NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting!
Old Jul 13, 2011 | 09:50 PM
  #7441
RoseCityMax's Avatar
Originally Posted by cashoit
4/1999 is referring to 2000 models.
Got it. Thanks again!
Old Jul 14, 2011 | 07:00 AM
  #7442
cashoit's Avatar
Originally Posted by 4thgenrocks
i've researched and everywhere I've looked it says that my 98 max's horn wires are GREEN/WHITE and come from the steering harness. My problem though is I don't have any green/white wires coming from the harness...only the yellow/blue wire for the airbag and the brown, orange and white for the cruise controls. I'm installing an 05 altima wheel and the horns the last thing to do
The horn connector is completely separate from the airbag and cruise connectors. THere should be 2 or 3 connectors behind the steering wheel. One of them is for the horn.
Old Jul 14, 2011 | 11:50 AM
  #7443
boldm28's Avatar
replacing tail light (reverse ) lens
I have a 1999 nissan maixma and was wondering how to replace the tail light lens which is on the trunk
TIA
Old Jul 15, 2011 | 06:45 PM
  #7444
4thgenrocks's Avatar
yea mine has only two connectors..the yellow and blue one which hooked up to the airbag and the cruise control brown orange and white one. though when i had the wheel off i did see another main connector that had a white striped green wire and a white wire in addition to some other variants of green and other colours...
Old Jul 16, 2011 | 01:01 PM
  #7445
beatdown97's Avatar
Originally Posted by sjtech
do it
what ballpark hp gain should i get from this type of setup with just a basic setup?
Old Jul 16, 2011 | 01:15 PM
  #7446
pmohr's Avatar
No more Maximas...
There's no way to even guess without knowing how you plan to do it. There is no 'basic setup'. Most every install is going to be different.
Old Jul 17, 2011 | 12:20 AM
  #7447
jeffro84's Avatar
So a few years ago I had my Bose head unit profesionally replaced with a pioneer unit in my 98 everything else is still stock bose. Im pretty knowledgeable with car audio but was scared to tackle the bose. Yesterday I purchased a subwoofer and amp and installed it myself. When I got evetrything installed, the radio will come on and function properly, but im getting no audio to the speakers. All I did was unplug the harness from the the the head unit, spliced the amp remote wire to the remote wire on the harness, and unhooked the battery to tie in the power supply. Is the no audio some sort of security deal with the bose portion? Please help
Old Jul 17, 2011 | 11:07 AM
  #7448
Shughes91's Avatar
I searched for some answers and haven't seem to find anything relevant. I have a 1997 Maxima and sometimes it has a problem starting. Some days I have to hold the gas down for a bit to just get it to crank. It turns over and its getting gas but still won't crank. One time it just randomly cranked up a few days later after sitting but a week ago it happened again and i haven't gotten anything to work. Everyone that's had this problem have responses like a clogged fuel filter or that the fuel injectors need cleaning. But 3 months ago I changed the oil & filter, air filter, fuel filter, and ran the fuel injector cleaner too. I can also go ahead and let ya'll know, the starter obviously works and there's no problem getting gas and the timing chain is fine. Any help is greatly appreciated. This is my only means of transportation right now and I just need some things that could affect this so i can rule out whatever doesn't work. Thanks, Savannah!
Old Jul 17, 2011 | 11:39 AM
  #7449
pmohr's Avatar
No more Maximas...
Did you check the fuse that powers the speakers?
Originally Posted by Shughes91
I searched for some answers and haven't seem to find anything relevant. I have a 1997 Maxima and sometimes it has a problem cold starting. Some days I have to hold the gas down for a bit to just get it to crank. It turns over and its getting gas but still won't crank. One time it just randomly cranked up a few days later after sitting but a week ago it happened again and i haven't gotten anything to work. Everyone that's had this problem have responses like a clogged fuel filter or that the fuel injectors need cleaning. But 3 months ago I changed the oil & filter, air filter, fuel filter, and ran the fuel injector cleaner too. I can also go ahead and let ya'll know, the starter obviously works and there's no problem getting gas and the timing chain is fine. Any help is greatly appreciated. This is my only means of transportation right now and I just need some things that could affect this so i can rule out whatever doesn't work. Thanks, Savannah!
