*NOOBIES* The "I am new here,but have a question" thread..(post your questions here)
i remember saying i like the salmon color and you said its just old *** paint
hey. i have a 91 max se. lately the car has been givin me some trouble. intermittently, the car will hesitate to accelerate from a complete stop or a slow start, then will all of a sudden take off after i jam the pedal down. also, the car seems to backfire? kind of like post ignition in the cat. converter? it only does this every few days or so and only for a little while. finally, a couple days ago the car was running a little rough and right before i pulled in my driveway the CEL came on. i checked the ecu for codes and came up with a 45 (leaking fuel injector?). i then reset the ecu and the car is running fine. i have thouroughly inspected the fuel injectors and i cannot find a leak. they all seem to be working properly as well but i ran some injector cleaner through just to be sure. i live in mohave valley, az and the average temp. around here is 110-120 degrees every day in the summer. could this have anything to do with it? the car is not overheating according to the temp gauge. also, a few months ago i took some advice from a friend and bored a few holes in the stock air box. this was supposed to increase airflow and horse power. all it really does is sound cool. could this be a problem? maybe the MAF isn't calculating the airflow correctly? these are just guesses. can anyone help me out with some solid answers? thanks in advance.
You have a injector/s leaking internally....you can't see it by visual inspection...remove each injector plug, stick a ohm/multi meter on each injector male prongs..Good injectors will read 12-14 ohms...any other reading outside of that spec would be a bad injector...
yea its done man anything is worth a try now, the previous owner didnt take care of it. so far ive replaced mostly the things dat needed to be fixed.
I have a '94 GXE but I really like the SEs. So I painted my grill and other trim pieces. I went to a junkyard and picked up some SE gauges, but sometimes the speedometer will stop reading for a second or two, or it won't read at all. The other gauges work fine, but is it just a faulty gauge or could it be because its bein used on the GXE computer instead of the SE?
I promise that cluster will work fine in your car, provided it works fine.
Can someone answer my question,
I have two codes, one is for one of my rear O2 sensors, and the other one is due to a faulty knock sensor. I have a 2001 Maxima (113k) and some people have told me that a faulty knock sensor does not trigger the check engline light, is this true? What does a knock sensor do? if i do not replace my knock sensor am i damaging my engine? how about my car in general?
Thank you guys in advance!
in the 5th gen section.
knock sensor is designed to sense detonation in the engine. if not fixed, you could get detonation (engine go "BOOM!"), not good.
run high octane gas, see if it goes away?
I have only been using v-power from shell so i probably do have to replace my knock sensor. Courtesy Nissan sells a knock sensor for $150.00. Do you have any idea how much labor will be?
I have had my car for about three years; i noticed the knock sensor code about a year ago. Strangely my SES light goes on and off but because of a poor auto mechanic i was never really aware of what was going on with my car. He would say "if it runs then go". I am no longer going to him as you can imagine.
Again do you have any idea what labor will be like? and do you think i have damaged my engine at all?
Do you think that my bad 02 sensor can have anything to do with this. Should i replace that first, since its cheaper? Sorry i am throwing a lot at you
I appreciate all of your help, thank you!
my 93' leaks, at the top corners of the windscreen water drips onto me and my passenger, is this common? will replacing the windscreen (which has a few chips anyway) and replacing the seal take care of this, or is it another seal that is broken that also needs attention? i don't have a sunroof and i don't know when the windscreen was installed or if it's factory
i'm going to get RAC insurance and take them up on their one free windscreen per year offer lol
SE (both VG and VE models) and GXE gauges are all interswappable. Only differences are whether or not there's an ABS light, or an 'OD Off" light, etc. The thing chrome is referring to is a capacitor i think, but that was mentioned for the tachometer being bouncy. Don't know if it's the same thing that normally causes the temp gauge to flake out tho, but even if it isn't, the culprit is most likely bad solder joints, which you should be able to see on the rear of the gauge if any are bad or not.
