5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Aug 1, 2007 | 11:42 AM
  #2561
hokie1525's Avatar
I suppose I could put the old stereo back and see if the light goes off. It just seems like a big coincidence to me so I was wondering if others have noticed this problem.
Old Aug 1, 2007 | 12:59 PM
  #2562
Bufflomike's Avatar
Sexier Than Simpson
Go to Autozone and have them pull the code and then we can tell exactly what the problem is. It may be your stereo has so much base you are kicking off the knock sensor code...
Old Aug 1, 2007 | 04:02 PM
  #2563
hokie1525's Avatar
Ok. I took it to Autozone. The code came up P0011 and P0021. They are "Camshaft Position Actuator A - Bank 1" and "Bank 2" respectively. "Timing Over - Advan."
I had him erase the code. I then drove home (about 3 miles) without the radio. The warning did not reappear. I'm going to drive without the radio in the morning and see if it comes on. If not, my guess is the poster above was right...some loud bass during my testing of the unit may have triggered a sensor to register a bad number. So I guess I have to limit my bass in the future...
Old Aug 1, 2007 | 04:30 PM
  #2564
irish44j's Avatar
retired moderator
We don't bass here in Fairfax anyways
Old Aug 1, 2007 | 05:54 PM
  #2565
MetalBlueMaxx's Avatar
----------irish44j
Hey, I got the ES FSB bushings you suggested..
To change em out there wasn't enough room for me to break the nuts with a socket, what do I do? You could remove the subframe bracket.. don't tell me I have to do that for 2 bushings..
Old Aug 1, 2007 | 06:51 PM
  #2566
irish44j's Avatar
retired moderator
Originally Posted by MetalBlueMaxx
----------irish44j
what do you mean there isn't room?
I'm pretty sure I used a socket....maybe you need a smaller one
or just use box-end wrench with another one flipped over on the end as a cheater for leverage....
The bolts aren't really very tight. Douse them in PB blaster and you shouldn't have any trouble breaking them free.
Old Aug 2, 2007 | 09:26 AM
  #2567
tsk808's Avatar
Clock Wiring Harness
From this link: http://forums.maxima.org/showthread....193#post548193
The writeup talks about a scanner. I just want to tap an LED in there. I know the yellow/red is 12V when ign is OFF. Do I use the black wire on the harness for my negative lead?
ty
Old Aug 2, 2007 | 01:39 PM
  #2568
Yeah I have really bad tools with lots of play Lol. I didn't think of the wrench.. I"ll try that. Thx. PB blaster.. who needs PB blaster. Yeah ok.. I'll go pick some up. Thanks for the advice woo FSB bushings, new boots, cut bumps, and new strut bearings my car is going to float
Old Aug 2, 2007 | 04:58 PM
  #2569
SE My 6sp's Avatar
Skyline Calipers
just wanted to know if the Skyline R32 front brake calipers are the same as the 300zx calipers and could be used in the maxima bbks like the blehmco kit. they look similar in design and structure but the R32's ar a bit beefier
Old Aug 2, 2007 | 08:02 PM
  #2570
imported_eddie_D's Avatar
I can't seem to find a write up on how to install reverse indigo glow gauges.
Anyone have any pointers? I know how to take the cluster out and thats about all. I don't want to flush mount the switch just, put in the gauges. I have an 01 maxima. and the gauges look like this
Any help would be appreciated.
Old Aug 3, 2007 | 05:00 AM
  #2571
Bufflomike's Avatar
Sexier Than Simpson
Hey where did you get those because I bought my car with them:
Old Aug 3, 2007 | 11:48 AM
  #2572
sirjinx21jay's Avatar
How Do You....
Can someone tell me how to replace the spark plugs in my car it's a 2000 SE Max????
Jay
Old Aug 3, 2007 | 12:00 PM
  #2573
NmexMAX's Avatar
dot dot dot ...
Jay
http://www.cardomain.com/ride/2076435/5
Old Aug 3, 2007 | 12:04 PM
  #2574
Originally Posted by NmexMAX
Thanks im going to check it out now.....
Old Aug 3, 2007 | 12:08 PM
  #2575
Now how hard is it to do this cause it looks easy but i dont want to be fooled by the pics.....
Old Aug 3, 2007 | 12:24 PM
  #2576
NmexMAX's Avatar
dot dot dot ...
Follow the instructions it's not that hard.
Old Aug 3, 2007 | 12:32 PM
  #2577
Oh ok....i will do that.... now i have to find a place that sells the ignition coils at a good price....lol
Old Aug 3, 2007 | 12:36 PM
  #2578
NmexMAX's Avatar
dot dot dot ...
BTW, you don't need to repalce the coils if they're not bad. You can, if you want to, only repalce the plugs.
