*NOOBIES* The "I am new here,but have a question" thread..(post your questions here)
Old Jul 30, 2008 | 06:37 PM
  #1601
3g94MaxGXE's Avatar
Yeah there are 3 bolts. Only thing is you do have to use gaskets, the ones that come with the car don't seem to be reuseable. I'm using a $9 tube of permatex silicone gasket maker to redo the gaskets on my valve covers, intake manifold, throttle body, etc. A process I'll likely be repeating soon when I can afford to get NWP Engineering phenolic intake spacers.
Old Jul 30, 2008 | 06:51 PM
  #1602
BenStoked's Avatar
Jesus was a Zombie.
Originally Posted by 3g94MaxGXE
It's either time for a new TB or you could have the old nipple welded back on. As far as where the hose is there is a big wad of them right in front of the IACV and it should be an easy find if you just look. I'll see if I can find a pic of the one you are looking for.
Didn't find a good pic but look where the red circle is, the hose should run along in that area. If you have to you can remove the dual duct to check for it.
I am wondering if the remains of the nipple can be removed (by a pair of needle nosed pliers, or drilling it out, and replacing it with some other tubing, held in place with plumber's solder or, if it can't be soldered by him, some jb-weld.
you could always just bypass the coolant lines. Im sure there is some sort of write-up about it. I wouldnt recommend it for a long term fix, but at least get you back on the road (without leaking coolant) for cheap and quick. (comments meant for ajan246, not 3g...)
Old Jul 30, 2008 | 07:03 PM
  #1603
3g94MaxGXE's Avatar
I actually feel like bypassing now that I know what it does, sounds like it creates more intake heat which is what we are trying to defeat by buying the NWP intake spacers.
Though your idea for ghettofixing it sounds good to me.
Old Jul 30, 2008 | 07:12 PM
  #1604
BenStoked's Avatar
Jesus was a Zombie.
part of the deal with the spacers is bypassing it, I believe.
Old Jul 30, 2008 | 07:14 PM
  #1605
3g94MaxGXE's Avatar
Yeah I was reading up on it tonight and the VG30E kit does have a coolant bypass though I didn't know if it was that or some other thing like it.
Old Jul 30, 2008 | 07:42 PM
  #1606
CapedCadaver's Avatar
Call me Wookiee Goldberg
yeah same thing. aaron might sell just the fitting. i dunno. i could never find those blasted things anywhere i looked. prolly b/c i fail, but whatever.
Old Jul 30, 2008 | 07:53 PM
  #1607
sleepyvg30e's Avatar
does the throttle body bypass cause more heat i was gonna buy the mods since its so cheap but if its cuasing higher manifold teps then ill probably wait for the nwp kit
Old Jul 30, 2008 | 08:00 PM
  #1608
3g94MaxGXE's Avatar
Well according to whats been said the bypass LOWERS heat.
Old Jul 30, 2008 | 08:31 PM
  #1609
yea it lowers heat, along with the rest of the NWP kit. the spacers also smoothen out the transitions from one part to another, rather than having the poorly-shapen gaskets cutting off bits of the airflow.
Old Jul 30, 2008 | 08:59 PM
  #1610
3g94MaxGXE's Avatar
Though those of us who are replacing our 14 year old gaskets with RTV this week aren't going to have poorly shaped gaskets....I hope.
Old Jul 30, 2008 | 09:01 PM
  #1611
make sure to wipe it away from the port with your finger so even as it squishes in it won't obstruct the airflow
Old Jul 30, 2008 | 09:08 PM
  #1612
3g94MaxGXE's Avatar
You know, now that I think about it I can do that on the TB....you don't exactly have that luxury on valve covers. I'm just hoping I got enough on them to get a good seal and not enough on them that I've got gooey crap all over my valves f'ing s*** up.
I did my best but it was my first time and the tube was defective.
