Technosquare ecu DYNO....
Old 03-18-2007, 08:59 AM
  #721
aryathegreat's Avatar
Originally Posted by !PrjctMax!
Main fun thing is the 7100 redline. Holding the shifter down and then letting go so it could shift by itself...it takes a little practice so that you don't bounce the redline and bog the motor, but once you get it, 1-3 gear is
i thought it was a "myth" to be able to hold down the shifter in tip to keep it in a gear. maybe im confused about what you are saying.
aryathegreat is offline
Old 03-18-2007, 11:48 AM
  #722
!PrjctMax!'s Avatar
No, I didn't send in my AFR, but i'd assume that just an intake would be easy enough for TS to figure out the ratio.
With the "holding the gear down," you can do so, but it's only beneficial in 1-2 imo. All you do is just hold it down and when it gets around 6800 ish, you let go and then the comp shifts at around 7000...you just have to play with it and figure out the optimal points to let go so that you don't bounce the limiter and bog the motor.
!PrjctMax! is offline
Old 03-18-2007, 11:53 AM
  #723
!PrjctMax!'s Avatar
On another note....for the ones that HAVE THIS MOD
When I got the ECU swapped at the dealership, the tech was very knowledgeable on modded Maxima's because he had a 5th gen with a lot of bolt ons and such. I asked him if he would have to reflash my ECU and he said no, unless I want it I was like NO THANKS! Only thing he told me that he'd have to do is reprogram the idle because it is electronic...would doing so, screw with any of the things that TS did to the ECU...I ask because like I stated before, right now this mod is kind of a "I feel some power" mod and would like to know if he accidentally screwed something up. I still have the 7100 redline, so would that mean that he didn't screw anything up, because if he did then EVERYTHING would have gotten "erased?" That's kind of confusing, but I think you guys get my drift.
Also, when it comes down to getting 100 octane gas...would it be alright if I were to use that for a tank or so and then go back to 93, or would this cause some pinging or knocking, or something else that would make the motor act funny?
thanks!
Old 03-18-2007, 12:32 PM
  #724
shawndon's Avatar
I just wish someone could get this done and be happy with results. It seems like everbody that gets it is all excited at first then as soon as they get they're like "man is it supposed to do that???? I'm thinking that the AFC NEO or pronto's idea about unichip are sounding better because there is not alot of satifaction with this mod. (yet) maybe it will take some time but, who knows.
shawndon is offline
Old 03-18-2007, 04:38 PM
  #725
!PrjctMax!'s Avatar
maybe I'm just skeptical because I don't have enough mods and accurate AFR for TS to actually tune the ECU to my cars needs. redline at 7100 in 1st and 2nd gear is fun and when I get my NEO installed (hopefully I still do) and I get it dyno tuned, all should be well!
Old 03-18-2007, 05:39 PM
  #726
briancopeland
Nope. Works! I SMOKED my friend's turbo-charged 240SX tonight at two straight lights. He couldn't believe it! I held the shift down on the "-" and let it go when it got to the NEW rev limiter and it worked great (shifted to second by itself).
The car was running great all weekend long. Put some $7/gallon 100 octane gas in it yesterday. Ran it around all day. Fun fun. There was a 1/4 tank left tonight and then I filled up with 93 for the week. My engine light has been off for a while now. I think that it really takes a week for the ECU to "learn" what it needs to to run great.
It would be fun to do a quarter mile and see what it does. My friend's 240SX can supposedly do it in 14.6!
Old 03-18-2007, 06:01 PM
  #727
!PrjctMax!'s Avatar
so should I give my ECU a few more days before I get disappointed about it?
Old 03-18-2007, 06:09 PM
  #728
Pronto's Avatar
I don't know, with all this EMC tweaking and mods on the cars, I don't see anyone running a sub 14 yet. Once the weather breaks I'll be testing my Max out to see what a stocker can do. My guestimate is a 14.8. We'll see.
Pronto is offline
Old 03-18-2007, 06:19 PM
  #729
!PrjctMax!'s Avatar
there have been some that hit 14.4 with just an intake....deus ran a 14 flat on a humid day...and he has or had the most done to the Max out of everyone (performance wise), so he should easily hit high 13's on a nice cool day
Old 03-18-2007, 06:55 PM
  #730
niceguy's Avatar
That turbo 240 runs what a friend of mine ran in his bolt on/JWT ECU 5 speed Altima...interesting....
niceguy is offline
Old 03-18-2007, 06:56 PM
  #731
niceguy's Avatar
That turbo 240 runs what a friend of mine ran in his bolt on/JWT ECU 5 speed '93 Altima...interesting....that's a neat trick though on the auto 6th gen...
niceguy is offline
Old 03-18-2007, 07:25 PM
  #732
!PrjctMax!'s Avatar
deus has a 6spd stick
Old 03-19-2007, 08:28 AM
  #733
briancopeland
Definitely. I was pretty bummed the first few days, but now I'm very happy. What a difference a week makes!
