NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting!
Old Jul 16, 2009 | 11:31 AM
  #4201
pmohr's Avatar
No more Maximas...
Originally Posted by J RO 9
my brake light came on last week, and my brake fluid was low. after topping it off, the same thing happened 2-3 days later. so i found the leak, and it was coming from the rear driver's side. it is confirmed to be the caliper that's leaking. i purchased a low-mileage caliper from a friend's parts car. his car was a 98, i have a 97. i went today to get the caliper changed, and it wouldn't fit on my car. my old caliper lined up perfectly with the 2 bolts, but the 'new' one would not. when my mechanic lined up the caliper to one of the bolts, the other bolt wouldn't reach. why is that?
i got the caliper for 20 bucks, i don't want to spend $90 on a new one
Is this what your mechanic is saying, or did you see it yourself?
Have you looked at the two side by side?
The calipers should all be identical. Are you sure it's from a Maxima? 4th gen?
Old Jul 16, 2009 | 11:38 AM
  #4202
J RO 9's Avatar
i saw it for myself, my mechanic showed me. is there a reason it didn't fit?
i saw my friend pull it off the parts car, came from a 98.
Old Jul 16, 2009 | 12:13 PM
  #4203
B_Eaze's Avatar
Pics? sounds like your friend may have had an 'upgraded' caliper
Old Jul 16, 2009 | 12:15 PM
  #4204
Leo_Koneval's Avatar
This is going to sound silly, but does it matter which side you pull and use? Like if I pulled the caliper from the right side of a car can I use it on the left side of the car I am putting it on?
Because it might be that you accidentally took the caliper from the wrong side or the caliper is just plain old weird
Old Jul 17, 2009 | 09:28 AM
  #4205
Notary Sojac's Avatar
Need to replace door weatherstrip
The weatherstrip that goes around the inside of the door frame on my 99 Max is starting to disintegrate. Who knows, why, all the other doors are fine.
Is there a good source anyone can recommend for a replacement?
Old Jul 17, 2009 | 09:43 AM
  #4206
defiance's Avatar
sounds like the caliper from the 98 was an "aftermarket" unit.
Old Jul 17, 2009 | 09:45 AM
  #4207
pmohr's Avatar
No more Maximas...
Which door?
Have you tried Nissan? One would think that they would tend to be a good source...
Or have you checked the classifieds?
Is there a reason it didn't fit? Yes, it's either the wrong part or it was installed incorrectly.
Again, did you look at them side by side? Have you tried using the torque member from your friends car?
Old Jul 17, 2009 | 09:47 AM
  #4208
pmohr's Avatar
No more Maximas...
Even so, it would've had to bolt up to the '98, no?
All of the rear calipers should be interchangeable, so unless his aftermarket unit uses a different bolt pattern and also came with the torque member...
Old Jul 17, 2009 | 09:48 AM
  #4209
pmohr's Avatar
No more Maximas...
The bolt pattern for caliper to torque member should be the same, IIRC. Of course if you put one on the wrong side, the bleeder would be facing the wrong direction and you'd likely have issues with the parking brake cable.
Old Jul 17, 2009 | 10:36 AM
  #4210
$uperstarr124's Avatar
Ok, so my struts on my 96 maxxy r done....like the ride of the car is horrible n it makes me not even want to the drive car...I been lookin for sum coilovers but dun't wanna buy new ones if any1 is sellin theirs please contact me asap
Old Jul 17, 2009 | 10:59 AM
  #4211
pmohr's Avatar
No more Maximas...
Posting your number on a public forum in the first place is just a bad idea.
Second, this is for questions about 4th gens, not trying to buy 4th gen parts.
Look in the classifieds, search eBay, craigslist, etc.
Old Jul 17, 2009 | 07:54 PM
  #4212
yea i been thinking about it all day...anyway too late.....already have companies n old grlfriends botherin me lol.....iite
Old Jul 17, 2009 | 08:39 PM
  #4213
Guys edit your posts, don't let your number get into the wrong hands it could lead to some seriously trouble or inconveniences down the road for you or the future owner of that number.
Old Jul 17, 2009 | 08:43 PM
  #4214
pmohr's Avatar
No more Maximas...
