NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting!
Old Mar 24, 2009 | 08:56 AM
  #3041
cvsmaxima's Avatar
Originally Posted by Rob_0126
A few posts back, Ive explained a noise, a low groan coming from my new powersteering. It is a cardone and prolly reman'd.
I talked to a mechanic, he said it's probably the way the rebuilder did the valves and is common. As long as the noise doesn't get louder, it should be ok.
But he said you could use some Lucus for ps's and it would quiet it up some.
Any experiences about doing this?
Rob;
In my experiance using Lucas (and i use it in everything) it will definatly prolong the life of whatever it is in, however as far as quieting your PS, I'm not sure how well that would work. It's likely that it could since it seems to make the fluids thicker (for lack of a better word) and it holds to moving parts better.
As far as using the Lucas PS Stop Leak (the only product that i know they have with the words "power stearing" in it) Here is a quote from LucasOil.com :
"It is 100% guaranteed or your money back. It is also totally effective in reducing slack, squeals, and hard spots in worn rack and pinions. Your results will be immediate and long lasting."
As a long time lucas customer i can only recomend that you try it. If nothing else it wont "hurt" anything.
Another product you might want to look at would be just adding a little of the normal Lucas Oil Stabaliazer instead, especialy if you dont have any leaks.
Old Mar 24, 2009 | 11:58 AM
  #3042
JoshB0809's Avatar
Ok i have a 1999 Nissan Maxima..
I wanted to know what bulbs id have to buy for my corners next to the headlights. my headlights a bright.. and then my corners have a yellow tint that come off to them.. its ugly!! what bulb do i buy so they match my headlights??
Old Mar 24, 2009 | 12:31 PM
  #3043
Rob_0126's Avatar
Originally Posted by cvsmaxima
Rob;
How much Lucas would you suggest? I don't want to put too much or too little in it.
Old Mar 24, 2009 | 12:33 PM
  #3044
Kevlo911's Avatar
Kevlo for President
1156 or 1157
Old Mar 24, 2009 | 01:07 PM
  #3045
JoshB0809's Avatar
Originally Posted by Kevlo911
1156 or 1157
Yeah I have boughten those lol.. They still come off yellow for some reason.. The lens are crystal clear
Old Mar 24, 2009 | 01:38 PM
  #3046
allensteiner21's Avatar
blue tinted bulbs will get rid of the yellow look.
Old Mar 24, 2009 | 09:30 PM
  #3047
sbecerra's Avatar
WHAT HAPPENS IF FUEL INJECTOR IS STUCK OPEN?
DOES ANY BODY KNOW WHAT HAPPENS IF FUEL INJECTOR IS STUCK OPEN?
Old Mar 24, 2009 | 09:33 PM
  #3048
pmohr's Avatar
No more Maximas...
Drop the caps, seriously.
Well it probably won't idle worth a damn, you'll be down on power, get crap MPG, and you'll end up destroying your converter.
If you're having symptoms of a problem, you'll get a much better diagnosis by posting the symptoms, not what you may think the cause is.
Old Mar 24, 2009 | 09:50 PM
  #3049
sbecerra's Avatar
My Maxima feels like a sparkplug is not working but they are all new. It also throws white smoke thru the exhaust and it smells like gas.
Old Mar 24, 2009 | 09:53 PM
  #3050
pmohr's Avatar
No more Maximas...
Any codes? Have you tested the coils or injectors?
By 'feels like a spark plug is not working', do you mean it misfires, runs rough, lacks power, what?
Old Mar 24, 2009 | 09:58 PM
  #3051
sbecerra's Avatar
Codes are P0300 & P1320
The coils are all new as well. I have not tested the fuel injectors.
Old Mar 24, 2009 | 10:01 PM
  #3052
sbecerra's Avatar
it feels like a misfire and lacks power.
Old Mar 24, 2009 | 10:02 PM
  #3053
pmohr's Avatar
No more Maximas...
Brand new or used ('new' to you)?
Testing the injectors is your next step.
Old Mar 24, 2009 | 10:03 PM
  #3054
sbecerra's Avatar
I also checked the the new sparkplugs and they seem to be wet.
Old Mar 24, 2009 | 10:05 PM
  #3055
sbecerra's Avatar
The coils are new from the dealer.
Old Mar 24, 2009 | 10:46 PM
  #3056
Leo_Koneval's Avatar
Oh, I have these blue bulbs I don't know the brand but you can find them in any Schucks store. There should be a section for regular bulbs and such and then a section for "performance" things like orange tint bulbs, blue tint bulbs, and just in case you need to know our clear corners use a 1157 bulb the ones with two nubs. The blue really shows if you do the bulb mod, where you trim off the higher nub thingy on the side of the bulb and then put it in backwards.
