*NOOBIES* The "I am new here,but have a question" thread..(post your questions here)
Old Apr 12, 2010 | 09:50 AM
  #5161
nyc_ink's Avatar
radiator leak -_-
yes i already ordered a new one just haven't got it yet.
so i need to find a way to still use the car intill i get it.
i have a bottle of "bars stop leak with pellets" but dont know how to use it cuz the instructions are confusing as f*ck.
oh yea is it hard replacing the new radiator when i get it or should i go to a mechanic?
i replaced the bypass and the upper hose like 5 months ago and just bought the lower one. i looked under the car and the leak is on passenger side like where that skinny hose is on the radiator. it trickles down my crossmember and on my splash guard. so the leak is coming from the that lower corner of the radiator.
btw what hose is this skinny one im talking about? so i can buy a new one.
thanks
Old Apr 12, 2010 | 10:13 AM
  #5162
CapedCadaver's Avatar
Call me Wookiee Goldberg
Originally Posted by nyc_ink
radiator leak -_-
thanks
eh, i wouldn't recommend the pellets crap.. even after you change the radiator, that stuff will still be in the rest of the cooling system (block, heads, heater core, hoses, water pump)
the skinny hose on top? that's the overflow tube that allows coolant to leave and re-enter the cooling system so it can remain at a constant pressure.
the other 2 "skinny hoses" are on the bottom of the radiator, and that's for the stock transmission cooler built into the bottom of the radiator.
Old Apr 12, 2010 | 10:16 AM
  #5163
BenStoked's Avatar
Jesus was a Zombie.
radiator leak -_-
thanks
The radiator serves dual function as an engine cooler (radiator) and a trans cooler. I believe the "skinny" hose to be a trans cooler line (it's smaller in diameter than a quarter, right?), because I recall the upper and lower radiator lines being the same size. not sure where to get the trans lines at.
Old Apr 12, 2010 | 11:47 AM
  #5164
nyc_ink's Avatar
yea i poured it in my radiator like a hour ago and didnt put the pellets in then i filled the radiator with anti freeze till it over flowed and then drove it for half an hour and it hasnt leaked yet so lets see if itll hold up till my new one arrives.
yea its that one, its on the bottom of the radiator on the passenger side.
i dont think the hose is damaged but i just thought i might as well replace it since its old.
Old Apr 12, 2010 | 11:53 AM
  #5165
nyc_ink's Avatar
oh yea i had posted this before but it got skipped -__-
im thinking of changing my 2 bad injectors this weekend so i wanted to know what hoses i should replace when doing this.
Old Apr 12, 2010 | 11:55 PM
  #5166
whichever ones break during disassembly
and/or whichever ones feel or look brittle. it's a call-it-as-you-see-it type of thing.
Old Apr 13, 2010 | 06:57 PM
  #5167
newbi_maxi's Avatar
i got a 91 maxima 5spd, and it runs good and everything, but before i bought the car the previous owner said he tightened the belt on the car for me and while driving it i hear this noise like a small motoror ticking kinda...kinda like a blower but its not...i opened the hood and it was the pulleys on the belt...it doesnt look like anythings wrong with it...it doesnt look like its loose or anything...i was thinkin maybe the guy tightened it too much...but not sure...
sooo is it a big prob?
Old Apr 13, 2010 | 08:28 PM
  #5168
chrome91's Avatar
moar n00bery
previous owner of my 3rd gen did the timing bet at 380,000km in 2004, and now in 2010 its at about 420,000km. i know mileage-wise its good for quite a while, but something is sticking in my mind about the mileage or every 7 years, whichever comes first
just wondering because if it is 7 years i'll do it this year
Old Apr 13, 2010 | 08:45 PM
  #5169
BenStoked's Avatar
Jesus was a Zombie.
Originally Posted by chrome91
moar n00bery
idk about 7 years, but would believe it.
When in doubt, do it.
Old Apr 13, 2010 | 10:51 PM
  #5170
chrome91's Avatar
yeah i was thinking just do it because of the if she snapped
its ~700ish for a dealer to do right? JSmax has a card that can get 10% off if the Nissan dealership does it, timing belt is one of those things i dont trust myself in doing
Old Apr 13, 2010 | 11:02 PM
  #5171
maybe one of the idler pulleys has a worn out bearing that's clicking there's 2.. 1 for waterpump/ps, and one for a/c. or maybe your water pump itself is making noise. easy way to find out what belt is causing the noise is to disconnect them one at a time until the noise goes away (turn the car off each time obviously). and if it doesn't ever go away then it's not a problem with the belts at all.
