5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Jan 18, 2008 | 09:25 PM
  #4681
sparatik's Avatar
Originally Posted by sparatik
I've gone through 3 defective factory Bose HUs (yes, the cut out issues), and I'm ready to move on to a better HU. Is there any way to tell if this double-din HU will fit perfectly? ...or would some modification be necessary?
Pioneer FH-P8000BT
http://www.pioneerelectronics.com/PU...ers/FH-P8000BT
that headunit is gorgeous..if you find out if it fits..lemme know
Does anyone have any experience in double-din replacement HUs?
  #4682
tav303's Avatar
I was looking at my stock intake and I saw that there was the MAF, but what is the other plug?? and where does it go onto an aftermarket intake. thanks.
Old Jan 18, 2008 | 09:48 PM
  #4683
SoonerFan's Avatar
Cletus
temp sensor
ziptied anywhere in the area
Old Jan 18, 2008 | 10:47 PM
  #4684
mikemaximus's Avatar
i have an 01 se with 90 some thousand miles and had the ses code you all speak of. took it to my local mechanic who seems trustworthy although he seems to be more of a domestic car guy. he replaced the 02 sensor and the light went off for about a week. the light comes and goes and im getting bad mileage (about 20, i used to get almost 30) i had a stalling problem last fall just before i got the 02 replaced. it fixed that problem, but the mechanic said the new code was for another 02 sensor. i've read about a million posts on here about new mafs and o2's and unhooking the maf and reprogramming the ecu, but most of them pick up after the owner had a ton of stuff replaced. im trying to avoid replacing too much. where do i start? straight to a new maf? if so, what tools are needed, and what about unhooking it and.or ecu reprogramming? or should i keep replacing 02's? basically i have seen all the suggestions, but im not sure of the order i should start with. sorry for rambling. any help is appreciated. thanks
Old Jan 19, 2008 | 09:10 AM
  #4685
tav303's Avatar
Originally Posted by soonerfan
temp sensor
so it doesn't need to be plugged into the new intake at all? my car won't throw any codes or anything if its not plugged in?
thanks
Old Jan 19, 2008 | 09:13 AM
  #4686
nebojsa_o's Avatar
thanks
Correct. Just tie it down somewhere in that area.
Old Jan 19, 2008 | 09:48 AM
  #4687
jbrooks870's Avatar
Will aftermarket headers and high flow cat create too much pressure for a stock muffler to handle?? Will back pressure be created, in which i would have to get a catback? And is there any way i can gut my stock muffler? I have 3.0 5th gen
Old Jan 19, 2008 | 01:08 PM
  #4688
kaige's Avatar
ok I have an 01 maxima 3.0 with swirl valve. The code is p1130. I have been pulling my hair out with this thing. I think I have figured it out. fingers crossed.
I have one vacuum line that goes nowhere.
there is a part called the swirl control valve control vacuum check switch. It sits on the driver side strut tower. I think my vacuum line is supposed to go there.
If anyone has this car will you please check and tell me if this thing has a vacuum line on it. i dont know how to describe it but I will try. Its small and black. It slightly resembles a pacifire. about the same size only the nipple is a bit larger. lol.
oh yeah, a couple wires come off of it and go a couple inches to a light blue wire harness.
Anyway hope someone can help.
Thanks in advance
Old Jan 19, 2008 | 02:00 PM
  #4689
tibal's Avatar
Hey all, I was planning on buying a Frankencar Intake and all of a sudden i cant get on website, or find it for sale ne where. Does anyone know where i could order or purchase one? Also, i live in Mass and do they have an actual store type thing that i could just drive to on my way to Westfield for school?! Thanks all
Old Jan 19, 2008 | 04:40 PM
  #4690
NmexMAX's Avatar
dot dot dot ...
Originally Posted by spdfreak
Why would you get the technosquare reflash? Have a dealer advance the timing using the consult II.