Old Mar 24, 2009 | 10:54 PM
  #3057
I need some advice, I have been adjusting my e-brake handle and when I first got the car, the e-brake would go up 20-30 clicks and still not stop the car, after adjusting it for the first time, it went down to about 5-15 clicks, and I could feel a strong tension in the nut when I adjusted it, and after I tried to get the clicks down even lower, the tension all of a sudden went away, and I could turn it for as much as I want to make it tighter and it won't get tougher to turn like it did before, although the lowest I could get it to was 10 clicks. I don't know if I started to turn the bolt onto the cable itself or if the thread on the nut is broken. But I can't feel any tension, and when I looked behind the rear tire I found where the cable meets the brakes but I didn't find any adjusting bolt or anything.
Should I release the bolt or just leave it alone and not try to make the handle any lower?
Sorry about the term mixup, I used the words bolt and nut in there to mean the same thing, sorry
Old Mar 25, 2009 | 12:42 AM
  #3058
MasterS's Avatar
Hi all.
Since I'm a newbee and need a small answer that I cant find. Tryed search but with no luck.
Got a -97 maxima that wont start. Just hears clicking when trying to start.
Suggestions of what to do ?
Old Mar 25, 2009 | 05:46 AM
  #3059
pmohr's Avatar
No more Maximas...
Originally Posted by MasterS
Hi all.
Have you done any of the basic diagnostics yet?
Checked the battery? Connections? Hit the starter? Tested the starter?
Did it just one day not start? Do the dash lights and everything come on, then go off when you turn the key to the start position?
Old Mar 25, 2009 | 06:35 AM
  #3060
MasterS's Avatar
Thanks for a fast respond. I see that I should put more info in here.
Checked battery, charged it and cheked the connections.
Havent tryed hitting the starter yet (Not shure on where it is..)
Havent tested the starter.
Just one day, after staying still some few days, it wouldt start.
Everything in the dashboard lights up like normal, and everything goes off when trying to start.
I have notised that the clock has reset itselv, dont know if it has something to say.
Old Mar 25, 2009 | 07:01 AM
  #3061
pmohr's Avatar
No more Maximas...
The starter is on the bellhousing, in line with the rear bank of cylinders.
If you remove the intake plumbing, it's easy to see.
You can see it here:
Old Mar 25, 2009 | 01:32 PM
  #3062
MasterS's Avatar
A small update.
Tryed with jumpercables, no start, still just clicking.
Lights in dashboard are on when strying to start the car. Clock is not resetting more and I just get a clicking sound.
Tryed tapping the starter with no luck.
Urgent need for help.
Old Mar 25, 2009 | 03:54 PM
  #3063
pmohr's Avatar
No more Maximas...
A small update.
'Tapping' won't really do anything, you've gotta be brutal with it.
Anyway, I would pull it out and bench test it (well I would try something else first, but you should just pull it).
Old Mar 25, 2009 | 05:01 PM
  #3064
A small update.
Is there anyway your alternator or starter or whatever is not getting power? When I accidentally used up all the power in my battery one day, it wouldn't start and when I did try to start it all I heard was just clicking
Old Mar 25, 2009 | 05:07 PM
  #3065
brendanschuler's Avatar
okay so im new to this.. ive looked all online but ive got a 2004 Inifiniti i35.. i just put some 20s on it but my problem is the rears are tucked nice and the fronts look like dump... i need to lower the front but dont want to touch the back.. is there any reasonably priced springs i can purchase to do so?? HELP!!
Old Mar 25, 2009 | 05:10 PM
  #3066
pmohr's Avatar
No more Maximas...
If it wasn't getting power, how would it click?
As he said above, the battery is apparently good, and he also tried to jump it.
Old Mar 25, 2009 | 05:11 PM
  #3067
pmohr's Avatar
No more Maximas...
Try posting in the correct section.
http://forums.maxima.org/5th-generat...on-thread.html
Old Mar 25, 2009 | 10:38 PM
  #3068
shanehouston's Avatar
'97 maxima SE Horn chirp
Hi all, I bought my '97 maxima about 5 years ago from a fellow i used to work with at the time. It seems that when he would come to work and use the remote to lock the doors i would hear the horn chirp. When i purchased the car it never really occurred to me until now lol that it does not do it. Seems i read somewhere that pressing the lock & unlock buttons at the same time will either able or disable this chirp and the hazard lights should flash. I have tried this however it doesn't seem to be working. The lock , unlock , panic & trunk buttons on the remote all work so i do not think its defective.. Any suggestions on getting it to work...
