5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Nov 23, 2010 | 06:12 PM
  #11881
foodmanry's Avatar
Da Roller Coaster!
Hmmm...new issue to me. Perhaps you may have an internal problem with your tranny preventing it from shifting. I would take it to a shop or dealer and see what they say. Hopefully it is nothing too serious.
Originally Posted by Doggus
I found out what's causing the shifting issue: the horizontal shaft in the shift rod that moves up and down with the thumb lever is sticking in the bottom position. For instance, press thumb lever, shift to D and the pin gets stuck in the down position. This allows you to bump the shift into reverse without pressing the thumb lever again. Also keeps the key in the ignition when you park as the pin comes up and actuates some plastic levers and a mechanical piece running to the ignition.
Looks like there is white lithium grease surround the pin. I sprayed with WD40 to see if things would loosen up...nope.
Any ideas?
I keep seeing DaveB's name. I need new coils anyway, maybe he'd have an idea on this one.
Old Nov 23, 2010 | 06:14 PM
  #11882
foodmanry's Avatar
Da Roller Coaster!
Originally Posted by jewels76
The battery light did not come on. The car started to shake and shutter after I applied the brakes.
Sounds like you got a problem with an ABS sensor or sensors. The dealer can diagnose which sensor is the problem, or sensors. I'm not sure if other shops have the capability.
Old Nov 23, 2010 | 06:16 PM
  #11883
foodmanry's Avatar
Da Roller Coaster!
Originally Posted by prprinceagd
and can u like specificly tell me where are the precats located? and my main cat is also located? thanks for the help...
Man...please work on your English. It was rough reading your previous post to this...I had serious brain freeze trying to figure out what you were saying.
The pre-cats are located just after the exhaust downpipes from the engine. They are easy to spot as they are fatter parts of the exhaust with heat shields. The main cat is located about a foot down from the rear pre-cat. It is a fatter part of the exhaust with a heat shield.
Old Nov 23, 2010 | 07:12 PM
  #11884
redgreen240's Avatar
Originally Posted by VQP0WER
Try and do a reset:
  • Turn the ignition key on for seven seconds (the length of time the airbag light stays solidly on).
  • Turn the ignition off within 1 second.
  • Wait at least three seconds to turn ignition back on.
  • Repeat these steps two more times (three total).
The system will start a series of airbag light flashes to indicate what the problem is and most likely this will be as far as you'll get with an FSM, but without a Consult. IF the light was brough up by a glitch, as it did with mine, this may clear the light.
Sounds like they didn't replace the ABS sensor for that rear tire when he got into a accident.
Yeah ill try to reboot the light tomorrow. And also, I had to replace the whole rear axle unit with abs sensors and all. I believe that the rear axle was out of an 02 or 03 because the ABS plugs were different so I cut and sodered the old plug onto the new wires... BLK to BWN and WHT to WHT
Old Nov 25, 2010 | 08:54 PM
  #11885
scott33's Avatar
Hi i am new here i just joined i bought a nissan maxima se 20th anniversary edition 2001 i had some question's im having problems finding some parts i need cause when i look it say's the part does not fit GLE or 20th anniversary edition i'm new to nissan's this being my first after having mainly honda's.i just joined here i am not sure how forum work's.i am looking for a mesh grill for my maxima and if anyone else has the 20th anniversary edition i had some question's.i have the bose system and the subwoofer cut's out sometimes is that normal and how do you fix it.
Old Nov 25, 2010 | 09:26 PM
  #11886
marvinzon's Avatar
First of all, welcome to the forum! To answer your question about the Bose stereo cutout, unfortunately its a common problem for all 5th gen Max owners (00-03). BUT, theres a fix for it, just go here: http://www.shiftice.com/bose_cutout_fix.html
If you'd like, I'd advise you to go around that shiftice site, it's like this org's holy bible. Hope that helps!
- Marvin
Old Nov 25, 2010 | 10:34 PM
  #11887
scott33's Avatar
thank you for your help marvin there is alot of threads on here i tried finding one for my 2001 nissan maxima se 20th anniversary edition but could not find one cause i wanted to talk to someone who had one cause it's hard finding some parts for mine or the GLE i wanted to know if someone knows where to get a mesh grill for it i tried looking but there for other 2001's except GLE or 20th anniversary edition.i looked on ebay could not find anything.does anyone know if the grill's are the same for all the 2001's maxima?
