*NOOBIES* The "I am new here,but have a question" thread..(post your questions here)
Old Feb 1, 2009 | 06:35 PM
  #2721
Greeny's Avatar
¯\(°_o)/¯
Throw out bearing....
Old Feb 1, 2009 | 06:39 PM
  #2722
Greeny's Avatar
¯\(°_o)/¯
Originally Posted by PMAX08
Hey guys,
Im looking to test my knock sensor with a meter or even a temp bypass, where is the knock sensor harness plug in the engine bay? ive searched but the pictures no longer exist in there, a pic would be great guys, thx
http://www.4dsc.com/articles/drivetr...k_sensor.shtml
Old Feb 1, 2009 | 06:53 PM
  #2723
chentwoten's Avatar
Greeny do you know where I can get a new or remanufacturd one? I looked at autozone but couldn't find any 'throwout bearing'. Is there another name they go by?
Old Feb 1, 2009 | 07:14 PM
  #2724
Greeny's Avatar
¯\(°_o)/¯
Release bearing..
Old Feb 1, 2009 | 07:29 PM
  #2725
chentwoten's Avatar
Thanks I just read that they come with the exedy clutch kits so I won't need to purchase one seperately, since i need the clutch kit too. Can somebody elaborate on what is in figure 6 on here aside from the clutch cylinder? Thanks. I gotta pull those parts next weekend.
Old Feb 1, 2009 | 07:57 PM
  #2726
BenStoked's Avatar
Jesus was a Zombie.
master cylinder, slave cylinder, hydraulic clutch lines (recommend a stainless steel line to replace all that), a clip that holds a fluid line (not sure if its clutch or brake, if its brake, you dont need it), a couple of nuts, and a wire (clutch sensor, mebe?).
Old Feb 1, 2009 | 08:08 PM
  #2727
internetautomar's Avatar
mod or sell?
Hey guys,
it's under the intake plenum.
Old Feb 1, 2009 | 09:48 PM
  #2728
CapedCadaver's Avatar
Call me Wookiee Goldberg
chentowen:
the "block" for the clutch hydraylics (right side of pic)
http://i164.photobucket.com/albums/u...p/IMG_1304.jpg
exedy clutch kit comes with all of this (EXCEPT the flywheel.. that was separate):
http://i164.photobucket.com/albums/u...s/IMG_1574.jpg
also remember to get the "gussets".. the things the lower 6 tranny bolt holes go through into the tranny
Old Feb 1, 2009 | 11:08 PM
  #2729
Infam0usMax's Avatar
im back guys with yet another question... its about wheels this timeim thinking 19"s but ive seen everybody with 18"s is it because the 19"s rub and have less tire or is it because the 18"s give u more tire space...?
Old Feb 1, 2009 | 11:52 PM
  #2730
it might be more a matter of the wheel width, and the offset. 7" width with a 35 offset will fit beautifully.. but i don't think you'll find alot of 19x7's... it might also have to do with using tires that are slightly under-width (ie stretching) which makes the shoulder/treadpatch a little bit narrower than the rim itself, meaning that you can run a wider rim than you could if you ran the 'proper' width tire. For example i have 225mm on 7" width.. stretching would be 205mm on a 7" to keep the same rims, or an 8" rim if i wanted to keep my tires. But there are risks associated with stretching.. so it's best if you can use width and offset to take care of the majority of the rubbing, rather than using a narrower tire.
Old Feb 2, 2009 | 02:17 PM
  #2731
chentwoten's Avatar
Caped, thanks for the pics that really clears it up. Looks like i gotta pull that block and the slave cylinder (it is attached to it, right?). Is that a fidanza flywheel in the picture? I am looking at the oem replacement exedy clutch kits (about 150) but the flywheel is real expensive (300+)? And do you have any pics of the gussets? Thanks again for all your help,
Mike
Old Feb 2, 2009 | 02:27 PM
  #2732
BenStoked's Avatar
Jesus was a Zombie.
