NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting!
Old Feb 8, 2009 | 08:42 PM
  #2601
pmohr's Avatar
No more Maximas...
Originally Posted by berserkotaku45
it feels like its slowing down and i have to give it more gas
Those aren't the exact conditions.
Does the RPM change at all? Is it like a misfire?
Low speeds, high speeds? Low revs, high revs? Starting off, or when shifting?
Old Feb 8, 2009 | 08:53 PM
  #2602
riccohou's Avatar
i got a check enginelight today. got the code checked out and it was the knock sensor and a new one, EGR flow malfunction. do i need a new EGR valve, or can i just clean it?
Old Feb 8, 2009 | 08:55 PM
  #2603
pmohr's Avatar
No more Maximas...
Try cleaning the guide tube before replacing the valve.
Old Feb 8, 2009 | 09:02 PM
  #2604
riccohou's Avatar
the guide tube is which one? is it the one on the top? and how should i go about this?
Old Feb 8, 2009 | 09:03 PM
  #2605
pmohr's Avatar
No more Maximas...
It goes from the valve to the UIM.
Take it off, clean it; that's the best way.
Or you could pull the UIM and clean it while it's on the car, but that's much more of a PITA.
Old Feb 9, 2009 | 09:38 AM
  #2606
berserkotaku45's Avatar
it happens while in 1st and 2nd gear, usually when starting off. i don't really think the rpm are changing. happens at lower speeds around 5-20 mph
Old Feb 9, 2009 | 04:44 PM
  #2607
Rob_0126's Avatar
Im considering buying a 95 Maxima Auto 112k miles.
Just a little inspection, I noticed it needs a new radiator.
The CEL light is on, the guy said it's not a sensor, but something unimportant: Im gonna find out what exactly he said before I buy.
Also, Airbag light is on, and the pass. airbag cover piece looks like it's popped up a little, like someone was trying to remove it.
The valve covers have some oil residue, and the back one has more. Also just a little light residue from the timing cover.
He said he would take off the cost of the radiator, so he's asking $1800.
I test drove the car. It pulls hard and drives fantastic to me. Im amazed at how much stronger these cars feel than my 92 camry v6.
Here are the pics I got:
Heres one of where the radiator is leaking(the square raised piece edge)
Heres a few of the outside:
I hope Im not image spamming. I just wanted opinions on if I should buy, and if you all see anything bad on the engine.
thanks.
Robert
Old Feb 9, 2009 | 04:47 PM
  #2608
pmohr's Avatar
No more Maximas...
thanks.
Robert
$1800 doesn't seem to bad. Whether or not you want to spend that much on a car that's going to need a fair amount of labor hours to get back to good condition is up to you.
Find out what the CEL is on for, first. You can check the codes yourself for free, only takes 5 minutes.
Old Feb 9, 2009 | 04:54 PM
  #2609
Rob_0126's Avatar
Putting a radiator in isn't a big deal on these cars is it?
Wonder if I should take it to a nissan dealer and get them to do an inspection, for what I dont see.
Can you tell anything by the pics of the engine?
Old Feb 9, 2009 | 04:55 PM
  #2610
pmohr's Avatar
No more Maximas...
15 minute procedure, minus drain/fill/bleed.
Old Feb 9, 2009 | 05:11 PM
  #2611
Rob_0126's Avatar
What the best radiator I can get, I dont want to go cheap here.
btw, did you notice anything that will need fixing by the picks or miles?
Old Feb 9, 2009 | 05:50 PM
  #2612
pmohr's Avatar
No more Maximas...
There's a nice Koyo in the GD section.
Besides the valve cover gaskets, nothing jumps out at me.
Needs a good cleaning though, under the hood, inside, and outside.
Old Feb 9, 2009 | 05:54 PM
  #2613
ahsrunner's Avatar
Have you done a tuneup? Is it misfiring?
no i havent done a tune up but i think i will take it in for one this week. ill ask the place about misfiring. thanks for the help!
Old Feb 9, 2009 | 06:02 PM
  #2614
Rob_0126's Avatar
Ill go looksee in a bit.
So it's normal for valve cover gasket leaks on these at 112k? I know it's old, which I suppose anything this old will have gaskets go bad.
Hope the seals are holding up.
