*NOOBIES* The "I am new here,but have a question" thread..(post your questions here)
Old Jan 8, 2009 | 04:13 PM
  #2481
300zmax's Avatar
Major newby question and i know i should be able to pull this info up somewhere but i cant find it. on the VG automatic tranny, which line is out (to radiator) and which is return? im installing a filter and cooler and i just cant find the info i need
Old Jan 8, 2009 | 04:54 PM
  #2482
Greeny's Avatar
¯\(°_o)/¯
ah man! i can't remember which one!!
I'm thinking top line= flow to rad..bottom line return..not sure though..
Old Jan 8, 2009 | 05:09 PM
  #2483
CapedCadaver's Avatar
Call me Wookiee Goldberg
wiking's cardomain delivers
Old Jan 8, 2009 | 05:17 PM
  #2484
300zmax's Avatar
oh dude you guys are awsome, i love pictures!
Old Jan 9, 2009 | 11:43 PM
  #2485
s12god's Avatar
hi my name is mike i usally troll the club s12 site. but i just bought a 94 nissan maxima for parts. it has a vg30e. same as my s12. i want to swap the engine out of the maxima into my s12. it would be the same as swappin the vg30e from the maxima into a z31. any one know what i would have to do with the trottle position sensors and wireing.?? i'm a little drunk but i'm going to part her out to your site i will start a new thread for that but i want to know about the swap.
Old Jan 10, 2009 | 12:17 AM
  #2486
chunkysause7's Avatar
How do you get the Fan control, A/C, and Heater unit out? I want to change my bulbs out in it to L.E.Ds.
Old Jan 10, 2009 | 06:43 AM
  #2487
if your S12 already has a VG, then you could just remove the intake manifold from the VG in the maxima, and put the intake from your S12 on it.. i assume everything on the S12 is properly set up and was running until you needed a new motor?
Old Jan 10, 2009 | 11:57 AM
  #2488
s12god's Avatar
I dont have my old plenum it was stolen i have to use the maxima plenum. i think i could run the plenum with the maxima ecu and then just run the extra wires could that work?
Old Jan 10, 2009 | 12:14 PM
  #2489
-ReLLiK-'s Avatar
I know 3rd Gens headlight housings are complete sh**, but whats a good lightbulb to get? I can barely see at night...
Old Jan 10, 2009 | 01:55 PM
  #2490
I switched to 9007s (55w lowbeam) and use Sylvania Xtravisions. I don't like silverstars because they are tinted blue, which reduces light output.
Old Jan 10, 2009 | 02:21 PM
  #2491
mle3131's Avatar
Cruise Control and High Beams stopped working
I have a 1990 Maxima. This car has been in the family since it was new, I have been driving it since 1993 or so. I obviously like the car; I've replace the transmission 3X. I am looking for help in two areas.
Cruise Control stopped working. The light on the dash comes on and acts as if it is engaging, but it does not.
Also, my high beams are no longer working. When I turn them on, my lights turn off.
Old Jan 10, 2009 | 02:37 PM
  #2492
probably the switch. cuz the fuse runs both high and low beam, so it's not a fuse.
Old Jan 10, 2009 | 02:41 PM
  #2493
mle3131's Avatar
thank you
Old Jan 10, 2009 | 04:03 PM
  #2494
Greeny's Avatar
¯\(°_o)/¯
thank you
i have a good headlight switch for sale if you want it..
Old Jan 10, 2009 | 04:21 PM
  #2495
mle3131's Avatar
How much? Do you have any suggestions for the Cruise? The horn works fine
Old Jan 10, 2009 | 04:29 PM
  #2496
Greeny's Avatar
¯\(°_o)/¯
The switch will be $30 shipped to your location, unless you are in canada.
the c/c actuator under the hood may be bad..(trace the c/c cable at the throttle body back to a round looking thing on the passenger side on the engine bay, that is the actuator) look at the wiring harness going to the actuator, make sure it's hooked up and no broken wires.
i have a good actuator also if you want it..