I know not of what you speak
Old Jul 18, 2009 | 02:51 AM
  #4215
haydeno's Avatar
Just got o2 sensor code so i changed the o2 sensor. Should i change the other two as well? Bosch says that changing o2 sensor can save 10% on gas but not sure weather to believe since they sell the sensors. Don't mind changing just want to know if its worthwhile or if i should just wait until they go bad again.
Old Jul 19, 2009 | 08:08 AM
  #4216
Rob_0126's Avatar
skipping problem
I need some help.
I just cranked the car up this morning. It started skipping.
The cel light says code 77, rear o2 sensor.
Would the o2 sensor cause engine to skip?
The car shakes, but it does drive. It goes in and out at random times, but mostly stays skipping.
UPDATE: Just checked codes after first reset, just 55, which i guess is the normal code. So no 77 code now, but it still skips; engine shakes, especially in drive. But the shake is still there in park, so I guess I can rule out the tranny.
I was guessing a coil going, but no codes?!
Old Jul 19, 2009 | 09:04 AM
  #4217
B_Eaze's Avatar
Originally Posted by Rob_0126
I need some help.
You mean knocking? Rear O2 sensor shouldn't cause anything to occur in ur car. You prob have a dead cylinder from either a bad plug or coil pack.
try unpluggin each coil pack while the engine is running. If you unplug one and it doesn't affect how the engine is running then there is they culprit
Old Jul 19, 2009 | 09:17 AM
  #4218
Rob_0126's Avatar
I let the car sit a few minutes, come back out to crank, and it wasn't doing it.
But after a few minutes, it started it again.
Old Jul 19, 2009 | 10:53 AM
  #4219
pmohr's Avatar
No more Maximas...
So when it is misfiring, have you narrowed down which cylinder it is yet?
As O2 sensors age, they can get lazy, and not report the proper readings yet still not throw a code. If they're original and you've got the cash (and have somewhat poor MPG) then it may be worth it, yes.
There's no point in changing the rear unless it's bad, as it doesn't affect MPG.
Old Jul 19, 2009 | 11:56 AM
  #4220
Rob_0126's Avatar
Not yet. The car stopped doing it.
The only thing that happened just before it started doing this was:
I took some hydrogen peroxide, and poured it into the vents between the bottom of the windshield and hood(on the outside), to get rid of a little mildew smell hopefully. I wouldn't have thought any electronic components would get peroxide on them because that vent gets rained in anyways.
Old Jul 19, 2009 | 02:04 PM
  #4221
nickoleyt's Avatar
Loud thump (clunk. bang) when shifted into gear
I have a '99 Maxima. When you shift into gear from park or nuetral the car jumps with a large clunk. I know not much about font wheel drive. In an older car I would assume motor mounts or universal joints. However like I said I am new to front wheel drive.
Any help would be appreciated
Old Jul 19, 2009 | 02:24 PM
  #4222
pmohr's Avatar
No more Maximas...
Have you checked out the motor mounts yet?
Old Jul 19, 2009 | 03:04 PM
  #4223
Sorry for barging in, but I have a burning question haha
A while ago we were talking in a thread about a person who had trouble programming their key remote and there was this piece of equipment with a antenna sticking out that I didn't know what to call or its purpose and so I have some pictures and I was wondering if you could help me identify it.
And here is where this piece is supposed to be connected to:
And sorry I didn't know what to call it and its purpose and so I didn't know what to type up for the search haha
Old Jul 19, 2009 | 03:28 PM
  #4224
pmohr's Avatar
No more Maximas...
Looks to be an antenna for a remote start.
Is it a little black 3 or 4 pin connector, with a flat telephone style wire? Probably a DEI unit.
Old Jul 19, 2009 | 04:47 PM
  #4225
nickoleyt's Avatar
Have you checked out the motor mountts yet?
No i dont really know how. I assume a slight rev of the engine with foot on the break.
Old Jul 19, 2009 | 04:48 PM
  #4226
pmohr's Avatar
No more Maximas...
You could do it like that, yes.
Obviously it must be in gear.