Also another question that i have been wondering for quite some time is the feature that rolls down the front windows with the remote. Is their a way to roll them up with the remote as well?
Old Mar 25, 2009 | 10:42 PM
  #3069
pmohr's Avatar
No more Maximas...
Originally Posted by shanehouston
Hi all, I bought my '97 maxima about 5 years ago from a fellow i used to work with at the time. It seems that when he would come to work and use the remote to lock the doors i would hear the horn chirp. When i purchased the car it never really occurred to me until now lol that it does not do it. Seems i read somewhere that pressing the lock & unlock buttons at the same time will either able or disable this chirp and the hazard lights should flash. I have tried this however it doesnt seem to be working. The lock , unlock , panic & trunk buttons on the remote all work so i do not think its defective.. Any suggestions on getting it to work...
Also another question that i have been wondering for quite some time is the feature that rolls down the front windows with the remote. Is their a way to toll them up with the remote as well?
The horn does not chirp on the factory keyless entry system. If you want an audible confirmation, http://www.vqpower.com/v2/articles.php?article_id=49
No, the factory system will not roll the windows up.
Old Mar 25, 2009 | 10:50 PM
  #3070
Thanks for posting that diagram. Im guessing that one could modify that mod by just replacing the buzzer and going straight to the horn?
Old Mar 25, 2009 | 10:53 PM
  #3071
pmohr's Avatar
No more Maximas...
There's a reason no one uses the horn.
Have you ever watched how long the hazards are on for when you lock/unlock? Now imagine the horn going off for that amount of time every single time you approached or left your vehicle.
Loud and annoying, it wouldn't be long before you changed it back to stock.
Old Mar 25, 2009 | 10:56 PM
  #3072
sounds as if im better off leaving it as is. thanks for the help..
Old Mar 26, 2009 | 02:10 AM
  #3073
Did these cars come with selective unlocking? If so how does that work?
Old Mar 26, 2009 | 09:36 AM
  #3074
Interstate78's Avatar
My 97 Max has a bad sensor, it is the sensor #1 bank 2. When I look for parts online they always refer to Left side / radiator OR right upper / Firewall side.
Anybody can help me with that?
Old Mar 26, 2009 | 09:42 AM
  #3075
pmohr's Avatar
No more Maximas...
As in 1 press for driver's door, 2nd for the rest? I don't believe so, but I haven't used the stock keyless entry for years.
A 'bad sensor' says nothing, you should specify 'oxygen sensor'.
Read the forum before posting questions, it could very well save your time.
For example, top of the first page: http://forums.maxima.org/4th-generat...2-sensors.html
Bank 1, rear bank, right bank.
Which means that bank 2 would also be referred to as the left bank or the front bank.
B2S1 is the front O2 sensor in the Y.
Old Mar 26, 2009 | 10:29 AM
  #3076
pmohr, just went have the Maxima aligned and it was brought to my attention that the 17" Arelli Q rims that have been on the car since i have owned it are warped. I guess im going to have to buy another set. Where is the best cheapest place to buy chorme rims online? I checked out tirerack.com but most all the rims listed have to much void in them for my tatse such as narrow spoke type designs.
Old Mar 26, 2009 | 10:38 AM
  #3077
pmohr's Avatar
No more Maximas...
Look around here - http://forums.maxima.org/tires-wheels-53/
But mostly just google.
Old Mar 26, 2009 | 10:40 AM
  #3078
jlockhart_715's Avatar
They do this with the factory key fob, it is 1 for driver 2 for the rest of the doors and they lock again after ~30 seconds if you don't open 1 of the doors.
Old Mar 26, 2009 | 12:35 PM
  #3079
smcgil989901's Avatar
Starting Problems
I have a question. I have a 1996 Maxima GLE. About two years ago, I had to wiggle the key to start the car. Eventually, it would not even start. I installed a ignition switch and it worked perfect. This all started about a week ago, the car would start in the morning. I sometimes could drive it to different stores and it would crank. However yesterday, I started it in the morning and drove to a store. When I got back in to start the car, it would not start. Tried wiggling the key and still no starting. Tried the battery cables, still no luck. About 6 hours later, my dad took me to get the car and it cranked right up. It seems that when it is dead cold, it will start and after starting it up, and getting hot, it will not start until it cools down. Takes about 6 hours to cool down. I hear no clicking, just the dash lights light up and the radio plays. I replaced the starter last year. What is causing this?
Old Mar 26, 2009 | 12:43 PM
  #3080
pmohr's Avatar
No more Maximas...
Not starting as in not trying to start, not firing up, which?
If it's not trying to start, have you tried starting the car in gear lever positions other than Park?
Have you tested the starter? Where did you get it from?