Is it a pain to pull the Intake to get the back valve cover? And reading thru threads, Id guess replacing the Knock sensor would be a good idea too?
Old Feb 9, 2009 | 06:35 PM
  #2615
wai18's Avatar
less than $2K for a max is a good deal.
Old Feb 11, 2009 | 04:50 AM
  #2616
speaking of cleaning under the hood, what would you use to do that, anything special?
also, whats the best oil to use? maybe if anyone copuld make a list of the perferred parts that are easy to change like oil, spark plugs, air filters etc. that would be awesome
Old Feb 11, 2009 | 09:08 AM
  #2617
Franco533's Avatar
Ok, where do i start.
My 99 Maxima Runs fine, but the check engine light comes on for a few weeks and goes out for a few weeks
I did the self diagnosis and got codes
0201- Ignition Signal Circuit
0707- Rear Heated 02 Sensor
0510- Points to problem with Rear Heated Sensor
This is from the Fault Light Sticky
"0201
Diagnostic Trouble Code 0201 indicates a problem with the ignition coil and power transistor. The ignition signal from the Engine Control Module is sent to and amplified by the power transistor. The power transistor turns on and off the ignition coil primary circuit. This on-off operation induces the proper high voltage in the coil secondary circuit.
The malfunction is detected when the ignition signal in the primary circuit is not entered during engine cranking or running.
The items to check include
- Harness or connectors (the ignition primary circuit is open or shorted.)
- Power transistor unit built into ignition coil
- Condenser
- Crankshaft Position Sensor (REF)
- Crankshaft Position Sensor (REF) circuit
A misfire on any individual cylinder should set a code, and a problem with the CPS should also set a code.
I would have expected to see DTC 0201 along with one of the following DTCs.
0407 - Crankshaft Position Sensor (REF)
0608 - Cylinder 1 misfire
0607 - Cylinder 2 misfire
0606 - Cylinder 3 misfire
0605 - Cylinder 4 misfire
0604 - Cylinder 5 misfire
0603 - Cylinder 6 misfire
You didn't get one of these "companion" DTCs, and that is puzzling. Maybe one of them will show up in the next few days."
But i didn't get any of these companion DTCs
Our mechanic Cleaned the Crank Shaft Sensor, before he did the car wouldn't start as quickly as it does now, is it necessary to completely change the CrankShaft Sensor?
How would i check the condenser, Harness and power transistor myself.
The rear Heated Sensor is least important, but where online can I buy a good one.
Old Feb 11, 2009 | 09:15 AM
  #2618
pmohr's Avatar
No more Maximas...
Check the FSM, it has detailed diagnostic procedures for all codes.
You can get a sensor from RockAuto, any auto parts store. I would go with an OEM style, not a universal.
Are you on the original coils? That's most likely what's causing the ignition signal code.
Old Feb 11, 2009 | 09:20 AM
  #2619
Franco533's Avatar
FSM?
We had to change a coil a couple months ago, because the car would shake when idle, but that problem is gone
Old Feb 11, 2009 | 09:25 AM
  #2620
pmohr's Avatar
No more Maximas...
FSM?
Factory Service Manual, see my sig.
And the '99s are notorious for coil failures. If they haven't all failed yet, they most likely will.
Old Feb 11, 2009 | 09:29 AM
  #2621
Franco533's Avatar
So i should just change them all now, or just ignore the light until the car actually acts up
Old Feb 11, 2009 | 09:30 AM
  #2622
pmohr's Avatar
No more Maximas...
Well you shouldn't ignore the CEL, no.
If I had a '99 with original coils, I'd consider replacing them all to be preventative maintenance.
Old Feb 11, 2009 | 10:33 AM
  #2623
98maxse5spd's Avatar
+1
Old Feb 11, 2009 | 04:13 PM
  #2624
Rob_0126's Avatar
UPDATE about CEL light:
Checked the code, it's 0707, which IIRC is the rear o2 sensor (95 max)
Sounds easy to replace, or is it?
He's replacing the radiator before I buy because I dont think the rad will make it to my house without exploding.
Old Feb 11, 2009 | 04:15 PM
  #2625
pmohr's Avatar
No more Maximas...
