5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Jan 6, 2008 | 09:51 AM
  #4521
petersenj20's Avatar
'02 shuts off around 5 minutes
Shut-off is instant, no sputter. It does it at almost the same time every cold start-up. If I am stopped when it shuts off, it will start right back up. If I am accelerating at the time of shut-off it is hard to start and will take 3-5 minutes of intermittent cranking.. I attribute this to fuel being dumped into the engine and temporarily flooding it.
Once it starts back up it will run all day without problems.
I tested the codes at Advance (don't remember the actual number) but it was the Cam Position Sensor. Having lots of practice using these codes that is a crap shoot. Could be another cause looking like a cam sensor, maybe not. There are two sensors and at $90+ I don't want to get too carried away replacing them to find out it is something else all together.
The fact that the hard re-start seems to come from too much fuel and shut-off is instantaneous, It sounds like an electrical part shutting off spark.
Since it always happens at the same time I thought it would be a good idea to see if anyone else has ever had the problem. I haven't been able to look at the plugs yet (always the first look of a drive-ability problem) and hope to do that today. Not sure what to expect from inspection though since it doesn't seem to be a problem of old or fouled plugs.
I looked at all the FAQ's, even found out how to point to the original FAQ's. Search sucks, as my topic seemed hard to put into a search. I read a bunch of posts in my search and turned up nothing.
I posted in the 5th Gen Noob post because of the 15 post limit and didn't want to anger anyone by posting 15 replies to up my count.
I'm not really a message board newbie or mechanics newbie, and I hope to make friends here. I will contribute what I can and try to stay out of the way.
Old Jan 6, 2008 | 10:10 AM
  #4522
AWESOME! You get to remove the upper intake plenum to check the rear spark plugs. I was hoping to get to do that.
Old Jan 6, 2008 | 10:56 AM
  #4523
alicious's Avatar
the org...not what it was
Originally Posted by 020189
A simple question that ive been wanting to get answered.
What mods are needed to to make a 5th gen look like a 5.5 gen Maxima?
I know it requires more than just the headlights.
Originally Posted by spdfreak
IIRC xlcrew switched his cars look to the 5.5 (A33B) look. You may want to PM him. I would guess that you would need headlights, front bumper, rear tail lights, and I think thats it. You may need some bumper brackets, but I'm unsure.
yeah he spent a grip doing it too
That pretty much sums up what you'd have to do though, spdfreak is dead on.
Old Jan 6, 2008 | 11:43 AM
  #4524
tibal's Avatar
Can anyone please help me with my interior lighting/ lead me in the right direction, as posted before. I appreciate it greatly.
Old Jan 6, 2008 | 01:29 PM
  #4525
tech123's Avatar
00 max 02 heater code p0155
I just bought a 2000 maxima
First thing I found was that the previous owner had removed the ses light so I replaced it and read the codes and came up with p0141 and p0155. I started by replacing the front two o2's when I put on my y-pipe this weekend. Cleared the codes and p0155 was still coming up (p0141 was as well but that senors heater resistance is to high after checking it)
Checked on the TSB's and read the wire brake problem on the wiring harness by the strut tower. So I went in this morning to try to source out the problem. Went to all data and started to follow step by step there instructions on how to check the sensor before looking for the wire break problem. Sensor resistance checks out ok. It have voltage where it should and there is continuity between pin 2 of the ecu and pin 3 of the o2. So I than switched the two new o2's to just double check that it wasn't an bad new o2. Still got the code with the back o2 in the front.
Now I start removing the harness by the strut tower. pulled the covering off from where it splits out to the back o2 and other sensors to down by where it goes through the fire wall. Found no broken or stripped wires after looking for about an hour. Re covered all the wires and sealed it back up and re checked everything with the scanner. Still getting the p0155. So I cleanned everything up came home and wrote this post.