So, from the top down. It won't crank without you touching the gas pedal? You say it 'turns over' but it won't crank...which makes no sense. By 'crank', do you mean start? Big difference there.
By 'randomly cranked up' do you mean it started cranking on it's own, with no one turning the key? Or it started up perfectly without issues?
So your problem is what, long cranking times and having to use the gas pedal for it to start reliably? Clean the TB and IACV first.
Old Jul 18, 2011 | 12:57 PM
  #7450
Mnick1's Avatar
I experienced the same thing and so did a buddy of mine. My issue was wrong spark plugs. I took it to a shop to have it figured out they said it was spark plugs. They put in the wrong kind and 2 days later I had your issue. I changed them to NGK's $15 and it started right up. Another time it was my coolant temp sensor $22 and coolant temp switch $9.
My buddies issue was... Lol he was simply out of gas. Moral of his story is make sure you have the bare necessities in place before troubleshooting. Hope this helps.
Old Jul 18, 2011 | 05:34 PM
  #7451
Perseus's Avatar
is there a how-to thread on replacing LCAs? i can only find how to change bushings and i'm sure there are a few unnecessary steps/tools listed if i just wanted to replace the entire LCA
ah thanks pmohr
Old Jul 18, 2011 | 05:47 PM
  #7452
pmohr's Avatar
No more Maximas...
http://www.youtube.com/watch?v=yTIeP...2C64F&index=20
Old Jul 19, 2011 | 11:53 AM
  #7453
russell's Avatar
My 99 would crank for a long time before starting. I had the starter tested at checker auto (now O' Reilly) and it tested good. I had them check it again and it failed. Replaced the started and haven't had any issues since. Even though the starter sounded like it was cranking pretty fast, it wasn't fast enough (I really couldn't hear a difference between the new starter and the old, but it fixed the problem).
I would check the starter along with pmohr's suggestions.
Old Jul 20, 2011 | 03:06 PM
  #7454
box12360's Avatar
i have a 98 infiniti i-30 that is having problems under the hood which is pretty close to this car. its a 3.0l 4gen motor. when i start it up it jumps to 2000 rpm's then after a few secounds the rpms start to go up to red line. someone cut the EGR cable and my friend started the car while it was cut. I put the new connector on and started the car and its still doing the same thing??? anyone ever heard of this or know how to fix this???
Old Jul 20, 2011 | 03:57 PM
  #7455
pmohr's Avatar
No more Maximas...
Originally Posted by box12360
hello all just trying to get my 15 post in for a new topic
No, that's not how this works. You post meaningful replies to current topics, or ask your questions in here. The post limit is in place for a reason, posting crap to get to 15 isn't tolerated well by the mods.
FWIW, the i30 is a Maxima, same chassis.
What do you mean by EGR 'cable'? A vacuum line, a wiring harness to one of the solenoids?
Checked for vacuum leaks, or a misrouted throttle/cruise cable?
Any codes?
Old Jul 20, 2011 | 08:58 PM
  #7456
box12360's Avatar
checked for codes no codes. EGR "cable" sorry meant wire to a connector, i looked for anything out of the ordinary with the vacuum hoses nothing. as i was looking earlier i did notice something odd on the throttle body. it looks like something should go here because the **** has wear marks
Old Jul 20, 2011 | 11:25 PM
  #7457
Mnick1's Avatar
Here's mine I hope this helps you out.