Old Nov 26, 2010 | 07:18 AM
  #11888
VQP0WER's Avatar
You would just have to go to Home Depot or somewhere similar and fabricate it yourself. There's a few threads in here about it, I'll try and find one. The grills for the 00-01 (all models) are the same.
Old Nov 27, 2010 | 05:56 AM
  #11889
Cjwilson's Avatar
Hello, I just bought a 2000 SE model last night and I noticed this morning that the radiator support is pretty much rusted through. From reading these boards I see that it is a fairly common problem but I am trying to decide if it is significant enough to return the vehicle for a refund. I paid 6k out the door which seemed to be fair considering the rest of the car is in good shape and is fully loaded and has 99k miles.
Should I head back to the dealership and return this car?
*UPDATE*
Took the car back
Old Nov 27, 2010 | 02:02 PM
  #11890
SEMaxima2000's Avatar
driving with bad maf sensor
my maf sensor is going out or is bad, anyways is it alright to drive with a bad maf sensor?
Old Nov 27, 2010 | 04:52 PM
  #11891
Nelsito65's Avatar
What exactly makes you think that it is going bad?
Old Nov 28, 2010 | 08:20 AM
  #11892
i've had it looked at and thats what ive been told, and it is doing all the stalling and stuff, is it alright to drive until i get it fixed?
Old Nov 28, 2010 | 09:12 AM
  #11893
jowo9's Avatar
Uh, it could fully go out any time, and then it's gonna be hard to drive. I wouldn't take the chance, but that might just be me...
Old Nov 28, 2010 | 06:39 PM
  #11894
gwshearer's Avatar
2002 SE
I need a new horn. Don't want to replace the OEM horn, want something better. Any ideas?
Old Nov 29, 2010 | 04:29 AM
  #11895
VQP0WER's Avatar
Originally Posted by gwshearer
2002 SE
PIAA Sport Horns (500/600mhz). You can get them off Amazon for about $35-40. Andd when you say you don't want to replace OEM, are you wanting aftermarket along with stock? If so, you vehicles stock horn wiring may not support the additional load. These PIAA are just about a direct replacement. I had them in my vehicle before the accident.
Old Nov 29, 2010 | 07:34 AM
  #11896
vinco's Avatar
2002 SE
The Infiniti G35 horns are pretty good, if you want a junkyard option.
Old Nov 29, 2010 | 10:27 AM
  #11897
Veets's Avatar
What parts are required to do the 00-01 to 02-03 front end conversion?
Old Nov 29, 2010 | 11:04 AM
  #11898
vinco's Avatar
Complete Bumper assembly, brackets, lights, grille.
Old Nov 29, 2010 | 01:20 PM
  #11899
ive read and people are saying after you get a maf sensor you have to go get the ecu reprogrammed at a dealership, do you really have to?
Old Nov 29, 2010 | 01:31 PM
  #11900
edgystud3nt's Avatar
Has anyone had a catalytic converter fail? If so, what were the symptoms? What happened?
Old Nov 29, 2010 | 02:47 PM
  #11901
michaelm815's Avatar
What is the size or name of the light bulb that fits side markers, license plate, door courtesy lights, etc... It's all the same bulb I noticed and I want to get some white replacement ones. Thanks!
Old Nov 29, 2010 | 03:22 PM
  #11902
Veets's Avatar
So it's not as easy as just bolting on a bumper?
Old Nov 29, 2010 | 03:45 PM
  #11903
ctsmith39's Avatar
Look here, it is the best site that someone from here made/found.
http://www.moodym.com/maxima/tech/maxbulbchart.html
Old Nov 29, 2010 | 04:29 PM
  #11904
VQP0WER's Avatar
You almost always will get a check engine light. Horrible gas mileage, loss of power, rotten egg smell, potential engine damage.
Old Nov 29, 2010 | 05:07 PM
  #11905
djshwini's Avatar
Ok so i am looking for a double din receiver that has Bluetooth for audio streaming and hand free. I came across this clarion for a great price and I was wondering if anyone had any experience with the HU or has any insight on the subject. Thanks.
http://www.amazon.com/Clarion-VX400-...pr_product_top
Old Nov 29, 2010 | 06:33 PM
  #11906
one more quick thing. I need to make another key for my 2000, anyone have or know about this one?
http://www.carandtruckremotes.com/20...akeyblank.html
I like how its only 20 bucks and has a nice silver burger right on the key, better than most transponder blanks ive seen
Old Nov 29, 2010 | 06:39 PM
  #11907
Nelsito65's Avatar
You might want to ask around in your area to find out who will program it for you before you get it. A lot of loscksmiths will not do it unless the key is purchased from them.