Old Apr 14, 2010 | 10:36 AM
  #5172
nyc_ink's Avatar
lmao wtf
doesnt sound good -__-
oh yea i put the bars leak and it did nothing
went to auto zone and bought a cheaper one the guy recommended and it worked jus fine. woke up this morning and no leak. now im jus waiting for my new radiator in the mail.
oh yea when i start my car it makes a loud whining noise like a screeching, its a nasty sound. i have to step onda gas for it to go away right away. i changed all my belts and water pump 6 months ago. could it be a loose belt?
Old Apr 14, 2010 | 11:11 AM
  #5173
lmao wtf
could be. could be wet or greasy belt as well.
Old Apr 15, 2010 | 01:50 PM
  #5174
A/M/G's Avatar
what is the fuel pressure supposed to be on a 93 maxima.
thanks
A/M/G
Old Apr 15, 2010 | 07:54 PM
  #5175
Teslette's Avatar
What kind of wheels will I be able to fit on my 3.gen without hitting the strut and rubbing the fenders?
I guess I'm even able to fit 19", but at what width and ET?? I've seen that the inner clearance is pretty slim..
Old Apr 16, 2010 | 04:05 AM
  #5176
nyc_ink's Avatar
so i got my new radiator and i installed it myself. in the process some red liquid came out the two skinny hoses on the bottom of the radiator. all the f*kkin parts that hold the screws in the fan broke so now i cant screw the fan back in plus my radiator mount on the top the screw broke off so now i cant screw it in , smh, lol
2 quick questions bro.
1.what is that liquid and do i have to add more since it leaked a lil bit?
2.now that the radiator is installed, is there anything i need to do as in making air come out radiator or something?
thanks in advance
Old Apr 16, 2010 | 04:42 AM
  #5177
BenStoked's Avatar
Jesus was a Zombie.
thanks in advance
1) check your transmission fluid level; if it's low, add more.
2) pull up a steep incline (or jack your car up in the front). with the engine runing, turn heater on. open rad cap, and wait.
Old Apr 16, 2010 | 07:28 AM
  #5178
A/M/G's Avatar
I guess no one knows the fuel pressure. It appears to be a secret.
Old Apr 16, 2010 | 08:21 AM
  #5179
BenStoked's Avatar
Jesus was a Zombie.
slow your roll, bro. 12 hours may seem alot, but it isn't, really.
http://forums.maxima.org/3rd-generat...-idel-wot.html
Old Apr 16, 2010 | 11:06 AM
  #5180
nyc_ink's Avatar
FML my heater does not work lmao i know there has to be another way right? lol
Old Apr 16, 2010 | 11:17 AM
  #5181
BenStoked's Avatar
Jesus was a Zombie.
'cuase there is air in the system, still.
keep bleeding, until the heater works, and it's not burping, anymore.
then do it a little while longer.
the OG's don't seem to like it much, but I got a prestone coolant flush kit(http://www.google.com/products?q=pre...ed=0CBEQrQQwAA). I also recall autozone selling just the "T" fitting.
put it on the top heater hose, I can bleed on flat ground, just have to work the air out by shaking/massaging that heater hose (wear heavy duty gloves; welding gloves work great, if you have some), and carefully pouring water/coolant into it (usually pour the 50/50 in the radiator, and add water; it rarely ever gets 0* here, so that's fine for my area).
Old Apr 16, 2010 | 01:05 PM
  #5182
heater doesn't work as a result of replacing your radiator? or you mean the hvac controls on the dash don't work properly?
Old Apr 16, 2010 | 01:07 PM
  #5183
... yet you could find it by searching, but he could not. that or he tried searching but didn't switch it to sort by "relevancy" like the sticky says to.
Old Apr 16, 2010 | 09:43 PM
  #5184
nyc_ink's Avatar
k so i installed it and it was leakin from the radiator cap so i bought a new one and now its fine. ran it on idle for 20 mins and no overheat then again for 15 mins so im good. ill see if the heater works 2morrow but it didnt work inda winter tho.
idk man last winter i froze my a$$ off cuz the heat never worked. im thinking heater core is done maybe. idk if the AC works yet imma have to get it recharged n see if it works.
Old Apr 18, 2010 | 10:15 PM
  #5185
chrome91's Avatar
anyone know if the 4th gen Mishimoto radiator will work on a 3rd gen? longshot, but Mishimoto seems to only have 4th gen radiator
http://www.mishimoto.com/mishimoto-p...ima-95-99.html
Old Apr 19, 2010 | 04:38 PM
  #5186
DarkZ31's Avatar
Hi I have a 93 maxima that wont start. I was driving going like 10 mph then the car had all of a sudden shut off. weeks later i found out the timing belt had broke had it replaced and still no start it just putters like it wants to. thanks any thoughts would help..