Any one have any suggestions on what maybe going on or if they think the break could possibly be in another section of the harness that someone else may have found before? All fuses are good in the interior and engine fuse pannles. Didn't have time today but I am thinking or running a new wire from pin 2 to pin 3 and seeing if my problem goes away. Any help is greatly appreciated.
Thanks Tech123
Old Jan 6, 2008 | 02:00 PM
  #4526
spdfreak's Avatar
Originally Posted by soonerfan
you also need a 3.5 engine
Just the engine cover.
Old Jan 6, 2008 | 02:20 PM
  #4527
Frigo's Avatar
I am new to this site and I have a question about where the bank 2 sensor 2 oxygen sensor is locatedon my 2002 GLE. My oxygen sensor went out and I'm planning on doing it myself in order to save money. I think it’s after the catalytic converter but is it on the passenger side. It would be cool if someone had a diagram or a picture. thanks
Old Jan 6, 2008 | 05:27 PM
  #4528
SoonerFan's Avatar
Cletus
dont mind the red...that was something else
Old Jan 6, 2008 | 06:25 PM
  #4529
MazerMadness's Avatar
Kindof an oddball question but does anyone know of a reputable shop in the western new york/greater buffalo area that does Quaife installs?
Old Jan 6, 2008 | 06:34 PM
  #4530
SoonerFan's Avatar
Cletus
try the regional forum for new york
Old Jan 7, 2008 | 03:22 AM
  #4531
tech123's Avatar
Can someone make my post above into a thread in this forum. I don't think enough people will see it here to get an answer for it.
Thanks tech123
Old Jan 7, 2008 | 07:01 AM
  #4532
spdfreak's Avatar
Thanks tech123
I will notify the moderator for you. Lets see if there can be an exception to the rule of, 15 posts before you may open a thread.
Old Jan 7, 2008 | 08:12 AM
  #4533
alicious's Avatar
Originally Posted by tibal
This is my first post, which i feel is good, i have found everything i need elseware, but i have a question that i just cant find to get answered!
Alright i simply want to change the interior lights of my 2000 Max, I just got a new Alpine Deck and installed everything myself, which is awesome!!, but i just want to change the other lights to make everything flow better, and well.. I'm on college break and want something to pass the time with my newly bought car!
(Climate Control (which is the electronic), Clock, windows/ locks on all doors, etc.
I just really want to know:
A. How many LED's i should order, specific recommendations on size, power etc.
B. What color do you recommend for the interior? I was thinking blue (My deck is the new iDA-X001 and is super bright blue, or red) (recommend it to everyone!)
C. Any helpful things that i should know
Thanks All
There's a thread in the 5th gen classifieds, you should check that out. There's a group deal going on that has exactly what you are looking for. Do NOT do "blue". White/hyper white (looks blueish anyway). Also Autolumination has great bulbs there as well, highly recommend them.
Dome
DE3175
Step/Courtesy light
161
Old Jan 7, 2008 | 08:17 AM
  #4534
tibal's Avatar
Awesome,
Yeah, i just want something other than the green to make everything flow a bit better. I will definitly check that out and also the group deal.
Anyone know the type of LED's used in the climate control, clock, and windows?!
I appreciate it!
Old Jan 7, 2008 | 12:01 PM
  #4535
MikeyC1027's Avatar
Just got my Berk Intake in the mail today, (2002 max) and am anxious to get it installed. Unfortunately, my Dad, who would normally be the one doing the installation, is still in China on a business trip. Dont want to pay to get it installed, and dont want to wait either. Between me and my brother, we shouldnt have a problem, but at the same time, i don't want to mess anything up.
The instructions that came with the intake seem to be suited for people who know cars, so was wondering if anyone could provide me with some help with the installation. (pictures of where everythings located, tools i should use for each step, etc.) Thanks in advance.
Old Jan 7, 2008 | 05:22 PM
  #4536
tav303's Avatar
I have a silver 01 maxima se, anyone have any opinion's on what a good color is for the calipers?