Read this:
http://forums.maxima.org/showpost.ph...79&postcount=6
Old Jan 19, 2008 | 04:57 PM
  #4691
SoonerFan's Avatar
Cletus
they havent made parts for maximas in years.
get a berk, its the same thing
Old Jan 19, 2008 | 04:58 PM
  #4692
SoonerFan's Avatar
Cletus
no
Old Jan 19, 2008 | 05:56 PM
  #4693
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
Originally Posted by NmexMAX
Thanks for the info, I'll definately go with the full reflash and SSIM.
Old Jan 19, 2008 | 08:15 PM
  #4694
Jcali2121's Avatar
definetly good to know
Old Jan 19, 2008 | 08:38 PM
  #4695
tibal's Avatar
THX
Thanks Sooner
Old Jan 20, 2008 | 09:09 AM
  #4696
jbrooks870's Avatar
no
Thanks man
Old Jan 20, 2008 | 09:39 AM
  #4697
jbrooks870's Avatar
Does anyone know of any catbacks that looks and is only slightly louder than stock? Thanks
Old Jan 20, 2008 | 09:43 AM
  #4698
spdfreak's Avatar
Looks like what?
Old Jan 20, 2008 | 09:45 AM
  #4699
spdfreak's Avatar
If he has an AFC, then he doesn't need the tunning. All he gets is the advanced timing and removed speed limiter.
Old Jan 20, 2008 | 10:13 AM
  #4700
machinehead131's Avatar
Cattman has dual tip but looks better than stock imo is louder as well.
Old Jan 20, 2008 | 10:30 AM
  #4701
jbrooks870's Avatar
I meant a catback that looks stock and isnt too much louder. I want to keep my car as much of a sleeper as possible and I dont like those 4 inch tip catbacks, they sound bad.
Old Jan 20, 2008 | 10:40 AM
  #4702
NmexMAX's Avatar
dot dot dot ...
Not to mention enhanced CVTC map and REAL advanced timing and a 13.0 FLAT AFR.
Old Jan 20, 2008 | 10:41 AM
  #4703
NmexMAX's Avatar
dot dot dot ...
The stock catback has been proven to support up to 250fwhp.
Old Jan 20, 2008 | 11:06 AM
  #4704
Yeah I think catback will be one of my last mods after TS F-spec reflash, SSIM, intake (GAB), headers+Y/bpipe.
I'm also curious if there are any gains to be had in the heads... I haven't seen anybody who makes aftermarket heads, but has anybody tried a P&P job + some port matching? Heads were some of the biggest gains I could get out of my GM engines and I'm suprised to see nobody touching them in the VQ35s. Seems with the increased rev limiter from the TS reflash, some slightly more agressive cams (maybe even stock cams out of the new model Z/G35s that are rated at 306hp?) and headwork could make for a nice topend increase.
Old Jan 20, 2008 | 11:12 AM
  #4705
JavY's Avatar
Need Help... iam installing my DDE's at this moment. When i powered them up they all turned on perfectly fine except one of them. Its lighting up all purple. Is this a defect ?? i already checked all the wiring and everything is fine ??
Old Jan 20, 2008 | 11:13 AM
  #4706
spdfreak's Avatar
I forgot about the CVCT. If you want to supply some links about REAL advanced timing, that would be appreciated.
Old Jan 20, 2008 | 11:16 AM
  #4707
spdfreak's Avatar
Is the car on and running? I have seen a car with aftermarket HID's light up purple because the battery wasn't fully charged.
Old Jan 20, 2008 | 11:19 AM
  #4708
JavY's Avatar
yess it is. the thing is that before i put them on the headlights, i just connected them to my battery to see if they were working. and it was white with just a little bit of purple but now the whole thing is purple.
Old Jan 20, 2008 | 11:23 AM
  #4709
NmexMAX's Avatar
dot dot dot ...
It’s in the link I posted for you earlier, I’ve monitored it for myself.
