5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Originally Posted by BMWHIGH1
Also by fllowing the precdures to get the ses code, there is a step that tells you to step on the gas when the car is off, wouldnt that flood the engine?
thank you so much for your help, one last question before i go and try getting the codes myself, when i follow the steps to get the code will the codes show on the dash?
oh okay cool so autozone it is, Is this service free or is there a charge and what exactly do i ask for when i go there
Originally Posted by irish44j
no. with electronic fuel injection systems, nothing happens with regard to the fuel when the engine is off. "Flooding" the engine is only on carbureted cars.
Originally Posted by choopster
can a 2002 cluster work on 2000-2001 maximaz?
thx
thx
but short answer: NO.
Why would you want the 2002 cluster anyways?
anything can work with enough money, expertise, and creativity.
i am making loads of trip these days ... adding upto my cars mileage. So i thought of swaping the orignal cluster with some second hand. since i have a 01 5speed. i am getting a 02 5speed cluster.
So, you're swapping because why?
Originally Posted by NmexMAX
02 5speeds don't exist in the Maxima realm.
So, you're swapping because why?:s yeah i meant 02 6 speed cluster. I have a 5 speed so the cluster doesn't have the auto tranny lights.
i am swapping inorder to stop mileage on my carz orignal odo.
#2: I really, really want to see the cluster out of the 02 5-speed, lol.
So if u reset the ECU. it won't reset the mileage.
http://forums.maxima.org/showthread....er#post5563931
any way to make clutch softer?. I know its hydraulic.
thx
thx
Originally Posted by longjas
I just bought some new wheels and I don't like the center caps they came with any idea where I could pick some new center caps up at? Thanks
J
J
Climate control bulbs-$40
Price for dealership to change them -$60
Doing it myself and finding out its the wrong bulbs......priceless!!!
So after I rip open my center console to change the bulbs for the climate control, I find out the dealer gave me the wrong dam bulbs....You would think they would know which ones to order. To add insult to injury they must think a female has no clue of what their doing.
of course. I was just wondering if there was a good place to look for some new ones.
OK questions:
1. Is it okay to use two different rotors with 2 different sets of pads.
Front: Powerslot with HPS
Rear: Brembo Blanks with PBR/Axxis Deluxe
2. Is this the right part number for front HPS pads? #HFHB268F665 for a maxima manufature date: 09/00. And is this the right number for rear PHS pads (just incase) #HFHB378F626??
Thanks!
Thanks!
Originally Posted by PandaXpress
OK questions:
Thanks!
Thanks!
2. Well you had the right P/N for the front hawks (HB268.665) but the rears are HB421.622. The 626 part number you gave are for maximas from 10/2000-2003. If you're sure about the build date, you have different rear calipers than the rest of the 5th gens, which means you need to get the pads I listed above. If you want to get PBR deluxe, the p/n is D 712 R for the rears.
Originally Posted by LA02MAX
1. Yes that'd be perfectly fine.
Doing some research I found this: PBR vs. HPS http://forums.maxima.org/showthread....58751&t=422559
and also I posted this in the PBR GD: http://forums.maxima.org/showpost.ph...&postcount=400
I was just a bit skeptic and decided to go with the HPS fronts (as you can see why from the link above)...so my Only question now is:
Personal experience wise..anyone have any say on PBR/Axxis Deluxe pads on Brembo Blanks?
Thanks man...I really appreciate it. (this will be remembered)
I got PBR metal masters and they kind of seem like a cheap pad. They don't fade or anything, but after only a year and maybe 14k miles, my brakes are squeaking and vibrating (uneven pad material buildup). I would just get the hawks all around so that you do it right the first time. I wish I had.
Need help please, i have an '02 gle with 53k miles, now i got my oil changed this past thursday. This morning when i start my car the abs light came on, no there was no hard break of an kind, i turn the car off then i started back up again, the light went away. after sitting for another 3 hrs i started it again and drove , then the service engine soon light came on. i turn the car off wait for about 10seconds then started it up again, the service light is still on, what should i do???
Hi everyone. I just bought a 2002 Maxima SE with 118k miles on it for $7700. It's a one owner and she has kept up the maintenance pretty well from what I can tell from talking with her and the available receipts.
I'm curious as to what I should have done immediately as preventative maintenance on a car with this many miles and what to expect from it. I'd like to drive it into the ground since I paid cash for it and won't have a car payment.
I'm hoping I didn't overpay, but that's yet to be determined based on how much I have to put into it I'm guessing.
I've been searching/browsing through the forums for 2002 SE posts but it's a bit hard to filter them at times. It seems some people think its solid and it's nickel and diming others to death....
I also noticed my car has a seal broken on passenger side real tail light. I'm guessing I need the whole assembly?? Where can I find a tail light for it for a reasonable price?
Thanks for any information.
Originally Posted by soonerfan
we all know that the Hawk HPS are the best pads for our cars...why do people try cheaper ones