Old Nov 29, 2010 | 07:39 PM
  #11908
The stealership programed my eBay flip key so they should definitely do this one for me. There's also a couple automotive locksmiths I can go to. Does the key I postEd in the link look decent to anybody?
Old Nov 29, 2010 | 08:48 PM
  #11909
00maxima-600rr's Avatar
hey guys, how you all doing, i just have a quick question, where can i buy a good short shifter, i couldnt find any threads about it, thank you!
Old Nov 30, 2010 | 09:50 AM
  #11910
ctsmith39's Avatar
I have not had the best of luck with the clarion HU's, i like the pioneer's. Look at this thread as i know i have seen discussions on HU's. http://forums.maxima.org/audio-electronics-21/
Old Nov 30, 2010 | 10:16 AM
  #11911
rays66fb's Avatar
2000 stock front coil springs.
Hello all, I'm in need of a set of stock front springs and can't seem to locate a pair. Does Anyone here have a set they are willing to part with even if used but low miles a plus. PM me with a price. Thanks
Old Nov 30, 2010 | 02:13 PM
  #11912
Kidnasty's Avatar
Anyone know anything megan racing coilovers vs. D2's?
Old Dec 1, 2010 | 10:15 AM
  #11913
jimjam's Avatar
Alright Im new Ive got a 00 maxima se stock to the fullest extent and im gonna have the car for long long time. But im looking to swap from a auto to a manual, ive searched this site and found useful info but what im looking for, so if anyone can direct me and or tell me the best way to swap and whats needed id appreciate it! Word from the 801
Old Dec 1, 2010 | 12:07 PM
  #11914
2kmaxseblack2k's Avatar
my maxi of 7 yrs is finally leaking oil. Its been making some funny sounds and Im really worried for its life. The leak is coming from directly under the engine, I was told the gasket is bad...but not really sure. Its been making a humming/buzzing sound when I accelerate..typically at low speeds. I just broke 167k miles. So I am really just wanting to keep the car until its no longer functional, but I dont see that happening for awhile. I recently had a power steering issue in the past, but that was fixed. Anyone have comments or anything that can advise me in the right direction?
Old Dec 1, 2010 | 02:28 PM
  #11915
xdsub40's Avatar
I've done alot of research and i can really find the detailed answers im looking for. Here it goes:
I just bought 350z rims and decided i wanted to lower the car. After researching H-techs will give me the smooth ride and moderate drop i was looking for (Im ok with a floaty feeling as long as im not bottoming out everywhere). Now i was looking for which strut is the best combination with the h-techs AND what other things should i replace at the same time (bump stops, strut plates ect.) so i dont have to go back down there again. And how much should i cut the bump stops? thanks for the help guys
Old Dec 1, 2010 | 02:50 PM
  #11916
I'm looking for a write up on how I can get a "chirp" sound like in an aftermaket alarm when i lock my 5.0 gen instead of the horn sound it has stock, without buying a whole new alarm system...is there any easy cheap mods to achieve this?
Old Dec 1, 2010 | 04:37 PM
  #11917
Kidnasty's Avatar
Or after the fix you can simply disconnect your battery for a bit, and the ces should be gone.
Old Dec 1, 2010 | 05:00 PM
  #11918
Slow Motion's Avatar
Hi,
I just bought a 2000 Maxima GLE. I would like to know if there is a (Thread) list of parts here that are interchangeable with this model. Navigation, Seats, Auto Shifter update, and etc. Has anyone put the 2010 maxima seats in the 00-03 maxima or G35 heated seats? I have done some searching but, I think I could be failing at it. I am not familiar with this car at all, if it was a 540i I would be golden but, I am new to the nissan game. Please help. You can send pm's so I can find what you have to say.
Thanks,
Slow Motion | Atlanta,Ga.
Old Dec 2, 2010 | 12:29 PM
  #11919
Trantice's Avatar
This has probably been asked and answered, but I can't seem to find the best search parameters. I am wondering if anyone has any recommendations for a Nissan repair place in Nassau or Suffolk county, Long Island?
I did find someone say that Westbury Nissan was good, but that was a thread that was 8 years old.
Old Dec 2, 2010 | 02:58 PM
  #11920
ctsmith39's Avatar
Originally Posted by Slow Motion
Hi,
Thanks,
pm'd
