Whose got the highest mileage?? Any issues?
Old May 13, 2008 | 12:24 PM
  #161
nwell2k3's Avatar
I had 215,000 on my nitrous Max and I have 230,000 on my Turbo Max. I had to replace the injectors, coils, starter, alternator, fuel pump, thats all normal for high miles....
I have owned german, american, and a honda. All of the previous cars have had under 100,000 miles and I have had less issues with my Maximas. I also had a 3rd gen that was totaled... But Maxima's are solid cars...
Old May 13, 2008 | 03:21 PM
  #162
Ludacris's Avatar
1998 SE, 140,000 miles
2 o2 sensors
1 radiator
1 knock sensor
2 CV Boots
Old May 13, 2008 | 07:32 PM
  #163
nafddur's Avatar
Originally Posted by Bearkat
219K miles right now on my '96 SE! The car has had a new timing belt & tensioner, water pump, clutch, and alternator & starter changed.
Why would someone have changed the timing chain to a belt?
Old May 18, 2008 | 09:49 PM
  #164
Yankel.v's Avatar
Mine has 215K. I have changed the belts, 1 ignition coil and Thanks G-d that's about it.
Old Jul 2, 2008 | 06:59 PM
  #165
smallt11236's Avatar
186,000 miles on mines...its a monster but w/a slow pickup..lol
IT needs:
Main engine mount
2 o2 sensors
Knock sensor
4 springs
Old Jul 2, 2008 | 07:16 PM
  #166
s13silvia2761's Avatar
170k still strong only replaced waterpump, knock sensor, plugs original coils, alternator
Old Jul 2, 2008 | 10:56 PM
  #167
Jamaha80
96 auto w/147k miles. Owned for last 50k miles.
Service history since I've had it (other than tires/obvious routine stuff):
Brake pads/rotors/rear calipers
KS
Struts(4)
02 sensors (all)
ECTS
Axles
ATF flush/filter
Plugs
Current problems:
Inner/outter tie rods
Muffler
Speedo stops working often
Radio lights are flakey
E brake cable(s) frozen/stuck
Old Jul 4, 2008 | 05:24 AM
  #168
wgray's Avatar
202000 still strong as hell good on gas 1995 se
Old Jul 5, 2008 | 11:50 PM
  #169
The Don''s Avatar
I got a 97 with 136k and surprisingly I have had no major problems whatsoeveinr thus far... All original parts.
Old Jul 6, 2008 | 01:23 AM
  #170
pahaf's Avatar
well, i love my car (peice of ****) ;p
1995 SE 5 speed
bought on 01-07-08 with 98k
now its 07-06-08 with 106k
so far:
fuel filter,
valve cover gaskets 2 times
clutch
injectors.
starting problem (grounding issue i later found out)
1 coil
knock sensor
camshaft position sensor
radiator
rear speakers were blown up (littrealy)
head unit decided to break as well
and right now i want to change the gasket between the steering wheel and the drivers seat
Old Jul 6, 2008 | 07:54 PM
  #171
97PKIMVQ's Avatar
I have about 196,XXX got the car in 04 when it was at 104,XXX
Replaced:
2 cv boots
3 sets of brake pads.
2 sets of rotors f + R
both axles
on 2nd tranny
radiator
3 starters
2 clutch's
Things that needs to be done...
Spark Plugs, Brakes front and rear rotor + pads. Drivers side CV boot, clutch, flywheel, PAINT JOB, heater core, ac condensor 5spd dash trim, RADIO.
i need to get rid of her... anyone want it 2k cash as is?. lol
Old Jul 7, 2008 | 07:33 PM
  #172
nafddur's Avatar
Replaced:
2 cv boots
both axles
on 2nd tranny
radiator
3 starters
2 clutch's
3 clutches and 4 sets of brake pads in LESS than 100K miles?? That's insane!
Old Jul 7, 2008 | 07:58 PM
  #173
webjohn's Avatar
Originally Posted by ltpacct
97 SE, 225,000 miles and still running strong. Gas mileage is getting worse.
Rebuilt trans. at 185K miles
Starter
AC compressor
Alternator
All 4 struts
Both front axels
and the usual brake parts
seafoam it. it'll clean out the engine. should help your gas mileage
Old Jul 7, 2008 | 08:02 PM
  #174
webjohn's Avatar
Originally Posted by nwell2k3
I had to replace the injectors.....
how do you no when u have to replace the injectors? probably a dumb question but oh well!