Old Apr 19, 2010 | 07:09 PM
  #5187
Dapperson's Avatar
What are the essential gaskets i need to replace when changing the injectors? I got this car to flip so the easier the better. I dont want to take everything off and replace and clean when doing this. I just want to throw in some injectors and off the thing. Is it just upper and lower manifold gaskets? TIA.
Old Apr 19, 2010 | 07:56 PM
  #5188
BenStoked's Avatar
Jesus was a Zombie.
valves are probably bent
pretty much.
Old Apr 19, 2010 | 08:04 PM
  #5189
chrome91's Avatar
VG30E=interference motor=if timing belt breaks, easiest to get a new engine
Old Apr 19, 2010 | 08:05 PM
  #5190
chrome91's Avatar
and Ben i demand Supra pics
Old Apr 20, 2010 | 08:47 AM
  #5191
easiest way to find out, go to the JY and take a radiator out of a 4th gen and put it into a 3rd gen. if oem-for-oem fits.. then there's a good chance aftermarket will too.
Old Apr 20, 2010 | 08:44 PM
  #5192
Dapperson's Avatar
more silly questions about injector install but thats what this thread is for huh?
is it easier to just get a seperate fuel rail, slap in some injectors i already have so its all ready to go when i take things apart instead of pulling each one out at that point? will it save any time or effort or is that just plain stupid?
Old Apr 21, 2010 | 04:58 AM
  #5193
BenStoked's Avatar
Jesus was a Zombie.
tomato/tomoto...
not stupid, but still the same amount of work. you seem to have the injectors, not the rail, so oyu will have to get one.
Old Apr 21, 2010 | 07:54 AM
  #5194
it only helps if you are prone to breaking shiit. that way you can brake shiit to heart's content before disassembling your engine's topend. tho more often than not, the only thing that breakes is old brittle vacuum lines, and the occasional o-ring if you are doing individual-injector replacements and don't use enough lube.
Old Apr 22, 2010 | 07:49 PM
  #5195
tam403's Avatar
check this PDF. it should show all the wiring diagrams and part locations.
http://www.nicoclub.com/FSM/maxima/1994/el.pdf
Thanks for the link! I was able to fine the Time Control Unit.
Well...after calling the dealership and them wanting $285 for a new Time Control Unit, I went to the graveyard and pulled one off of a 93 SE. Same problem...Ignition circle light and dome light go off as soon as I shut the door. I was hoping the other unit was going to fix the problem. Is there something else that could be causing the problem? I have check all of my fuses. Could there be a relay or something that has gone bad?
Old Apr 23, 2010 | 08:35 AM
  #5196
kennozoo's Avatar
Hello there,
I just purchased a 1991 Nissan maxima with 107k miles.
During idle it is kind of rough, the dashboard lights are dimming and coming back, then dimming again and coming back over and over
Any ideas what is causing this?
Old Apr 23, 2010 | 09:06 AM
  #5197
eruotanen's Avatar
Could be mass flow sensor. My 94 Max had similar engine running issues, and although the diagnostic code did not indicate bad mass flow sensor, my old time Nissan mechanic said he had seen this before and by replacing he had fixed a similar problem on another Max. He would not guarantee it would fix the problem. I told him to go ahead and try it, and sure enough, it has not missed a beat since.
Old Apr 23, 2010 | 12:35 PM
  #5198
MasterJoe03's Avatar
Vg30e Vg33e swappable?
I know that the Vg33e and the Vg30e engines are swappable, although I am very curious to know how much of a process it is. I have a 1993 Nissan Maxima with the Vg30e sohc, I broke a piston . I will have to either replace the engine or get a rebuild kit. A rebuild kit would also require machineing work on virtually everything. So I have resorted to replacing the engine. Being a real man lol, I started looking around to see what engines I could swap in so while I'm replacing the broken engine I might as well replace it with more power. So how easy would it be to put a Vg33e in my 1993 Nissan Maxima??
Old Apr 23, 2010 | 12:39 PM
  #5199
BenStoked's Avatar
Jesus was a Zombie.
in theory the crank/water pump/oil pump will need swapped.
still can't find anyone who has done it, yet...
I recently asked the same question, read the thread for what the responses were
http://forums.maxima.org/3rd-generat...ap-really.html
edit: feel free to use that thread to ask more questions, or post a write-up
Old Apr 23, 2010 | 02:51 PM
  #5200
balbes's Avatar
engine lurching
Hey guys can u help me? When im driving sometimes the car will lose speed abruptly as if someone has hit the brakes... also in neutral when im pushing on the gas the power keeps dropping and going up even tho im keeping the acceleration steady.
