5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Aug 8, 2007 | 08:20 AM
  #2641
CCS2k1Max's Avatar
What power antenna? It's built into the rear window.
Old Aug 8, 2007 | 08:21 AM
  #2642
Kyle00's Avatar
WSH for teh cup
Does the power antenna come up?
Yes, please tell me that was a joke...
Old Aug 8, 2007 | 08:56 AM
  #2643
RadManPL's Avatar
So, any ideas on my bad reception?
Old Aug 8, 2007 | 09:02 AM
  #2644
alicious's Avatar
the org...not what it was
Originally Posted by Solebreaker
2kSE bought a month ago runs fine just hit 69000 anythings i should be worrying about?
As long and the brakes feel good, the MAF is strong, all your fluids are good and level then you should be fine.
Old Aug 8, 2007 | 09:05 AM
  #2645
maximalxl's Avatar
Old Aug 8, 2007 | 11:11 AM
  #2646
NJYTHRD's Avatar
Power Steering
I Have A 03 Maxima. The Power Steering Is Leaking, Anybody Else Have This Problem? Hopefully It Isnt The Presure Hose. The Leak Is Coming Out From Under The Overlay Hose To Hose That Is Connected To The Gold Part Right Bye The Strut.
Old Aug 8, 2007 | 11:16 AM
  #2647
NJYTHRD's Avatar
Power Sunroof
The Other Problem I Have, My Sunroof Wont Work With I Use The Slide Switch. It Works With The Manual Button. Any Ideas What Might Be Wrong
Old Aug 8, 2007 | 11:24 AM
  #2648
Bufflomike's Avatar
Sexier Than Simpson
There is a reset for this although I dont have it. I just push it all the way back and forward when it stops working(twice) and it then works.
Old Aug 8, 2007 | 04:40 PM
  #2649
MetalBlueMaxx's Avatar
PLEASE HELP QUICK--
My car is jacked up and I don't want to reassemble.
This ES FSB bushing mod is killing me. First no room, can't break bolts, got PB got them off now. Only to find the stock bushings melted and pinned in between the sway bar and SFC or whatever it is. I'm scared if I lift the bar I'll need an alignment. Please help.
Old Aug 8, 2007 | 05:13 PM
  #2650
irish44j's Avatar
retired moderator
Originally Posted by MetalBlueMaxx
PLEASE HELP QUICK--
lift the bar......it won't affect your alignment at all.
Old Aug 9, 2007 | 05:47 AM
  #2651
jkmorgan3max02's Avatar
I have an '02 SE and just encountered the same problem. I will be replacing that hose this weekend. If you can wait until Saturday evening to do anything, I'll let you know how it goes. I've searched the forums and can't find any evidence that many others have had the same thing.
Old Aug 9, 2007 | 10:18 AM
  #2652
02Maximan's Avatar
From page 85
Originally Posted by 02Maximan
I have a question about my 02 6spd max. Sometimes when im just easing around and then I step on it pretty good say in 2nd or 3rd, the car kina lurches. it kind of reminds me of how an auto downshifts but its not nearly that major. My initial thought was that the engine mounts were shot but i'm not sure now because it doesn't do it all the time. Maybe the MAF? Someone wanna help me out here?
I ran across this today. http://maxima.theowensfamily.com/tsb/NTB03-022.pdf Could this be what I'm experiencing? I just replaced the MAF and the hesitation is still there. How common is this TSB?
Old Aug 9, 2007 | 11:08 AM
  #2653
KRRZ350's Avatar
My apologies, I had my newbie threads mixed up, this is the problem with the 5th gen forum, 4 people quickly hop on my mistake..... meanwhile nobody even bothers to give him further advice. wtf is that./
Remove the deck and take a look at the antenna cable in the back, that's where i would start.......
Old Aug 9, 2007 | 01:11 PM
  #2654
Trurida18's Avatar
what do you have Aftermarket or stock Headunit? If its aftermarket slide the Headunit out and connect the antenna wire to the Ant Remote wire...
Old Aug 9, 2007 | 03:10 PM
  #2655
Man.. this mod is killing me. 3rd time to unbolt. Thanks for the tips.