97' gle, 160,xxx, had since 157,xxx
as of now: replaced front passenger axle(inner and outer boot ripped)
front passenger bearing
rear passenger brake hose
spark plugs
front driver caliper slides
still needs: KS
2 front rotars
front passenger caliper slides
front passenger abs sensor(result of bearing replacement)
egr solenoid valve (p1005)
might need a new rack, but not 100% sure.
theres a leak somewhere around the ps pump but im not losing ps fluid or motor oil. so im stumped there too.
like i recommended in the above post, seafoam.
oh and the horrible side swipe compliments of my dad
and a hood strut
my dad had it since 50,000 miles in 1999 and since then i know he replaced the alternator and the starter 2 or 3 times, im not sure, and he replaced the rack and pinion once
Old Jul 8, 2008 | 10:17 AM
  #175
phillyzj's Avatar
98 5spd, just turned 168k.
I bought it in 1/06 with 110k on it.
I've done:
KS
front brake pads
both axles
cat back
nothing major, drive it all the time
Old Jul 8, 2008 | 06:59 PM
  #176
97PKIMVQ's Avatar
lolz... yeah it is... I drive a bit hard... NO ABS kind of sucks... <-- scary when the brakes lock up. Nearly totalled my car twice because of it. KNOCK ON WOOD~!!!
Old Jul 11, 2008 | 01:48 PM
  #177
volodya84's Avatar
189k 5spd SE QNO
knock sensor, 02 sengor, pcv valve with connecting hose, fan assembly, radiator (all fixed)
maf, ball joints, struts, rear calipers - not fixed just yet
Old Jul 11, 2008 | 07:39 PM
  #178
BobXX's Avatar
'97 with 150k
- a/c compressor
- radio (x2)
- hood struts
- antenna mast
- starter
- alternator
- serpentine belt
Old Jul 11, 2008 | 09:12 PM
  #179
z00york145's Avatar
114k
-windshield washer fluid
Just picked up the car yesterday, the guy didn't explain to me what was replaced, i'm sure that in the next couple of months i'm gonna be replacing the brakes, calipers, c/a's and the struts probably.
oh yeah, and i think my starter is going to be replaced soon as well.
Old Jul 11, 2008 | 11:03 PM
  #180
xml2k's Avatar
I have 289,000 miles on a 1996 SE 5 speed. It burns oil so I never have to change it, just put more in. Sometimes I run the oil low. OK I run the oil low more often than I like to, but it can take it.
I replaced the Radiator, Clutch, and Oxygen Sensors. I need some struts for the hood, which is peeling, I think its the clearcoat. The rear window doesn't roll up or down so I have to wedge something in the sill to keep it up (I tried duck tape, but ended up streaking glue on the window, which is still there). The radio doesn't store stations anymore so every time after I start the engine I have to re-enter presets, and the antenna doesn't retract.
This car can take a licking and keep on ticking.
I really have fun with this car. I don't have to worry about shopping carts or thieves.
Truly, I appreciate that this car is unbelievably reliable, and the builders (Nissan) get my respect.
Old Jul 12, 2008 | 05:41 AM
  #181
Armelius's Avatar
It is a great car but you should fix that oil burning. Could be something very easy and inexpensive.
Old Jul 23, 2008 | 09:50 PM
  #182
I got 207K on mine. The belts were bad(changed), alternator was shot(changed), still need new brakes, tires, and thats about it. Engine still running strong for a stock.
Old Jul 23, 2008 | 10:12 PM
  #183
leefitz's Avatar
I had just over 160K on my '97 GXE before I sold it to a good friend (which I might be getting back!!!) I see it everyday and it still pulling strong. My friend sold his Altima to buy my '97 Max. I miss that car.
replaced front strut plates
new clutch
Old Jul 24, 2008 | 10:34 AM
  #184
THEJEFFERATOR's Avatar
just turned 200k yesterday !!
injectors
1 coil
2 rear calipers
maf
k/s
replacing motor mounts and a/c compressor asap...new paint soon !!
[URL=http://g.imageshack
Old Jul 24, 2008 | 11:25 AM
  #185
1998 Maxi's Avatar
216000 I love my 1998 Maxima I have replaced both O2 Sensors, of course breaks, calipers, cv joints. Oh and I also have a problem with the check engine light communicating with the engine to shut of the engine light which was caused by the O2 sensor. If anyone can help me there I would appreciate it.
Old Jul 24, 2008 | 12:00 PM
  #186
maxdall's Avatar
Not mine...but.
My mom's car is a 91 - has 283,XXX on it. Still is a very solid car. I just purchased an '08 - I have 754 miles on it - no problems.
My mom's car has had injectors replaced, a transmission at 200K. Other things I missing for sure. She still has the original exchaust.
