5th Gen: What did you do to your 5th Gen today?
yeah... i took a chance on a craigslist partout for $20. he claimed it worked prior to the engine jumping timing. i'm hoping for the best but it can't be any worse than the crap you buy at autozone/advance. i figured if/when this goes out i'll get my original rebuilt, until then i'll hope for the best. cars just under 230k miles and only sees about 3k/year. wanting to get this through 20 years
They're sealed with black ribbon but there's plenty there to reuse.
You don't need to clean it up. Just tuck any stretched out threads back in place. The ribbon material can be reused over and over.
Just remove the 8mm nuts from inside and push slowly and steadily. Don't hammer it or strike it. If it's really stiff you can push on the individual bolts, one at a time, with a piece of wood or something like that.
This would probably work better in the heat than in the cold.
Sorry this is a headache i know but Were there rubber washers that came off with the OEM tail light?
I removed mine because i was rear ended and had water leaking in.
The impact opened up a gap then rain washed the seal away.
When I removed the lights to reseal the studs looked like they had rubber washers on the studs.
I picked up a couple washers 1/16" thick and bolted these down and now a gap at the top of each tail light.
I'd just put a pinch of the excess ribbon gasket material around the base of the stud if the gasket is missing. That ribbon gasket is good stuff. I keep a roll of it on hand for several different uses. There should be enough excess though to go around the studs.
The ribbon gasket shouldn't wash away with water. It's possible someone had it apart before and cleaned it off. You can get a roll of the ribbon gasket at any parts store. A little goes long way.
pulled down some more trees
Gonna pull down some more in that pic today.
Had this car about 10 years, this thing wont die. i plan on scrapping it, the end of this year.
Oh by the way it has 5th gen wheels and a DEK engine
Gonna pull down some more in that pic today.Had this car about 10 years, this thing wont die. i plan on scrapping it, the end of this year.
Got the Edelmann HPPS hose in.
Works fine!
Sanded then primed bumper cover and now sanding it down with P220 sandpaper.
Drilled out broken studs for bumper mounting brackets.
Put 11/32 crank case hosing in and going for the 1/4" fuel injection return hose
Works fine!
First let me say, it's awesome to be back. I lost my password so couldn't get on here for quite some time. I did the website, loss ur password thing, and never got a temp password to get back on. Anyhow, it finally happened tonight and I am excited.
I have done many repairs to the Maxima, sadly it's a 2000 SE, not with a ton of miles, but age is sure coming thru. Then again, so am I ... hahaha. I replaced the alternator, starter, battery negative with a larger gauge. Ignition switch, and the IACV. All within several months of eachother. Ohh ... and cleaned the TB, everything seems to be working well, however the idle sometimes is spot on, and other times it's a little high. Mine idles right @ 750 normally. Occasionally, it's idles @ 800 in park only for a sec or two, then goes back to 750. I'm not concerned, just don't remember it being this way, no codes or anything.
I adjusted my sunroof today. Here is a my how-to on it.
https://maxima.org/forums/5th-genera...djustment.html
I thought it could've been from the 3/8" pcv line I used in place of the OE size. I also considered the 5/16" line could've been the issue.
I doubt it.
Now I'm considering it's time for a new Fuel Pump.
I started the car then shut it off pulled the plug on the MAF then restarted. It's starting but stalling out.
Just ordered the Hitachi FUP0013.
Next to nothing in big cities. ***** sellers think they're gold mines in less populated areas (200k miles, rusted, but only 2,500, what a steal). But most are trashed, so they're worth nothing.
Their value hasn't changed in years, here, even with the increasing mileage. Used car market is ****ed thanks to the **** economy (I know, TV news won't tell you how bad it is).
Cars of this age are really worth what someone will pay for them. There's such a range in condition. They run from near perfect to "don't slam the door!"
I'm about to list my stock 00 GLE. I'm going to ask somewhere between $2,500 and $3,000 for it.
It's got ZERO rust, even on the exhaust and a near perfect interior. Huge list of recently replaced parts and work. I wouldn't ask that if it were ragged out but it would take a lot more than that to have a mechanic bring one up to this condition.
After replacing this I was having issues.
The connect elbow doesn't seem like it's a firm tight connection. It's real loose and isn't square and tight on the post. I sent through a message up there to Beck Arnley about it.
I may just get the Genuine filter as a replacement or may just pull the elbow from the old filter snap a new aftermarket tab in and get submersible fuel line and just use the filter (-) the Beck Arnley elbow.
It looks like a good filter but an oversized elbow.
Replaced the driver's side axle for the 75th time. Did the full swap in 27 minutes including jacking/lowering the car.
Got the OP parts axle from ebay. Pictured, it had a vibration dampener, but the one that was delivered didn't....sigh. It does drive better than my previous axle, though, so not a complete waste.
LOL. Rough crowd out here.
Hey. I know it sounds insignificant but I knew someone that would get a new set of rugs every two years and it really kept the interior looking great. The all weather mats really help you to get more mileage out of the rugs.
Had a cold misfire with my 2000 Max GXE. Only lasted about a minute or two until it warmed a little. Only when accelerating. Didn't show a code on scan tool. Took a chance and replaced all 6 coils with about 80k miles on them. That did the trick. It wasn't too much of a gamble since I used very inexpensive coils purchase on Ebay. Perfect fit and seem to work just fine. Even if they last half as long I am still way, way ahead.
I halked up a giant loogie and spat it all over the instrument panel because for no reason whatsoever my pcm started smoking, threw a p505 idle code and now won't start at all.
I had a 1989 max best car I ever owned then bought 2001 max has been the worst car I ever owned as far as expensive problems (rust, brakes, electrical, suspension, radio lasted less than six months when I bought it new, now computer is fried) will never buy anything nissan ever again.
Did a couple of 0-60 runs using Ulysses Speedometer app GPS. Not scientific, but two way runs about 10.7 seconds. Just mashed the throttle. Kind of short of the 7 seconds it was supposed to be new.
2001 GLE Auto, running regular gas.
