Nitrous
Nitrous Oxide
Ok, in the near future, I am looking into putting a 50 shot Nitrous oxide system in my car.....for obvious reasons since I can't afford a Supercharger. However, do I need to get an UPRD ecu or anything like that? Do I need to get a valve body upgrade? Also, what shop/store/company offers drop in nitrous setups for the Max that are under $1000.00. Thanks guys
Erik
Southeast Maxima Group
p.s. As you ca see, I am pretty clueless about nitrous.
[Edited by Ramius83 on 01-05-2001 at 08:49 AM]
Erik
Go to Zex's web site and click under their Performance Product Line link, tell's you all the good stuff. I believe they have systems for around the 550 range, plus they say all their systems were designed to work on stock set-ups. Good luck.
Originally posted by Ramius83
Ok, in the near future, I am looking into putting a 50 shot Nitrous oxide system in my car.....for obvious reasons since I can't afford a Supercharger. However, do I need to get an UPRD ecu or anything like that? Do I need to get a valve body upgrade? Also, where can you get nitrous setups that are under $1000.00. Thanks guys
Erik
Erik
Re: Nitrous Oxide
Stay away from ZEX. Go with NOS or NX (Nitrous Express). I personally would go with NX because all their kits are wet setup. After all my research, I don't really like Dry setup.
Erik
Erik
Re: Re: Nitrous Oxide
That may be true, I don't know to much about the differences in the systems. Just tryin to help ya out. 1MAX2NV probably knows more than I.
Erik
Erik
What is the difference between the two?
What is the difference between a wet and a dry set-up. About how much would a wet setup cost from Nitrous Express? Why are the dry setups from ZEX not good, thanks.
Erik
Erik
the difference between dry and wet
wet systems inject fuel and the nos into the intake manifold.
dry systems just injectn NOS into the intake manifold.
you may also want to look into direct inject systems. I'm not sure if it is possible with the dual intake runners. I'm not all that familair with how the system works.
I would also look at JWT's NOS system. It is a very complete system and includes a piggy back ECU that controls the whole system. It is expensive, but it is a very complete system. you can purchace it from cattman at http://www.cattman.com . He sells it a a discount compared to the JWT prices..
FroMan
FroMan
Oh, by the way
Who here has both set-ups, the Nitrous Express and the ZEX? I would like your opinions....thanks
Erik
Erik
is the nos bad for your engine? I have herd that it was but a lot of people are starting to get them for there imports. Does it strane your engie? Is it bad in the long run for your car? Is sounds like a great idea but not sure if it hurts it. I have 107,000 miles on my car is it worth it?
My 4DSC
Jan 4, 2001 07:21 PM
