5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Apr 3, 2013 | 04:35 PM
  #16121
DennisMik's Avatar
Originally Posted by Jolie_Emerald2013
Hi I have a 2000 Maxima GLE , of coarse it used so i bought a key fob fot it on ebay (oval shaped one) and did the programing the hazards flash after insterting the key but when the buttons are pressed on the key fob nothing happens. Also i noticed that if you press the lock button twice on the drivers door the car starts itself runs. I DESPERATLY need some help guys.
The FCC ID # for the 2000 Nissan Maxima key fob is: NHVWBU43. Is this the FCC ID on the key fob you bought?
The door lock starting the car sounds like there is an after-market alarm/starter system installed. Check into this as after marked alarms disable the factory alarm. Find out the brand and model and get the keyfob for that.
Old Apr 3, 2013 | 07:46 PM
  #16122
Jolie_Emerald2013's Avatar
no My Fcc id is different KBRASTU10
Old Apr 3, 2013 | 09:06 PM
  #16123
DennisMik's Avatar
That is the FCC ID for the 2001 Maxima. It is also used by the 2000 and 2001 Infiniti.
Old Apr 4, 2013 | 07:06 AM
  #16124
Amerikaner83's Avatar
in other words that's why it's not working.
Get one with the proper FCC ID and you'll be
OR answer this:
Old Apr 4, 2013 | 08:32 AM
  #16125
Omar522's Avatar
New Member with Maxima Issues
Hello All,
I've been wanting to join this forum for some time now, and I've finally done so! I purchased my 2001 GLE at auction on May 2011. I've been using it for all of my transportation since. The car, although has some good points, has a slew of problems, but I guess that's the risk when you buy at auctions. I bought it with almost 168,000 miles and I'm just touching the 200,000 mark. When I first drove it, after all the paperwork was done, the check engine light goes on. It's been on ever since. I changed an O2 sensor, the gas cap, but that didn't repair the problem. Shortly after purchase, upon putting the car on the lift, the majority of the bottom was rusted out, literally.
The floor of the car is left to rotting metal. So much so that you can touch the driver and passenger side carpets just by placing your hand underneath the car. They flap with the windows down. I changed the front struts at the end of last year since they were completely shot. As of the beginning of winter, the serpentine belt squeals loudly on every cold start , up to a minute or more sometimes. I've noticed it's considerably loud in the cabin, and it seems there's some sort of exhaust leak toward the front of the car. I've also changed the control arms about 3 times on this car, once from an accident that was my fault, and the other two were wear and tear (a completely worn bushing, that was new on the car the previous year when I needed to change both of them) I was surprised that this particular control arm lasted less than a year. I heard that this problem is common for Nissan's. I don't know if it's me, but I've also noticed that the car uses a lot of fuel. I think it should get much better fuel mileage due to the way I drive. It may not be burning properly.
Most importantly, this car has worrisome transmission problems. It's an automatic, so sometimes it doesn't' go from second to third, or from third to fourth. This is particularly common on hot days, or when the weather gets warmer in general (i.e. begging of spring or summer on an above average temperature day). It also doesn't shift if really abused, meaning driving in a bad mood and flooring it from every stop I was told that the transmission fluid should be changed, but that would either repair the problem, or destroy the transmission completely. In order to get it into the next gear, it's sometimes necessary to force it, (floor it) so it revs high, forcefully selecting the next gear. I've noticed it also takes a while to shift normally.
I know this is a long message, and I apologize for that, but I'm desperate at this point. I hope this car continues to hold out. I was told buy a mechanin that the rust was probably due to the car sitting for a long time, unused, and it was a Massachusetts car, which was affected by snow and salt. If I was able to just get a better look at the car, I wouldn't have thought twice about leaving it, but being at auction, you don't really have that choice. I was also desperate for a car back then. I used to drive an Acura Legend before. Sometimes, I miss having it. This car, being the GLE model, should be more comfortable and soft than the SE. The car's ride is sometimes unbearable too, as the suspension feels to hard and unforgiving. You feel every bump in the road. Even after replacing the front struts, it's still too hard. The car looks in good condition from looking at the body, but you'd never guess what is wrong with it. The main problems are suspension, transmission and fuel mileage, check engine light, and whatever else I mentioned. I want to thank any and all in advance who respond the this message. I appreciate any help, or advise that you give. Thank you!
