*NOOBIES* The "I am new here,but have a question" thread..(post your questions here)
Old Dec 17, 2008 | 02:19 PM
  #2401
CapedCadaver's Avatar
Call me Wookiee Goldberg
Originally Posted by TXprinthead
I guess it would have to be a GXE then, the car was bought for $2k and has had $4k dumped into it just to keep it running . it's not nice like a lot of the Maximas you guys have. Either way it's the climate control unit and having heat/ac I am concerned about.
heh yea i know the climate control is the bigger issue. i was just tryin' to make sure you were asking the right group of people. what you're describing sounds like an electrical malfunction within the unit itself... like from bad solder joints or something. do you know how to check and repair bad solder joints? usually when things like that fail (like the clock, or the door lock timer) it's bad solders.
Old Dec 17, 2008 | 02:36 PM
  #2402
TXprinthead's Avatar
From: Norman, OK until the Maxima of Malice works 90%
I appreciate the help. I will pull it out again and take it apart to look. If it looks too bad I may just pick up a replacement rather than soldering (sp?) it myself. I really didn't want to buy a replacement to find it was not the issue. I'm going to go pull it and check.
Old Dec 17, 2008 | 08:02 PM
  #2403
sleepyvg30e's Avatar
idle problems?
i have been seeing very irregular idle and im wondering if its not a larger problem on its way i recently drained the transmission fluid other than that i haven't worked on the drivetrain recently at all
the car when stopped or with transmission in park will jump rpm's from 6-700 up to 900-1000 instantly u can hear the difference in the engine even see a lil more exhaust come out
the car operates perfectly otherwise no throttle problems while driving or anything irregular like that only other thing that might be related is that i get a lil vibration between 75-90mph then it goes away
Old Dec 17, 2008 | 08:31 PM
  #2404
ibyouhaveavacleak, and maybe unbalanced wheels causing vibration on the highway
Old Dec 17, 2008 | 10:07 PM
  #2405
awesome finally i can add some color to the engine bay with some bright red vac hoses and your probably right about unbalanced wheels i know im due for alignment
Old Dec 18, 2008 | 12:35 PM
  #2406
one more thing anyone know how to replace the window master switch my chiltons manual basically told me to **** off
Old Dec 18, 2008 | 01:12 PM
  #2407
1: remove door panel
2: replace switch
3: reinstall door panel
there's a couple screws involved in there too. and the black gooey crap on the clear weathersheet. you might need to buy some extra black gooey crap. it was mentioned in greeny's taillight/OOOOOPS thread
Old Dec 18, 2008 | 03:12 PM
  #2408
2: replace switch
see i knew there was something like that why cant they just say "dont forget about the black gooey crap" in chiltons im sick of it im buyin fsm
Old Dec 18, 2008 | 03:18 PM
  #2409
well the black gooey crap shouldn't be a big issue for you.. moreso when replacing the window regulator. but just in case your weathersheet is loose, you may wish to reseal it with new gooey crap.
Old Dec 18, 2008 | 04:13 PM
  #2410
heres another one for ya the cigarette lighter which ive been using as a phone charger shorted out when i bought an actual cigarette lighter and it was the wrong size now the charger wont work and theres a lil burnt mark on the cigarette lighter but the adapter looks fine and still has its light glowing
what do i do rip out the whole dash and replace it?
Old Dec 18, 2008 | 04:28 PM
  #2411
the light glowing? like on the adapter? hmm try another adapter (i'm sure a friend/relative has a car charger you can test) and see if it works. but first, shine a light into the cig lighter socket and see if anything in there looks melted. if it looks fine then i guess go ahead and try a different charger. if you want to take out the black panel and replace the socket, i have a spare you can buy. installation is not terribly hard.. just takes a little muscle to push it into place, iirc.
Old Dec 18, 2008 | 08:41 PM
  #2412
gonzalez's Avatar
Steering Issue
I just upgraded my wheels from stock to 96-98 Cobra rims sitting on 235/45/17 rubber. My steering feels wobbly, like it over compensates and tends to pull to one side either left or right when i brake hard most of the time. I got an alignment after installing the wheels and had the inner tie rod ends replaced. I was wondering what can i do to correct this problem?
