5th Gen: What did you do to your 5th Gen today?
Old May 8, 2016 | 10:21 PM
  #2521
cornholio's Avatar
That looks like a healthy auto.
i take this as a positive thing, especially coming from you. soo thanks!
i told myself this weekend my goal was to keep this thing on the road for total 20 years. granted i only put on about 5-6k per year, to me another 4 years means:
new tires at some point (sooner than later - lightweight rims? will watch craigs for something)
new shocks/struts (coilovers?, maybe more of a want than a need)
rear calipers replaced in the last 1-2 years, but possible front bbk upgrade. who knows
Old May 8, 2016 | 10:55 PM
  #2522
Child_uv_KoRn's Avatar
Bad *** Newb
I must be pretty *****y.
Do you have a link on those hood stops? I hope they weren't 10 dollar each lol.
Old May 8, 2016 | 11:44 PM
  #2523
maxiiiboy's Avatar
The same thing here: Cornholio, could you tell us where you purchased your hood stops? I need two of them, soon .....
Old May 9, 2016 | 07:01 AM
  #2524
cornholio's Avatar
haha, you know what you're talking about and you don't sugarcoat things, i like it
i bought the hood stops from nestorlugo, he has a few pairs he is/was selling
https://maxima.org/forums/5th-genera...-stoppers.html
Old May 12, 2016 | 09:10 AM
  #2525
donpire's Avatar
I upgraded my 02 to the BBK. I notice that now my car has a heavier front during take off. Gas miles is a little lower too. As I filled up with gas yesterday, at 158 miles, it took 11.27 gallons of gas. Anyone else getting poor gas miles after Big Brake Kit upgrade? Put on 05 maxima front calipers and rotors.
Old May 12, 2016 | 10:55 AM
  #2526
losifanatic's Avatar
I'm have a BBK and I'm still getting 28mpg highway and 22 to 24mpg normal driving
Old May 12, 2016 | 11:04 AM
  #2527
NmexMAX's Avatar
dot dot dot ...
23-24 here, mixed driving. I've had the A34 BBK and now the EVO BBK, neither one affected it.
A34 rotors are fairly heavy, but with the 5.5 gen, shouldn't matter.
Old May 13, 2016 | 08:43 AM
  #2528
donpire's Avatar
Well, I've been easy on the right petal so far. We'll see what this tank of gas comes out to. I'll have to give an update when its all said and done. This is also 85% city driving.
Old May 13, 2016 | 10:07 AM
  #2529
NmexMAX's Avatar
dot dot dot ...
That probably doesn't help, but still, you might try and do a complete tank and see what it comes out to, as in adding about 16 gallons or so, better average.
Also, http://www.racingbrake.com/NISSAN-MAXIMA-s/259.htm
I've used those, they're not much lighter but they are a bit.
As for me, yeah decided to go soft with teh BC's and went to 5f/7r, down from 15f/18r.
Ride is awesome, handling is not as cool as it was, damn you compromise!
Old May 13, 2016 | 10:10 AM
  #2530
cornholio's Avatar
imgur stole my photos
Old May 13, 2016 | 10:56 AM
  #2531
96SEmaxB's Avatar
Replaced dead MAF (19$ 6N200 - eBay life)
Deleted the intake air resonator, installed cone valve-cover breather filter
Installed MAF connector to air intake cone (eBay again)
Cleared codes (evap, damn gas cap)
So ya, 5.5s are so much more high maintenance than 4th gens, like a 35 year old woman vs a 20 year old..fml
Old May 13, 2016 | 11:12 AM
  #2532
NmexMAX's Avatar
dot dot dot ...
Damn, that’s cheap.
Not in my experience, on both accounts, 20 y/o's are needy, 35 y/o are independent.
My A32 was far more wacked out at this point vs my 5.,5 gen.
Old May 13, 2016 | 08:19 PM
  #2533
mrjamaica98mx's Avatar
Hit and run my gf was driving she got the other cars license plate how much $ u guys think.