This might not work, if not I'll have it up in an hour.
http://www.facebook.com/photo.php?fb...type=1&theater
In case I deleted by mistake try this one,
Old Jul 21, 2011 | 08:50 AM
  #7458
box12360's Avatar
Yes thanks that helped allot, do you happen to know what that link does or what it is called, i need one i think this is what is causing the engine to rev up
Mnick 1 what kind of car and year is this off of
Old Jul 21, 2011 | 02:50 PM
  #7459
Mnick1's Avatar
If I'm not mistaken it brings the throttle back into an idle position. I could be wrong and there may be a better explanation than mine. I'll check it out and get back to you in about an hour.
Old Jul 21, 2011 | 04:10 PM
  #7460
pmohr's Avatar
No more Maximas...
All 4th gens have that same FITV setup.
It helps to raise the idle until coolant temps warm up, but I've noticed absolutely no difference without it, be it below freezing or over 100 deg outside.
Again, checked the throttle and cruise control cables? Has someone hooked an engine vacuum hose up to the cruise control actuator?
If you disconnect both cables, does it still rev up? Unplug the IACV?
When it revs up, is the throttle plate opening, or is it getting air through the IACV?
Have you checked the TPS adjustment?
Old Jul 21, 2011 | 05:08 PM
  #7461
Mnick1's Avatar
"Yes thanks that helped allot, do you happen to know what that link does or what it is called, i need one i think this is what is causing the engine to rev up
Mnick 1 what kind of car and year is this off of?"
1996 4th gen Maxima VQ30DE engine
Old Jul 21, 2011 | 06:55 PM
  #7462
box12360's Avatar
ok wasn't the fast idle cam as pmohr said, hugeeeeeeeeeeeee props by the way pmohr, i disconnected both cables and it idles fine, i now need to adjust those cables so it idles right any suggestions??
Old Jul 21, 2011 | 07:06 PM
  #7463
pmohr's Avatar
No more Maximas...
Which cable is pulling tight on the throttle body? I've seen some hook up engine vacuum to the cruise actuator before, and it causes some rather interesting idling.
Back the adjustment all the way off, adjust it up until the idle changes, then back it off about a full turn of the nut. That should roughly give you the best throttle body operation and throttle response.
Old Jul 22, 2011 | 02:40 AM
  #7464
Perseus's Avatar
I have a slow beading of oil on the passenger side. It's collecting on the 22mm bolts next to the LCA but the LCA is wet also; everywhere else looks dry. Any clues on where the leak is coming from?
Old Jul 22, 2011 | 03:44 AM
  #7465
pmohr's Avatar
No more Maximas...
Could be an oil pressure switch, oil pan gaskets/o-rings, timing cover o-rings, PS high pressure hose, really anything in the area. You need to clean it off then try to pinpoint the leak.
If you can't spot it, you can also use some UV dye.
Old Jul 24, 2011 | 12:33 AM
  #7466
chamyang18's Avatar
I bought an OBX header. I realize it didn't have the hole for the 02 in the front. Do I have to custom a hole?
Old Jul 26, 2011 | 01:29 PM
  #7467
box12360's Avatar
a/c Condenser
I have a 1998 infiniti i30, i need a new condenser. Recently i went to a junk yard and found a condenser on a 96 or 97 maxima and its about 2 inches shorter than the one on my infiniti. I'm not sure if it is because of the year of the motor or baecause the infiniti condenser is bigger. anyone have any idea on this? Can i use the smaller condenser (not sure if the fittings will work) and put less oil and r-134a in it???
Old Jul 26, 2011 | 01:46 PM
  #7468
pmohr's Avatar
No more Maximas...
The '96-98 i30 uses the same condenser as the 97-98 Maxima. Most likely the fittings have changed, as they did on the compressor with the Maxima year split.
Brand new, you're only looking at ~$80 for a condenser. Much better to buy new than used, especially with A/C components; if the compressor on this junkyard car died, there could very well be a load of metal debris inside its condenser, which you may or may not be able to flush out. Not to mention possible punctures from road debris, which may not even be visible until the system is charged.
