NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting!
Old Feb 10, 2010 | 01:40 PM
  #5401
Originally Posted by Mmax99
I know about those upgrades. but like would i need a test pipe, resonator, where the precats are and if i would need a b- pipe. or what not.
Search bro. The complete setup is: headers with ypipe, fastcat, catback. Nothing more, nothing less. That will get you from the engine to the tailpipe.
Resonators and test pipes do not = power.
Catbacks include the bpipe
Some catbacks include a resonator, some don't.
Old Feb 10, 2010 | 02:52 PM
  #5402
Ham1's Avatar
Originally Posted by sgtboehn
I bought my max with a blown head gasket with 158K on the clock for 400 bucks! I found a newer motor with only 42000 miles for 200 bucks! I would say if you can find a deal like that and can do it yourself, then I would say it is worth it.
Or you can just tear the motor apart and replace the head gasket. Do some searching around and see what you can find...your call!
Wow, where did you find an engine for $200 bucks?!
MB
Old Feb 10, 2010 | 03:20 PM
  #5403
sgtboehn's Avatar
MB
Was looking on Cragslist and happened to find one in E. ohio. Just look around a bit, you may have to do a little traveling...but it may be worth it in the end!
Old Feb 10, 2010 | 03:59 PM
  #5404
Mmax99's Avatar
Ah Thanks The Wizard!
Old Feb 12, 2010 | 06:53 AM
  #5405
L2theBR's Avatar
I have a question regarding the cattman headers...
Approximately how much are the cattman headers? I couldn't find it anywhere on their website and I e-mailed them as well with no response thus far. I also tried using search with no results. The closest I've gotten is about $850 but the post was 2 years ago.
Old Feb 12, 2010 | 09:57 AM
  #5406
They're still $850-ish.
Look in the Group Deal forum, his sales are everywhere...
Yes, the unique ypipe is included in the $850 price tag.
Call Cattman, he's a great guy. He'll answer all your questions.
Old Feb 15, 2010 | 03:59 PM
  #5407
Remminator's Avatar
Hi all, noob here and half way through a 3.5 swap. The engine i just picked up has no intake manifold (upper or lower) and no injectors/fuel rail. I plan on using my 95 ecu, so I know that means doing the timing swap. Could someone please advise as to the best im/fuelrail/inj set-up. Thanks.
Old Feb 16, 2010 | 05:18 AM
  #5408
sgtboehn's Avatar
Well was getting ready to drop the new motor in and noticed a broken bracket on the passenger side axle that apparently attaches to the back of the motor. Just wondering if this is sold separately or would it just be easier to purchase the entire cv axle?
Was searching the forums didnt really see anything and I didnt really wanted to start a new topic on this. Here is a link to the pic.
http://forums.maxima.org/album.php?a...ictureid=14384
Old Feb 16, 2010 | 05:23 AM
  #5409
pmohr's Avatar
No more Maximas...
The bracket does not come with a new axle. Your best bet is the classifieds or a junkyard.
Old Feb 16, 2010 | 05:27 AM
  #5410
sgtboehn's Avatar
Im guessing this is one of those difficult parts to get a hold of? Would it be worth it just going to the "stealership" just to check and see if its available?
Old Feb 16, 2010 | 06:47 AM
  #5411
86gtconv's Avatar
I would definitely try a junk yard first. We have an LKQ here that you pull your own parts and the prices are reasonable.
Old Feb 16, 2010 | 10:17 AM
  #5412
sgtboehn's Avatar
Yea that would be the more affordable way to go...just need to take my shovel with me since we have near 3 feet of snow!
Old Feb 16, 2010 | 03:18 PM
  #5413
saleener94's Avatar
hard shifting!
Does anyone know if a bad speed sensor might cause rough shifting on an automatic? My CEL is on for that sensor but i am strapped for cash. However if it is causing the hard shifting I will dig up some money and buy it immediately I just need to be sure.
Old Feb 16, 2010 | 09:06 PM
  #5414
96MaXiclean's Avatar
Im also a noob and im wondering what other gen. maxi wheels will fit on a 4th gen.?