Old Aug 9, 2007 | 06:18 PM
  #2656
Dynasty47x1's Avatar
Who has done the VB mod and where did you take your car to get it done. im thinking about getting it done to speed up my acceleration.
Old Aug 10, 2007 | 02:40 PM
  #2657
imported_eddie_D's Avatar
Is there a common lag or problem on 2001 models?
I've had my SES light come up more than 3 times now. And, before I can go to autozone to get it diagnosed the SES light comes off?
I have 3 buddies that have the same issue. Is this common and what should I do?
Old Aug 10, 2007 | 03:12 PM
  #2658
NmexMAX's Avatar
dot dot dot ...
www.maximumtuning.net it wont really help acceleration. Our 4AT's are so tall geared that you'll shift once before 60, and twice before 90 if held to redline.
Old Aug 10, 2007 | 03:40 PM
  #2659
irish44j's Avatar
retired moderator
the code is still stored there, even if the light turns off. Go get the code read.
Old Aug 10, 2007 | 07:11 PM
  #2660
wifes_maxima's Avatar
O2 sensor question, Ive been running the search and cant come up with someone else that has run across this same problem but if someone knows about it please point me in the right direction. About 2 weeks ago I did a basic tune up on my 2K max has about 117K miles on it standard platinum plugs, oil change, air filter no biggie done it before. Now the car starts throwing an SES, I hook up my Auto X-ray first time I get a P0138, high voltage, so I reset it and see what happens about 3-4 days later light goes off, now its a P0139, Low Voltage, reset, then a few days later P0140, no voltage. And today another light back to the P0138. Any ideas as to why a bad sensor can throw such erratic codes or is there a problem elsewhere?
Old Aug 10, 2007 | 08:48 PM
  #2661
irish44j's Avatar
retired moderator
just for fun...this thread is freakin' long
Who Posted?
irish44j 334
soonerfan 175
NmexMAX 108
CoolMax 82
LA02MAX 61
VaporHead 50
PandaXpress 47
Puppetmaster 42
maxig0 31
MetalBlueMaxx 31
Bufflomike 30
Succinct 29
machinehead131 28
G&S Maxima 28
GigEmAgs07 26
JimmyH 24
00MaxSE 24
The Law 23
OC guy 22
SEmy2K2go 21
alicious 19
dmpesso 19
djcallao 19
macnolias 18
choopster 18
longjas 18
GBAUER 16
Memphis2k1 15
02Maximan 15
clborden 14
BMWHIGH1 14
Staticmax 14
SE My 6sp 13
CCS2k1Max 12
huffdaddy2008 12
CraigsMax01 12
jocoo 12
aamir 12
YungmaxiOwna21 12
sirjinx21jay 11
Topher3284 11
dwareroy 11
gooroo 11
KRRZ350 11
sam201180 11
Dynasty47x1 11
mike2576 11
01_Maxine 11
Little John 10
Nineleven 10
BLK2BLU 10
gephelps 10
SuperStasiu 10
fldash 10
hayai240sx 10
atlridin 9
ricodemus 9
lake3031 9
Child_uv_KoRn 9
chopstix2nrz 9
Kyle00 9
Mastro75 9
bwinter7 9