Caped kinda hit around the answer; there isnt enough rubber. if your max is a daily driver, then 19s (even 18s) are too big for a decent ride. too little sidewall to absorb the bumps. I think that is why there are so few maximas with 18s, and 19s. technically, I think a 20 could fit (OD of tire is about 25.5 or so, too lazy to google atm), but the ride would be so harsh, you would get back problems driving it (or maybe the harsh vibrations would act as a massage? )
Old Feb 2, 2009 | 03:12 PM
  #2733
Mike
the slave cylinder bolts onto the tranny case.. there's a rubber hose that connects that to the block.
the flywheel in the pic was an OEM one. I have a fidanza you can buy for $225 tho if you want it. They are like $350 new.
gussets are bolted onto the engine just above the oilpan and reach down and rap around the driver side of the oipan, where the tranny bolts in at the bottom. you also need those spacer plates. the gussets are 30429 and 30429M
Old Feb 2, 2009 | 03:16 PM
  #2734
yea.. that's the thing i never quite got why people want to say "19's will rub" cuz as long as the rim is narrow enough, and the sidewall is short enough, then you won't rub. but yea, the ride will be awful.
Old Feb 2, 2009 | 03:21 PM
  #2735
Greeny's Avatar
¯\(°_o)/¯
It's all about the "look" these days guys, not about how it rides...
Old Feb 2, 2009 | 03:33 PM
  #2736
BenStoked's Avatar
Jesus was a Zombie.
fawk a look, if I have to drive it every day, for an average of an hour of my time, I don't want to put a friggin tire/wheel combo on it that is going to make that hour more miserable than a trip to the doctor for a rectal exam (at least, one can imagine it would be that bad)
Old Feb 2, 2009 | 08:39 PM
  #2737
92vince's Avatar
hey guys, i have my 92 GXE in MINT condition for sale in NJ 08852. but i cant post it, would someone please post it for me in the forsale section?
http://cnj.en.craigslist.org/cto/1018580178.html
-vince
Old Feb 2, 2009 | 10:18 PM
  #2738
you guys are crazy but u did add more to what was said... yeah my car is a daily driver and im really just thinking about 19's because i want them shows around this time next year i should have a new max im still thinking '01 cause i like the body style but yeah i know that how the right will be but i only drive it to work and back i really dont go anywhere else but i guess ill do some sweet 18's or get just get the 19s and deal with it... lol but hell thankx for the info on that...
Old Feb 2, 2009 | 10:23 PM
  #2739
on to another question i have... i know u guy might be like well damn how many things does this guy want to know well i want to know as much as ur gonna tell me its my first car and i gotta take care of it... but why is there no light under my hood? lol i been looking for one everywhere under it and i dont see it and there is this line under my hood that keeps coming off i think its a vacc line ill post a pic in a few mins about that and my trunk light is shot to hell so i put a neon in it and that sucks also because its not bright enough what can i do to get a real bright light in there? replace it with an LED bar?
Old Feb 2, 2009 | 10:37 PM
  #2740
LEDs SUCK for lighting up spaces.. they are good as indicators if you see them head on, but not for outright illumination. I'd suggest a Cold Cathode tube like you can get in the computer case section at Best Buy or Tiger Direct.. it's designed to run on 12v already, so that would be a direct wire-in.
as for the hood light, there isn't one. if you want to add one, you will just have to figure out a good place to mount something, with a glare shield on it to direct the light down rather than out.
Old Feb 2, 2009 | 11:46 PM
  #2741
I just came across this... 20" x 7.5" with damn near no tire lol but nice ride overall...
Old Feb 3, 2009 | 02:16 AM
  #2742
BenStoked's Avatar
Jesus was a Zombie.
as caped said, ccft are what you want. I picked up some blue ones the other day for ten dollars. had two 12 inch tubes. they are for a computer, but snip a wire, and whamo: good to go.
Old Feb 3, 2009 | 09:35 AM
  #2743
ill search for em and wire it up and post pix if i get them to work lol...thankx again my peeps
Old Feb 3, 2009 | 09:47 AM
  #2744
300zmax's Avatar
i like the color the shaved handles and the interior, the wheels on the other take to much away from the car. imo im a fan of stock se rims with the centers painted
Old Feb 3, 2009 | 10:46 AM
  #2745
BenStoked's Avatar
Jesus was a Zombie.
z31 sawblades ftw!
