*NOOBIES* The "I am new here,but have a question" thread..(post your questions here)
Old Feb 12, 2009 | 02:49 PM
  #2801
tresboi's Avatar
I may be mistaken, but isn't or wasn't the cefiro the j-spec maxima, although RWD with the rb20det? Same body, different drive train... I could be way off.
Edit: I am way off. It was closest to the Laurel and Skyline & was the basis for the Sylvia. Maybe next time.
Old Feb 12, 2009 | 02:52 PM
  #2802
BenStoked's Avatar
Jesus was a Zombie.
Originally Posted by tresboi
Same as a 3rd gen Maxima, correct? These might look nice...
http://cgi.ebay.com/ebaymotors/JDM-N...Q5fAccessories
no, not the same. one of the guys here sent me some sweet pics of a maxima> a31 front clip conversion, awhile back. he asked me not to show anyone, but he hasn't posted it up, so idk if he ever fully finished. but it looked good.
it took a bit of work to do, remolding the grille, hood, and some other stuff, but he did it.
Old Feb 12, 2009 | 03:29 PM
  #2803
Infam0usMax's Avatar
I checked on it to make sure and nope
Old Feb 12, 2009 | 05:13 PM
  #2804
chentwoten's Avatar
does anybody know the part # on the black metal tabs on a throwout bearing? One of mine is broken and i need a new one. Thanks.
By the way im a newbie and was wondering if i head to the nissan dealership will they be able to source me parts within a reasonable timeframe(???) I live in the bay area if that helps. I need to get the boot for the tranny and also these tabs to complete my parts.
Old Feb 12, 2009 | 06:46 PM
  #2805
300zmax's Avatar
new throw out bearing, and they might have it to you in a few day. i would use courtesy nissan . com
Old Feb 12, 2009 | 07:29 PM
  #2806
chentwoten's Avatar
no i already got a new throwout bearing.. i need the clips on the side.
Old Feb 12, 2009 | 08:42 PM
  #2807
biggz2332's Avatar
Originally Posted by 300zmax
sounds like low pressure, did you replace the fuel filter?
i hope you didnt get the paper tab in there like my buddy did on his truck, lol
Yea i changed the fuel filter two weeks ago and no the paper tab didnt get in there lol, but i could tell you that i put a propane tank around the MAFS and the engine raced up and went back to normal i recently fixed my MAFS because it had bubbles in it But what im thinkin is i need a new MAFS completly because it has never been changed. but would a bad MAFS cause a car to shut off when it starts
Old Feb 13, 2009 | 05:34 AM
  #2808
Greeny's Avatar
¯\(°_o)/¯
http://www.courtesyparts.com/30514-s...-p-183906.html
Old Feb 13, 2009 | 09:21 AM
  #2809
300zmax's Avatar
well i dont understand what you are getting at with the propane but yes it maybe the MAFS
Old Feb 13, 2009 | 11:43 AM
  #2810
internetautomar's Avatar
mod or sell?
the propane indicates a vacuum leak not a bad MAF
Old Feb 13, 2009 | 01:00 PM
  #2811
300zmax's Avatar
the propane indicates a vacuum leak....
well i never new you could do that
well i dont understand what you are getting at with the propane but you problem with the car might be contributed to the MAFS, the ECU diagnostic should show it.
Fixed
Old Feb 14, 2009 | 05:51 PM
  #2812
chentwoten's Avatar
Got my tranny out today, was a real tough one getting the axel off. The driver side axel boot broke open and peanut butter (ha ha) came out. Should I go to pick n pull and get another one in better condition or is there something i can do about it. Thanks.
Old Feb 14, 2009 | 05:53 PM
  #2813
Greeny's Avatar
¯\(°_o)/¯
Don't screw around with used axles, just get a new/reman axle/s..
Old Feb 15, 2009 | 12:57 PM
  #2814
chunkysause7's Avatar
Manual Transmission Fluid Change
Ok so i'm trying to unscrew the filler plug on my transmission but it won't buge a single bit, I used a breaker bar first didn't move a bit, and then i borrowed my friends impact gun and gave that a shot, but still won't buge. Is there a way to get this filler plug off??
Old Feb 15, 2009 | 02:04 PM
  #2815
CapedCadaver's Avatar
Call me Wookiee Goldberg
just fill it from the speed sensor hole instead.
Old Feb 15, 2009 | 03:14 PM
  #2816
g3arhead's Avatar
I NEED HELP
i have a question, i looked through the other pages and didnt find a thread on this. i am trying to figure out the name of a part. its basically under the throttle body but a lil bit toward the back of the motor. all the vacuum hoses connect to it and it has a couple of connectors on it and it has 2 black ***** on it. if someone could help me that would be great
Old Feb 15, 2009 | 04:25 PM
  #2817
Where would the sensor hole be? Do you perhaps to have a pic for that.
Old Feb 15, 2009 | 04:50 PM
  #2818
Greeny's Avatar
¯\(°_o)/¯
Valve assembly solenoid..
http://www.courtesyparts.com/maxima-...1640_1643.html
Old Feb 15, 2009 | 05:07 PM
  #2819
chentwoten's Avatar
i have a question,
for the exedy clutch kit it did not come with any clips on the throwout bearing but the ones on the throwout bearing that we took off the tranny has black metal clips that don't fit. Does the exedy clutch kit throwout bearing omit these clips?? thanks.
Old Feb 15, 2009 | 06:33 PM
  #2820
garipito22's Avatar
need some help I own a 05 max, a weird sound while driving 40 to 60 mph, then it goes away, nissan dealer are telling me is the timing chain, it that possible for a car that has all services done every time is needed?.
