New v2OBX headers?
Old Mar 18, 2009 | 04:50 PM
  #521
99Silvermist SE's Avatar
So I got these headers installed saturday and went and tuned the car today and got 250hp and 242.63 torque. I had it tuned with a VAFC2 with a mostly flat 13.1 A/F ratio. The dude said he'd email the run files tommorow. I have felt a bit of a power decrease before I had these installed and had replaced the MAF sensor thinking that would help but with 98k on my car I guess it's time to change the spark plugs finally. My current mods are Berk intake, SSIM, No VIAS, Headers, Greddy cattback, UDP, intake spacers and of course the VAFC2. My 1st run before a tune was 223hp. I would think that was pretty low for what I had. There has been 2 times before I got it tuned that I floored the car it felt just like it did after the tune. ohwell I'll have to investigate....
Old Mar 18, 2009 | 05:41 PM
  #522
datdude20's Avatar
250...not bad ....i put out 247whp.....but i havent dynoed since i put my spacers on and my new exhaust set up
Old Mar 18, 2009 | 06:24 PM
  #523
PulsarGTS's Avatar
You guys are all lying there is no way these headers could perform, they are made by OBX and are too inexpensive.
Old Mar 18, 2009 | 06:30 PM
  #524
pmohr's Avatar
No more Maximas...
...what?
Old Mar 18, 2009 | 06:51 PM
  #525
Jreed2008's Avatar
inexpensive = less performance???? Since when does the price of a mod effect gains? Seems that OBX is doing something right by keep production cost down of the headers and not sacarficing on quality. I think most org members are just stuck on cattman that's all even if these version 2's prove to be a great alternative
Old Mar 18, 2009 | 07:46 PM
  #526
Mr. Blue Sky's Avatar
i do believe he was being sarcastic
Old Mar 18, 2009 | 08:10 PM
  #527
diverdown3's Avatar
I could smell it.
Old Mar 18, 2009 | 09:23 PM
  #528
knight_yyz's Avatar
Toolie
Spacers won;t affect peak power, but you'll see a jump in the midrange, 2k to about 6k
Old Mar 18, 2009 | 10:51 PM
  #529
maximo018's Avatar
Originally Posted by CMax03
I'm not having a hard time at all! I installed my Cattman headers/ypipe myself... Which included air tools and hand tools, no lift, just jack stands. But the fact is I did mine and did it once, and it's still running hard like a champion with no problems nor drama! No money out of my pocket for someone else to do the work...that money you spent is another mod for me!
Okay we, I guess you can say successfully installed the headers today. The same way CMax03 did. Matter of fact it was in his garage with the stands. It took us hmmm... (without the break) about 5 1/2 hours. This include CMax03 Delvin who is also on the org and me. I will post pics later. We shaved the rim of the xmember and grinned an upside down arc in the engine mount bracket in the rear. Other than the 2 o2 bung spacers everything went well. I'll try to have pics up by tomorrow evening. No promises, but soon. Sounds great a bit more masculine than the cattman, but thats opinionated.
Old Mar 19, 2009 | 12:00 AM
  #530
CMax03's Avatar
Originally Posted by MIK3
Man, I've been juggling back and fourth as to whether I want to install my Gen III's myself or not. What was the biggest PITA during install?
Extending the O2 sensor harness for both primary O2 sensors, and the rear heat shields adjustment back near the fuel tank! After you install you may need to have the catback cut and reduced 1/2". During the removal of the heat shields those small bolts on the rear bank heat shields were corroded and a chore to remove if they strip!
Old Mar 19, 2009 | 05:30 AM
  #531
Jreed2008's Avatar
Lol yeah I realized that halfway thru my rant, but I do believe a lot swear by cattman and don't give much other exhaust companies a fair chance. But its good 2 see the Obx has much potential has anyone got these coated yet?
Old Mar 19, 2009 | 07:55 AM
  #532
durckelg's Avatar
Would it be worthwhile to install these headers on a bon stock 03 auto? How about with a VAFC2?