Old Dec 18, 2008 | 08:46 PM
  #2413
well it's possible that something was keeping the car from aliging right and the alignment place just said "you're good to go" when it really wasn't. try taking it somewhere that will do a free alignment check and ask for a full readout of the results. it will either tell you if those items are in-spec, OR you will be able to compare it to the FSM yourself.
how evenly are the tires wearing?
Old Dec 18, 2008 | 08:51 PM
  #2414
does this only happen when you break hard or does it pull while your driving as well if not it could be a defective brakes that would explain why the alignment didnt fix anything
Old Dec 18, 2008 | 08:57 PM
  #2415
well.. my car does that too though. new inner and outer tierods, new balljoints, new control arm bushings, new calipers, new rotors, and lightly used brake pads. and i greased the living hell out of the slidepins and stuff. but it still sometimes pulls one side or the other. mainly it does it over bumps, or on banked surfaces (like pulls to the left in the left lane cuz it's angled that way for drainage). i have a slight feathered edge on the outsides of my tires
Old Dec 18, 2008 | 09:13 PM
  #2416
really? i never noticed anything like that on mine arent u still runing original cv shafts?
Old Dec 18, 2008 | 09:25 PM
  #2417
no i have switched to a VE5 tranny so i'm using Goon's old CV axles (among other things). "anything like that' being when my car pulls toward the left in the left lane (and sometimes in other lanes... but sometimes to the right)? well that's cuz something is not right with my car.
I'm thinking that SOMETHING in my alignment wouldn't align right no matter what they did... and they just didn't bother to tell me. Originally i assumed it was the caster from me forgetting a washer behind the control arm bushings.... but that didn't fix it so now i'm thinking they either messed up the toe, or that my camber is wrong. that's why i was sugesting him to get a readout (as i have been to lazy to do ) and compare it to the acceptable range in the FSM. my what i said about my car was to show that there is nothing wrong with my brakes because everything is new except the master cylinder and brake lines.
Old Dec 19, 2008 | 02:30 AM
  #2418
gonzalez's Avatar
It only happens when i break hard, the rear calipers are new.
Old Dec 19, 2008 | 02:31 AM
  #2419
gonzalez's Avatar
The tires look ok but i'll double check today.
Old Dec 19, 2008 | 02:48 AM
  #2420
rear brakes don't do much. you definitely DO need rear brakes but they only do like 20-30% of the work when you're hard on the brakes. the front ones would be much more likely to pull the car to one side, if the brakes are the problem.
Old Dec 19, 2008 | 07:51 AM
  #2421
internetautomar's Avatar
mod or sell?
check your brake hoses. when they fail they can collapse preventing a caliper from releasing.
Old Dec 20, 2008 | 10:02 AM
  #2422
thomas gowen's Avatar
i have 1994 nissan maxima fuel injector is bad each time i change it the o ring shreds is there a way to prevent this from happening
Old Dec 20, 2008 | 10:41 AM
  #2423
try installin stainless steel brake lines we have rubber ones that come stock theyre not only more expensive but are very easy to break and wear apart
Old Dec 20, 2008 | 04:42 PM
  #2424
mod or sell?
did you use oil / petroleum jelly on the o'rings to lube them up before you tried to install the injectors in the rail?
Old Dec 23, 2008 | 08:51 AM
  #2425
sweet tea's Avatar
Very quick question here. I have a 1990 Maxima SE that's rarely let me down before. I've had it for two years now and it's got 161,000 miles, runs great. However, it's now sitting in the Wal-Mart parking lot refusing to start. When I turn the key, my interior and exterior lights will come on and I hear a clicking noise, but the engine refuses to turn over. A friend tells me I need to test the battery, and if it's good, then it's a starter issue. If the battery is bad, then it could be an alternator or battery issue. Now, I trust him, but just need to get the battery tested...I will take it into Wal-Mart and test it there, but first,
-how do I remove the battery?
I found this website ( http://www.ehow.com/how_2191602_remove-car-battery.html ) that looks fairly trustworthy but I can't figure out the Maxy's 'grounding system type.' I checked through the whole manual but can't seem to find any indicators.
Help a sister out?
Old Dec 23, 2008 | 09:15 AM
  #2426
Greeny's Avatar
¯\(°_o)/¯
Help a sister out?
First of all, do you have a tool set?
Old Dec 23, 2008 | 09:22 AM
  #2427
sweet tea's Avatar
Check.