Old Aug 3, 2007 | 12:43 PM
  #2579
i thought that i should do that cause i just bought the car in march of this year and the check engine light comes on and off periodically and the p120 code reads all the time so i was just trying to take baby steps at correcting the issue with what time and resources i have so i was wondering why not change them cause i dont know who did what on this car before i bought it and the dealership where i got the car from is being really "tight-lip" (lol) about the maintenance done to the car.......they probably do not know.... lol
Old Aug 3, 2007 | 12:55 PM
  #2580
NmexMAX's Avatar
dot dot dot ...
In that case, it's a good idea.
Old Aug 3, 2007 | 01:01 PM
  #2581
http://www.procarparts.com/store-det...0MX%2D12041RGX
Anyone?
Old Aug 3, 2007 | 04:24 PM
  #2582
Sadida's Avatar
what are the cheapest and/or easiest performance mods for a 5th gen auto?
Old Aug 3, 2007 | 04:30 PM
  #2583
SoonerFan's Avatar
Cletus
3.0 (00-01) or 3.5 (02-03)?
the answer is in the stickies.
if you have specific questions about a specific mod, post here for more information.
Old Aug 4, 2007 | 04:47 AM
  #2584
SoonerFan's Avatar
Cletus
bump...so people who cant remove their MAF wire harness realize the correct thread for newbies questions
Old Aug 4, 2007 | 11:42 AM
  #2585
ageezee's Avatar
I have new clear marker lights and all the links in the stickies with directions to swap them out are dead....anyone know where a good tutorial is?? I don't have a manual so i'm not sure if it tells you in there or not..2000 GLE
Old Aug 4, 2007 | 11:45 AM
  #2586
NmexMAX's Avatar
dot dot dot ...
http://www.courtesyparts.com/nissan-manual/index.html
Old Aug 4, 2007 | 11:52 AM
  #2587
BamaMule's Avatar
Anybody know where i can go to find a list of the original colors that the '03 came in?
Old Aug 4, 2007 | 12:17 PM
  #2588
ageezee's Avatar
thanks!!!!!!!
Old Aug 4, 2007 | 12:34 PM
  #2589
SE My 6sp's Avatar
anyone know about the skyline calipers
Old Aug 4, 2007 | 01:14 PM
  #2590
SoonerFan's Avatar
Cletus
Old Aug 4, 2007 | 01:37 PM
  #2591
SoonerFan's Avatar
Cletus
some answers can be found with google
http://www.carsdirect.com/2003/nissan/maxima/colors
Old Aug 6, 2007 | 06:52 AM
  #2592
jkmorgan3max02's Avatar
Power Steering High Pressure Hose is leaking!
Has anyone replaced the Power Steering high pressure hose on an 02? I need suggestions for getting to the lower side for replacement.
Old Aug 6, 2007 | 07:35 AM
  #2593
Brunt182's Avatar
Any ideas on how to remove a stuck spark plug socket that is in the chamber? I have tried everything to get it out. My only hope is to wait for the car to cool off a bit, then try to go at it again. The wrench extension just won't hold on to the socket.
Old Aug 6, 2007 | 08:34 AM
  #2594
SexiMaxSE's Avatar
Hows it going... Since its obvious that the whole Helios HID thing didnt work out too well for some folks(my apologies to all who got burned), Is there another company out there who offers HID kits for an 02 SE.. Headlights and Fogs?
Old Aug 6, 2007 | 09:37 AM
  #2595
alicious's Avatar
the org...not what it was
Several in the GD section
http://forums.maxima.org/showthread.php?t=515274
http://forums.maxima.org/showthread.php?t=403059
http://forums.maxima.org/showthread.php?t=518750
Old Aug 6, 2007 | 09:59 AM
  #2596
Quick question whats the bulb size for the map light and the dome light. For a 2001 Se. I remember readint it somewhere, just can't find it again. Thanks in advance.
Old Aug 6, 2007 | 10:08 AM
  #2597
KRRZ350's Avatar
Is it stuck on the plug or in the chamber? If it's stuck on the plug than yes, and it's going to sound so simple...... Unscrew the plug, take it all back out, and tightly wrap electrical tape around the socket and extension, if it is stuck in the chamber you will need the assistance of some really really long needle nose pliers.
Old Aug 6, 2007 | 10:16 AM
  #2598
kevinhcraig's Avatar
I have a 2003 Maxima and recently installed a trailer hitch. Does anyonehave any idea what the maximum towing capacity is? I am trying to keep it below 1500 lbs.
Old Aug 6, 2007 | 11:17 AM
  #2599
NJYTHRD's Avatar
rotors.........
I was looking at all the good upgrades and suggestions on the other threads , but my question is -- has any body stayed stock and bought rotors from NAPA.....? and if so were they up to par? (with the ceramic pads..)
thanks for the input.....
Old Aug 6, 2007 | 11:24 AM
  #2600
SexiMaxSE's Avatar
thank u Alicious... That helped alot.. I appreciate it.