Old Jul 30, 2008 | 09:58 PM
  #1613
ajan246's Avatar
Yeah I initially thought the same thing... but i tried to get the remaining piece out without totally wrecking things and it's a stubborn guy
Old Jul 30, 2008 | 10:00 PM
  #1614
ajan246's Avatar
Yeah I initially thought the same thing... but i tried to get the remaining piece out without totally wrecking things and it's a stubborn guy. I'm considering juts bypassing until I can get a new TB
Old Jul 31, 2008 | 02:03 AM
  #1615
thereapersson's Avatar
Edit: Problem solved!
Old Jul 31, 2008 | 10:47 AM
  #1616
eleDmCent's Avatar
Originally Posted by Greeny
Ok folks,This thread is for new members/w under 15 posts to post their questions regarding the 3rd Generation Maxima
Before asking questions,please READ the general maintenance sticky---> CLICK HERE
Please do not post ***** in this thread
ALL MEMBER RESPONSES MUST BE A QUOTE OF THE ORIGINAL QUESTION
ey idk if this is a dumb question or not but can i throw a cold air intake into a my 90 max?
Old Jul 31, 2008 | 11:38 AM
  #1617
300zmax's Avatar
i have been reading in the post something about weak 5 spds but im confused, is it the vg ve trannys that are weak or the VQ trannys are the week ones?
Old Jul 31, 2008 | 11:55 AM
  #1618
the vg auto is weak... both the VG and VE manuals are generally regarded as decently strong tho some cite the VE as being stronger than the VG manual.
Old Jul 31, 2008 | 02:59 PM
  #1619
BenStoked's Avatar
Jesus was a Zombie.
well, I threw a whole steering rack into the trunk of my car, and it fit pretty nicely! (then I had to install it)
there are a few threads about CAI installs, you just gotta find 'em.
Old Jul 31, 2008 | 06:26 PM
  #1620
3g94MaxGXE's Avatar
Yes, there isn't one made for our cars but you can get an ebay 90-93 Honda Accord intake and it fits. I opted for a short ram but guys like pearl have done a little cutting and I think one additional bend and used the full CAI.
Old Jul 31, 2008 | 09:07 PM
  #1621
C|A's Avatar
C|A
How hard is it to change the tranny fluid on these cars? My Uncle is going to give me a 1992 Maxima, and the first couple things I want to do it change the oil, tranny fluid, brake fluid and coolant. How long and how much will this take?
Old Aug 1, 2008 | 06:21 AM
  #1622
internetautomar's Avatar
mod or sell?
is it an SE or GXE?
GXE has no easy way to change the trans fluid
SE has a pan on the bottom you can drop to change the fluid
Old Aug 1, 2008 | 11:57 AM
  #1623
Maxdogg1989's Avatar
NEED HELP PLZ 1989 MAXIMA
Hey I Own A 1989 Maxima That Ran Fine Until The Timing Belt Jumped...I Had A Shade Tree Machanic Put My Timing Belt Back On But Im Not Sure If He Set My Timing Right Cause Now I Hear A Misfire And When At A Stop Sign My Car Acts Like It Want 2 Cut Off But It Drives Normal @ High Speeds..What Do U Think The Problem Could Be...And Also I Hear No Signs Of The Motor Knocking Or Ticking Real Loud
Old Aug 1, 2008 | 12:04 PM
  #1624
BenStoked's Avatar
Jesus was a Zombie.
perhaps some bent valves. have the compression checked.
Old Aug 1, 2008 | 12:42 PM
  #1625
mod or sell?
I'm sure that is it.
unless it snapped while parked, it bent valves.
Old Aug 1, 2008 | 01:15 PM
  #1626
he said it jumped... not broke.
Old Aug 1, 2008 | 02:29 PM
  #1627
94se5spd's Avatar
Does anybody know the difference between a VE30DE and a VG30DE besides the vehicles?
Old Aug 1, 2008 | 02:37 PM
  #1628
3g94MaxGXE's Avatar
Horsepower, shorter heads on the VE, etc. Not to mention VEs are known for clacking VTCs, something that isn't a problem on the VG.