-Omar522
Old Apr 4, 2013 | 09:19 AM
  #16126
DennisMik's Avatar
Originally Posted by Omar522
Hello All,
(text clipped)
-Omar522
Hello Omar. Sorry to hear about your car problems. I can't give any specific "fix this" answers because you haven't provided enough information. But with multiple problems, you need to focus on one at a time and analyse it thoroughly.
Your check engine light is on - what are the codes? Solving this might improve your gas mileage complaint, but you have not told us what the gas mileage is. And have you ever changed the spark plugs?
Changing the control arms so frequently is not a good thing as you know. It is not normal to have to replace these frequently as some much less than informed person has told you. How do the tires wear? Is the wear abnormal? Could the car have been in a bad accident and have frame damage? If the right side needs replacement more frequently, that could be from the power steering leaking and rotting the bushings. Also we have learned the hard way that the cheap, made in China E-bay parts don't last long.
You say the car's ride is harsh. That is suspension problems and it may somehow be related with the control arm problem. You probably need to take the car to a collision frame shop and have them check it out. They have equipment that other places don't have.
The transmission - I am far from an automatic transmission expert. When you say that Nissan does not have a good something, the automatic transmission definitely falls into that category. If you are a pedal to the metal driver, you will be familiar with transmission replacement. Don't ask why I say this. But the check engine lights could have codes for the auto transmission. Or you could run the self diagnostic on the auto trans and see what that tells you. Or maybe the shift solenoid pack in the transmission needs to be replaced.
So focus on one thing, do some diagnostics and let us know.
Old Apr 4, 2013 | 04:39 PM
  #16127
Barbequber's Avatar
2002 SE 6MT Flashing CEL
Was driving to school today when I noticed quite a rough idle; enough to noticeably vibrate my seat. A couple minutes later I got a CEL that would flash a few times and disappear for a couple minutes just to return and flash again. About 6 hours later while driving back home I got a solid CEL until I came to a stop and idled, when it would start flashing. As soon as I drove again it would turn solid. Picked up an OBD2 reader and pulled 4 codes: 2 counts of P0300(Random Misfire) and 2 counts of P0021(Intake Camshaft Position Timing - Over-Advanced(Bank 2)). I'm only 17yo and this is the first time I've had a problem with the car so I'm very new to this. Can anyone suggest a fix? Is this something I could do with some guidance or best left to a mechanic? Thanks.
Old Apr 4, 2013 | 06:04 PM
  #16128
Camshaft position sensors need to be replaced. Start saving up and purchase one front and one rear ignition coil.... You will eventually get the code that tells you which specific cylinder is misfiring. OEM coils ONLY...unless you always want a p1320 code
Old Apr 4, 2013 | 07:27 PM
  #16129
Barbequber's Avatar
Would I be correct in guessing that the factory recall here would cover the costs of a camshaft position sensor replacement if I went to Nissan? Also, where might I find OEM coil packs, online or otherwise? Thanks a lot.
Old Apr 5, 2013 | 04:05 AM
  #16130
jeepdude87yj's Avatar
check eng light
On my 2000 maxima my engine light has been on for a while for a bank 2 cat, (think i need the front cat?) but now its come on for a cyl 1 misfire. changed the cyl 1 coil pack and came back on right after. It somewhat hesitates and runs rough only when started from dead cold. runs fine when its warmed up. any suggestions?? thx
Old Apr 5, 2013 | 04:11 AM
  #16131
jesseroscoe's Avatar
did you replace the coil with and OEM coil or aftermarket? also, did you examine the plug in cyl 1 when you replaced the coil?
Old Apr 5, 2013 | 04:20 AM
  #16132
replaced it with nissan and the plugs are ok
Old Apr 5, 2013 | 05:15 AM
  #16133
might as well verify whether the replacement coil is good by swapping it with another cylinder's coil. iirc, the vq30 coils are different between the two banks, so you would just swap with #3 or #5. that should be a fairly quick test to help rule out the actual coil.
