5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Jan 10, 2008 | 10:03 AM
  #4601
Orgullo's Avatar
$$ Ballin on a Budget $$
Originally Posted by wyche89
thats exactly who i went through... i sent the D2S bulbs back tonight in exchange for some D2R bulbs... he told me that they would fit, and may even be better than my stock ones, but they're just not.. i noticed the absence of a glare shield on the bottom of the D2S bulb, and that little bubble is in a different place.. oh well.. hopefully my output will improve
Of all people who should know it should be him. Yeah... you definitely need the D2R bulbs unless you are going to run projectors of some sort. None the less problem seems to be solved. GL
Old Jan 10, 2008 | 11:08 AM
  #4602
maxximaa's Avatar
Originally Posted by Scottwax
Osram Silverstars (the European spec) are even brighter. Longer and wider beam pattern.
it's called ULTRA in Canada, not sure about the states
Old Jan 10, 2008 | 04:12 PM
  #4603
MikeyC1027's Avatar
Just curious: Whats the best way to launch an 02 with an automatic transmission? Read something about a technique called "power braking" which supposedly applies to all cars with auto trannies, and was wondering if thats the ideal way to do it? (if so whats the best rpm to do it at?) Or do you guys just floor it while trying to limit wheelspin as much as possible. Sorry for such a noobie question, but this is my first car and thought itd be a better idea to ask it here than to ask someone like my dad...
Old Jan 10, 2008 | 04:24 PM
  #4604
Scottwax's Avatar
That's Mr. Detail to you
Powerbrake and your tires will go up in smoke out of the hole. Better to just flash the converter (no powerbraking) at about half throttle and keep the tires on the verge of wheelspin as you push towards full throttle. I usually don't have my foot buried until about 25 mph or so due to wheelspin.
Old Jan 10, 2008 | 04:30 PM
  #4605
MikeyC1027's Avatar
Appreciate the input.
Old Jan 10, 2008 | 07:06 PM
  #4606
reeloop's Avatar
My car seems to have lost its ooomph lately, I remember how It used to have alot of torque steer, and I realized there is now barely any, and sometimes none. I am almost at 60,000,
should i take my car to a shop, what do you look for in a situation like this anyway ? maf, spark plugs ? could be anything really right ?
Just looking to narrow it down to the problem, where should i start ?
Old Jan 10, 2008 | 09:20 PM
  #4607
Scottwax's Avatar
No codes, I take it-otherwise you would have mentioned them, right?
Start with the basics. You need air, spark and fuel for the engine to run. Change the air filter and plugs and you might need to (although Nissan says you normally don't) change the fuel filter.
Old Jan 10, 2008 | 09:47 PM
  #4608
maxximaa's Avatar
does anybody know if the 04+ berk intake would fit my 02?
thanks
Old Jan 11, 2008 | 12:44 AM
  #4609
CreativeSkillz's Avatar
I can't figure out why I can't post in some sections.
Old Jan 11, 2008 | 01:48 AM
  #4610
NmexMAX's Avatar
dot dot dot ...
's are doubting pertinent information..........Let them. ... They will back.
Old Jan 11, 2008 | 01:59 AM
  #4611
NmexMAX's Avatar
dot dot dot ...
Apparently you have not read the stickys, not or the first rule re: this thread. But THE RULES.........
Old Jan 11, 2008 | 02:48 AM
  #4612
SoonerFan's Avatar
Cletus
i cant figure out why you didnt read the required rules when you signed up.
Old Jan 11, 2008 | 10:28 AM
  #4613
highlyaspir8ed's Avatar
don't really think this is a noob question... but...
I did I search to bring back jack **** on this topic so I decided to post it here.
do any of you have any recommendations for a good after market clutch? I have a 5th gen 5 speed that seems to be hiccuping when I shift it into gears from time to time.
Old Jan 11, 2008 | 11:10 AM
  #4614
Puppetmaster's Avatar
Okay guys, please quit with the BS and the OT posts, especially those that are outside our forum rules for discussion. You know who you are. I've cleaned this up and hope we can stay respectful here. PM me if you have any questions, thanks.
Old Jan 11, 2008 | 04:07 PM
  #4615
Tee00Max's Avatar
yea i wanted to know if i could peal off the black piller between the driver and passenger side door because its fading really badly....i tried painting it and it didnt go to well.....
Old Jan 11, 2008 | 04:10 PM
  #4616
SoonerFan's Avatar
Cletus
yes it peals off...factory paint underneath
Old Jan 11, 2008 | 04:12 PM
  #4617
Tee00Max's Avatar
thanks man
Old Jan 11, 2008 | 04:19 PM
  #4618
Tee00Max's Avatar
do you know an easy way to peel it off cuz i jus went outside and tried and it seem like it was up there very well....is there a thread for this???? anything i could spray on to make it easier
Old Jan 11, 2008 | 04:22 PM
  #4619
nebojsa_o's Avatar
I have a '02 with the Canadian gage cluster, kms instead of miles. The trip computer shows average speed, and all that stuff in kms. Is there a way to change that to MPG and MPH? Same for the auto climate system, it's in Celsius, can it be switched to Fahrenheit? Wondering if this can be changed, or is it built in part of the cluster that's not changable with the push of a button... Thanks
Old Jan 11, 2008 | 04:26 PM
  #4620
SoonerFan's Avatar
Cletus
where the covering meets the rubber....use a razor to cut along that line.
