5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Apr 14, 2009 | 03:31 PM
  #8281
LUIS PEREZ's Avatar
QUESTION I NEED DROP SPRINGS DOES ANY ONE HAVE A SET THEY WANT TO SELL I NEED IT FOR A 96 I30 BUT WAS TOLD THAT THE MAXIMA ONE ARE THE SAME...
IF SOME ONE HAS THEM AND ARE IN NEW YORK AREA JUST PM ME
ALSO IM NEW HERE AND DONT KNOW TO MUCH WIT CHECKING STUFF BUT MY PMS SO IF HAVE ANY INFO JUST PM ME...THANK YOU ALL HELP OR INFO WILL HELP........
Old Apr 14, 2009 | 03:36 PM
  #8282
pmohr's Avatar
No more Maximas...
First, seriously, drop the caps. No need to yell.
Second, '96 or '98? Your profile says '98.
Third, you're in the wrong section. 96-99 I30 is the A32 chassis, same as the 4th gen Maxima.
Old Apr 14, 2009 | 08:52 PM
  #8283
maxima dude's Avatar
i got many questions
1. when crusing and i shift into 4th ...the 4th gear will vibrate very slightly...wut can that be?
2. why doesnt nismo make cold air intakes for 02-03 maximas?
3.does the glx or gle all red taillights fit on a 02?
4.when driving at highway speeds and braking the car shakes and sounds like im going on those lil grooves thats on the side on the highway to wake you up...i think warped rotors?
5. is their a huge differnce in performance or anything else with having hlsd and not having it? i kno both wheels dont spin without hlsd ...
this is a 2002 maxima se 6speed
Old Apr 14, 2009 | 09:00 PM
  #8284
pmohr's Avatar
No more Maximas...
  1. The shifter? The car? When shifting into, or when 'cruising' in 4th?
  2. Why would they? There isn't much aftermarket support for the Maxima, much less Nismo.
  3. You didn't search, did you? I found it on the first page of search results. And what is a 'GLX'?
  4. It's possible, yes. When's the last time you did brakes?
  5. In a straight line? Going around turns? And who said that both wheels wouldn't spin without HLSD? That's completely incorrect.
Old Apr 14, 2009 | 09:07 PM
  #8285
the 4th gear problem...everything is fine i can shift into 4th fine....just when its in 4th and i let go of the gas to cruise is starts to vibrate only in that gear..jus the shifter vibs...its weird
2.idk nismo makes a cold air intake 04-06 maxs
3.sry didnt mean glx lol i was thinkin glx but relized it was gle did a typo..
4.jus got the car...has 50k on it orginal...so i gotta check the brakes prolly tomorrow
5.idk i thought without hlsd only one wheel spins until fluid heats up in the tranny to make the other wheel spin? if im wrong plez correct me on this whole hlsd and non hlsd thing
Old Apr 14, 2009 | 09:25 PM
  #8286
pmohr's Avatar
No more Maximas...
HLSD uses nothing but mechanical force, not fluid.
VLSD uses a viscous fluid coupling, but the statement is also incorrect for that.
An open diff can easily spin both tires, you in no way need a limited slip for that. Of course, there's no real point in doing so, but that's a different topic.
You can generally get on it a lot more through corners with a limited slip diff, and off the line traction will be somewhat increased.
Unless you're constantly fighting traction problems, or you've got the spare cash to spend, I wouldn't go for an HLSD trans 'just because'. Unless of course you were buying a new trans and there was a negligible price difference between the two.
FWIW you can get the HLSD unit from Nissan separately, but it's about the price of a used 6MT:
38411-8U010, $562.71 each at Courtesy.
Old Apr 14, 2009 | 09:37 PM
  #8287
ok ima keep my non hlsd lol thanks for summing that up....anything you think about that 4th gear vib?
Old Apr 15, 2009 | 01:19 AM
  #8288
kpmikey808's Avatar
any suggestions or good lowering springs? had ground control coilovers with tokico shocks but it was so bumpy and the front would always hit on bumps or potholes- have H and R springs now but do not like the drop
Old Apr 15, 2009 | 10:23 AM
  #8289
Teddie18's Avatar
Search the Suspension thread.