Old Jul 26, 2011 | 02:00 PM
  #7469
box12360's Avatar
if you dont mind me asking but i asked auto zone and they were talking $150 for a condenser, but if i could get one for 80 i would do def do that.
Old Jul 26, 2011 | 02:04 PM
  #7470
pmohr's Avatar
No more Maximas...
Spectra 74758
Old Jul 26, 2011 | 02:38 PM
  #7471
Mnick1's Avatar
You can also try here for compatible parts then do price hunting.
http://www.autopartswarehouse.com/de...QQP40104P.html
Old Jul 26, 2011 | 07:53 PM
  #7472
LeeDATC's Avatar
how to change plugs
what do I need to take off to change the plugs in a 99 maxima with a 3000 24 valve engine
Old Jul 26, 2011 | 08:00 PM
  #7473
pmohr's Avatar
No more Maximas...
The coil cover, if you still have it, and the EVAP canister purge volume control solenoid valve.
And the coils.
Old Jul 27, 2011 | 07:19 AM
  #7474
cashoit's Avatar
NO NO NO.
I jus went through this problem with my AC.
Nissan manufactured 4 differnent AC setups. ther is a 95-96, a 96-97, and 97+, 98-99. If u want EVERYTHING to match up, u need to match up production years. Check on the driver door to see when u car was manufactured then get the condenser that fits in the corresponding production year.
Failure to do so may lead to also having to buy matchin ac lines as they are NOT the same port size or interchangeable between production years.
I spent a month sorting out my ac man. Its workin now tho..ice cold
Old Jul 27, 2011 | 11:26 AM
  #7475
Fauken's Avatar
Read in a post related to obx items and yeah you would have to custom fit the 02 sensor.
I will try to find the related thread and post it for you here
Old Jul 27, 2011 | 05:14 PM
  #7476
box12360's Avatar
ok guys i had my car aligned today and this is my question: look at the pictures below the aligment was pretty messed up, the guy told me that the passanger side axle was slinging oil. After he showed me the paper and i looked under the car i asked him if the reason the axle shifted about an quarter of an inch was from the alignment? he said no and i think he was trying to F*** me. i could see where the aligment had moved the axle that far because i could see steal and not greese covered steal. should i be worried about this ??
Old Jul 27, 2011 | 05:18 PM
  #7477
pmohr's Avatar
No more Maximas...
Can't even try to read those printouts, they're so bad.
No, the alignment will not change the in/out position of the axle within the trans. The passenger side axle is bolted to the intermediate bearing, that's what keeps it in place (as the circlip does on the driver's side).
If you're seeing the camber (only setting that could conceivably do so) affect the seating of the axle in the trans, you've got bigger issues than not understanding how the driveline is set up.
Old Jul 27, 2011 | 08:07 PM
  #7478
box12360's Avatar
Sorry man my camera really sucks, the chamber was actually ok on the read out, -.4 degrees. The toe was 1.72 degrees to the left off on the axle that was messed up. But anywho A. should i keep a close eye on this. i'm thinking yes. B. Could this cause that front wheel to lock up? C. I could not even guess how this could happen and is there a solution? new axle or maybe some bearings. when i was under it seemed like it could be pretty easily taken off other than packing some new bearings. the part of the axle that was different was the inner part, end that is connected to the transmission.
Old Jul 27, 2011 | 11:55 PM
  #7479
Fauken's Avatar
Can anyone inform me as to where the distributor cap is in 96 GXE. I want to clean my engine bay but need to cover that, so as to prevent it from damaging.
Old Jul 28, 2011 | 08:15 AM
  #7480
DennisMik's Avatar
There are no spark plug wires. There is no distributor cap. There is no distributor.
Plugged on to each of the spark plugs is a "coil pack". It is an ignition coil that creates a spark for the spark plug that it is installed on, therefore you have 6 coil packs. The ECU determines when a coil pack needs to create a spark and sends it a signal to do so.