I was thinking red or blue, but not sure if that is too ricey? thanks.
Old Jan 7, 2008 | 05:28 PM
  #4537
SoonerFan's Avatar
Cletus
its very easy and will make sense once you start taking the stock box off.
start doing it then ask here if you have questions.
Old Jan 7, 2008 | 05:29 PM
  #4538
SoonerFan's Avatar
Cletus
its your car...do what you want.
opinion? black or silver. yes red or blue would look ricey.
Old Jan 7, 2008 | 05:37 PM
  #4539
JCD89's Avatar
New to the Max Game
Does anyone have a copy of the 5th gen front suspension layout from a repair manual that they can post? Thanks.
Old Jan 7, 2008 | 05:40 PM
  #4540
SoonerFan's Avatar
Cletus
is this enough? or you need all the stuff between the wheels too?
Credit: housecor
Old Jan 7, 2008 | 07:57 PM
  #4541
Scottwax's Avatar
That's Mr. Detail to you
Silver car? Black.
Old Jan 7, 2008 | 08:17 PM
  #4542
Psyfa's Avatar
Originally Posted by alicious
Had the same issue, your ECU is probably cooked. Nissan usually are the only ones that can re-program you a new one, I was lucky enough to find someone local that could re-program mine after replacing the IACV.
To be sure that it's not the MAF, try starting the car with it hooked up, or better yet start it and then unplug it to see if it effects your idling.
are there instructions on the proper procedures for doing this in the stickies somewhere?
Old Jan 7, 2008 | 09:33 PM
  #4543
DasYears
does anybody have the link to the free sts mod handy? cant find it through searching anymore...
Old Jan 8, 2008 | 05:54 AM
  #4544
alicious's Avatar
See - http://forums.maxima.org/showthread.php?t=375256
Old Jan 8, 2008 | 06:54 AM
  #4545
Scottwax's Avatar
I put "sts mod" in search and came up with a bunch of threads.
http://forums.maxima.org/showthread....hlight=sts+mod
Old Jan 8, 2008 | 07:10 AM
  #4546
rkreddy's Avatar
I have been having trouble with my ac belt squeaking after i got them replaced about a week ago. I went back to the mechanic and he sprayed some lubricant on the part of area that makes the sound when i start the ac. But this was only a temporary fix after about half a day the squeaking started again. I know its not the belts that are squeaking, its the thing that starts turning when you turn on the ac. I think that i can fix it by using some kind of lubricant but i want to know what kid is good that will not wash off or wear off after a few days like WD40. I was thinking of some kind of grease but i don't know what kind. Any other info is also helpful. TIA
Old Jan 8, 2008 | 07:35 AM
  #4547
phatboislim's Avatar
sounds like your belt needs to be tightened
Old Jan 8, 2008 | 08:08 AM
  #4548
You sure he didn't just hit the belt with belt dressing? Lube on a friction plate like in the A/C clutch is a bad thing. Like phatboislim said, tighten the belt. Belts will often stretch a bit after initial install and is normal to need re-torquing. If the factory doesn't spray the belts then why should a shadetree mechanic?
Old Jan 8, 2008 | 08:33 AM
  #4549
maxximaa's Avatar
does any body have a pic of Cosmo Racing intake for 02-03?
send to me at dao82@shaw.ca or post it here, thanks very much.
Old Jan 8, 2008 | 08:41 AM
  #4550
yea...i mean basically..if you want it to stop squealing right then..why waste money on a belt dressing...spray water on it
Old Jan 8, 2008 | 08:44 AM
  #4551
segundo3000gt's Avatar
my maintenance skills are pretty minimal and i'm wondering if anyone can suggest when spark plugs and wires should be replaced. my car is just over 90k miles and i've noticed recently that i might be 1-2 mpg lower than what i'm used to. local shops are saying because it's so time consuming to replace the spark plugs on the '02 maximas that labor added to parts will approach $500. i'd rather not spend this unless it's necessary.
otherwise, anyone know of someone in the minneapolis area that is able to do this on the side for cheaper?