Hi, my name is Stephen and I am deaf. I am new to this so please bear with me. I owns 1991 Maxima. It has a VG30E motor, factory rims, a factory tachometer (white), pw, pl, fully loaded, sunroof, factory spoiler. <---Not sure if it is GXE or SE) The only custom is muffler. It has 190,000 miles on it. A previous owner had it installed by a custom muffler shop according to the reciept. This car has 8 reports from car fax such as sold, bought from dealership, tickets, no accident at all. I paid this car for 1,200.
Now, I am on the last straw with this car because nobody can figures out whats wrong with my car except replaces a lot of things such as tuned up, change oils, change the fuel filter. I changed air mass flow sensor myself.
I have two different problems, not sure if both are related but similar. First is when its idling, it dropped to 300-450 RPM it started to shaking especially stopped at a stop sign or red light after drive it. I have no idea whats the problem is. Sometime it does or it doesnt. It will idle fine. My step dad, brother and the mechanic guys said the motor sounds fine. No knocking or anything according to them since I can't hear. What is the right rpm when you idling? 800 or 1,000 RPM?
Now another problem which is much worse than first one. This one gives me a huge headache. Note it does randoms when it wanted to. Sometime its fine and very smooth then suddenly, it get rough and jerky very violent causing the motor to stalling then its fine. Its like its fighting to make this car go. The RPM bouncing back and forth and I was trying to give it a gas but it doesnt as I floor it..nothing then boom, it went off then stalling. I was like my god! It does that only after 2,000 RPM so I had to drive it below 2,000 RPM but it still jerky a bit. I went through 3 different mechanic shops, they cant figure it out whats wrong with it. The engine light doesnt came on except window washer fluid (orange light from left side on tachometer) I filled it up and the light is gone. My step dad, brother and the mechanic guys said the motor sounds fine. The rpm reading sometime fine, it would lose the power even I floor it, it supposed to hit 5K RPM but it doesnt. It would go to 2,000 to 3,000 RPM and the meter climbing slowly even Im on straight road.
I am very frustrating and upset with my car especially at the mechanics. I dont know what else to do but ask for your helps and advices. I would be appreciated for an answer from you guys. Thank you.
I presume the car is an auto trans; does it get to 2000 rpm no problem, and then fall flat on it's face? you say "jerky", would shaking also be accurate?
has any mechanic checked out the injectors? they are a relatively common issue.
you are right, it should rev to 6500, actually, before rev limit kicks in. does it rev fine in neutral/park?
based on the description, sounds like it is running in fail safe mode. can't remember what all causes that, but I do recall Mass air sensor being one that would.
now, about your car; are all the gauges white? mirrors flat black? tail lights black(ish), not red? NO chrome, anywhere (unless it's flaked off)? that is an SE.
idle should be about 800-1000, yes.
I dont think the mechanics have ever check the fuel injection system. (he did replaced the fuel filter, probably havent check the fuel pump yet)
You mean fuel injector or there is more than a various injectors than fuel injector?
Yes, sometime it revs fine, sometimes it shaking when I let the gas pedal go in neutral/parking.
What do you mean running fail safe mode? I did replaced the MAF sensor along with air ram and replaced the air filter as well and the mechanic guy did replace the hoses as well. Still a same result.
Last edited by Motorexskygtr32; Jul 14, 2010 at 08:03 PM. Reason: added a few more descriptions
same was happening to me. its the fuel injector. u may have a few bad ones. turn ur car on and pop ur hood ,wear gloves (thick ones) and pull ur spark plug wires on at a time but put it back tho one at a time. the ones that cause the car to feel n sound like its dying are the good injectors and the ones u pull out and the car stays the same (no affect) are ur bad injectors.
and if ur grill is the same color as the car its an SE. and if the taillights are dark and not red.
\Okay, let me clear this up...when I pull the spark plug wire at one a time, if it is dying, its a good injector. If it has no effect like motor running still, its a bad one?
For Fuel Injector, how much it cost to replace?
It is also possible to have a bad fuel pump as well?
Ah, thanks. It is definitely SE. :-)
You mean there is two different problems, Fuel Injectors and spark plug wires?
