5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Jul 14, 2007 | 10:45 AM
  #2441
KRRZ350's Avatar
Nope, but there is a "dealer & vendor experience" section of the forum, and if you search and spend enough time on here you will generally come across alot of good reviews & opinions on various products.
Old Jul 15, 2007 | 03:04 PM
  #2442
MetalBlueMaxx's Avatar
Hey yall.. I searched and couldn't find. I recently put on tokico illuminas to match my eibach coilovers and to replace my blown stock struts. Since getting new struts handling has gotten amazingly better, but when I hit any significant bumps at more than say 5-10mph I have experience some tramatizing crashes. Twice bolts where even squeaking afterwards. Cringe cringe.. One time I hit a joint on the freeway and it crashed so hard that it literally slung my wiper **** on. Another thing are manhole drains on one side of lanes.. those things KILL me. Arrrr
Thats really really bad and I'm tired of it.. I know everybody on here doesn't have stiff suspension and deal with that.. anything I can do? I want quiet suspension like everybody else. And I'm tired of being paranoid about bumps most people don't even think about. O yeah I run my illuminas on 4 and reducing it to 1 doesn't help. Thanks, please help.
Regaurds
Old Jul 15, 2007 | 03:36 PM
  #2443
CoolMax's Avatar
is invisible
Regaurds
http://forums.maxima.org/showthread.php?t=449807
Did you trim your bumpstops?
http://forums.maxima.org/showthread.php?t=291334
Old Jul 16, 2007 | 04:50 AM
  #2444
Reizy's Avatar
Can someone help me out here? Im still looking for an answer.
Originally Posted by Reizy
I recently bought an 02 SE with an auto transmission and am having it slip from 2nd to 3rd especially when cold. I read the TSB for the valve body and read some threads about the VB mod. I dont really want the jolt during shifting so Id like to stay stock. Im wondering if my problem is related to the VB and Id like to change it out and see. The problem is I cant find the part anywhere online. Is it a pricy part or is it something that I can take out, clean, inspect and replace to solve my problem? What would I be looking for? I already did the flush and still have the problem. The car has ~75K miles on it.
Originally Posted by SuperStasiu
Take it back to the dealer the car should of come with some 60-90 day warranty or if you bought an extended warranty take it back to the dealer and have them replace it
I wish I could but I bought the car private party and sure enough the tranny was nice and warm when I bought it and didnt slip. It mostly does it when cold or under load. Has anyone had Nissan service the tranny per the TSB for slip? Did the VB fix the problem?
Old Jul 16, 2007 | 06:10 AM
  #2445
NmexMAX's Avatar
dot dot dot ...
The VB mod fixed my problem. My problem was the 1-2 shift more so than the 2-3.
www.maximumtuning.net
If you don't want the jolt, get the stage I.
Old Jul 16, 2007 | 08:53 AM
  #2446
d4ster3's Avatar
Originally Posted by irish44j
don't waste money on buying any. Just get some black paint and paint yours. They will still shine through at night if you use light coats and then some clearcoat.
clears on a black car look retarded.
is any certain type of paint needed for this??
also how do u remove them??
Old Jul 16, 2007 | 11:55 AM
  #2447
Dynasty47x1's Avatar
I just saw this pic on cardomain of a 6th gen convertible whats up with that but it looks like a 2 door.
[http://www.cardomain.com/ride/672142
Old Jul 16, 2007 | 04:43 PM
  #2448
digyabooty's Avatar
I have a 00 and i was wondering what would i need to do to change them to the 02-03 hid's?
Old Jul 16, 2007 | 04:52 PM
  #2449
SoonerFan's Avatar
Cletus
you can do...research
Old Jul 16, 2007 | 07:05 PM
  #2450
irish44j's Avatar
retired moderator
I used dupli-color universal black, and 2-3 coats of gloss clearcoat.
Old Jul 16, 2007 | 07:25 PM
  #2451
pbn85's Avatar
I have a noob question so ill ask here:
I was in the process of putting my stock intake back on and I got close. The MAF has 4 screws that connect it to the stock airbox. I got 3 screws on but theres one thats impossible to reach with your hand. Im thinking the only way to bolt all 4 up is to take the MAF out...is this correct? I heard so many stories of people's MAFs failing so I didnt want to mess around with it unnecessarily if theres no need. How exactly is it taken out? Theres a silver bracket around it and loosens and tightens with a flathead screwdriver...is this the right way to do it?
Old Jul 16, 2007 | 07:29 PM
  #2452
SoonerFan's Avatar
Cletus
you mean the bolts on the MAF tube?
you can get them all on...use an extension
Old Jul 16, 2007 | 07:31 PM
  #2453
pbn85's Avatar
extension? Can you elaborate? I think I know what you mean I just want to clarify
I have absolutely no room to get my hand under...Im thinking I should just take the MAF out?