Old Feb 3, 2009 | 03:38 PM
  #2746
lildrew069's Avatar
g37 rims
i have a quick question would g37 rims fit on my 90 max the tires are the front 225/45r/19 19x8.5 and the back is 245 40r 19 19x9 if they dont what size tires should i purchase to make sure they fit? thanks
Old Feb 3, 2009 | 03:49 PM
  #2747
BenStoked's Avatar
Jesus was a Zombie.
not a wheel guy, but for others, here are the specs:
Front:
* Weight: xx lbs
* Size: 19 X 8-1/2J
* Material: Aluminum
* Offset: 43 mm
* Tire Size: 225/45WR19
Rear:
* Weight: xx lbs
* Size: 19 X 9J
* Offset: 45 mm
* Tire Size: 245/40WR19
edit: after re-looking at the sizes, I am pretty sure that no matter what tire you put on there, with whatever spacers, they are still too big for the car. not 100% but still sure.
Old Feb 3, 2009 | 07:17 PM
  #2748
lildrew069's Avatar
thanks
Old Feb 4, 2009 | 01:54 PM
  #2749
300zmax's Avatar
where can i get some good pics of a 5speed swap on a VG? im going to be doing the swap soon, spring ish
Old Feb 4, 2009 | 02:05 PM
  #2750
mod or sell?
here
Old Feb 4, 2009 | 02:09 PM
  #2751
coolsun's Avatar
Did anyone Try to Reto fit Projectors into stock SE fogs?
Old Feb 4, 2009 | 11:59 PM
  #2752
PROBLEM: My car happens to be leaking antifreeze from the left side of my engine near the alt. and its getting over the belts and eveything on that side but i cant ever see where its coming from because its always over evething when i go to look could be be the water pump?
Old Feb 5, 2009 | 06:23 AM
  #2753
mod or sell?
steam clean, add dye to antifreeze, start motor and look for source of dye.
It most likely the water pump.
Old Feb 5, 2009 | 06:25 AM
  #2754
91SER_Facehugger)'s Avatar
is there a 2 door conversion for the 4dr
Hi id like to introduce myself i am a former non car guy i found cars after i had kids they are so much fun and hurtling down the road at 150 plus is freaking amazing had i known how much potential was in a maxima i wouldn't have been so much of a honda ***** my question is does anyone have any information on a 2door conversion i have one pic i found somewhere of it i really want to see what it would look like and all the purist sorry i just found it irrestable with 2 doors it's like a skyline/montecarlo looks wise perfect for custom bodykits oh i do that too thanks guys let me know
oh i am dan by the way
Chics are like nitrous you know it's dangerous but u gotta hit that
Old Feb 5, 2009 | 06:26 AM
  #2755
300zmax's Avatar
my money is on the pump and the hoses just above it.
time for a pump and belt change. while your ripping stuff apart new thermostat and new hoses
Old Feb 5, 2009 | 06:31 AM
  #2756
BenStoked's Avatar
Jesus was a Zombie.
2-door maxima is photoshopped, not a real car.
edit: they also had a concept drawing for a 2 door max, but they never made it.
Old Feb 5, 2009 | 06:33 AM
  #2757
300zmax's Avatar
ok first thing, please use periods to end sentences, seriously confusing. next there are no two door conversions that i am aware of. ive see suicide rear door kits claiming to be universal, but no two door kits for the gen3 or any other max for that matter, if you want two door get a Z.
the only two door max pic i have seen was illustration from car and drive another member posted.
Old Feb 5, 2009 | 11:28 AM
  #2758
mod or sell?
all things are possible with enough stupidity and money.
you have kids and want to change from a 4 door to a 2 door?
you have kids and are doing 150 on a public road?
GROW UP!!!
Old Feb 5, 2009 | 11:37 AM
  #2759
Pearl93VE's Avatar
I can has?
I did the two door conversion on my car a little while back:
Old Feb 5, 2009 | 12:24 PM
  #2760
300zmax's Avatar
better yet sell your kids and rwd your car with the VK45DE!!
check out the forum for some Serious mods. if you do body kits you should know how stupid that sounds