Old Mar 19, 2009 | 07:58 AM
  #533
pmohr's Avatar
No more Maximas...
Originally Posted by durckelg
Would it be worthwhile to install these headers on a bon stock 03 auto? How about with a VIAS?
Yes. What do you mean with a VIAS?
Old Mar 19, 2009 | 11:31 AM
  #534
Sure it would.
I used the VAFC2 to tune with and gained about 25hp from it so I would say tunning is a very important aspect. You could use a SAFC, VAFC, Emanage or whatever else is on the market to help with the tune.
Old Mar 19, 2009 | 05:10 PM
  #535
durckelg's Avatar
Sure it would.
How much will the output be restricted by the stock exhaust?
Old Mar 19, 2009 | 06:01 PM
  #536
tshay1's Avatar
i have had these sitting in my house for about 2 week now b/c of time constraints. so i guess my biggest issue is how long will it take to install on 01? and also if i dont have the ac lines or a/c condenser will i have to move the o2 sensors? will i also have to tune it or will the a/f ratio be ok? also this doesnt really relate to this exact topic but how many people run mass run headers and are able to pass emissions?
Old Mar 20, 2009 | 12:47 AM
  #537
maximo018's Avatar
mine are coated
Old Mar 20, 2009 | 02:13 AM
  #538
CMax03's Avatar
Originally Posted by maximo018
mine are coated
You know you'll have to reposition that O2 sensor seating between the swaybar and the rack and pinion! Your header O2 sensor bung needs to be reposition(90*) to the passenger side so you may need to remove the rear section, drill it for the bung, weld it on and clean up the rear manifold/ypipe of any shavings internally and reinstall it! Hope that welding doesn't screw your ceramic coating up to bad.....
Old Mar 20, 2009 | 12:22 PM
  #539
Jreed2008's Avatar
mine are coated
Oh ok well I know coating reduces a lot of heat and protects from rust, might be a dumb question but does it add any extra weight to the headers??
Old Mar 20, 2009 | 12:27 PM
  #540
diverdown3's Avatar
The performance gains far outweigh any weight added by the coating.
Old Mar 24, 2009 | 02:17 PM
  #541
TheOnlyMax88's Avatar
Are you talkin about the OBX headers you have? Those are 2 questions thats keeping me from purchasing too im from mass aswell, I wanna get the most out of them and i also dont wanna fail emissions.
Old Mar 24, 2009 | 10:30 PM
  #542
knight_yyz's Avatar
Toolie
you don't HAVE to tune headers. But there are a lot of reason's why you might want to. If you run rich after the header install you take the chance of ruining your o2's and your main cat. You will not get great gas mileage. I am getting roughly 8.6L/100km (27.something MPG) with my headers and a tune. (50/50 city/highway) That's better mileage than most stock maximas. Tuning will net you an extra 10-20 horsepower over untuned header install.
I'm not sure if anyone has ever run lean after an install but that would be a worse case scenario. Running lean will kill your engine quick. So if you are going to spend the money on headers it makes sense to spend the extra bucks and get the most power you can from them and not have to replace your cat and primary o2's because you ran rich for too long.
Old Mar 25, 2009 | 05:14 AM
  #543
Grand_hustle17's Avatar
9 hours!!!!!....this aint no turbo kit instal....
...sonds like somebody having a hard time....it only took my mechanic 3 hours to do mine....i guess if u have the proper tools and area..it makes things a whole lot easier...
Good mechanic aint he... why ya gotta go on everybody else though jeesh manny
Old Mar 25, 2009 | 05:19 AM
  #544
i would also thinkt that the extra $400 spent would be the amount spent for someelse to do it, no headache of installing and we came out the same price
Old Mar 25, 2009 | 07:10 AM
  #545
dwade27's Avatar
ok so
cutting Xmember?
cutting rear mount?
??rear 02??
is that all did i miss anything?
Old Mar 25, 2009 | 07:19 AM
  #546
MaximusMorpheus's Avatar
Good points here.
