JWT+ Nitrous?
Old Jun 16, 2003 | 08:37 PM
SonicDust187's Avatar
JWT+ Nitrous?
I am getting my NX installed this week and later on I am thinking of adding a JWT ecu. However because the ecu adds timing and changes the air/fuel map, will this hurt my engine? What can I do to balance the advanced timing and nitrous ex: colder plugs?
Old Jun 16, 2003 | 08:47 PM
CalsonicSE's Avatar
You have a 98 Maxima, right? JWT doesn't have ecus for 97+, only for 95-96.
Old Jun 16, 2003 | 08:52 PM
I know, but you can use it in my car if the tranny and model match up. However, I will have the check engine light.
Old Jun 16, 2003 | 09:37 PM
CalsonicSE's Avatar
Well JWT does offer a ECU with an embedded nitrous program. However, that's used for their single solendoid NOS application...dunno about NX. You could call them and ask.
I'm no expert, but I would guess if you use a bigger fuel jet in your NX kit as well, as the recommended colder plugs, you SHOULD be fine. However, I definitely wouldn't wanna risk it. You may still have detonation. Advanced timing is a no-no for nitrous.
Old Jun 17, 2003 | 12:54 PM
KLoWnPR109's Avatar
The ECU advances the timing I'm pretty sure. If you are wanting the nitrous, just get the add on for the ECU
Old Jun 17, 2003 | 01:58 PM
What add on?
Old Jun 18, 2003 | 06:58 AM
xHypex's Avatar
Originally posted by SonicDust187
What add on?
http://www.jimwolftechnology.com/nitrous.htm
-hype
SmoothMax
Apr 16, 2001 06:53 PM
Cumalot
Mar 15, 2001 06:25 PM
Ramius83
Jan 5, 2001 03:31 PM
My 4DSC
Jan 4, 2001 07:21 PM
Cumalot
Nov 26, 2000 04:30 PM