Old Aug 1, 2008 | 02:39 PM
  #1629
94se5spd's Avatar
Do you know if any of the parts like stock 300 cams would bolt into a VE?
Old Aug 1, 2008 | 04:40 PM
  #1630
BenStoked's Avatar
Jesus was a Zombie.
no. they wouldnt. the VE only came in the maxima, and no other vehicle. the heads are too different to make it work.
Old Aug 2, 2008 | 08:13 PM
  #1631
mod or sell?
jumped should still bend the valves.
Old Aug 2, 2008 | 10:33 PM
  #1632
so i see. carry on then
Old Aug 3, 2008 | 01:47 PM
  #1633
Nefarious90's Avatar
I was just thinking, since my instrument cluster on my vg went bad. I was wondering if someone has ever replace theirs with one from a 4th Gen. Also I was wondering as well if someone has ever replaced their Master cylinder with one from a 300z or any other nissan with a larger brake system. Thanks in advance.
Old Aug 3, 2008 | 01:58 PM
  #1634
BenStoked's Avatar
Jesus was a Zombie.
never heard of anyone using a 4th gen cluster in a 3rd gen, except a rare case where they had a 4th gen engine/wiring in it. I was able to pick up a new cluster from the junk yard for about $20. if you are after the "cooler" 145mph (or just white) gauges, the VE gauges will bolt up and work fine in any 3rd gen. likewise for the gxe's black gauges.
I haven't heard of anyone doing the MC, either, but I do not see why it wouldn't work, amusing it would bolt up. but just because I haven't heard of it, doesn't mean it's never been done.
Old Aug 3, 2008 | 02:10 PM
  #1635
Thanks, I am most likely going to the junk yard to pick up the new cluster (145mph) but was thinking if the fourth gen worked that would be nice. As far as the MC I need to research this to see if its worth it to try. Once I do the larger brake system.
Old Aug 4, 2008 | 07:04 AM
  #1636
mod or sell?
the 4th gen cluster sucks compared to the 3rd gens.
leave your MC alone unless you are getting advice from someone with a degree relating to break engineering
Old Aug 4, 2008 | 04:07 PM
  #1637
tmolloy's Avatar
Camshaft Sprocket Alignment
Hello all! I have a 94 Maxima and I have have replaced almost everything on the front of the engine (all the belts; camshaft oil seals; water pump; thermostat; etc.). However, while replacing the camshaft oil seals, the right camshaft sprocket has become misaligned. I can't remember exactly how it happened or how to fix it, as it's been about 2 weeks since I last worked on the car (I've been out-of-town). All I remember is that while trying to retighten the sprocket, it ended up "jumping" and I tried to get it back to it's position by rotating it a few more times by "jumping it" if that makes sense. Needless to say this didn't work very well. In the end the sprocket mark is out-of-alignment with the rear timing belt cover mark by quite a bit (the rear cover mark is about at 0 degrees and the sprocket mark is about at 270 degrees). If I remember correctly, I only jumped the sprocket a few times, and now I'm trying to jump it back and the alignment mark doesn't seem to be moving much at all. I'm not exactly sure what happened. But in the end the sprocket is out of alignment quite a bit (about 90 degrees) with where it needs to be and I have no idea how to get it back. Any help would be greatly appreciated!
Old Aug 6, 2008 | 10:02 PM
  #1638
xx-Marshall-xx's Avatar
kthxbye2u
how the eff do i get these injectors out of the fuel rail?!, they are stuck i cant pull them out
Old Aug 6, 2008 | 10:18 PM
  #1639
Pearl93VE's Avatar
I can has?
http://www.viddler.com/explore/MyGreenMax/videos/5/
Old Aug 6, 2008 | 11:39 PM
  #1640
kthxbye2u
omg pearl thanks so much! fast response too
really, and props for greeny for always making helpful videos and pics
Love this site
