5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Dec 8, 2006 | 04:31 PM
  #681
tancythor's Avatar
Valve adjustment 2001?
Has anyone done a valve adjustment via the shims? Or has anybody paid a dealer to do it? My 2001 3.0 DOHC has 110k on it and is ticking slighlty (but enough to warrant attention). I do not have the special tool for depressing the valve lifter like it says in the manual and do not have a dial caliper to measure the shims. What have others done? I called my dealer and they said they were hydraulic and could not be adjusted...lol..that tells me that I certainly wont let them work on it...if they do not know about the shims... I was Aircraft Mechanic for 20 years in the Air Force so atleast I know how to read...lol
How much has it costs to have a valve adjustment?..if any of you paid to get it done?
Old Dec 8, 2006 | 06:24 PM
  #682
Memphis2k1's Avatar
Can Someone find me the part number for an AE Shift ****.
Old Dec 10, 2006 | 07:07 AM
  #683
ChadSpeed's Avatar
Originally Posted by Daniel514bama
My car is behaving just like it's having the VTC problems found on 3rd gen maximas.
http://forums.maxima.org/showthread.php?t=491753
http://forums.maxima.org/showthread.php?t=407923
On cold starts I get clacking and this morning it was down right scary (30 degrees). Sounded like my valve train was coming apart, then as it warmed up it went from heavy to light pinging and then cleared up altogether.
Other symptoms:
Before it got this bad it used to howl a little on cold starts until warmed up. Last year my starter died and was replaced. This year the new starter is beginning to grind on cold mornings like this morning. Could this be high compression left over from advanced timing when the engine was warm? Also I had some moderate pinging this summer when engine got warm so I replaced MAF sensor which seemed to help, but perhaps the cooler weather fooled me to think it got better
Any ideas are appreciated. Thanks
2000 Maxima w/110Kmiles
I had the same problem last winter. I do all my own maintence and the dealer said it was from me not using a oil filter with a antidrain back valve. I started using Mobil1 $8 filter with antidrain back valve and have had no more noise this winter, its been 9 degrees outside and no noise when starting.
Old Dec 10, 2006 | 10:20 AM
  #684
Staticmax's Avatar
ok I got a problem... I bought a 02 maxima SE in march never had a problem yet awesome car now Monday i had my belts changed and Tuesday I put an Berk intake on it now i hear a mild grinding when I'm driving between 1,600- 2,200 rpms but it doesn't make a noise when I'm accelerating though those rpms. The noise is coming front the front of the car. Can anyone help me?
Old Dec 10, 2006 | 07:13 PM
  #685
Daniel514bama's Avatar
Thanks Chad, I'll go ahead and try the Mobil filter.
Old Dec 10, 2006 | 07:38 PM
  #686
gephelps's Avatar
My 03' Maxima SE is making a funky rotten egg like smell, after hard acceleration. I have smelled when other Japanese cars have passed me on a 2lane. Our Maxima eats about a quart of oil per oil change, no leaks though. Any possibilites would be great, thanks.
Rotten eggs sounds like cats to me.
Old Dec 10, 2006 | 09:22 PM
  #687
DragdMax's Avatar
can i swap my 2000 maxima leather interior into my 2002 maxima? super newb question but answer would be very much appreciated.....
Old Dec 10, 2006 | 09:24 PM
  #688
SEmy2K2go's Avatar
Go BUCKS!!!
Yes, you should have no issue swapping the interior.
Old Dec 10, 2006 | 09:34 PM
  #689
DragdMax's Avatar
thanks you very much se2k2. will i have a problem with my dashboard and side panels? my 2000 is all black and my 2k2 is all beige? again sorry for the newbiness i just wantthe best for my car.
Old Dec 10, 2006 | 09:42 PM
  #690
SEmy2K2go's Avatar
Go BUCKS!!!
Oh, didn't realize you were talking about the dashboard and all. Why would you want to put older pieces in there just to change the color? I'd just dye the dash and misc other pieces and swap seats and door panels. You're going to spend a lot of money doing the whole entire interior.
Old Dec 10, 2006 | 09:51 PM
  #691
DragdMax's Avatar
again se3k3 you have fallowed through. so the seats should be no problem i should just dye the rest. great. could i go to a local car shop and do the dying or is there a certain time or place that takes care of this. and im sorry one q, will the power seats work?
Old Dec 10, 2006 | 11:23 PM
  #692
AceofSpds's Avatar
wat
power seats should work
Old Dec 11, 2006 | 09:24 AM
  #693
DragdMax's Avatar
thanks chops. so i believe ill try to get the ball rollin on this...
Old Dec 11, 2006 | 09:46 AM
  #694
westchamp24's Avatar
Noises After Strut Replacement
Yesterday, I replaced all 4 stock struts with Tokico Blues. After I picked the car up from being aligned, I started noticing a noise coming from the rear passenger side wheel area when I went over bumps. The knock sounds similar to the trunk lid not being shut, and the resultant noise when you hit a bump. The knock occurs on the rear ends way back to the ground after a bump. It isn't particularly loud, or terrible sounding, but it definitely was not an issue before the change.