Old 03-19-2007, 09:31 AM
  #734
Pronto's Avatar
Shouda, coulda, woulda,...know how many 400hp Honda Civics I've crushed? Until someone puts those #s up there's alot of spectulation (track time not some dyno crap) what your hard earned money is getting.
Pronto is offline
Old 03-19-2007, 09:43 AM
  #735
DeusExMaxima's Avatar
I havent run my car in the 1/4 yet. I bet its low 14's or maybe better.
DeusExMaxima is offline
Old 03-19-2007, 10:39 AM
  #736
briancopeland
I agree that something like the 1/4 mile is where "the rubber meets the road" vs. dyno's etc. (still valuable when tuning and testing). However, if the 1/4 mile was all I was after I would have bought a $23K (what I paid for my loaded '05 Maxima SL) used Pontiac GTO with an LS6 engine in it and RWD. While I would love to see my Maxima do well in the 1/4 mile, I'd RATHER take it to Road Atlanta and see how the whole upgrade package works (Engine, Suspension, Brakes, etc.)
I've seen a lot of people down on OUR Maximas on this forum, but I'm here to tell you that even with FWD, limited available mods, a fair bit of weight, our cars are VERY capable of being all-around performers. Will we ever pull an 11 sec 1/4 mile? Probably not w/o extreme upgrades. That said, our 6th Generation Maximas have the capability to perform like some of the best, 4-door, sports sedans of the same size. I'm going to keep mod'ing mine 'til my vanity license plate reads "M5KILLR" and can back it up!!!
Old 03-19-2007, 11:08 AM
  #737
shawndon's Avatar
I agree with brian. We can be performers as well I also believe that there are going to be even more parts out here for us to take advantage of just like the previous gens before ours and I cant wait.
shawndon is offline
Old 03-19-2007, 11:26 AM
  #738
Nations 1st 6th Gen Turbo
chernmax's Avatar
From stock to those of us who have modded the 6th Gen, this car is capable of anything... I'm currently a 14 runner also and maybe even high 13's under the right conditions.
chernmax is offline
Old 03-19-2007, 11:27 AM
  #739
!PrjctMax!'s Avatar
I think I mistook(is this a word? ) you for chernmax then
Old 03-19-2007, 11:32 AM
  #740
chernmax's Avatar
Dues car Rocks, if you have to make an error, i'm glad you made that one...
chernmax is offline
Old 03-19-2007, 12:35 PM
  #741
Newbie just Registered
RHMax's Avatar
Originally Posted by briancopeland
... I'm going to keep mod'ing mine 'til my vanity license plate reads "M5KILLR" and can back it up!!!
We're a long way from an M5... Maybe E28 M5.
RHMax is offline
Old 03-19-2007, 12:37 PM
  #742
briancopeland
You're right. I'll be happy to kill some M3's in the meantime!
Old 03-19-2007, 01:19 PM
  #743
shawndon's Avatar
I'm not sure if I will be able to to get one of those ECU's from car-parts.com because my car is an 06' I just bought it last June. Will I have to get a brand new ECU?? If so I will just have to rent a car or something for 3-4 days cause I quoted an ECU at the dealer and it was $890.00 that ECU better blow me for that much.
shawndon is offline
Old 03-19-2007, 01:52 PM
  #744
briancopeland
Alright. My friend with the 240SX is NOT happy. Says he had his girlfriend in the car and would have kicked my A-S-S otherwise. He's challenged me to the drag strip in Commerce, GA in two and weeks and says that 14.6 was his S-H-I-T-iest 1/4 mile time and that his best runs are more like 13.8. I love a challenge, so I'm going to forget my little budget for this NISMO Maxima project and go for it. Need the following asap:
1. Cattman Catback
2. Underdrive Pulley
3. APEXi NEO to make it run right
Anythinge else? Help me out here. It's The 6th Generation vs. The Turbocharged 2.5L 240SX. Any mod suggestions, discounts OR racing strategy suggestions appreciated! We'll video tape it and post the times, etc. Need lots of help from The Forum. Thanks in advance!!!
Old 03-19-2007, 02:09 PM
  #745
Pronto's Avatar
Brian this is what I want to see. Real time WFO. I would suggest changing your oil to Mobile1. That's worth 5 hp. Pump your rear tires up to the max load rating. Get rid of any excess junk in the trunk. Before your race check out the starting line. See which lane looks better. At my track its the tower side but check out if they're spraying track bite on one side more than the other. Before you go practice your launches so you don't spin too much. As soon as you get back to the pits open your hood to help cool down. If you want to be cooler rig a manual switch to the fan. Don't worry about the guy in the other lane, concentrate on cleaning the tires off and staging as shallow as possible. BTW what is his girlfriend, a beast? 100 lbs= .10 in the 1/4.