Old Jul 24, 2008 | 12:34 PM
  #187
submaxzero's Avatar
168+ here n still moves like a beast catch me on youtube name is submaxzero
Old Dec 23, 2008 | 04:02 PM
  #188
wildsalmon
1997 GLE, purchased new, 130,000 miles
Radio went out at 100,000. Replaced it with Alpine with XM. Never has sounded as good as the original. Kept the speakers.
When should I replace shocks?
Rear seat leather that is exposed to window sun is getting dry. Need better treatment for the leather.
Worst mileage around town is 22 MPG
Best mileage on the highway is 32 MPG
I fill it with Premium gas
New transaxles at 120,000
I avoid Nissan dealerships for service
Also have a 2003 Suburban with 120,000 and 2004 CRV with 28,000
Old Dec 23, 2008 | 05:22 PM
  #189
maxfever1987's Avatar
Originally Posted by komik
96 5 Spd SE - 236,000 miles
I just bought it a week ago. It runs strong aside from a miss in cylinder 2 (waiting on coil pack). I think it needs a passenger side axle and some minor front end work. Otherwise it's great.
just curious.. how much did u get it for?
Old Dec 24, 2008 | 08:41 PM
  #190
gregmaxin's Avatar
96 gxe, 216k,engine still runs really strong, replaced both axles, just replaced the radiator, just bought new bearings, replaced ignition switch, new tires and basic tune ups
Old Dec 24, 2008 | 10:30 PM
  #191
ecpunx's Avatar
On my 93 SE (being retired this weekend as a matter of fact) 283,000 miles. Bought it in 99 with 114k.
Left Axle
Fuel pump...three times
Alternator rebuilt
Starter
Power steering rack
Slave Cylinder (twice)
Dry rotted fuel line
Clutch (pretty sure it was OEM, done at 230k)
Its got valve seal smoke and lifter noise right now.
Love the car, going to be hard to part with it. Its had its share of nickle and dime problems, but still, it never let me down when it counted.
Old Dec 27, 2008 | 02:37 PM
  #192
Drdla's Avatar
390,000KM = 242,000 Miles
No huge issues, I still get 8l/100km on the highway = 35MPG!
Old May 10, 2009 | 10:13 PM
  #193
rnaymik's Avatar
1999 GLE 107,000 miles.
all ignition coils (was tired of one going out...then another)
starter
egr
and body work on the front and rear...got hit a stop light.
Old May 11, 2009 | 03:42 PM
  #194
JEXTEL's Avatar
223,XXX
-2 trannies
-6 alternators(leaky vavle cover)
-vavle cover gaskets
-radatior
-muffler
-wheel bearing
-axel
-struts
-knock sensor
-2 coils
Old May 11, 2009 | 11:16 PM
  #195
mantis40's Avatar
My 1998 I30T had a ton of ****, 145k, but it runs amazing now...
1. CV Joints (they were clicking when I made turns, got a lifetime warrenty on them)
2. Radiator (it cracked so I replaced it with a high performance 100% aluminum radiator)
3. Thermostat (it was somewhat clogged, but it was the original, so I replaced it when I put in the new radiator)
4. Starter (it usually took 2 or 3 trys to get the damn thing to start, and it made a horrible noise when I start it in the morning)
5. Alternater (it plain old died, replaced it with a little more powerful one)
6. A/C Compressor (it died and made my belt squeek, I didnt even replace it, I took the whole A/C system out and put a smaller belt on the pulleys, very happy without A/C!)
7. Brake Pads & Rotors (brakes started grinding against the rotors, evenutally one brake pad actually fell off in pieces)
8. Lower Radiator Support Beam (very very very rusty and falling apart, the only thing I didnt replace yet)
9. Re-painted the Hood (it was keyed badly)
Old May 13, 2009 | 12:56 AM
  #196
tosheto's Avatar
98 max with 250k. blew up radiator, KS, the rest is just maintenance.
Old Jul 26, 2009 | 09:34 PM
  #197
rwalltwo's Avatar
98' GLE
98 GLE
265k+
Major Issues:
CAT or EGR smog problem
Old Jul 26, 2009 | 09:40 PM
  #198
Romulus811's Avatar
My dad's 95 Maxima Automatic has got over 500,000 miles, just a belt tensioner and a starter
Old Jul 26, 2009 | 09:42 PM
  #199
Romulus811's Avatar
i just bought a 98 Maxima SE 5 Speed with 229,XXX miles, neither of the cooling fan motors are working
Old Jul 26, 2009 | 10:18 PM
  #200
f550maranello2's Avatar
500,000? maybe 50,000?
pics?
