). Has anyone out there had any success coverting the rear drums to discs and adding ABS?
I know some models of the 94's had ABS; GLE & SE.
I found a rear disc coversion kit at dragtimes.com. Still looking for the ABS!
people here have done the disc swap, but i dont know about the ABS swap, might be more trouble than its worth
i think ABS was just a option that wasnt deadset on any year, my 92 GXE has it but most junkyard cars here dont.
Im not sure yet, I have two auto tranny's one from a 90se and the other from a 91se (I think) that I pulled from a junk yard. I know they were both a SOHC. Now I want to possably use one of them in a 1992 DOHC maxx, not sure the trim on the 92 as I just started looking to buy it off of CL. So your saying its hard to tell w/o knowing the model of both. but it could be possable?
Help with 1990 maxima alarm
Hello, i own a 1990 nissan maxima i purchased yesterday. The previous owner was unable to provide me with the code for the keypad on the door. I being curious wanted to figure it out and started playing around with it. well i hit the "lock" button on the keypad and locked the door, my key that was provided to me does not unlock the door (i dont know if it is because i locked it with the keypad or if the two keys that were provided to me just dont work on any of the 3 locks). So i took on my "happy auto-owner" attitude and unlocked the door using a coat hanger. this set off the alarm and it continued to go off even after i turn the key over in the ignition. so right now i am at a stand point in my newly found nissan maxima project. i went online and no one that i found has had the same problem. i unhooked the positive terminal and started going to work on diagnosing it following online instructions. i took the glovebox out and located the modual for the keyless alarm system. wrote down the numbers and went online again with them. it says to reset the personal code i type in the bottem fixxed number located on the box and than input my own personal code. well i attempted this and nothing came of it and the alarm still continued to go off. then i tried disconecting the two "anti theft" fuses, one under dash and one under the hood. alarm continued to go off. Also tried disconnecting the two wire harnesses feeding the keyless entry alarm module. so thats where i am at and i am stuck. BTW i called nissan themselves and they told me to take the glovebox out and check out the module as well. please please please help me i do not want my new car to be barn ridden forever i want to get it on the road but if i cant get this figured out i am not going to even bother. PLEASE reply with some help even if you dont know just point me in the right direction. Thank you.
sorry im not good at picking stuff out of big paragraphs lol. so you basically have no good key, cant reset the doorcode, and have to open the door with a coat hanger?
your key should still work for the lock, doesnt matter if you used the keypad or not to lock the door. did you try the driver and passenger side locks?
i dont know how to reset the code myself, previous owner of mine had a catchy code that i kept and my door lock timer went so until i replace it, my keypad doesnt work alltogether lol. if you dont have the user manual, i could look it up in mine how to reset it
lol im sorry im just freaking out about it because i dont know what to do. i do know how to reset it but it will not reset because the alarm is activated. (its going off horn and lights) i was told that the key turn to the left than to the right will shut it off but my key isnt turning even a little bit. i tried drivers side/passenger/trunk. key didnt work in any but i was just thinking that the antitheft kicked in and wont allow the locks to be unlocked.
if they are sure, perhaps the key was almost never used in the door, and is worn to the point that it will not turn in the tumbler.
first step is to get into the car. under the steering wheel is a cover (the on your knees will hit if you move teh seat all the way forward
). remove it.underneath, you will find a couple of boxes. been a while since I looked, but one should say anti-theft, or something; unplug it.
you should be able to start it, but, like I said, it's been a while since this was approached.
if it works, check your glove box (I think that is where it should be) for a door key code. A locksmith should be able to create a new key from that code.
if there is no code, you will still want to find a locksmith to get a key made for the doors.
does the 1990 maxima have to seperate keys? one for ignition and one for door? because both mine are the same thing. i will try that to get it started right now. thank you for at least that. lol, i cant believe how fast i am getting replies on here.
yeah, Maxima.org is pretty busy. and am busy trying to go to sleep, I am usually heading to bed right now. stupid daylight savings....
lmao, daylight savings doesnt bug me, its weird the first day getting up in the dark all the sudden but otherwise im fine. ive never worked the next day of daylight savings, but apparently lots of people come in a hour later from forgetting to set their clock ahead. people come early too when we set it back
and yeah you might just need a new key if the ones you have are worn out
wire bug, windows, moonroof, trunk pop.
So the other day I let my lil nephew swap out the CD player in my daughters 1990 SE max. Due to the fact that someone cut the factory wires and hard wired it he gave up on it. The next day when my daughter started it up and went to move it and the drivers side door window went down, the moon roof opened, the drivers side seat belt stayed down and the trunk lid popped open. It was like the car was possesed. I looked at it and it seemed to start freaking out after the car was started and when the drivers side door was closed. I removed the CD played, and because someone prior to me and my nephew cut out the factory wires to hard wire the CD player, I went to the JY and got the wire harnes for the car side and re-wired it, then bought the wire harned for the CD side and wired it to the CD and hooked it all up..... guess what... same problem. I can hear a click noise behind the foot kick plate on the passenger side and I can hear the trunk pop about every 2 seconds. All of this happens only after the car is stated and as soon as I close the drivers side door. this has to be the weirdest thing I have ran across since I've been rolling maximas durring the past 5 years.
any ideas????
Still nothing??? come on you guys are the smartest guys I know when it comes to the MAXX, please help
any ideas????
Last edited by dadswieser; Mar 19, 2010 at 12:10 PM. Reason: cant find the problem...
moar n00bage
i was checking out Razo, and they have auto shifters for sale. ive always wanted the trigger-style one, some they sell come with overdrive and some dont. as long as i got a overdrive one, how hard would it be to swap shifters? is it a 20 minute deal or do i have to dig around and swap a ton of stuff?
something like this
http://www.carmate-usa.com/html_razo...t_at_super.htm
something like this
moar n00bage
something like this
something like this
i dunno, that shifer you linked too is kinda... well... oogly
well the chrome one at least. but if it says it fits your car then it should be simple.
k who can help?
i bought a varad l.e.d alarm scanner but i dont want to hook it up to the alarm cuz i dont wonna F it up. i want it to turn on while the car is off and i want it to turn off while the car is on. how do i connect this in a way i wont kill my battery? i was thinkin a rocker switch but its gonna be using juice from the battery while the cars off to power the scanner.
The rpms and power drops on my car below 25 MPH and happens at approximately 15MPH during acceleration worse when stopped completely..Sometimes it happens some times it doesn't.This is an automatic.I am leaning towards TPS or Fuel regulator maybe even computer.I've done all the standard maintenance, plugs filters etc.
The car starts fine doesn't stall or anything.
Hey guys. The Maxi wont go into first or second. There was also a burning smell, I guess you could say, in the cabin, and engine bay. Was driving fun up until about 30min ago. Couldn't find anything in search. Lemme know what you think!
auto or manual? and what engine? if it's a VG auto, odds are it's a dead tranny because well, that's just what VG auto trannies like to do.
transmission rebuild time!!