Old Jan 10, 2009 | 04:50 PM
  #2497
mle3131's Avatar
I have recently had issues with my throttle body that have seem to have been corrected simply with adjustments. Cruise went out way before issues began. Could it be related? Sadly, I am looking for another car, just would like to fix what is inexpensive before I make it someone's hobby car. I have absolutely loved this car.
Old Jan 10, 2009 | 04:56 PM
  #2498
Greeny's Avatar
¯\(°_o)/¯
What kind of "adjustments" did you do?
if you want any parts, just pm me or post a request in my part out thread.
link to part out thread--> http://forums.maxima.org/1st-3rd-gen...-part-out.html
Old Jan 10, 2009 | 05:29 PM
  #2499
mle3131's Avatar
Adjustment was done by mechanic. I don't know what he did. Car was stalling if I didn't give it some gas.
Old Jan 10, 2009 | 05:32 PM
  #2500
Greeny's Avatar
¯\(°_o)/¯
He probably turned the iacv screw up to increase your idle, the iacv should have been cleaned.
Old Jan 11, 2009 | 06:13 AM
  #2501
Obsession_92-94's Avatar
Could have cleaned the MAF as well.
Old Jan 11, 2009 | 05:37 PM
  #2502
-ReLLiK-'s Avatar
Im looking for some lowering springs.
KSports 2.2" front 2" rear
Zenn 2" front 2" rear
Which one is better? Would that .2" more in the front make that much of a difference?
Old Jan 11, 2009 | 05:46 PM
  #2503
Greeny's Avatar
¯\(°_o)/¯
both are waay too low of a drop for these cars, you will incur bottoming over bumps, and steering geometry issues.
Old Jan 11, 2009 | 05:48 PM
  #2504
-ReLLiK-'s Avatar
hmmm... well in that case, if Hectic doesnt get your springs, lemme know. Buying new struts/shocks would be the smartest thing to do also, but is it neccesary?
Old Jan 11, 2009 | 05:51 PM
  #2505
Greeny's Avatar
¯\(°_o)/¯
Most definitely necessary, don't bother putting drop springs on without a minimum tokico strut upgrade.
Old Jan 11, 2009 | 05:54 PM
  #2506
-ReLLiK-'s Avatar
lol ok thx. You see im trying to avoid doing the RIGHT thing. Being 18 means my funds arent where i wish they were. But if i want it right, i gotta pay the $.
You know anyone selling struts for cheap?
Old Jan 11, 2009 | 06:01 PM
  #2507
Greeny's Avatar
¯\(°_o)/¯
New
http://www.shox.com/
http://www.internetautosupply.com/ca...6e7859ba41be54
Old Jan 12, 2009 | 12:46 AM
  #2508
Infam0usMax's Avatar
I have a 92 Maxima GXE im looking for some wheels but really dont want them to be small does anybody know if 19"s will fit? Ive seen every car like mine with only 18s on it and i seen two with 20"...
Old Jan 12, 2009 | 07:20 AM
  #2509
moar info are needed:
19"x?" with an offset of ??mm with a P2??/??R19 tire
Old Jan 12, 2009 | 07:50 AM
  #2510
internetautomar's Avatar
mod or sell?
small????
Old Jan 12, 2009 | 08:18 AM
  #2511
300zmax's Avatar
More info needed, like what do you plan to do with the suspension. Ive meet to many people that want to lower their cars on massive rims. i thought 16s looked big on our cars!
Old Jan 12, 2009 | 08:29 AM
  #2512
BenStoked's Avatar
Jesus was a Zombie.
be prepared to have a ride that feels like mike tyson is punching you in the *** over every bump. (not to mention, the damage all that pounding does to the car)
Old Jan 12, 2009 | 08:35 AM
  #2513
keepingitsuave's Avatar
Whats up, My 3rd Gen offically died on me 3 weeks ago (the timing belt went and theres damage to the valves) so my brother is goin to donate the car anyway i bought some aftermarket speakers and wanted to take them out, is there any good diagrams around to show how to take the rear seats and the door panels so i can disconnect the speakers?
