*NOOBIES* The "I am new here,but have a question" thread..(post your questions here)
Thanks for the advice guys. I've been workin' my *** off this week, so I'll test your theories this weekend and let you know the results. I'm leaning towards the wheels being messed up as causing the vibration. Tire pressure was off a good bit on all tires and I have three different types of tires. Putting new tires on this weekend also.
New glitch though: I just did some surgery on my shifter. I made a DIY short throw shifter by heating up the stock shifter in the oven and sliding the pivot ball up the shaft. While putting it back on my car (I haven't tried all that hard. I spent about 10 minutes this evening messing with it but the cold ran me back inside) I can't seem to get the two pieces that press the bearings (above and below the ball) together to meet back up. No matter how hard I press, they just won't come together. The bearings come together fine, but the metal plates above and below aren't cooperating. I can't understand what's forcing them apart. Any ideas?
88 VG30 to 90 Max?
Must replace motor in 90. Got a line on good motor out of 88. Conflicting info and techs that were 6 years old when car was new has me a little confused. A visual inspection brought me to conclude that I can after swapping I/E manifolds, oil pan, motor mount, add oil filter mount, and probably other, small items, it would work. Can anyone tell me if I'm on the right track? I've really got to get this car back on the road. Any help would be greatly appreciated.
amator40@yahoo.com
amator40@yahoo.com
got a quick question. ive got a '92 maxima thats been through it all (all 400,000km of its life with no major repairs), and a few days ago i tried to do a stupid tight squeeze move and i never made it and bit a curb at about 50 km/h
. i think snow took alot of impact but the car felt it. car is absolutely fine, nothing broke, but my RPM gauge is done for. it stays at 0, but occasionally it will twitch like crazy and go from 0-8 a few dozen times then stop. it ran good for a few minutes yesterday then went to 0. it ran fine before i bit the curb
its the automatic version so the RPM isnt a huge deal but i wouldnt mind getting it going again, any way to repair the RPM gauge without taking alot apart? or is it a lost cause?
. i think snow took alot of impact but the car felt it. car is absolutely fine, nothing broke, but my RPM gauge is done for. it stays at 0, but occasionally it will twitch like crazy and go from 0-8 a few dozen times then stop. it ran good for a few minutes yesterday then went to 0. it ran fine before i bit the curbits the automatic version so the RPM isnt a huge deal but i wouldnt mind getting it going again, any way to repair the RPM gauge without taking alot apart? or is it a lost cause?
fuel pump installation
Ok guys i have been outta here for a little bit . And once again i come with a little Question.
How do you put a fuel pump in a 92 maxima.
I've heard so much stuff im already confused (as the tank may have to be vacuum out or something like that ) please explain if i can do this on my own or if this vacuum thing is real and has to be done by a shop.
If i can do it explain how as if I were a three year old no fancy car talk to make this as simple as possible.Pictures will be greatly appreciated. please help i did order the fuel pump but dont know where is located on the car.
pull the back seat out, there is a metal plate in the middle. pull that off, you have access to the pump.
no vacuum stuff to worry about.
--> http://forums.maxima.org/3rd-generat...fuel-pump.html
one last question
can you switch out the rear speakers in a '92? mine worked, but they werent the best so i removed them (looks like they werent meant to be removed, it was hard) but i got them out and replaced them with some aftermarkets i picked up for $5. reconnected everything and it was a no-go. i thought maybe it was the new speakers since they were $5. a few days ago i bought some expensive **** new speakers, wired them up, and still nothing.
one last question
I have a 2001 maxima and when im driving the rpm will jump from 1 to 3 then back down to 1 and the car jerks. My acceleration could be smoother also. Can any1 help me does my maf need to be replaced or is it deeper than that.