Old Apr 15, 2009 | 12:07 PM
  #8290
ice32's Avatar
anyone have opinions on quality between the generations? ive heard the maximas made outside of japan arent as good as the others.
Old Apr 15, 2009 | 03:19 PM
  #8291
Progress's Avatar
It's business time.
All 5th gens and below were made in Japan. If you heard that 6th gens aren't as good as 5th gens you won't get many people to argue otherwise here.
Old Apr 15, 2009 | 04:17 PM
  #8292
SuperStasiu's Avatar
Quick question:
Are 4th gen axles same as 5th gen ones?
I have a 01 with abs and traction control
Old Apr 15, 2009 | 04:19 PM
  #8293
pmohr's Avatar
No more Maximas...
Originally Posted by SuperStasiu
Quick question:
Assuming you match up the side/ABS/VLSD/trans, then yes.
Old Apr 15, 2009 | 04:56 PM
  #8294
arcueda's Avatar
mayb a dumb question
but IYO whats the best racing chip
wanna do some engine work to gain hp
kinda new around cars
PM me if u care thanks
Old Apr 15, 2009 | 04:59 PM
  #8295
pmohr's Avatar
No more Maximas...
There are no 'racing chips' for the A33.
Unless you mean a modified ECU, or a reflash?
In that case, you need to search. Everything you could possibly want to know about them has been covered time and time again.
Old Apr 15, 2009 | 06:21 PM
  #8296
IHAVEA2KMAXIMA's Avatar
Originally Posted by IHAVEA2KMAXIMA
I have a question regarding my coils.
CEL came on, so I took it to dealership and I was told it was for p0420 and p1320. They told me to get my software updated which can possibly get rid of the p0420. I agreed and they reset the CEL after the update. No light still after 300miles of driving. My question is if my ignition coils are still bad? That was the first time I ever got the p1320. I just hit 100k last week. Is it a good time to change the coils out or just wait till they crap out?
bump
Also... how hard is it to change out my engine mounts? Dealership also commented on my work order that "lower engine mounts broken" and "upper engine mount sagging".
Old Apr 16, 2009 | 12:39 PM
  #8297
Subternal's Avatar
To rebuild or not to rebuild...
So I have an 02' with 130k miles, that has massive oil consumption issues (1qt every 500miles). The car is completely stock and has never even seen 4.5k RPM's. From doing searches on here I have somewhat confirmed my suspicions of bad/faulty rings. My car is also well out of warranty so getting a replacement is not gonna happen for free (from nissan). So my next step I guess is to rebuild an or the engine using aftermarket parts.
1)So from other people point of view, am I looking at this wrong?
2) is there a better alternative?
I hesitate to buy another used engine for fear of the same issue's.
3) If I did go the rebuild route could I use a block from a 350z? as long as it is a VQ35DE?
Last question...Are there any specifics that I should replace when I or if I do this rebuild other than the obvious rings, piston, gaskets?
Old Apr 16, 2009 | 12:43 PM
  #8298
pmohr's Avatar
No more Maximas...
No, you can't use the Z33 engine. Nor the V35, nor the Pathfinder...
You can't use the RWD engine for a FWD car.
Rebuild is going to cost you a fair amount, if you're having a shop do it. Between shop labor costs and their markup on parts, machining, etc, I'd just go with a used engine and have them drop it in.
Why would you replace the pistons? Assuming good condition, of course. Don't forget bearings, that should be a given.
Old Apr 16, 2009 | 04:49 PM
  #8299
NofrillsGLE's Avatar
Automatic transmission
I searched the forum and think that my 2000 GLE needs the TSB NTB00-039a service done. Basically on WOT or 3/4 there is a delay/hits the rev limiter from 1-2nd gear shifting. All normal acceleration/driving it shifts smoothly and normally. Since experiencing the delay/rev limit I have not driven the car hard/at WOT. But I want to sell the car for something thats manual. I don't want to pass the buck on someone else when I go to sell tho. BUT, I also do not want to spend $2000 to sell the car in perfect condition, I'd be breaking even if I sell it after paying for repairs....