Old Dec 23, 2008 | 09:34 AM
  #2428
300zmax's Avatar
Very quick question here. I have a 1990 Maxima SE that's rarely let me down before. I've had it for two years now and it's got 161,000 miles, runs great. However, it's now sitting in the Wal-Mart parking lot refusing to start. When I turn the key, my interior and exterior lights will come on and I hear a clicking noise, but the engine refuses to turn over. A friend tells me I need to test the battery, and if it's good, then it's a starter issue. If the battery is bad, then it could be an alternator or battery issue. Now, I trust him, but just need to get the battery tested...I will take it into Wal-Mart and test it there, but first, [B]
Ground is not an issue just follow the directions that site tells you, the driver side terminal is the ground (Negative) side and the passenger side of the battery is the possitive.. But before you go pulling stuff outlook it over very well. Check the terminals realy well. does the positive side look like it has snow on it and if so the problem is the connection to the battery (clean it jiggle the wire and try and start the car). if its ok, get someone to help you jump the car before you pull the battery out. get a cheap'o volt meter and place it on the terminals (red for positive : black for negative ::ground: while the car is running. if you get a reading of over 14 volts the alternator is good anything under 12volts and the alternator is bad. turn off your car and reconnect the jump wires on the battery for 5 or 10 minutes while their car is running. use the meter again and if you get over 12v on the battery it might still be saved.
good luck!
Old Dec 23, 2008 | 09:41 AM
  #2429
Greeny's Avatar
¯\(°_o)/¯
Check.
You will need just one tool, a 10mm wrench or a 10mm deep well socket..
Old Dec 23, 2008 | 10:40 AM
  #2430
Help a sister out?
theres no such thing as a "positive" grounding system anymore thats just there for antique cars every car manufacturer has used a negative ground system since the 1940's
Old Dec 23, 2008 | 12:48 PM
  #2431
sweet tea's Avatar
Word, good to know. Thanks everyone for your help. I got the battery out & tested it, and of course it was dead. Purchased a new one and got it installed successfully...Car wouldn't start until I put it in neutral and tried, but it is running now. I appreciate it.
Old Dec 25, 2008 | 10:59 AM
  #2432
chunkysause7's Avatar
Amsoil
Do we get discounts on Amsoil website?
Has anyone drained there 5 spd and put Amsoil Synthetic Manual Transmission Gear Lube 75W-90 API GL-4 (MTG)?
Old Dec 25, 2008 | 11:51 AM
  #2433
thrillseeker's Avatar
i got a 92 maxima sohc with auto i was driving to salem it worked fine then on the way home it would not down shift nor did the overdrive or the performance or comfert switch work so i am thinking tranny controller any insight i am going to check the fluid levels now by the way it is snowing
Old Dec 25, 2008 | 01:50 PM
  #2434
BenStoked's Avatar
Jesus was a Zombie.
SOHC? sounds like the tranny is starting to go into safe mode. my understanding (only this, because I have a manual transmission, and I don't pay too much attention to tranny problem threads) is this is because the auto is starting to die, or there is some sensor going bad. this is a frequent thing with the SOHC autos. a search should yield better answers than mine.
Old Dec 25, 2008 | 06:10 PM
  #2435
fluid levels are fine smells fine it just seems like the electronics are not working hwere is the controller located ? i could swap it out i have searched
Old Dec 25, 2008 | 06:46 PM
  #2436
also just went out there and turned it on the p on the power comfert switch flashed i think 4-5 times what does that mean?
Old Dec 25, 2008 | 07:00 PM
  #2437
http://boredmder.com/FSM/Nissan/Maxima/1994/at.pdf
go to page AT-45 and do that diagnostic procecure.
Old Dec 25, 2008 | 07:03 PM
  #2438
Greeny's Avatar
¯\(°_o)/¯
or just refer to the stickies..
http://forums.maxima.org/3rd-generat...nsmission.html
Old Dec 25, 2008 | 07:24 PM
  #2439
ok i looked over the self diognostics but something that makes me think its the tcm is all forwaord gears can be selected and it will go forward reverse works it just wont downshift and the over drive or the power comfert switch will not work ..thi is the exact reasons i did not want a auto lol
Old Dec 25, 2008 | 07:29 PM
  #2440
Greeny's Avatar
¯\(°_o)/¯
don't just "look it over" you need to actually do the diagnostic procedures..