there's a noobie thread in the 2000-2003 section.. that's where this post belongs
worst part is when i took out my stock speakers i trashed them right away. ive still got the front speakers and subwoofer in the trunk so its not a total loss. anyways, thanks for the info
dang, that sucks. my '92 is too near the end of its life to put more money like that into (399,958km today, should hit the scary 400,000 tomorrow). next car will either be a skyline or more likely a '99 maxima (or another 92 if i can find a mint one) and i'll keep my speakers for then. thanks for the info
(a skyline, you say? is that wishful thinking?)
a skyline would have been as much as a maxima, i found 2 skylines with 150,000km this month for only $5000 right hand drive, full body kit, everything, no problems. one was even a automatic. i paid about $1700 for my maxima, $1000 in audio, $500 in other stuff, $1000 in brake work (i hit a fresh cement speed bump on road work and wrecked my brakes) so that adds up to about $4200, and the skylines were even OBO
i already got a head unit (deck) installed thats aftermarket, i needed a new one to wire my subs so i got a JVC
yeah, buying one someone imported then wants to sell later is easier
A couple weeks ago i found a sick supra that was 2002 i think, and it was freshly imported from japan and was a full on ricer. it was like $15,000 though, and not a nissan
so i ordered some LED lights to go behind my gauges, the ones on the thread in the main page there, anyways, i havent been able to find a good replacement walkthrough anyone got a link to one or have some time to explain? thx
step 1-4, then there's 4 screws holding the gauge cluster in place. 3 harness clips to unhook from the back... then the 194 lights are in the larger reddish sockets.
gotta ask one last question
on 92's (and probably other year models) theres a switch near the shifter that says power and comfort. never figured out what they were for, and a few weeks ago i flipped open the owners manual and it says that power is used for aggressive driving and goes into higher RPM's. ive been wanting to try the power mode, but is it hard on a older '92 with 400,000km?
yes, i've seen it recommended as a longevity measure. Internetautomar did it on his, nc90gxe is doing it on his too ever since it was rebuilt. if you get a freshly rebuilt tranny i'd also advise taking a page from nc90gxe's book and changing the tranny fluid every 3rd oil change.
thanks for the help. i took it for a spin on the power mode and its way nicer than the regular mode, think i'll stick with it unless i get out on the highway which would be rare
if you already have an aftermarket H/U then all you need to do is wire around the amps at each speaker.
Very easy to do.
at each amp there is a 4 wire connector , it has 2 thick and 2 thinner wires. connect the 2 thinner wires to your speaker and viola' you just bypassed the amp and you are now running your speakers off your H/U
somewhere I may have described it in more detail. Though it has been a couple of years since I did it.
Sup peeps? One question and I need to know if its a problem... ok im trying to replace my headlight not the bulbs but the whole thing and the white **** ur suppose to turn does nothing how and I suppose to take it off?
you don't have to do anything with the white ****. that's an aiming thingy. just unbolt the bracket from the car, and leave the bracket on the old headlight. the new headlight should come with its own bracket anyhow
i actually was just going to ask something like this. my ultrawhite bulbs came today, do you just pull the copper bracket to get the headlight cover off?
just bulb replacement is done from the back of the headlight. On the rear of the headlight, there is a grey bulb support bracket with wires going to them, you'll need to spin the bracket (I believe counter clockwise) until it unclips, pull the headlight bulb out of the assembly and unclip the headlight and replace.
copper??? cover? what are you trying to do? remove the assembly or put bulbs in? the bulbs on 3rd gens are the easiest to change of any car i've ever worked on... pull the harness, twist yoke, old bulb out, new bulb in, put yoke back, put harness back. i'd bet a dollar that i could change both of my bulbs in 30 seconds or less.
yep, just trying to switch the bulbs. the guy who had my car before me had the same ones as always and ive never switched them yet, theyre really weak and its time for new ones
ive never switched a bulb before. lol. my headlights have a copper bracket over the headlights plastic cover thats on tight, i thought you removed that but its there good.
anyways, i'll go out with a flashlight now and see if i can find the harness