I was quoted $1,900 from a Seattle Nissan Dealer to perform the service. Is there some other way to fix my problem? Or some other shop suggestion in the NW here? I tried looking in the NW forum, but couldn't find much as far as shops willing/had the knowledge to perform the service needed.
Thanks in advance.
Old Apr 16, 2009 | 04:52 PM
  #8300
bump
Just keep the engine supported some how and you should be able to do them fairly easily. Then again which mounts? The sides or the front and rear one.
To kind of answer your other question about the coils, when i had to replace mine i had a missfire a couple thousand miles before they finally went bad. I replaced all at once for the just incase scenario. 40k miles later no problems i also changed the plugs mine went out around 100k. I got them off ebay all 6 for around 300 but that was a couple years ago.
Old Apr 16, 2009 | 05:52 PM
  #8301
MadVillan's Avatar
Originally Posted by Dayo
Hey Guys,
So I found a pair of 2002 - 2003 genuine Nissan Maxima headlight assemblies with ballast and bulbs on ebay for a great deal. So I want to install these on my Maxima but I'm a little unsure what this entails. Is it as simple as plugging the existing cables into the ballasts or is it a little more involved? Do I need to get heavier duty cables or will my stock cables work fine, will the ends need to be rewired etc?
The conversion / retrofit kits I see online look like the ones that the Govt. wants to outlaw and for good reason from what I’ve seen, basically designed to go in existing halogen housing. In the end all I want to do is put a 2003 headlight assembly in my 2000 Maxima and enjoy the benefits of HID vs. what I’m using right now.
Anyway, looking for a little guidance, thanks in advance to anybody who can spell this out for me.
Thanks guys
Im looking for these same answers... ive been searching the forums and found nothing... anyone have some useful info that i could use?
Old Apr 16, 2009 | 07:28 PM
  #8302
Teddie18's Avatar
I don't understand, it took me less than thirty seconds to find this thread. There are many more. http://forums.maxima.org/5th-generat...-how-here.html
Old Apr 16, 2009 | 07:50 PM
  #8303
shummy's Avatar
Hi Guys,
I'm new to your forum, so I can not post thread. Btw nice Board !!!
I'm a new owner of a very clean 2001 Maxima with A/T transmision. I know it is A/T, but....
Here is my problem:
When I start the car, the Idle is around 1200-1500 and sometime it bouncing to 1900
I cleaned the trottle body. but it didn't fix the problem, It look like a manifold leak.
Could it be something else than a leak?
I have a check engine for the ISAC, maybe it's only because the ECM doesn't understand why the idle doesn't match with the ISAC control...
Where should I look for leak on the manifold?
Thanks guys
Old Apr 16, 2009 | 07:56 PM
  #8304
at24's Avatar
Originally Posted by shummy
Hi Guys,
Here is my problem:
Thanks guys
its easy man
the problem can be solved by changing the advanced timing to 17 and also changing the idle from 625 to 690 , this will help make the idle rpm lower and it will make it a lot faster in performance wise as well.
good luck =]
Old Apr 16, 2009 | 08:04 PM
  #8305
shummy's Avatar
Sorry but how can I do that ?
I'm a new owner of Maxima. Before I had a Eagle talon Tsi awd, it was easy, I just had to turn the CAS (Cam angle sensor)
You are sure it's not a leak problem?
thanks for you're answer it was fast
Old Apr 16, 2009 | 08:12 PM
  #8306
at24's Avatar
lol no problem , well there are two things you can do, first keep the car parked overnight then at the morning move it and see if you can find any leakage , then drive around with the car at about 4000 rpm and then park the car at a spot for like 2 hours and get back to it and move it to check for any spills, if you find nothing then there are no leaks.
Second thing you do if you want to advance the timing to 17 degree is to go to a nissan dealership and tell them you want to do it , or you can go to a mechanic that you know that has the CONSULT II machine . Its only a small programming process , it will cost something between $0-$70 which depends on the person you go to
hope that helps
Old Apr 16, 2009 | 08:20 PM
  #8307
shummy's Avatar
by keak I mean leak of air. Some air is introduced in the system without any control of the trottle body
Are you kidding me???