Old Feb 15, 2009 | 06:58 PM
  #2821
Greeny's Avatar
¯\(°_o)/¯
LOOK HERE!!----> http://forums.maxima.org/6th-generat...-2004-2008-48/
Old Feb 15, 2009 | 08:03 PM
  #2822
chrome91's Avatar
wrong gen, this is the '89-'94 section
Old Feb 16, 2009 | 11:09 AM
  #2823
300zmax's Avatar
1989-94 Maxima 11 inch 4 piston kit Max11-4
these will not fit under stock wheels, correct??
Old Feb 16, 2009 | 11:55 AM
  #2824
BenStoked's Avatar
Jesus was a Zombie.
if they do not, it would be because they are just a smidge too big. should fit fine under 16"s for sure. (just installed some 13" brakes on a prelude w/17"s and they BARELY fit see here)
Old Feb 16, 2009 | 12:00 PM
  #2825
300zmax's Avatar
wow thats tight!
ok well i want to hang on to my saw blades. arent the Z saw blades 16" or are they 15s as well?
Old Feb 16, 2009 | 12:15 PM
  #2826
BenStoked's Avatar
Jesus was a Zombie.
wow thats tight!
I believe the TT z31 had 16" but not 100% on which models that was. (you should know better than I would )
Old Feb 16, 2009 | 12:50 PM
  #2827
300zmax's Avatar
true sad to say the z i had was an 86 turbo, had if for a month then parted it. i was going to turbo my max with it but it became to costly at the time. rebuild the motor with a new turbo and jwt cams then sold it to a drifter. last year the jackass over headed the thing and F***ed it. oh well i made my money lol
Old Feb 16, 2009 | 01:13 PM
  #2828
wow thats tight!
if it uses the stock rotors, it seems like it should fit. you MIGHT have spoke clearance issues tho.. the SE (sawblade) wheels are wider with the same offset so that'll give you a few MM more spoke clearance than GXE wheels would... and the Z sawblades are 16x6.5+20 iirc. I think azurebluez has them
Old Feb 16, 2009 | 04:23 PM
  #2829
Obsession_92-94's Avatar
Are the VQ fuel injectors similar to the VE injectors? I am working on getting some refurbished ones. These have a two year; 24000 mile warranty.
Go ahead and laugh at me internetautomar...
Old Feb 16, 2009 | 04:43 PM
  #2830
BenStoked's Avatar
Jesus was a Zombie.
same part number.
Old Feb 16, 2009 | 04:52 PM
  #2831
you're still probably wasting your time with refurbished injectors... even if you get new ones for free you still have to take them off and change them and reinstall them, pray you don't mess up the o-rings, etc. if you are gonna put them on tho (i assume on a VE engine) then at least put the refurb in the front... since on a VE you can pull the front rail w/o pulling the intake.
Old Feb 16, 2009 | 05:19 PM
  #2832
same part number.
So then I would be ok to get this part then.
Well that is the problem. I have two that are out; one in front and one right behind the other. So the intake has to come off anyway.
Old Feb 16, 2009 | 06:00 PM
  #2833
well.. if you just take one good injector from the front, move it to the back, then put both refurbs in the front just to make it easier if (when) they fail. for me it doesn't matter.. i have to remove the intake no matter what. which will be soon as #4 is reading 50 ohms but you can still save yourself the trouble of pulling the intake twice (unless a rear injector fails )
Old Feb 16, 2009 | 06:25 PM
  #2834
I had one that was reading 23 and the other 112 ohms. The car was vibrating real bad with these two under 1500rpm. The other four are comfortably between 12-14 ohms. The new injectors would be a solid red color, much like the ones that were pulled?
Old Feb 16, 2009 | 06:35 PM
  #2835
Also, are the pickup screens the same between the VE and the VQ?
Old Feb 16, 2009 | 06:47 PM
  #2836
hell if i know
they say they're the same part number.. so they should go straight in. part # matching is more important than color matching.
Old Feb 16, 2009 | 07:28 PM
  #2837
chentwoten's Avatar
hey guys when mounting the clutch pedal to the car for an AT to MT swap, do i need to retain the sensors (2 electrical connectors, one for the clutch depressed, one for not)?? thanks in advance.
Old Feb 16, 2009 | 09:13 PM
  #2838
yea. wire the top one in series with the smaller connector on the brake pedal (cruise control cancel switch) and wire the bottom one from any 12v wire (i used one of the green/black wires from the harness plug that is clipped into the top of the ECU/TCU mounting bracket) and the other side, wire into the brown wire that connects into the back of the black relay that is on top of the left side of the SMJ (big wire junction behind the fuse box under the dash). On either switch, it doesn't matter which wire connects to what polarity.. all they do is complete a circuit.
then on the park/neutral switch, swap wires around until it looks like this (except i messed up. red/black, NOT yellow/black):
when i do the 5spd swap on nc90gxe's car i'm gonna make a definitive step by step writeup since although everyone always says "go search" or "look at the writeup" frankly, the 5spd swap writeup i saw kinda sucked... hard.... phasta's was far far more useful.
Old Feb 16, 2009 | 10:39 PM
  #2839
chentwoten's Avatar
alright thats awesome, thanks man. going to get that done and also wire up the other wires. tomorrow im going to work on the hydraulic clutch lines and the slave cylinder lines. for the clutch lines that go to the block what size do i need when i go to autozone?? i was thinking about using braided lines and getting new fittings to go with them i presume. thats necessary, right? also, for the slave cyl line what type of hose should i get?? thanks...
Old Feb 16, 2009 | 11:50 PM
  #2840
I just got my ride back from getting old parts out and new parts in lol in other words updated...but anyways... tonight i was wondering where would it max out at ive seen a few vids of people getting them all the way up to 125 GXE and 145 SE mine kicks back at 110 any reason why? really not a prob just wondering why it does that..