Size:  248.9 KB always something.
Old May 14, 2016 | 04:57 AM
  #2534
rvamax's Avatar
New outer tie rod ends, new brembo rotors and hawk hsp pads in the rear, still debating slotted in the front, new maf, cai, sdground kit, new hood stops, work aluminum locking lugs, and I finally wired up the halos.
Old May 14, 2016 | 05:05 AM
  #2535
rvamax's Avatar
[QUOTE=mrjamaica98mx;9110080]Hit and run my gf was driving she got the other cars license plate how much $ u guys think.
$300 at maaco
Old May 14, 2016 | 05:09 AM
  #2536
HerBlue2kSE's Avatar
Original owner of a 2000 SE with 127,500 miles. Decided to start the front suspension rebuild including new struts, bushings, sway bar end links, tie rod ends, and other parts. Car has recently moved from my wife's daily driver to mine.
Old May 16, 2016 | 09:26 AM
  #2537
Heel Til I Die's Avatar
Pinpointed the strange noise coming from the engine in my '00 SE. It turned out to be the alternator. I guess after 250K miles and added electrical components, the stock alternator from the factory had enough.
I swapped in a new one from autozone since I had a discount. It was a Duralast Gold. Part # DLG13284. I haven't confirmed with a multimeter, but it's supposed to put out 125 amps. Hopefully, it holds up.... another 250K miles?
Old May 16, 2016 | 12:24 PM
  #2538
Bad *** Newb
Maybe 2.5k mi lol
Old May 16, 2016 | 01:50 PM
  #2539
Shifter bushing went on me. Ordered the es bushings for it. Supposed to be here today. I'm pulling it apart now.
Old May 16, 2016 | 05:32 PM
  #2540
Donkeypunch's Avatar
I thought about not every fixing anything on it again.
I did the spark plug seal last year. It's leaking again.
I did motor mounts like 2 years ago. They're broken again.....
Old May 16, 2016 | 05:34 PM
  #2541
Bad *** Newb
RTV and urethane, baby!
Old May 17, 2016 | 05:42 AM
  #2542
CMax03's Avatar
I recently replaced all the smaller P/S rubber hose sections with generic transmission hoses and cut my larger supply hose and installed an inline magnetic filter. That's between the reservior and the pump....
Old May 17, 2016 | 06:12 PM
  #2543
nestorlugo's Avatar
or
Old May 17, 2016 | 08:54 PM
  #2544
Old May 17, 2016 | 09:09 PM
  #2545
Bad *** Newb
I don't bother replacing VC gaskets (the normal type) or tube seals. I RTV all of it. No leaks
Fill motor mounts with your urethane of choice (I use window weld). I don't even remove the old rubber.
Old May 18, 2016 | 07:59 PM
  #2546
Cotozic's Avatar
I don't think I've ever been happier. Just "rolled" this thing home a couple days ago.
Old May 18, 2016 | 08:44 PM
  #2547
Your inbox is full so I'll ask here.
What do you rtv exactly? I just don't want to take the manifold off again fkn sucks.
Also, how do those window weld mounts feel?
I'm reading that window weld is hardness of 55a do you know the hardness of the ES ones like 90a or something like that?
Old May 18, 2016 | 09:02 PM
  #2548
Bad *** Newb
Normally, just the bottom of the gasket. If it looks especially shrunken/hard, then I squirt a bead in the VC groove, too, and squish the gasket back in.
As far as the tube seals, I put a bead halfway on the top lip, halfway on the side, so when you push down the VC, it squeezes in between. Afterwards, just wipe the excess out of the tube.
General info: I clean all surfaces with brake/carb clean and shop towel. Let the RTV thicken before reinstall. Only just gently place the part down to the surface and finger snug bolts. Wait for RTV to half dry (can be 2 hrs depending on temp). Fully tighten and profit?!?!