Old Feb 17, 2010 | 03:17 AM
  #5415
icecreampaint's Avatar
Suspension eibach pro kit ....what struts
Yes I'm new here...
And yes I kno there is a whole suspension thread but it didn't answe my question. First off I got my car 95 maxima. It had a blown head gasket which was a biatch to change and I got it all fixed and workin pretty well now but I ordered some ebiach prokit drop springs an was really wondering what struts are the winnin combination for these springs. And also how low oh a drop after settleing should I expect
Old Feb 17, 2010 | 04:48 PM
  #5416
Rob_0126's Avatar
Just put a fresh TPS yesterday. Using revised method, variable is set at 545 ohms - 4.3K ohms WOT.
Coming home from work today, something weird happened.
I went to punch it into the passing lane, the AT downshifted, the car started to pick up for .25 sec, then power and rpms dropped back, as if the tranny upshifted(but it did not upshift).
But about .5sec later, it took off fine.
To see if it would do it again, I nailed it from a roll merging, and it took off like a rocket, without a hiccup.
Was this just a flook? It hasn't ever done this before. And this is the first WOT accel. I have done, since I installed the new TPS.
Would a faulty CKPS cause this?
Old Feb 17, 2010 | 06:09 PM
  #5417
BuckeyeMax1982's Avatar
I have heard of this. I had a similar problem on my '96 I30. My tranny didn't shift perfectly, but it wasn't terrible. My speedometer was the main reason I replaced the VSS because my odometer would have been off and the speedo was irratic. I replaced the VSS (vehicle speed sensor) and all 3 symptoms were cured. There was no CEL at any point. My $.02...
Old Feb 17, 2010 | 06:15 PM
  #5418
Originally Posted by glitterati
Hello. I drive a 1995 Maxima and recently had a bunch of work done at my local Kelly Nissan dealer in Chicago. I'm talking knock sensor, o2 sensor, fuel injectors, etc. I was reading the paperwork and was floored when there was a comment saying that I was using 87 octane gas instead of 93 octane gas which is causing my car to misfire. For as long as I have been driving, I have been using what I thought was premium 93 gas from Shell. I've also been recommended this from a tech at Orland Park Nissan. When I told him that I've been using 93 premium, he looked at me like I was crazy.
Is it really my gas from Shell that is causing issues with my car? I always make sure to use premium gas as suggested by my manual and by the gas cap. All these years I've been thinking that I was using 93 while the techs at Nissan are telling me that it's 87? Thanks for all future replies if any.
I think your car is misfiring for something completely other than Shell gas. Of all the gas stations in my area (Dayton, OH), Shell is the best and highest quality gas available. I've never had trouble in 9 cars I religiously filled with their gas exclusively (I know, I'm **** retentive...). The misfires I had in my 4th gens was due to MAF issues, coil issues, and knock sensors. You will probably get a knock sensor code with any misfire, but most times it is due to a faulty coil or MAF, which causes the misfire and throws the knock sensor code. At least that has been my experience in owning 2 4th gens and working on 2 others for friends...good luck.
Old Feb 17, 2010 | 06:19 PM
  #5419
Originally Posted by Mike-95SE
sorry, i forgot to mention my dad insisted he buy a used axle from a junk yard, which is in pretty good condition, except that the boot on the wheel side of the axle, has a tear in it... so i wanna know how to get the new boot on.
Get a new half-shaft (reman...) from autozone. lifetime warranty and works perfectly. it's only $79...or roughly thereabout.
Old Feb 17, 2010 | 06:29 PM
  #5420
Dustin2049's Avatar
Short Shifter Issue
I just installed my new short throw and when the car is running the shifter squeks when you shift. I made sure the bearings and the ball were greased and it isn't rubbing the heat shield so I was just wondering what could cause this issue.
Old Feb 18, 2010 | 02:41 PM
  #5421
96 SE JET's Avatar
ok check engine light came on and got it checked there was no code just said something about transmission and to see dealer also a knock sensor p325 code . I have a 1997 se 5speed
Old Feb 18, 2010 | 03:00 PM
  #5422
What brand of STS?
Old Feb 18, 2010 | 03:01 PM
  #5423
And....your question is what again???