Old Jan 12, 2009 | 08:40 AM
  #2514
BenStoked's Avatar
Jesus was a Zombie.
http://www.geocities.com/craigbraceg...t_removal.html
http://www.geocities.com/bracecraig/.../speakers.html
Old Jan 12, 2009 | 10:36 PM
  #2515
cvsmaxima's Avatar
91 Maxima - MT5 to AT ?
I have a 5MT in my Maxima at the moment, however the sycros are trashed and now the transmission is locked up. Sooo i started looking for another one, however they are apparently harder to find then i thought. I DID get another one however it was from a '92 with limited slip and my axles didnt fit. So back to the drawing board. Now i have aquired another '91 maxima (trashed in an accident) but the motor and transmission are in great shape, unfortunatly, its a A/T. now from what i have read id rather keep the MT but im totaly stuck now. Please let me know what if any ideas you may have about what i should do next. Convert to AT? sell the AT parts and keep lookin got a MT?
Any help is appricated!
One other thing, any ideas where i could post the parts i have that i want to get rid of?
Old Jan 13, 2009 | 03:38 AM
  #2516
TXprinthead's Avatar
From: Norman, OK until the Maxima of Malice works 90%
all right guys, i'm back, and i'm still in oklahoma thanks to my maxima. been doing a lot of turd polishing (i'm 3rd owner). I did get a new climate control from "apostore" on ebay, first didn't work but they stand by their guarantee. I replaced my passenger side "a" arm or whatever bushing and lower ball joints on both sides in hopes of getting an alignment (also tossed on some kumho tires from an old ehonda of mine). The fellas at Tires Plus are now realizing I need to replace my inner tie rod and i would like to know if anyone has any experience or info on how to do this (my Chilton's Manual doesn't cover it). On the bright side my ride now has heat, and I have a new panasonic head unit on the way from cruthfield with adapter! (still going to have to replace the antenna). Anyhow I would appreciate your expert knowledge on the lower/inner tie rod situation. also pleas let me know what to expect to go wrong next (trans is good, struts have been done, new brakes, ball joints, climate control, HU, motor mounts, thermostat, and soon to come a new oil pan, just a shame the body isn't all that great). I honestly don't know what to expect if i attempt the inner/lower tie rods on my own, so pleas let me know if it's best to suck it up and pay somebody to do it for me
btw if anyone around okc needs stereo equip i have 2 older kicker 10" comps in a good condition box with older fosgate 360a2 amp and clarion mcd360 cross over i am looking to sell (i haven't bothered to tear apart the car to get the **** control from the front however)
Old Jan 13, 2009 | 04:01 AM
  #2517
Greeny's Avatar
¯\(°_o)/¯
all you need to finish the lsd trans swap is the axles from a 92-94 SE manual maxima, you will also need the hub/spindle assemblies from a 92-94 se maxima, though these do not have to be specifically from a manual se...Converting the car to an AT is going to be a royal pita, you will have to swap not only the trans, it will also require a auto radiator/entire wiring harness from the auto car, and the auto ecu and tcu <--( transmission control unit)
Old Jan 13, 2009 | 04:07 AM
  #2518
Greeny's Avatar
¯\(°_o)/¯
---> http://forums.maxima.org/3rd-generat...t-writeup.html
Old Jan 13, 2009 | 07:47 AM
  #2519
300zmax's Avatar
i hate black ice. let me start off with that. i was taking and exit this morning and slipped and hit the curb. luckly the curb is only 3 inchs tall.
now my steering wheel isnt center but the car tracks fine. i can still drive with one finger and the wheels look fine other than some scuffing on the driver side (curb hit side). the arm looks fine but i wont know 100% till its up in the air this weekend.
did i whack my alignment or can it be worse than that? and is it ok to drive for a week? the steering wheel is about 15 degrees off clockwise ( if that makes sence)
i appreicate the help
Old Jan 13, 2009 | 01:09 PM
  #2520
-ReLLiK-'s Avatar
ok so now that ive installed new headlight bulbs, when i turn the **** to turn the lights on, my bright symbol turns on with it. Not to mention when i actually DO turn the brights on, the lights get dimmer... wtf. is it grounded somewhere or something???