mist max2000 8
oldmanshirt 8
phenryiv1 8
Bham Max 8
SiLvErBaCk82 7
bluesky2702 7
STILLENGLE 7
Porkepik 7
capt_z1 7
dmaljunk 7
RadManPL 7
UKmaxima 7
whiteghost 7
chris in va 6
GOLD00GXE5SPD 6
zgendron 6
Patrick.R 6
llama 6
abraxus22 6
Old Blue 66 6
MichMaxFan 6
slickrick 6
rrj72 6
Canepole 6
Max_Ryder 6
Psyfa 5
pt929mm 5
TheSpaZinNOVA 5
SLVRMAXX 5
SHuggsUNC 5
KhanMan13AK 5
IloveVQ 5
kenshi 5
AndyT 5
mtl-maximus 5
ctrent86 5
MAi30t 5
eddie_D 5
Reizy 5
nk2k2 5
flxsunxchick 5
bluX 5
1PhatMax 5
drinkredstripe 5
wawacito 5
gbwillner 5
DoonBusy 5
DragdMax 5
707SE 5
93 SE 5
MaxiPad'01 5
d40sithui 5
tsk808 4
knight_yyz 4
maximashine 4
WeeZyFellA 4
NismO2max 4
AHI 4
Daniel514bama 4
MaxBurg03 4
Sirl 4
illlojik 4
Magista 4
dkim34 4
Tragikcomic 4
ShQiPtaR2287 4
maxima blondie 4
Merlot02SE 4
slowls 4
Froggmann 4
buffy 4
Torgus 4
randycacc 4
Ricfutures 3
MadAlex2002 3
Jfree 3
alabranche 3
life-rocks 3
mynesbts 3
viperxiv 3
DJ Kaanco 3
JROD'02 3
ChadSpeed 3
maximamass 3
Silver01Maxima 3
Metal Maxima 3
iamatis 3
AcidJake75 3
maximanigel 3
schlmeil 3
iNFINITEPro 3
Relaxima 3
allday850 3
StreetzINC 3
craigalta 3
kwk1 3
larryg 3
fastmax24 3
Rossello 3
The Hulio 3
BigFly_2K2SE 3
Heavy D 3
hokie1525 3
pyro02se 3
kevinhcraig 3
Tension710 3
DonS 3
delguiner 3
heyjerr 3
beancooker 3
99blackmagic 3
JohnWEngle 3
NJYTHRD 3
vman09 3
matt_aitchison 3
mikessilvermax 3
chaoticchao 3
Smokin Max 3
Kevin Trout 3
breaker05 3
Maximo070 3
SexiMaxSE 3
Eric F 3
MaxGirl970 3
Brianm0121 3
daddymax 3
XKlusive_Drunky 3
Islandman 3
Meshuganah 3
felon 3
02MAXZIMA 2
MacGarnicle 2
naiveshopper 2
clayman88 2
ajamil 2
Jayphil82 2
cflemm 2
IllegalMax 2
littledevil 2
claplante 2
Mark S. 2
JDMGLE 2
ICEMAN76 2
MrLaidley 2
cowans 2
Larryw 2
AE_Racer 2
Maximax2 2
Pragmatic 2
Airacuda 2
suess88 2
tim625 2
Ritz 2
Rydicule 2
toastedoats 2
Romster 2
andyslone 2
MG-SVT 2
thomasskull666 2
sexima_00 2
bigbirney420 2
K.O.D 2
slowstang 2
infie 2
Tony Adymy 2
BlackEnigma 2
tim_2006 2
genious 2
forumboy2k2 2
skiingss454 2
four 2
Trevor28 2
tancythor 2
myke321 2
warlord84 2
jtmoor002001 2
digyabooty 2
az2kamui 2
replicant 2
rowen93se 2
hotjiggaman 2
billytrippin33 2
Decoy036SPD 2
MaximaSe617 2
Occhoppersb418 2
KidHauler 2
catrell23 2
jeisai 2
hottmaxx2003 2
Nissanaholic 2
MaxBoost925 2
mtlmaxima01 2
Rhegaana 2
KEV03SE 2
Ezreggie 2
Mike_Amaral 2
aja656 2
Sam524 2
alenhard 2
Southpawvol 2
636specman 2
brs2c 2
PITCH 2
PhillyB 2
jkmorgan3max02 2
ageezee 2
BhB 2
Dave2112 2
sircastic 2
MyBlue02 2
MAXSE2kMT 2
Nissanx54 2
Hillsboro Max 2
jchin34 2
joeb's01max 2
cefiro80 2
spooledyou08 2
shur 2
Maxim24 2
PitchBlackMax 2
TC_Max_SE 2