Spark plugs wires the one that connected to the spark plug and other end is distrubtor?
new ones from napa or autozone are like $110 each. used remanufactured ones are like 6 for $100 something on ebay or u can go to the classifieds here n go to 3rd gen section and sometimes ppl wreck there cars n part it out and u can them cheap from them or u can make a thread asking whos selling working ones.
im not sure bout fuel pump, i dont kno much on that
how do high beams on our cars work? cuz i have to turn my light switch all the way to the end for my headlights to turn on. i know somethings not right. i shouldnt have to click all the way for low beams -_-
There is a small clockwise **** on the end by the stick, if you turn, it will click for orange lights to turn on. Now, last click to turn again, it turn the headlights on. You are doing right for low beam lights. Now for high beam lights, you just press foward by the left stick then thats high beam lights.
If you have a fog lights, there is a small button behind of the left stick. Hope my explaination is clear to you.
i have an 89 maxima 5speed and im trying to find a cold air intake or a short ram intake.. all i can find is on a 92 n newer.. will they fit onto my 89?? this is my first import any advice is nice.. also... when i got the car i pulled the plugs and they were gaped at close to .060 the book said .044 so i regapped them and i lost some power if i slam on the gas n shift.. so i went n got the Bosch 4 plugs and still the same.. any ideas how to get that momentum back??
I rechecked my car to see how the headlights work to make sure. Now, by where the steering wheel, there is a stick on each side front of the steering wheel. I dont know what it called but on the right side of a stick is for wipers, and other side (left) is for headlight.
im a guy.
are u a chic? (cuz u put the kiss smiley) if ur a dude that is not cool
-_- lol
yea i kno u have to push the switch stick forward to get high beams but i thought like other cars one click turns on the parking lights and low beams and the second click it turns on ur high beams.
im a guy.
-_- lol
im a guy.
-_- lol
OMG, Im so sorry. I was trying to click a smiley face. Not a kissing face!
Im a guy, btw.
What size globes go in the auto mode switch that light up the P or C? or the ones that go in the push buttons like demister and dimmer? i also need ones for a digital climate control, my climate control buttons do not light up at all, only if i press them a small light comes on, but nothing else apart from the screen, i am going to buy globes today for other things so if i could get them all in it would be nice, i have never seen this kind before and if you don't know what you need the shops surely never know for you
lolyea dats gay how the light switch is, smh
Lol...yeah! Anyways, how much did it cost you to get your car fix for fuel injectors? Did you do it on your own or you sent it to the garage?
Do usually older cars like Japanese cars is harder to diagnosed with the problems in general car repair shops? Because Maxima is my second Japanese car. My first car is 94 Altima which I never had a problem for a year because I kept my Altima an updates with the car maintenances until someone rear-ended me in an accident. I was awarded for $2,000 by someone's insurance so that's how I got 91 Maxima. That's why I don't know much about it.
injectors can be expensive, some places are $600+ with labor. apparently its not the hardest to do yourself though
some older imports are bad for not throwing codes (3rd gens sometimes wont at all) but really older imports are usually simpler than all of the electronic crap on new cars. off of the top of my head, older imports can get wiring problems which can take a few hours to track down but thats it i think
One more question that I need to know how to make my car better with fuel encomy. Usually my car can takes about 250 miles per tank...I know something isnt right about that. Whats the average miles per tank?
92 accord cai will fit.
bosch sucks, get NGK. doesn't matter which, as long as it is NOT BOSCH!!
we drive jap, not euro.
Ah, I knew it gonna cost more than 600+ bucks but hopefully, I will tune it up better. Is it a good idea to take my car to Jiffy Lube for a tune up? Because it is illegal to do the oil change, etc at the apartment complex where I lives.
if you are having injector problems, that is a major factor, too.
find a big parking lot (wal-mart), throw some big card board boxes down, and change the oil there (no promises you won't get in trouble, though).
and bout the oil change do wat i do lol go to the back of the aparment complex area where its dead and no one can see n do it ther or buy wat u need from autozone n park on the side where dey cant see n do it ther too.
EDIT- DAMMIT BEN BEAT ME TO IT
well i know a mechanic whos gonna change mine for $75 but at a regular shop its a lot like $400 - $600. or u can do it urslef i made a thread dat should be a sticky on how to do it urself.
That means Im screwed because I have to replace all 6 fuel injectors??