Correct, rear O2 - http://boredmder.com/ecucodes/index....Y1995&DTC=0707
It's no problem, take 15 minutes if it isn't rusted in place. The harness connector snaps into the body right below the driver's seat, and everything can be done from underneath. Just make sure to get some PB blaster or something.
Old Feb 11, 2009 | 04:34 PM
  #2626
Rob_0126's Avatar
How vital is this sensor? Im going to replace it, just will get to it in a few weeks when I have the time.
PB blaster for sure.
And can you make the connection under the car or do I have to pop the console in the car?
Old Feb 11, 2009 | 04:35 PM
  #2627
pmohr's Avatar
No more Maximas...
All done from underneath.
It's useless, basically. All it does is check catalyst efficiency.
Old Feb 11, 2009 | 07:09 PM
  #2628
trooplewis's Avatar
Turn on the car, turn wheels hard right, set parking brake, turn off engine.
Pop the hood, go out look down into the engine compartment on each side just behind the front wheels, and see if the CV boots are split. Real easy to see if you have the wheels cranked right. These guys have me spooked about CV joints and axles!
Old Feb 12, 2009 | 08:49 AM
  #2629
Maxterror's Avatar
Man thanks for all who have replied to my questions and others, I'm about to go out and buy a new drivers side fender for 80 $ and I also asked the places if they have rear rocker panels. But from what I heard they aren't even made after market. Does that mean I'm gonna have to make my own bcus mine are rusted.
Old Feb 12, 2009 | 09:00 AM
  #2630
pmohr's Avatar
No more Maximas...
Rocker panels? As in along the bottom of the door?
Or do you mean quarter panels?
Old Feb 12, 2009 | 09:14 AM
  #2631
Maxterror's Avatar
Some people call them either , the one section that's about 8 inches towards the end of the board going toward the rear tires
the final 8 inches or so , that's what we call rear rocker panels , you can see the line that separates it from the longer part of the board
Old Feb 12, 2009 | 09:24 AM
  #2632
pmohr's Avatar
No more Maximas...
Never seen it that bad on an A32 before. You can buy the entire left side of the car from the back of the fender up to the end of the rear door from Nissan, but not the rocker panels themselves.
Your best bet is just cutting out that entire rusted section and having a body shop weld in some new sheetmetal.
Old Feb 12, 2009 | 09:58 AM
  #2633
SrgScott's Avatar
I am looking to purchase a Nissan Consult II. When i looked on ebay, they had a few that where around 7k. And then there were a few that did not seem to be quite as.....involved....if you will. I am not suprised at the 7k price fo the "official" Consult II. But is there a computer program i could buy and just use my notebook computer, or am i stuck with the official one?
I have an OBD II scanner, but i would like a consult.
Thanks guys.
Old Feb 12, 2009 | 10:00 AM
  #2634
pmohr's Avatar
No more Maximas...
Thanks guys.
Nothing is going to do each and every thing that the CONSULT-II can do, but google for those programs.
There's ConZult, I believe that works with the A32.
Old Feb 12, 2009 | 09:00 PM
  #2635
blktalon456's Avatar
Just joined a few weeks ago. Have a question how hard is it to put a alternator on a 4th gen?
Old Feb 12, 2009 | 09:03 PM
  #2636
pmohr's Avatar
No more Maximas...
Book time is 1.9, it shouldn't really take you but an hour, hour and a half.
Old Feb 13, 2009 | 09:50 AM
  #2637
thanks pmohr. Will see what happens
Old Feb 13, 2009 | 10:25 AM
  #2638
eutecticpt's Avatar
Is there a trick to disconnecting the O2 sensor plugs? Also, is it OK to use dielectric lubricant on the O2 plugs?
Old Feb 13, 2009 | 10:27 AM
  #2639
pmohr's Avatar
No more Maximas...
Push the tab, pull apart
Although you probably have all the connectors with the slide tabs, so slide the tab in until it clicks, then pull apart.
Dielectric grease isn't really a lubricant, it's an insulator. And you don't need it.
Old Feb 13, 2009 | 04:58 PM
  #2640
Rob_0126's Avatar
Wouldn't it be good on the connectors because of condensation or water splash under the car?
As for anti-seize, can you use anti-seize on the o2 sensor threads without affecting the sensors function? I know that stuff gets all over everything if your not careful.