Get some HR heads and some aftermarket cams, with some rev insurance and be done.
Old Jan 21, 2008 | 07:46 AM
  #4710
phatboislim's Avatar
Originally Posted by UConnJack
So you feel the use of 87 could be causing misfires and/or the P1320 general ignition code? Or do you just think it may be causing the rough ride? I just ask because I am hestiant to drive it through 2 tanks of gas if there is a misfiring cylinder, as I can't imagine that would be good for the engine?
Thanks.
PBS recommendation: use what the factory recommends as octane gas and it could solve your issue at hand
Old Jan 21, 2008 | 03:06 PM
  #4711
Scottwax's Avatar
That's Mr. Detail to you
You can get a muffler shop to mandrel bend a new B-pipe and use a Walker Quiet Flow muffler. I heard them on an Impala SS and it was barely louder than stock. I don't know if there is a dual tip version though.
Old Jan 21, 2008 | 03:08 PM
  #4712
Scottwax's Avatar
http://forums.maxima.org/showthread.php?t=551360
...Anyway, about the heads, I had them professionally ported by my machinist that has recently retired, nothing but top notch work from him. I had him clean up the intake ports and do some bowl work. The intake split is knife edged. Exhaust ports were also cleaned up and polished.
While he was in there he installed the JWT valve springs and shims.
All of the lifters/cam buckets are the correct height for a cold lash of .010-.013" with the C2 cams.
Cams themselves are 261/261 duration, and have .456"/.456" (11.5824mm) lift
http://www.jimwolftechnology.com/cus...asp?PartID=461
I would be lookinng for ~$2000 shipped for these guys..
Old Jan 22, 2008 | 01:37 AM
  #4713
Frigo's Avatar
How do I get the maxima and the GLE logo off while keeping them in tact. Also are there holes behind the lettering or are they just gluded on? Also I was wondering the same for the Nissan logo.
  #4714
Frigo's Avatar
How do I get the maxima and the GLE logo off while keeping them in tact. Also are there holes behind the lettering or are they just gluded on? Also I was wondering the same for the Nissan logo..
Old Jan 22, 2008 | 06:58 AM
  #4715
Scottwax's Avatar
In tact?
It's one word, not two. Means something entirely different when you make it two words.
You need a heat gun or hair dryer and fishing line. Heat the letters up with the heat gun, then run the fishing line as close to the trunk lid as possible, behind the adhesive on the letters. Then you will need to use a paint safe adhesive remover (3M makes a good one) to remove any adhesive that doesn't come off with the letters. Then polish and wax the area. The letters don't have holes behind them but the Nissan logo does. Unless you plan on filling the holes and repainting the area, leave the logo in place.
On my own car, I removed "Maxima" but left the "SE" there:
Old Jan 22, 2008 | 10:21 AM
  #4716
smv77's Avatar
I have a 2002 SE with low profile tires on it that handle like crap in anything other than dry pavement. Which is ok for me, that is why I have them. But I want to purchase another set of rims so I can one set for winter and one set for the rest of the year. My problem is I dont know what rims I can put on. Can I use rims from GE's, GLE's etc. from older or newer models? I have 17x7 rims. Can someone help me?
Old Jan 22, 2008 | 10:29 AM
  #4717
spdfreak's Avatar
Read here.
Old Jan 22, 2008 | 10:43 AM
  #4718
MikeyC1027's Avatar
I'm looking at converting the fogs on my 02 to HID. What size bulbs should i be looking for? H3, H3c, or D2R? I've heard all three when people have been talking about the 5.5 gen.
Old Jan 22, 2008 | 11:30 AM
  #4719
smv77's Avatar
Read here.
How do I find my offset?
Old Jan 22, 2008 | 11:42 AM
  #4720
smv77's Avatar
I went to the read hear and I couldn't find all I needed. Maybe I should get some more info and come back tomorrow. I dont want to go with a smaller or larger rims size due to the fact that it will mess with my speedometer.