jbran555 2
milek 2
d4ster3 2
2002MaxNJ 2
5thgenmaxima 2
secSEblue2k2 2
DOHCtorJT 2
Davy D 2
ATLienGeorgia 2
D_Roc 1
CreativeSkillz 1
jdm01se 1
ahallmaxima 1
Network13 1
Caidwen 1
Derrick2k2SE 1
fastman 1
girvinman 1
master44 1
maxworld101 1
BamaMule 1
MaxPaul 1
santarosa 1
brian35201 1
Mikeb120 1
Eshelon 1
Terence 1
BewstAdd1ct 1
hdrk98 1
DukeN 1
Y2K1GLEMAX 1
beano 1
gotcha640 1
vansskaterfreek 1
jhiat00 1
westchamp24 1
pyroz 1
pats_max 1
bjr 1
SleepinGLE 1
2K3MAX2NV 1
Gemini67 1
jesse1020 1
phinz01 1
mokiblk2k2 1
leztrampmax 1
rdotharder22 1
PrinzII 1
ssquire37 1
chris288 1
2000maxSE-T 1
carsarecool 1
maximalxl 1
jpd 1
02nismaxlegnd94 1
Eenis 1
kbabas 1
ghostridden 1
eastnwest88 1
ComfortablyDumb 1
JohnnyS 1
some_dude 1
CannaBis 1
ke.max 1
edge540 1
almoodie 1
attomica2 1
El Gabito 1
dblock75 1
Merlyn 1
cobra21 1
maximizeme 1
Dan_E_Hughes 1
kinnex 1
Fox_90 1
Dennis'Maxima 1
JOE01 1
cpo_sharky 1
knave 1
cmr1972 1
s1mm01485 1
wifes_maxima 1
bostonirishguy 1
Teddie18 1
mcphebus 1
MaReK 1R 1
S00NR1 1
cpuguy06 1
westler92 1
Brunt182 1
ManUtd18 1
02i35black 1
Alika 1
cyrusjumpjet 1
harpua 1
MaxDallas 1
Zizzer 1
TontonPoulet 1
Hollywood! 1
02bluese 1
NYC2K2MaXx 1
MAXI BLUE 03 1
rkyat 1
Just_The_Factz 1
SilverBulletGTP 1
MaxHind 1
Pilkmax3355 1
craigts 1
Ephraim 1
madcheeku 1
EXTREMA 1
MrRooks 1
irax 1
sc0tty8 1
maxximaa 1
cobra989 1
ken3624003 1
prigrg 1
Solebreaker 1
MR.Large 1
maximavol 1
IPSpoofer 1
MaxBlu5 1
IHAVEA2KMAXIMA 1
mebur**** 1
97gshogun 1
Kebrandon 1
Tank987 1
Maximhuh 1
doublelegend 1
vitalelement 1
dazeskater24 1
jirpel 1
BenjiBoy650 1
vicdor 1
TL5 1
rocketsled 1
maxwannabenow 1
gimmethayayo 1
parazer 1
El_PrOfE 1
crynz 1
ToneBoat923 1
mtownyellaboy 1
sontakke 1
blacksam0423 1
AJA_MAX 1
notched306 1
mikemondy 1
notuptodateguy 1
NewEnglandPats 1
nicenotrice 1
FRZ251 1
Sadida 1
Elf 1
Folsomfella 1
ChrisD 1
n3985 1
Trurida18 1
mohmony 1
sirmixalot42691 1
XyNoix-HIC 1
Phillie 1
Revs2Hard 1
Dayo 1
twoina2 1
Scorpioflat 1
guod 1
raelity 1
02max85 1
Warning 1
Show Thread & Close Window
Old Aug 10, 2007 | 08:50 PM
  #2662
irish44j's Avatar
retired moderator
sounds like it's time for a new 02. You need to check the stickies above to find out specifically what those codes mean in reference to the maxima.
http://forums.maxima.org/showthread.php?t=374481
Old Aug 10, 2007 | 08:52 PM
  #2663
SoonerFan's Avatar
Cletus
im second in helping the newbs!!! remember that people.
i only flame newbs if they start a new thread....in here, you get help
Old Aug 10, 2007 | 08:54 PM
  #2664
irish44j's Avatar
retired moderator
lol me and you have lik 20% of all the posts in this thread!