Old Apr 5, 2013 | 06:35 PM
  #16134
IceBerg's Avatar
Finally got the max
I have finally got mine 5.5 max the issue with the car is that the fuel guage stays on full would the code p0462 mean anything specific also my high pressure power steering hose is leaking really badly anyone have a diy nad link for correct part thanks!
Old Apr 6, 2013 | 01:07 AM
  #16135
DennisMik's Avatar
P0462 is the fuel level sensor in the gas tank. That explains your gas gauge problem.
For the power steering hose, read this thread. It is not a true howto thread, it has some directions and photos.
http://forums.maxima.org/5th-generat...hose-02-a.html
Old Apr 6, 2013 | 12:37 PM
  #16136
IceBerg's Avatar
Thanks DennisMik i order the hose from rockauto despite the possibility of the whining noise ,i didnt order the fuel sending unit because im not sure if that is the reason i would get that code.Is it a 90 percent chance that its the sending unit?
Old Apr 6, 2013 | 07:10 PM
  #16137
gadoe305's Avatar
Got a ticket for my windshield tint 35%
Attached Thumbnails 5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread-image-1061829859.jpg
Old Apr 6, 2013 | 07:22 PM
  #16138
DennisMik's Avatar
I think it's a good possibility. There are 3 things involved - the gauge in the dash, the sender in the gas tank and the wires in between. The gauge is ruled out because you have the P0462 code. A bad gauge cannot cause the code. This leaves the sending unit and the wires. Wires don't go bad that often. And when the wires are inside the car as they are in this case, the likelihood of bad wires is even less. That leaves one thing, the sending unit.
Personally, I would not play the odds and automatically buy a part that costs more than $5. I would diagnose the problem and be certain. Easiest thing to do is get the FSM and run the diagnostic on the gauges. I am going to reference the 2002 FSM since you didn't say what year your car is. In the future, please tell us because there are differences in each year model of the car. But we're ok for this because the 2002 and 2003 are the same.
Download the Electrical section of the FSM from here and go to page 122 for the diagnostic. If the instrument cluster and the gauge is good, the gas gauge will indicate a half tank.
http://boredmder.com/FSMs/Nissan/Maxima/2002/EL.pdf
Download the Fuel section of the FSM from here. The gas tank stuff starts on page 4. Do not remove the float unit when you have a full tank of gas. 3/4 tank would be ok but less is even better.
http://boredmder.com/FSMs/Nissan/Maxima/2002/FE.pdf
To get to the sender unit, you remove the rear seat bottom cushion and then remove the access plate in the middle of the car. **CAUTION** The rubber hoses have pressurized fuel in them. Before you disconnect the hoses, start the car and then remove the fuse for the fuel pump (fuse # 29) so that the car "runs out of gas" and the engine dies. Some gas may still dribble out of the hoses, but at least it won't spray out.
When you get the float/filter/pump assembly out of the tank, you can test the float with an ohmmeter. On the float unit where the wire harness plugs in, measure across pins 2 and 5. In the wire harness, pin 5 is a black wire and pin 2 is a green wire. Do not have the wire harness plugged on for this test.
With the ohmmeter test leads on pins 2 and 5, move the float arm up and down. If the ohmmeter reading does not change, the float is bad.
Nissan part numbers - Float unit 25060-5Y700. O-ring 17342-01A00
Old Apr 6, 2013 | 08:31 PM
  #16139
windshield tint is illegal in pretty much every jurisdiction unless you have a note from your eye doctor... At least, more than like 6 inches from the top anyhow
Old Apr 7, 2013 | 03:46 AM
  #16140
IceBerg's Avatar
My apologizes its a 2003 se,thanks I really appreciate the help I will be running the diagnostics today,would the fact it stays behind full when car is on and drops to E when turned off rule out a bad cluster
Old Apr 7, 2013 | 07:17 AM
  #16141
IceBerg's Avatar
i did the cluster test the fuel guage drop down to empty and fuel warning light is on .but when not in test mode and car is started normally it shoots back up pass full ,Now im wondering if its the cluster i found this http://forums.maxima.org/5th-generat...uge-issue.html
Old Apr 7, 2013 | 11:55 AM
  #16142
heavychevy's Avatar
tranny vin codes?
was wondering if anyone possibly could either tell me or let me know about a link that explains all the vin codes. basically for 2000-2003 trying to find out what code is hlsd lsd and the standard open differential. searched a lot and only found one person saying the vlsd has a v in the tranaxel code thanks
Old Apr 7, 2013 | 12:51 PM
  #16143
jptmaxima's Avatar
On the hot scale, from min to full on the transmission dipstick, how much ATF is that?