Old Jul 19, 2009 | 09:02 PM
  #4227
watson's Avatar
Ok, so I have searched about this but have got no info on what is happening to my car. Washed the engine bay the other day, i covered up all the fuse box's but not the alternator. After washing it and leting it dry I start up the car and battery light and brake light are on, so I know that points to the alternator so i decided to keep the car running for a while with all the accesories on(stereo, ac, lights...) and the car still has not died. I have taken the car out for over 200km and the lights are still on but car is still going. The battery is an old battery that has died on me many times from the last time my alt died so dont think the battery is just strong. Now i used an air pressure to spray the alt and the alt connector to make sure there is no water left in it. I have a feeling I may have messed up a sensor or something that triggers those 2 lights. So now I am just wondering how can I get rid of these lights since my alt is fine(or seems to be fine). I have started my car several times and drove alot with my music on and the ac blowing. Can anyone help? Cheers
Old Jul 19, 2009 | 09:58 PM
  #4228
Really? Haha
I bought the car this way and didn't know it had a remote start, at first I thought it was some sort of technology that came stock but I guess the old owner did some work on the car and was nice enough to NOT include the remotes and such haha
Old Jul 19, 2009 | 10:05 PM
  #4229
B_Eaze's Avatar
It might be your battery but check ur idler pulley and the voltage of ur car while running. If voltage is around 14V chargin system should be fine
Old Jul 20, 2009 | 12:59 PM
  #4230
jhonny's Avatar
hi guys
it's been a week since my car had the h&r springs installed. after three days, everytime I
do a narrow turn my car makes a noise coming out from the struts. i believe it's the strut bar. so, do I need to replace the bar? or what else could it be?
I've searched in the forum and I haven't found any answer
thank you in advance,
jhonny
Old Jul 20, 2009 | 01:20 PM
  #4231
pmohr's Avatar
No more Maximas...
Really? Haha
Follow the wire back down, it'll likely lead you to the remote start/alarm's 'brain', unless it's been removed.
Originally Posted by jhonny
hi guys
jhonny
Why do you think it's the strut bar? Unless it's been flipped upside down and is hitting the engine when you're on the gas, it can't really make any noises.
Did you replace the strut mount bearings while you were in there? That's likely your problem.
Have you checked to make sure it's providing adequate power? Check the voltage at the battery while idling, it should be around 14 volts.
Check the FSM, EL-35 has a nice diagnostics flowchart for this situation.
Old Jul 20, 2009 | 02:30 PM
  #4232
jhonny's Avatar
i think it's the strut bar because every time i turn, either when the car's not moving or is moving, it makes this noise. i talked with my mechanic and he agreed with me. no, i did not replace the strut mount bearing. also, it seems that the noise it's close to the suspension and tires
Old Jul 20, 2009 | 03:04 PM
  #4233
pmohr's Avatar
No more Maximas...
That still doesn't make any sense.
The strut bar does not move when you turn the wheel. Nor when you accelerate, decelerate, or do barrel rolls in midair.
Well, have you removed the strut bar and gone for a drive yet? It takes 5 minutes to remove (not even), and it's easier than waiting on replies here.
Old Jul 20, 2009 | 03:55 PM
  #4234
jhonny's Avatar
ok. could it be anything else other than what you just said before?
Old Jul 20, 2009 | 04:03 PM
  #4235
pmohr's Avatar
No more Maximas...
It could be several things in the front end, but the strut mount bearings are most likely.
Old Jul 20, 2009 | 04:07 PM
  #4236
jhonny's Avatar
do you have any idea how much it could cost?
Old Jul 20, 2009 | 04:14 PM
  #4237
pmohr's Avatar
No more Maximas...
Have you even tried to price it out yet?
It depends on where you get it from, what manufacturer, what region, sales/coupons/etc, who does it, how much they charge an hour, how many hours they charge to do it.
Look for prices yourself, that's the only way to get accurate pricing. Then call up whoever does your work, ask them.
Old Jul 20, 2009 | 04:20 PM
  #4238
jhonny's Avatar
ok thanks
Old Jul 20, 2009 | 05:05 PM
  #4239
ahsrunner's Avatar
I have a quick question. My 1997 maxima se does not have the low end power that it should. When I floor it from a dead stop, i can't even get it to squeak the tires. Anyone have any idea what the problem could be? It does show a code for the knock sensor if that may have something to do wich it. Thanks!
Old Jul 20, 2009 | 05:23 PM
  #4240
pmohr's Avatar
No more Maximas...
Replace the KS, first off.
Judging power by being able to spin the tires is a completely inaccurate method.