Old Jul 16, 2007 | 07:32 PM
  #2454
SoonerFan's Avatar
Cletus
Originally Posted by SLVRMAXX
extension?
a socket extention
you dont have to remove the MAF from the tube.
you put an intake on...how did you remove it then
Old Jul 16, 2007 | 07:36 PM
  #2455
flxsunxchick's Avatar
USF Class of 2009
I have searched the threads, and I do apologize if I've missed it, but...
...my boyfriend and I changed my brakes this weekend - my rotors were warped so we replaced the pads and rotors. The front two wheels, fine, no problem, but the rear two - we weren't able to fully depress the caliper pistons and the new brake pads were too thick to put on with the new rotors. Thankfully, my old pads were in pretty good shape. We replaced everything and then realized, after bleeding the brake lines, that I had no pressure under on my brake pedal. We rebled the system, no result. Did it a third time, including disconnecting the ground from my battery, and the ABS Sensors, and still no luck. We came to the conclusion that the master cylinder was dieing.
Can a master cylinder be killed/die if air is in the lines, the vehicle is driven, and the air gets into the master cylinder? Or was it probably going before, even though I didn't have a single problem before changing my brakes?
Also, anyone having problems completely depressing the rear caliper pistons?
Thanks.
Old Jul 16, 2007 | 07:46 PM
  #2456
pbn85's Avatar
the arrow points to where the bolt is that I just cannot reach...I need my hand to atleast put it in its place. I have an extension...
it looks like a lot of extra space but you know how massive the stock air box is...once its in place I have no room
Old Jul 16, 2007 | 07:56 PM
  #2457
SoonerFan's Avatar
Cletus
remove that tube from the car then attach it to the box. install the box and tube as one piece
Old Jul 16, 2007 | 07:57 PM
  #2458
SoonerFan's Avatar
Cletus
Thanks.
you need a special tool to compress the rears (due to the e-brake). you might have messed up the master cylinder.
Old Jul 16, 2007 | 07:58 PM
  #2459
KRRZ350's Avatar
Thanks.
You must use a special tool (or needle-nose pliers) to TURN the rear pistons, they don't push in with a c-clamp, instead they are threaded.
As for the bleeding, I HIGLY doubt that it is the master, there is a special order that you must follow in order to bleed the brakes..... Right Rear---Left Front---Left Rear---Right Front. Also keep an eye on the level in the master obviously
Old Jul 16, 2007 | 08:03 PM
  #2460
pbn85's Avatar
so I DO have to remove the MAF right? And basically re-attach the MAF to the hose as one piece with the stock air box?
and holy **** I just realized how new looking my popcharger was...now it looks nothing like that
Old Jul 16, 2007 | 08:04 PM
  #2461
SoonerFan's Avatar
Cletus
thats where you confused me
you remove the MAF TUBE
not the MAF itself (from the tube)
Old Jul 16, 2007 | 08:07 PM
  #2462
pbn85's Avatar
haha yea sorry..thanks
Old Jul 16, 2007 | 09:12 PM
  #2463
What is the part number for the 2002 headlight wiring harness im having trouble finding it on the courtesyparts site the re did the site and the search gives 200 results.
Old Jul 16, 2007 | 09:30 PM
  #2464
No I didn't trim the bumpstops.. that would be the issue.. the one mod I haven't done myself this is what I get. Arrrr THanks for the help..
Old Jul 16, 2007 | 09:43 PM
  #2465
SoonerFan's Avatar
Cletus
call daveb
Old Jul 16, 2007 | 09:45 PM
  #2466
Maximhuh's Avatar
i recently pulled the a/c clutch/pulley and removed a bad bearing similar to the post found here:
http://forums.maxima.org/showthread.php?t=506182
the bearing used in that post however is not the correct size . the bearing i removed is smaller and has the size
50mm outer diameter
30mm inner diameter
15mm width
i can't find this bearing size anywhere... any suggestions ?
the car is a 2000 5sp non-se the ac compressor is unidentifiable by looking at it, i can't seem to find any markings or nameplates
thanks for the help
Old Jul 17, 2007 | 05:53 AM
  #2467
USF Class of 2009
I completely forgot about using that other tool.
As far as bleeding, we did do the RR, LF, LR, RF order, and we disconnected the battery and ABS sensor...but there was also a good amount of fluid leaking from the MC.
If it turns out the MC is good, we'll return the part to the store, (it should be coming in today).
Thanks for the heads up about the rear pistons.