Old Feb 18, 2010 | 04:17 PM
  #5424
96 SE JET's Avatar
My question is what does this mean and what do i need to do ? Has anyone experienced this
Old Feb 18, 2010 | 04:34 PM
  #5425
Ummm....you never told us the transmission code!! KS code could be a piggy back code to the tranny code, so take care of that first.
Max have any symptoms/ problems??
Old Feb 18, 2010 | 07:08 PM
  #5426
96 SE JET's Avatar
none that i can tell just check engine light and there was no code
Old Feb 18, 2010 | 08:52 PM
  #5427
7mJoe's Avatar
I have strong smell of coolant in my cabin when I get it it after its been sitting for the night or a couple hours. I searched high and low for any leaking hoses or lines and found none. I noticed though that I smelt some coolant around where the PS reservoir is. But could the smell be coming from a leaky heater core? Or am I just imagining this!?
Old Feb 18, 2010 | 09:22 PM
  #5428
a bad KS doesn't throw a code, that is normal. If you don't have any symptoms/problems, what made you check to see if you had any codes?
  #5429
Very well could be a leaky heater core.
Old Feb 18, 2010 | 10:53 PM
  #5430
7mJoe's Avatar
Is this common? Is it typically the hoses or the actual core that go bad? I would assume the hoses right? Guess I'm gonna have to remove the dash eh? Anyway I can get a visual on the core from passenger or drivers side without removing anything?
Old Feb 19, 2010 | 12:17 AM
  #5431
Nope, not common at all. The core usually goes bad, not the hoses. Big pain to get to it unfortunately, no easy way around it. I'd get some free second and third opinions before I tore the dash out etc.
Old Feb 19, 2010 | 01:26 AM
  #5432
7mJoe's Avatar
Yea, I'm not planning on going at it anytime soon. Worst comes to worst I can just re-route the lines when summer rolls around until I can get crackin at the solution.
Old Feb 19, 2010 | 04:43 AM
  #5433
96 SE JET's Avatar
The service engine light came on and I wanted to know why when I checked there was a p325 code and it said something about the trans and 2 see dealer
Old Feb 19, 2010 | 12:51 PM
  #5434
dansmaxi's Avatar
Hey guys im new to the forum, Im in Ottawa canada and just bought a 1996 Maxima 5spd, I bought it off a former .org member but dont remember the username, Ill post some pics up of the max
Here is a link to a pic http://s995.photobucket.com/albums/a...5.jpg&newest=1
Old Feb 19, 2010 | 12:52 PM
  #5435
Welcome!
Old Feb 20, 2010 | 08:43 AM
  #5436
watson's Avatar
Hey Dansmaxi, Im from Ottawa too, if you ever have any questions about your car or need help with things feel free to ask me, ive done most of the basic stuff on our car(alternator, starter, rad, ks, exhaust...)
Old Feb 20, 2010 | 11:04 AM
  #5437
96 SE JET's Avatar
Ive read the post about the EGR cleaning but has any one ever bought one from autozone. Got a p1400 code dont think i can clean it out on my own.
Old Feb 21, 2010 | 09:15 AM
  #5438
Skeezy's Avatar
Hi all, i have a '96 maxima 3.0l, with 129K on it and was wondering if any of those fuel additives were worth adding, i wanna clean out my engine and fuel line i dont think its ever been done. i use BP gas 87 octane and mobil1 oil. any recommendations for keeping the car running good? and any advice on K&N filters are they any good? thanks
Old Feb 21, 2010 | 09:52 AM
  #5439
B_Eaze's Avatar
What are you trying to do? replace the EGR tube, EGR valve, the sensor? Either way you look at it its gonna be the same amount of work. If you can remove your old ones then you can definitely clean it so why not save teh $100 ?
http://forums.maxima.org/4th-generat...g-dummies.html
http://forums.maxima.org/4th-generat...ing-p0400.html
http://forums.maxima.org/4th-generat...e-removal.html
Old Feb 21, 2010 | 10:06 AM
  #5440
adamsanders's Avatar
Start using premium fuel, these cars were designed to run on it.