I actually made these mounts too soft for me by accident. You can vary the amount of air in them by nozzle size (it comes out really thick and ropey, so smaller nozzle leaves some air pockets). I definitely recommend to just ooze it en masse and make them solid. Regardless, they're cheap and great. I believe 1 tube of the 3M stuff will do both mounts if you dont remove the rubber (not recommended for auto mounts) and don't build an excessively thick outside layer. I sprayed a lot of carb cleaner on them and it seems to have worked. The urethane has definitely made a permanent bond.
I have ES inserts in the other maxi and loved it. It wasn't rough at all. VQ is a smooooth engine. Inserts will give you a little vibration at idle, nothing excessive by any stretch of the imagination, to me. My spec v without balance shafts is excessive LOL
IM comes off in a few minutes after you trash the brackets to the block. With an intake, it's just a few hoses and a few bolts.
This may not be the "right" way, but it's cheap and works.
Old May 18, 2016 | 09:36 PM
  #2549
ok, thanks. I'm going to order new ebay mounts and seals now.
So just the front and rear mounts break? I can't remember which ones where broken the first time.
Old May 18, 2016 | 10:09 PM
  #2550
Bad *** Newb
I've never seen a busted side mount, but there's been some reports on here. I would assume once the front and rear are made firm that no more wear will occur on the sides. I'm sure the only reason they fail is b/c of all the play the other two allow.
Probably safe to say that 95% of failures are front/rear.
Old May 19, 2016 | 12:20 PM
  #2551
maximatech12's Avatar
Originally Posted by SSJRICH
Lets hear what you did to your 5th Gen today!
I swapped in my 01 SE "carbon" tail lights from my other maxi. Also painted the front grill black (not the Nissan Logo)
Should have the new tires mounted on my 18" 350z Touring V1's today.
I'll post some pics when I get them on!
Implemented coolant bypass implemented 7.5 amp fuse to replace 15 amp fuse in engine
control 1
Old May 21, 2016 | 11:23 AM
  #2552
rvamax's Avatar
control 1
Made sure both motor mount wires were cut
Any chance you could post some pictures, I need to do this too, thanks.
Old May 21, 2016 | 11:28 AM
  #2553
rvamax's Avatar
installed carbon tailights and played around with some plastidip
Old May 22, 2016 | 10:00 AM
  #2554
BlackoutSE's Avatar
Installed my new grille (post rear ending someone which is why i needed the grill, hood is on its way) its the aftermarket black mesh
Old May 24, 2016 | 02:39 PM
  #2555
VQ35maxima=Beast's Avatar
Got my headers in finally, along with a resonated test pipe. Too raspy for me with a straight pipe, and test pipe, might go high flow cat and stock muffler with no res. we will see...
Old May 25, 2016 | 12:55 PM
  #2556
Check out my profile pics. Basically I left the small L hose underneath alone. I carefully cut off the two hoses from the water valve routing the chamber out of it all.
Old May 25, 2016 | 07:08 PM
  #2557
Took off the test pipe, guess im running right off the y-pipe for a day or two until I can get some bolt drilled out on my cat....
Old May 25, 2016 | 07:20 PM
  #2558
Bad *** Newb
.... scrap it and make some cash
Old May 26, 2016 | 05:40 PM
  #2559
The shifter bushing finally showed up today. Dang O'Reilly dropped the ball on that one. Only a week and a half late
So got them put in. Wow what a difference. So tight and precise! With the bushing trashed you couldn't tell I had a short shifter bracket installed. You can now!!!!!
Oh I washed and waxed it today too
Old May 26, 2016 | 05:41 PM
  #2560
Itz Shak's Avatar
Just put on that BOP. I don't know if it's all in my head, but I felt no loss down low, in fact it feels like it gained down there. Definitely felt the power gain up top, the rpm needle spun quicker. I'll find out later if it's all in my head.