Well I guess I didn't do my homework because I didn't know that by not tuning you could ruin an o2 sensor or cat. I probably had the headers on for a couple of years without a tune. Now I see why one of my o2 sensors failed, couldn't figure out why. Oh, well. live and learn.
Not sure if my cat has failed, how would you know if your cat has failed? Maybe I should just replace it with a high flow cat.
Glad it is tuned now and can see why it is valuable to do it. Car does get better gas mileage and feel power difference.
Definitely recommend people consider a piggyback tuning module when buying headers and not to wait to long to tune the car.
Old Mar 26, 2009 | 10:15 AM
  #547
C-Young's Avatar
Just wanted to post a couple pics of my new obx headers for yall to take a look...
These are going on next month due to the arm and the leg they want to charge me to put them on.
Old Mar 26, 2009 | 11:31 AM
  #548
mist max2000's Avatar
thanks for the pics... how much are 'they' charging?,.. and update this thread when you get them on
Old Mar 26, 2009 | 12:29 PM
  #549
C-Young's Avatar
Nissan - $900
Precision Motors - $847
Premier Auto - $588 (shop looks real shady though)
The shop I'm going with, Straight Up Performance, says he's done a lot of 350Z header replacements and will do mine for $618. Estimated 8 hours of work.
Here in Lawton, OK theres not much to choose from.
Most are just used to putting ridiculous spoilers on Dodge Neons and such... feel me?
At least the emissions police don't give a damn here.
Old Mar 26, 2009 | 01:02 PM
  #550
Weeble1's Avatar
The Whistle go WOOOOO
I'm way too lazy to go threw that many pages. How did they dyno? Any legit comparisons to Cattman? And sound clips?
Old Mar 26, 2009 | 01:03 PM
  #551
Kevlo911's Avatar
Kevlo for President
Sorry but that is way too much $$$. Go to some local exhaust shops.
Old Mar 26, 2009 | 01:07 PM
  #552
datdude20's Avatar
pretty good...i put dwon 247whp untuned
Old Mar 26, 2009 | 01:12 PM
  #553
Weeble1's Avatar
what other mods?
Old Mar 26, 2009 | 01:26 PM
  #554
datdude20's Avatar
what other mods?
at the time i had SSIM, intake, headers and a clogged greedy catback
im bout to put sound clips in the sound clip section...gimme 2 minutes
Old Mar 26, 2009 | 01:28 PM
  #555
Weeble1's Avatar
im bout to put sound clips in the exhaust section...gimme 2 minutes
sweet. So I should put down possibly 260 or so with intake spacer kit, Vias blockoff, headers, megan cat back and a tune...
Old Mar 26, 2009 | 01:31 PM
  #556
datdude20's Avatar
maybe ...if u puttin down 260..then so am i...lol.....we have similar mods...car feels way better wit my new exhaust
Old Mar 26, 2009 | 01:33 PM
  #557
NYC_VQ30DE-KT's Avatar
QUEENZ CRAZIEST
^Nice to hear what you got. But your gonna have to do more mods for you to get 260+
Old Mar 26, 2009 | 01:35 PM
  #558
C-Young's Avatar
Yeah I hear that.
Problem is... there are only 2 places here that do exhaust... Midas and this garbage place called Crows Muffler and Exhaust. I took my old car there to put an HKS muffler section on. They straight cut off the old muffler and welded a new one on without any bumper clearance. I had a white car so my bumber turned black and they welded some rusty *** bars directly to the muffler tips to hold it on. Unbelievable!
Needless to say I won't go there again in my lifetime.
Good shops are really scarce in this town.
Old Mar 26, 2009 | 01:36 PM
  #559
datdude20's Avatar
homeade intake,SSIM, nwp spacers, obx headers,gutted cat and 2.5 inch exhaust no resonator jus straight pipe all the way back to the greddy muffler
where is the thread wit the exhaust clips...send me a link someone
Old Mar 26, 2009 | 01:54 PM
  #560
datdude20's Avatar
http://www.youtube.com/watch?v=rXA68PYtdQ8
excuse the bees in the can...lmao