Old Jan 8, 2008 | 08:50 AM
  #4552
it's about time for you to change them out. when you change them out get NGKs
Old Jan 8, 2008 | 08:57 AM
  #4553
An '02 doesn't have wires (DIS) but the plugs are supposed to last 100,000k. Is a mile or 2 mpg wort $500? Thats up to you. I think this site has a regional location that you may find people that will work on it. The upper intake plenum has to come off to get at the rear and is very time consuming. There is a pictorial how-to I read in the sticky's that would help you a long way. If your maint skills are pretty minimal, I wouldn't touch it alone. Too much to go wrong with such a complex job. I would be glad to do it for you but alas...GA is a long way away.. I'll see if I can find the thread for you. Search sucks being a newbie.
Old Jan 8, 2008 | 09:07 AM
  #4554
Here are the links to the 5th Generation and 5.5th generation. 5th- http://forums.maxima.org/showthread.php?t=338587 5.5th- http://www.greghome.com/Greg%27s%20G...eplacement.htm
Old Jan 8, 2008 | 10:43 AM
  #4555
spdfreak's Avatar
This thread is NOT a substitution to searching!
Old Jan 8, 2008 | 10:50 AM
  #4556
thanks for the help guys. the first forum you posted, petersenj20, makes it look like i will get a check engine soon light when my coils go bad so i may just have them replace the spark plugs.
Old Jan 8, 2008 | 11:08 AM
  #4557
JennyBunny's Avatar
Smashed Screen
Hey guys, I've got a little problem. I've got a '03 SE with a 6-CD changer that was having the speaker cutout issue.<dumbass> I got mad and hit the screen </dumbass> . Would an electronics store be able to replace the screen or am I screwed and need a new unit. Thanks for any help.
Old Jan 8, 2008 | 11:45 AM
  #4558
better find a used deck lol
Old Jan 8, 2008 | 12:12 PM
  #4559
NmexMAX's Avatar
dot dot dot ...
Originally Posted by sirus444
I heard a lot of people are saying that 2000-2003 Maxima's have "Black Box" in them.
"Black Box" - prevents from going maximum speed. Limits the speed of the car.
IS THIS CORRECT OR THE PEOPLE ARE AS*** FOR SPEADING THIS RUMMOR?
I'm asking this, because a lot of people tell me that I can't reach 140MPH, after I posted 100MPH+ run on www.youtube.com. Gone 135MPH about 3 years ago and nobody believes me.
http://www.youtube.com/watch?v=bEYQ7fj-B6Q
Ok, so a 'black box' does not do this, it is programmed into the ECU itself. From what I hear, a black box records information that is vital when a crash is sustained, and is tough enough, typically to withstand a crash.(Simialr to what an aircraft carries) Yes, 2002-2003 Maximas do have speed limiters. 6MT is ~ 149MPH, where the 4AT is said to be about 130MPH. Both of these have been proven on a dyno, and not some less than competent non autobahn highwaydriver.
I used to give her love taps for years, and it would temporarily fix the problem. But, now, it is completely black and only works via the steering wheel control buttons.
Try this place for some more knowledge on the subject (new deck):
http://forums.maxima.org/forumdispla...aysprune=&f=21
There is a TSB or something similar on it, but from what I've seen, it is only a temporary fix (dealer fixed the problem, only to have it return). And in your case, they might charge you since there is physical damage.
Old Jan 8, 2008 | 12:42 PM
  #4560
Im looking to get a quaife atb for my 02 max. I notice that quaife offers one differential for the max but does not specify which gen it fits, are all gens the same? Also, there are no shops in my area that I trust to install something like this, has anyone had luck having a dealer install a quaife? I know thats a pricey proposal. Is the quaife worth it? Is it possible to get the OEM LSD (helical?) installed by the dealer on an 02 max?
Thanks alot.