Are noises like this common after struts are replaced? If not, what is the most likely culprit - the bump stop, strut mount...etc. I realize I should have replaced all this yesterday, but the strut kits weren't in stock, and the OE looked to be in fine shape.
Any insight would be greatly appreciated.
Old Dec 11, 2006 | 11:36 AM
  #695
Staticmax's Avatar
Can anyone help me? I have been getting a grinding noise but i've noticed that it only happens in second gear the noise comes from the front of the car mostly between 1,500 - 2,500 rpms just had my belts done and a berk intake thrown on there a week ago could the noise be my clutch? i have a automatic 02 SE by the way thanks for the help.
Old Dec 11, 2006 | 07:22 PM
  #696
myke321's Avatar
HIDs on 2002's?
I'm thinking of buying a 2002 Maxima(trading in my 96SE). I have one Question, How are the HIDs on the 2002? Is the beam patten good? The car being a 2002, are the HID bulbs ready to blow? Do they light up the road comparable to german car?(well almost?)
Thanks.
Old Dec 11, 2006 | 07:37 PM
  #697
oldmanshirt's Avatar
Thanks.
I just had a bulb blow on mine (at 75k mi), and not only did it leave shards of glass inside the headlamp housing, it scalded the top part of the reflector. So in retrospect it's probably wise to swap out the bulbs.
To answer your other question, IMHO the HIDs are very good on dark roads, but if the road is well-lit you might not notice much improvement from a good set of halogens. The way they throw light on the road results in kind of a jagged edge on the sides, with an abrupt cut-off at the front. That seems to be a fundamental flaw with the open reflector headlights versus projectors, which have a much smoother pattern and more coverage (saw an '05/'06 LS430 the other night with projectors that lit up the road about 30 feet to either side). So compared to most German cars, these probably aren't as good. But they definitely look nice and high-end from the outside of the car, which is probably their main appeal to most people.
Old Dec 12, 2006 | 03:27 PM
  #698
MaReK 1R's Avatar
ohh yeaa
im having problems with my trnny can anyone help me..???:
Old Dec 12, 2006 | 08:04 PM
  #699
Staticmax's Avatar
how do you know its the tranny?
Old Dec 13, 2006 | 12:07 AM
  #700
YungmaxiOwna21's Avatar
Newb with Newbie questions...
First of all, thx for the thought of somewhere where newbs can get some help..
My first question is does anybody know where or how i can come across some leather seats for my '00 Maxi Se and will 2003 and older (2001-2003)model seats fit my '00?
Second, can anyone with experience with this shed some light on it for me... I REALLY want a sunroof installed in my Max. I've heard/seen nothing good on this especially aftermarket, on these cars. Wat options are left or should i jus 4get the sunroof? Thx
P.s. - I reside in Georgia & im willing to travel for good, quality service!!
Old Dec 13, 2006 | 07:17 PM
  #701
Fox_90's Avatar
Shakin,Rattlin and Rolling
Just a couple of quick ones, in the rear clunking at lower speeds sounds like the strut towers, wondering if this is a common problem. Secondly I have a vibration between 90-120km and the tires have been checked mulitple times, C.P.R on the brakes all around and all is well? Any ideas? Again could this come back to the struts? Lastly how do I get the privledges to participate in the regular forum? Thanks to all that answer
Fox
Old Dec 14, 2006 | 08:06 AM
  #702
I'm interested in installing Hawk brake pads (either ceramic or HPS), but since I have extremely limited experience doing brake work, I wanted to have a trusted mechanic do the work. The only one I know wants $105 to change the pads and machine the rotors (this doesn't include the price of the pads). As far as I know, both my rotors and the pads I've been using are stock.
My question is, do the rotors really need to be machined, or is he just trying to get more money? My car has 76k miles on it, but I've only had it since 61k and I've only been moderately hard on the brakes in that time. There is a pulsing sometimes on longer stops from speeds of about 55+ mph, but a few ppl on here have said it might be a buildup of pad material. If all I need to do is change the pads, then I'd rather do it myself. But should I also get the rotors machined like this guy says?
Old Dec 14, 2006 | 08:25 AM
  #703
myke321's Avatar
Thanks. Do you have any pics the cutoff/beam pattern?
Old Dec 14, 2006 | 01:04 PM
  #704
Quick CV Axle Question
Time to change cv axles on my auto 2000 max. With no leaking from tranny axle seal, should I be concerned with causing a leak? Should I go ahead and replace these seals if they are okay since I'm already there? Thanks.
Old Dec 14, 2006 | 02:34 PM
  #705
Memphis2k1's Avatar
I hate doing this but BUMP! Anybody? Is the shift ****/level the called the same as a Shift Boot? Everythingnissan.com has a shift boot for: 20th anniversary - 2000-02 - 2000-022001 $139.15 $104.36
Its in the collison catolog. Under console - center console - shift boot - 20th Anniversary.