And the car pull hard I tried against other Maxima and they were in my mirror
Old Apr 16, 2009 | 08:22 PM
  #8308
shummy's Avatar
Oh and by the is the intake manifold collector is reusable?
I will probably lift the collector this weekend
Old Apr 16, 2009 | 08:26 PM
  #8309
at24's Avatar
there is nothing as leak of air.... u can use a gab , look for it on other threads , it involves making holes all over the intake system so it wont be a problem at all in the maxima , and yes it is reusable
Old Apr 16, 2009 | 08:37 PM
  #8310
shummy's Avatar
Are you drunk or tired?
Maybe I don't understand what you're telling me
Old Apr 16, 2009 | 08:41 PM
  #8311
at24's Avatar
why u calling me drunk for?
i am telling u what i know
sorry if its not enough
go make your own thread after posting 10 more posts anywhere
goodluck
Old Apr 16, 2009 | 09:43 PM
  #8312
Hi Guys,
Here is my problem:
Thanks guys
First lol at the other guys replies he is simplifying it way to much.
Ok i think you mean IAC idle air control valve not ISAC it is located in the throttle body i believe were the butterfly valve is. When you open the throttle by hand you can kind of see a small depression well thats were its at. Try cleaning really well there again by wetting a rag with carb cleaner.
Or just remove the throttle body and clean it real well but be carefull not to damage the iac. Also move the throttle by hand to see if it sticks.
Another thing that it could be is a clogged or broken vaccum line check them to see if you have a cracked or leaking hose.
One thing you can try to maybe fix this is using seafoam, do a search on it.
Hope this helps
Old Apr 16, 2009 | 09:47 PM
  #8313
Thanks in advance.
Any transmission savvy ppl in here? Or at least know where I can find some?
Old Apr 17, 2009 | 03:09 AM
  #8314
Most would say try replacing the trans yourself since you can buy an auto trans for 300-800 bucks or see if anyone in your local forum can help you out. Or maybe just get rid of the car if when driving normally its fine, since dealers warrant most cars they sell the new user might get it fixed for free
Old Apr 17, 2009 | 05:45 AM
  #8315
memphisballer's Avatar
Originally Posted by at24
hey
why are the headlights bad?
the ebay ones
Not bad.Just mainly for looks not performance.Or for doing a fairly simple projector retrofit.
Old Apr 17, 2009 | 07:12 AM
  #8316
Subternal's Avatar
ok so no 350z engines, gotcha
I figured rebuilding wasn't going to be cheap (at least not like rebuilding of a chevy) but Im not really into the idea of a "shop" doing this. I am planning on doing most of this myself.
As far as pistons, Im not sure of your answer...why wouldn't I replace the pistons? If I am tearing the old engine down to fix an internal engine problem why would I want to put old pistons back in?
As for bearings and such, oh of course I would replace that, along with seals, gaskets, ect..
Where would be the best place to get a bare block then?
Old Apr 17, 2009 | 09:03 AM
  #8317
shummy's Avatar
Hope this helps
Thank you
I already cleaned my TB and it's not the problem
But I'm not sure but I hear some noise behind the Intake manifold collector. What could leak in this area?
If I remove the intake manifold collector this weekend. Could I reuse the gasket ?
Thank you
Old Apr 17, 2009 | 12:34 PM
  #8318
C-Young's Avatar
hope that helps
I just called the Nissan dealership here and they told me they would have to take the "font cover" off to do this. Said it was about 8-10 hours labor.
I then stated it should only be a small programming procedure using a CONSULT II machine and he still said it would be 8-10 hours labor.
So that's a little more than $70 dollars...
Are they just feeding me some BS cause they don't know what theyre talking about or what?
Please shine some light...
Old Apr 17, 2009 | 03:05 PM
  #8319
Tell them they are retarded lol it takes like ten or five minutes to do this. Plug in nissan consult tool, change timing turn keys to off position, turn car on check if timing is at 17 and bam thats it lol. Trying calling a different dealership. The timing on these cars is electronically controlled not by a timing belt like older cars lol
Old Apr 17, 2009 | 03:10 PM
  #8320
Thank you
Thank you
Do you mean the vias activator? The thing circled in red?