2000 Maxima
Old Apr 7, 2013 | 03:00 PM
  #16144
DennisMik's Avatar
The diagnostic is supposed to have the gauge point half way. The gauge does not move instantly, the FSM says to wait a bit. If you waited and the gas gauge needle was not in the center, it sounds like either the gauge or the cluster is bad.
Be advised that when you change clusters, the odometer mileage will not be the same. Mileage is stored in a memory chip that is part of the cluster.
Old Apr 7, 2013 | 04:08 PM
  #16145
DennisMik's Avatar
It would be nice if you would help us to answer you question by telling us what year and what kind of transmission, i.e., manual or auto.
Code:
manual trans model numbers
year  vlsd     non-vlsd
2000  RS5F50V  RS5F50A
2001  RS5F50V  RS5F50A
2002  RS6F51H  RS6F51A
2003  RS6F51H  RS6F51A
Automatic trans model numbers
year  vlsd     non-vlsd
2000  RE4F04V  RE4F04B
2001  RE4F04V  RE4F04B
2002  RE4F04V  RE4F04B
2003  RE4F04V  RE4F04B
Old Apr 7, 2013 | 05:04 PM
  #16146
IceBerg's Avatar
Thanks alot DennisMik really helpful,the needle stopped at a quarter tank i have come to the conclusion that it is a bad cluster due to your info ,other maxima owners and numerous threads on this topic.Also is there a way to get the mileage corrected?
Old Apr 7, 2013 | 05:19 PM
  #16147
DennisMik's Avatar
There are laws about changing the odometer mileage reading. It is illegal for anyone except a select few to do this. Dealers and maybe an independent speedometer shop can change the mileage. I would imagine that they would have to replace the cluster and then I have no idea what they would charge.
However, if you are a proficient technician at printed circuit board repair, read this thread.
http://forums.maxima.org/5th-generat...nt-2002-a.html
Old Apr 7, 2013 | 05:36 PM
  #16148
Kevin Ellis's Avatar
I'm thinkn about putting a set of I35 back seats into my 2001 GLE Maxima
I'm thinkn about putting a set of I35 back seats into my 2001 GLE Maxima, will they fit..can someone let me know
Old Apr 7, 2013 | 05:42 PM
  #16149
IceBerg's Avatar
I rather not take the risk if it ends up being a higher mileage cluster i will just try to have it noted on the cars history ,i will update soon as i change the cluster
Old Apr 7, 2013 | 06:20 PM
  #16150
murphys_law's Avatar
02 maxima Random misfire code after new engine
OK guys so I bought a 02' Maxima with a blown engine and commenced to replacing it with one that I acquired(thanks to a buddy). I'm having a few issues and wanted to post up and see if anyone had ideas.
So engine is in and we start it for the first start up, smokes like crazy and smells super rich. Misfire codes etc. We pulled the intake manifold off replaced the injectors and it stopped dumping fuel(I'm assuming one of the old injectors was stuck from old gas or something). Start it back up and has a crank sensor code, swap that out code goes away. Now it has a random misfire code, so I swapped all coils, has new-ish NGK plugs, swapped out all the variable timing solenoids, mass air, TB, cam sensors, cleaned out the gas tank, check the fuel pump, I mean everything. Happen to pull the crank sensor out and try to start it, and see that the flex plate is wobbling a little bit, guess we bent it when putting the transmission back in. Buy a new flex plate, and while waiting pull the engine to verify that the timing chain hasn't slipped. Pulled it all apart today and it looks like all the marks line up and there are no problems with the timing. In the next few days I will be putting it all back together with the new flex plate and HOPEFULLY that will cure the misfire. The reason I am posting is to get some feedback about any problems anyone else has had. So I've heard of ecus being fried from the electric motor mounts and this car obviously has one, and its destroyed.