Any ideas? Thx
Old Dec 14, 2006 | 02:39 PM
  #706
bjr's Avatar
bjr
I was wondering where guys get there yellow fog light bulbs/covers. Thanks.
Old Dec 14, 2006 | 03:33 PM
  #707
GigEmAgs07's Avatar
what is the benefit of slotted rotors? found a set on craigslist for 40 bones.
Old Dec 14, 2006 | 05:03 PM
  #708
Fog Lamps
Any1 with instrutions on changing fog lamp bulbs?
Old Dec 14, 2006 | 09:29 PM
  #709
Has anybody tried these fog housings for a 5.5 gen?
http://cgi.ebay.com/ebaymotors/02-03...QQcmdZViewItem
Old Dec 14, 2006 | 10:50 PM
  #710
MadAlex2002's Avatar
Originally Posted by phenryiv1
Credit to Semy2k2go & phenryiv1:
This thread is for the new members so that they are able to post a question. It can be ANYTHING that is 5th generation related. If we think it is important, we will either answer or make it into its own thread. If not, we will delete it. ....
OK, second time this has happened:
- Engine stalled accelerating out of a turn at a stop light (first time was accelerating away from a stop light)
- Check Engine Soon light came on and is still on
- Car still starts, but only after ~ 10 seconds
- Tach is dead (at 0) regardless of throttle, speedo and other instruments OK
- Can sorta feel it missing at low throttle
Last time it happened the problem cleared itself (tach came back to life, start problems went away) after ~ a tank of gas, so I suspected a bad tank of gas (used a bottle of fuel system cleaner and filled up next tankful at an Exxon rather than a Sheetz). My last fill-up was at a 7-11/Citgo, and am at ~ 3/4-tank now.
Both times it happened, weather was "wet" in the AM - light rain last time but in the summer (was sunny when it stalled in PM), very foggy this time, but partly sunny in late AM when it stalled - so I'm also wondering if it might be intermittent electrical.
Old Dec 15, 2006 | 07:57 AM
  #711
clayman88's Avatar
Check the 5th Gen How-To's Sticky for a bunch of stuff like this...
http://forums.maxima.org/showthread....427#post275427
http://forums.maxima.org/showthread....18#post1610118
Old Dec 15, 2006 | 08:02 AM
  #712
clayman88's Avatar
Check out these links for some good reading:
http://forums.maxima.org/showthread.php?threadid=124860
http://forums.maxima.org/showthread.php?t=477415
Hopefully that will answer most of your questions..at least it did for me.
Old Dec 15, 2006 | 01:20 PM
  #713
NmexMAX's Avatar
dot dot dot ...
First place to strt would be to get the code that set off the SES light.
Old Dec 15, 2006 | 03:53 PM
  #714
Will do, but will try to kill two birds with one stone .... Since I've had the battery for over 3 years now (since I bought the car, used, in July 2003) I'm gonna take the car to a shop for a new battery (and electrical system check) and have them pull the code(s) before and after.
[ My previous car ('94 SHO) had some flakey behavior late in its life that went away when I put a new, quality battery in it - might as well do something simple for the Max that's likely needed anyway. ]
Old Dec 15, 2006 | 04:43 PM
  #715
Thanks.
Gotta say, I bought a used 2002 SE after owning a '94 SHO, and the difference in the headlights was literally night and day to me the first time I drove the Max at night. I have been doing a lot of night commuting (40 miles every AM) to try and avoid the Northern Virginia traffic, and the HIDs give me a vastly increased sense of safety compared to the SHO - far better pattern, brightness and consistency (AFAIC, the SHO was pretty much unsafe to drive at highway speed on a clear night, and downright scary in other weather conditions).
Old Dec 15, 2006 | 05:24 PM
  #716
knave's Avatar
Newbie here... I bought a MAF adapter for a cone intake (I plan to get a K&N) off ebay, it's the black plastic kind with a little rubber gasket. Is there a writeup on this? I didn't check first, but now that I look, there's an awful lot of crap going on in the intake on the 5th gen. What do all those things do?
Edit: This is a stock 2001 SE.
  #717
GigEmAgs07's Avatar
i have found a fstb for a '98 maxima online. custommaxima.org is kinda vague about whether or not it will fit in a 2k. Will a '98 fstb fit on my 2k?
Old Dec 15, 2006 | 06:53 PM
  #718
El Gabito's Avatar
I'm not exactly new here, but don't feel like starting a new thread. I know I saw a thread a long time ago (when the search was free) with a write-up of an OEM LSD install in a RS6F51A trans (02 max). If anybody could help I'd appreciate it.
Old Dec 15, 2006 | 08:56 PM
  #719
I do, but they're on another computer and I wouldn't be able to post them for about two weeks. Sorry.
Old Dec 16, 2006 | 06:18 PM
  #720
tancythor's Avatar
Star Here
It really is a simple part to change..just go to a part store and take a peek at one of the repair manuals..disconnect the connector...remove the clamp that holds it on the air duct ...remove the four bolts that attach it to the filter housing...thats about it.
You also can read through the posts at http://forums.maxima.org/showthread.php?t=398513