Old Jul 17, 2007 | 06:46 AM
  #2468
littledevil's Avatar
Hey there, this noobie question thread is a great idea. I'm the proud owner of a 5th Gen as of February, and just have a coiuple questions I'd like to bounce off the experts:
1) My Bose 6-disc deck is shorting in and out when I hit small bumps; the entire left side speakers (doors, tweets...etc) short on and off. Would this be coming from the deck, and has this ever happened to anyone else?
2) When the temperature gets below about 12-13 degrees C, the CD player skips incessently - to the point where just have to listen to the radio. Ever happened to anyone? The dealership quoted me ~$375 for a new deck including parts and labour.
3) In researching aftermarket decks, I've found that I need some sort of amplifier adaptor in order to power the Bose sound system, is this true? if so, where's the cheapest place to get one?
Thanks for any and all help that can be provided.
Old Jul 17, 2007 | 07:28 AM
  #2469
NmexMAX's Avatar
dot dot dot ...
Happened to all of us. Give it a good slam, or take it in and get it replaced for free under the TSB. Should work ok for a few months, then the problem will return. I just keep giving mine the nudge, and it works fine after that.
Same thing happens here, enjoy the radio while it 'warms' up.
We have a forum dedicated to Audio, check in there for opinions. http://forums.maxima.org/forumdisplay.php?f=25
Old Jul 17, 2007 | 05:41 PM
  #2470
crynz's Avatar
xenon retrofit
Hi,
I'm new, and I've read the rules and I understand I am not allowed to ask about xenon retrofit due to stealing etc.
However, I am looking to buy a pair of new xenon headlight housing+xenon lights from ebay: http://cgi.ebay.com/ebaymotors/02-03...36802453QQrdZ1
I want to know: Does this retrofit onto my 2000 Maxima? I am dieing for an answer and I've exhausted my searching and have found no real answers. This type of factory retrofit worked on my 2003 mini cooper and I am very satisfied with that so I'm wondering if I can do this on a 2000 Maxima (which didn't have factory xenon as an option). I got this maxima as a hand me down and I really would love some xenons on it =).
Thank you so much........
Old Jul 17, 2007 | 06:06 PM
  #2471
parazer's Avatar
Hi,
I found out from reading the forums that my front whell bearings are shot(winding noise, clunking on bumps). Nissan near New Orleans charges me 1300 including parts. Im in the Navy so we have a hobby shop on base , I know I can do it my self but im looking for a write up hopefully with pics. They also have the press to put them in, car is 02.
Thanks, Rudy N.
Old Jul 17, 2007 | 06:21 PM
  #2472
digyabooty's Avatar
I've been researching and researching but cannot find a how to for installing 02 hid's in a 00. Can somebody give me a link to it, pls?
Old Jul 17, 2007 | 08:42 PM
  #2473
pats_max's Avatar
Yeah Im new
So Im think about gettin' the Injen RS intake and the Gready Evo2 exhaust system. Im just wonderin how many extra ponies these mods would get out of my fully stock 2000 max?
Old Jul 17, 2007 | 08:56 PM
  #2474
SoonerFan's Avatar
Cletus
dont get the Injen...its overpriced and does the same as other intakes
i suggest the one from berk
Old Jul 17, 2007 | 09:02 PM
  #2475
S00NR1's Avatar
OU > *
for the Berk Intake. I've had mine for nearly 3 years now and couldn't be happier.
Old Jul 17, 2007 | 09:07 PM
  #2476
Tee00Max's Avatar
i gotta quick question...i changed the bulbs in my fog lights and when i popped my panel i lost some of the screws that screw the panel back and its hangin down a lil....what can i get to screw or put it back 2gether...
Old Jul 18, 2007 | 06:33 AM
  #2477
[QUOTE=NmexMAX]Happened to all of us. Give it a good slam, or take it in and get it replaced for free under the TSB. Should work ok for a few months, then the problem will return. I just keep giving mine the nudge, and it works fine after that. [QUOTE]
Thanks for the info. WHat is this "TSB"?
I'll check out that audio thread.
Old Jul 18, 2007 | 06:38 AM
  #2478
SoonerFan's Avatar
Cletus
get the tabs from a dealership or use zipties
Old Jul 18, 2007 | 06:40 AM
  #2479
SoonerFan's Avatar
Cletus
technical service bulletins
nissan sends them to dealership to help them fix common problems
http://maxima.theowensfamily.com/tsb/
Old Jul 18, 2007 | 04:58 PM
  #2480
Network13's Avatar
I can't find any info on reproggraming keys. I've found several on programing the key fob but not the keys them selves. I've got an 02' Is there a link or how too I'm over looking? I'm Not in the position to pay $100 bucks for a key right now.