What I'm wondering here is
A: Would the wobbling flex-plate cause timing issues that would manifest as a misfire?(previous experience with cars tells me yes, but my buddy was talking about how it should run off the cam sensors if there is a problem with the crank sensor)
B: Has anyone had to replace an ecu from the motor mount issue and if so could you provide some details on symptoms etc?
PS engine had a compression test done by me that tested 175 psi across all 6 cylinders so I know the compression is good and valves are not bent which reinforces the timing being fine.
Thanks to anyone for the help in advance and I look forward to being able to contribute whatever I can to the forums.
murph
Old Apr 7, 2013 | 06:54 PM
  #16151
L36's Avatar
L36
murph
A bad/wobbling flex plate can easily cause a misfire issue. Since you have tested the compression to be good, and you already addressed the injectors; the next step would be to check if spark is given. If you still run into misfire issue after the new flex plate, see if all of your 6 cylinders throw a spark.
Remember, if you mix up the harness plugs say between cylinder 4 and 6, that will cause a misfire issue. Ensure that you plug all the right harness plugs to their corresponding cylinders.
Since you mentioned a possibility of a fried ECU due to electric motor mount that's blown, its possible but don't rule it out as the cause yet.
Old Apr 7, 2013 | 07:07 PM
  #16152
Stru's Avatar
murph
Holy sh*t, why do all that work to a 10 year old car...
I had to replace an IAC valve and TPS and thought "why am I bothering" the entire time...
Old Apr 7, 2013 | 07:18 PM
  #16153
Because I got the car cheap . O and i'm poor, more knowledge than money.
BTW no possible way the cop wiring harnesses are mixed up. Good call on checking spark, unless the ecu is bad I have spark because every single coil pack has been removed and replaced.
Old Apr 8, 2013 | 07:04 AM
  #16154
Child_uv_KoRn's Avatar
Bad *** Newb
I tell ya, this buddy gets no respect. You won't even say who this clown is hoarding maxima motors and a shell.
Old Apr 8, 2013 | 08:24 AM
  #16155
DaveFosh's Avatar
Help hard to find oil leak.
I own 02 SPD. Have already replaced both valvecovers. Still losing oil but no smoke at startup but smell oil after engine warms up. Any suggestions. Thanks
Old Apr 8, 2013 | 08:34 AM
  #16156
uptownsamcv's Avatar
go for a drive and park over a large piece of cardboard. my maxima was leaking at the half circle seals on he oil pan ends and the large oil cooler O-ring...
Old Apr 8, 2013 | 09:06 AM
  #16157
NmexMAX's Avatar
dot dot dot ...
Code:
year  vlsd     non-vlsd
year  vlsd     non-vlsd
Just a sidenote, but the H = HLSD for the 02-03.
Old Apr 8, 2013 | 06:41 PM
  #16158
Nismonieves's Avatar
PLEASE HELP!!!! Starting issue
Ok so I was on my way home from work today. I was cruising along when I went to accelerate I felt horrible power loss, I tried it again and same thing. I then approached a stop light and the car died on me. I pushed into a parking lot and let it sit for 5 minutes then tried starting it. It slowly turned over. So I called my dad to give me a jump. We tried for about 10 minutes and finally she started up. But as soon as she started there was a loud ping then the engine stopped. I then took out the battery and took it to autozone where it tested bad. I bought a new one and installed in the car. When I tried to start the car it just stayed stuck. I kept trying and finally the starter started to smoke. So what I'm thinking is the starter is stuck engaged and won't turn over anymore. Or I just jumped timing an bent every intake valve. Had any one else had this issue, or are there any suggestions. I need help thanks
Old Apr 9, 2013 | 12:53 AM
  #16159
DennisMik's Avatar
What I would suggest is remove the starter and see of you can turn the engine by hand. Put a socket on the crankshaft pulley and see if you can turn the engine clockwise with a long breaker bar. If it turns, it would indicate that the starter locked. The fact that the starter was smoking says that starter is bad anyway.
Old Apr 9, 2013 | 08:07 AM
  #16160
Ya I plan on doing that after work today. But doesn't explain why it cut off in the first place. Thinking that was caused by the crankshaft sensor