Pronto is offline
Old 03-19-2007, 02:18 PM
  #746
briancopeland
Real time WFO - Explain further please...
I'm running Castrol Syntech - Should be similar enough, right?
Rear tires pumped to the max - What about the front? A little low perhaps?
Pick the proper lane - check
Practices launches - check (hard with the automatic, TCS off, etc. etc.)
Hood up in between - check (keep it cool!)
Don't worry about other guy, clean tires - Spin them on the water???
Staging as shallow as possible - ???
His girlfriend is DEFINATELY A BEAST, HA, HA, HA!!!
Thanks, man!
Old 03-19-2007, 02:19 PM
  #747
Pronto's Avatar
WIDE F'n OPEN!
Roll through the burnout box just ahead of the water. Don't spin them in the water.
Before you race check the starting line to see where the electric eyes are. The first is pre-stage. Roll slow into it and stop immediately. Inch slowly as you can to just tick the staged light. That will give you maximum roll out for launch on last yellow ie; to get a hole shot. Shift at about 6900 so it won't hit the limiter on shift.
Pronto is offline
Old 03-19-2007, 02:58 PM
  #748
briancopeland
Got it. I'll watch a few more episodes of PINKS before the race too ;-)
What about my mods? They're the greatest lead time. I've got to get'em ordered and installed, etc. before the race. I was going to do the brakes next, but I'm guessing they're not really needed? What can I do to my car to get it going in the 1/4 mile? See list of mods to date below.
Will the sway bars and MMI get me anything in the quarter mile? I left them off of the original list. Perhaps it goes like this:
1. Catback exhaust
2. UD Pulley
3. APEXi NEO
4. Sway bars
5. 18" wheels and drag radials
Old 03-19-2007, 03:35 PM
  #749
!PrjctMax!'s Avatar
sway bars won't do anything, but the MMi will make the power tranfer to the wheels more efficiently, but don't add any "power"
Old 03-19-2007, 03:45 PM
  #750
briancopeland
Got it. What else?
Old 03-19-2007, 04:20 PM
  #751
dot dot dot ...
NmexMAX's Avatar
Why get a NEO, and not a VAFCII?
NmexMAX is offline
Old 03-19-2007, 05:00 PM
  #752
briancopeland
Show me where to get s SVACII and I'll buy it. They don't produce them anymore. Don't have time for eBay, so show me someone that has it in stock and I will buy it tonigth.
Just ordered my Cattman Catback. About to order my UD Pulley as soon as I very the belts that I need too. Thank!
Old 03-19-2007, 05:02 PM
  #753
SEBOY's Avatar
where you get belts from??
SEBOY is offline
Old 03-19-2007, 05:06 PM
  #754
dot dot dot ...
NmexMAX's Avatar
I just googled VAFC and found it in many places for a little more than it should cost, but at this point, it doesn't seem like money means much right now.
http://www.alamomotorsports.com/apexi/safc.html for starters.
Belts can be gotten from any local automotive stores. All you need are the correct sizes.
NmexMAX is offline
Old 03-19-2007, 05:13 PM
  #755
SEBOY's Avatar
wow it look like the last one is the best right??/
SEBOY is offline
Old 03-19-2007, 05:17 PM
  #756
briancopeland
Moved this over to a new thread. Thanks!!!!
http://forums.maxima.org/showthread.php?t=515074
Old 03-19-2007, 07:00 PM
  #757
madmik's Avatar
Only thing he told me that he'd have to do is reprogram the idle because it is electronic...would doing so, screw with any of the things that TS did to the ECU...? thanks!
The idle can be adjusted +/- 250rpm and the timing +/- 2 degrees. It does not affect the TS flash.
madmik is offline
Old 03-19-2007, 07:27 PM
  #758
briancopeland
SEGirl, I love you and swear that I won't make fun of you no more. YOU tell me where I can by an UD Pulley and the belts that are needed for my '05 and I will send you muy flowers. Roses - Promise.
Su amigo,
Brian
Old 03-19-2007, 07:39 PM
  #759
!PrjctMax!'s Avatar
super!
gigabyte
01-06-2017 06:05 PM
Omar Abdurrahman Siddiqi
08-26-2016 05:18 PM
BLACKKILA.GTR
09-29-2015 11:23 AM
Dasmith
09-23-2015 08:28 PM
QueensMAX
09-15-2015 04:14 AM
Quick Reply: Technosquare ecu DYNO....