then start peeling it from the other side where it wraps around
Old Jan 11, 2008 | 04:28 PM
  #4621
SoonerFan's Avatar
Cletus
i remember in the FSM that there is a way to do it.
for the climate control, you have to enter the diagnostic mode on it and you can change it.
the guage info is controlled in the ECU and can also be changed....need the OBD i think
  #4622
Tee00Max's Avatar
i gotcha......thanks
Old Jan 11, 2008 | 07:09 PM
  #4623
nebojsa_o's Avatar
What do you mean by "need the OBD i think"??? I have a OBD II scanner, but as far as I know it's only for checking what the engine codes are, so I'm guessing this OBD stands for something else?
EDIT: Thanks for the answers in the previous post, I'm looking though the FSM right now. Soooooo much info!
Old Jan 11, 2008 | 07:24 PM
  #4624
NmexMAX's Avatar
dot dot dot ...
He means Consult II, dealer only item, they are probably the only people that can do it, if it can be done.
Old Jan 11, 2008 | 07:36 PM
  #4625
SoonerFan's Avatar
Cletus
that is what i meant...sorry
Old Jan 11, 2008 | 09:43 PM
  #4626
nebojsa_o's Avatar
Ahh, alright. Thanks for helping out anyways. I doubt I'll go that far to convert it. I was thinking maybe there is a combination of buttons to push in order to change it.
Old Jan 11, 2008 | 11:06 PM
  #4627
Well I can't seem to figure out where these rules are, I signed up forever ago.
And the cheap google search doesn't work worth a damn, and I don't have the privileges to use the vBulletin search.
Old Jan 11, 2008 | 11:40 PM
  #4628
MaxBoost925's Avatar
Drug Money
then stop whining and donate.
Old Jan 12, 2008 | 01:02 AM
  #4629
I don't have to anymore. It's open to everyone.
Found all the information I needed, thanks for leading by example. Senior members should really set a better example for new people, but who am I to voice my opinion here?
  #4630
SoonerFan's Avatar
Cletus
please keep up.
we no longer encourage donating on here...they get their money from ads.
they have opened searching and OT to everyone.
let this place now implode...but it wont matter. money will have been made
thanks for the memories maxima.org
Old Jan 12, 2008 | 01:04 AM
  #4631
Drug Money
please keep up.
Oh the humanity!~~
Old Jan 12, 2008 | 12:29 PM
  #4632
chaoticchao's Avatar
ok so here's the problem with my car. when i come to a complete stop, sometimes the gas pedal will get stuck (not really stuck, but you'll have to press on it kinda hard so it'll go) and i was wondering what was wrong with it. i heard from a friend that you'd have to buy some sort of fluid and put it in but the only fluids i can think of are the transmission and steering fluids... which doesn't make sense at all. any body knows what's wrong with my car??
Old Jan 12, 2008 | 04:57 PM
  #4633
parapeligicdrumr's Avatar
hi guys, do you know where i can find the part missing in this picture?
if i do buy one that is a different color, where can i match the gold on the car?
ive had a look at rear side markers and im wondering if the smoked markers look better than the clear ones? the car is gold-ish
Old Jan 12, 2008 | 05:04 PM
  #4634
Scottwax's Avatar
Oh the humanity!~~
Old Jan 13, 2008 | 08:45 AM
  #4635
gunzs's Avatar
how to .... removal of 2000 max,ac compessor clutch, compessor good but the clutch is bad should i buy new compesser or just replace the clutch?
Old Jan 13, 2008 | 07:31 PM
  #4636
Scottwax's Avatar
Since odds are the compressor is 7 years old, I'd replace that too. No sense replacing just the clutch on a compressor that old, IMO.
Old Jan 14, 2008 | 05:44 AM
  #4637
phatboislim's Avatar
is it awkward that my SES light went off by itself a week after my catalytic converter unclogged itself. i bought this car almost a month ago, with it being extremely sluggish to it now feeling like its in top shape performance, and as of yesterday, my SES light took the liberty of being off.
anyone have this 'privilege'?
and no i have not changed anything, not even the spark plugs in this car yet.
Old Jan 14, 2008 | 09:19 AM
  #4638
SuperStasiu's Avatar
U can order it from the dealer it comes painted and everything you just give them ur paint code when you order it i think it runs around 100 bucks
Old Jan 14, 2008 | 09:21 AM
  #4639
026SpdSE's Avatar
Service Engine Soon Light
I've done some looking around and the info that used to be in the "Got check engine light...what should I do?" thread is no longer there, so can somebody help me out?
I have a 2002 6 speed SE and start it up today and notice my service engine soon light is on. I had the 0011 and 0021 codes pop-up about 9 months ago but cleared them and they haven't come back since. Can someone provide me with the procedure to check the codes once again as well as the procedure to clear the codes? Also, a listing of the codes if you have it.
Thanks!
Old Jan 14, 2008 | 09:24 AM
  #4640
first off what year is your car? since the 5th gens 2000-2001 are throttle by cable and the 5.5gens 2002-2003 are throttle by wire. You might wanna clean out your throttle body that might help and thats what is probably wrong with it