Old Aug 10, 2007 | 08:57 PM
  #2665
SoonerFan's Avatar
Cletus
we are smart and helpful
Old Aug 10, 2007 | 08:58 PM
  #2666
cobra21's Avatar
$4DsC$
standard a/c controls for auto climate controls?
if my car didn't come with the auto climate control unit. can i easily swap the old A/C controls for the auto climate control unit? would that be a simple plug and play? interested in doing it if it is easy.
Old Aug 10, 2007 | 09:39 PM
  #2667
pyroz's Avatar
does anyone know the bulb size for the replacement bulbs in the manual climate control? mines went out and i'm having a really hard time finding it. i have a 00 SE. Thanks
Old Aug 10, 2007 | 10:09 PM
  #2668
SoonerFan's Avatar
Cletus
god bless you for asking this here and not starting a thread.
this question is asked very often.
Answer
not worth the time and money since you need the following -
new climate control unit
two temp sensors
about 10 feet of wiring
Old Aug 10, 2007 | 10:21 PM
  #2669
SoonerFan's Avatar
Cletus
also
thank you for not starting a new thread.
i did a search to find your answer and found about 20 threads started to ask this question
Answer
3 bulbs, 27545MA
Old Aug 10, 2007 | 10:49 PM
  #2670
pyroz's Avatar
thank you very much. the free search function don't work that well
Old Aug 11, 2007 | 07:20 AM
  #2671
CoolMax's Avatar
is invisible
http://forums.maxima.org/payments.php
Old Aug 11, 2007 | 07:21 AM
  #2672
CoolMax's Avatar
is invisible
oh neat, i am somewhat helpful.:attention:
Old Aug 11, 2007 | 07:41 AM
  #2673
AceofSpds's Avatar
wat
zomg ur too kewl for that though
Old Aug 11, 2007 | 08:46 AM
  #2674
GigEmAgs07's Avatar
soooooo a couple weeks ago my maf got cleaned and the throttle body as well. That was to get rid of how my car was dying while sitting in park.
Prior to that, and still now, my car feels so week. Driving back to college station yesterday, i floored her a few times to see how she would respond. If i'm going 70 and need to punch it a bit, she gets to about 4000 rpm and will hardly accelerate at all. The highest i could get was about 4500 rpm but it was like that was the ceiling. The lack of power up there is very noticeable, and is enough to make me think twice about passing all the dang semi's on hwy 6.
any thoughts?
Old Aug 11, 2007 | 09:36 AM
  #2675
irish44j's Avatar
retired moderator
any thoughts?
sounds like you damaged the MAF, unfortunately.
your "dying when in park" is probably attributable to a bad IACV (common problem) rather than a dirty TB/MAF anyhow.
Old Aug 11, 2007 | 10:17 AM
  #2676
GBAUER's Avatar
any thoughts?
Definitly a bad MAF. Mine behaved EXACTLY like that before I replaced it.
go to www.car-parts.com and try to find one there before you head to the stealership. I found one that was practically brand new for $60. The dealershipe wanted $385.
Oh, and Irish said it might be your IACV: It's not. I thought that myself and the cleaning had no effect at all.
Old Aug 11, 2007 | 10:45 AM
  #2677
I changed my clock today to white with the red cellophane(sp). It's a little dim. Is the red cellophane a little too thick? Didn't seem like to me. Any solutions?
Thanks in advance.
Old Aug 11, 2007 | 11:24 AM
  #2678
bwinter7's Avatar
Thanks in advance.
If you alter the clock like that, it's going to seem dim. The clock light isn't that bright, and just filtering out all the colors but red'll make it look that way. You'll be able to see it better at night. Out of curiosity, you don't leave your lights on during that day, right? cause if you do, I'd suggest that you turn up the dimmer switch if it isn't already
Old Aug 11, 2007 | 11:33 AM
  #2679
Nah I didn't have my headlights on. When I turned em' on I could'nt see the clock at all. I tought I did something wrong. But, I guess not. We'll see how it looks like at night.
Old Aug 11, 2007 | 11:57 AM
  #2680
bwinter7's Avatar
What kind of cellophane? I'm sure that you could get much better results by using that red reynolds wrap (the food kind), because that's thin, red, and will stick great.
Just thought of something, wont the clock seem white after that? The geen numbers in the clock, + Red covering, I'm not sure, but it might look white.
