5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Mar 5, 2011 | 09:40 AM
  #12601
mccpu's Avatar
Idle Air Volume Learning
I have a 2000 Maxima AT and I'm trying to do IAVL posted here
http://forums.maxima.org/6792957-post1.html
but I have few questions.
How do I turn ON the PNP switch?
US Maxima's don't have daytime light systems, correct?
I perform the procedure while the car is in Neutral?
TIA
Old Mar 5, 2011 | 04:36 PM
  #12602
Hydronnner's Avatar
Pre Cat Delete
I have an 02 Maxima with a bad precat. I saw somewhere that you could delete it by getting some headers for the car. Is this true? If not how would i go about doing this?
Old Mar 5, 2011 | 04:39 PM
  #12603
Ghost_54's Avatar
Yes if you go with headers and replace the Y pipe you will have eliminated the the pre cats .. you have to also replace the Y pipe as the headers will not match up with the stock y pipe
Old Mar 5, 2011 | 05:00 PM
  #12604
Hydronnner's Avatar
K thanks for reply. Could you recommend any website to get these things from and would it matter what y pipe i got with the headers? Or do all of them pretty much go with whatever? Sorry but im kinda new at modding lol.
Old Mar 5, 2011 | 06:04 PM
  #12605
95VQ30's Avatar
you can get OBX or Cattman Headers/Y pipe. OBX can be found in numerous places- just google it(can be had for under 400), good headers but not as nice as Cattman in regards to fit and finish but they are half the price of Cattman(700+ shipped).
Cattman- you will have to call Brian, (really good and informative guy-makes the best exhaust for the Maxima) because they are odd in not having a current and functioning website. I know if he updated that site he would get a few more sales a month easy.
Both header set ups should squeeze out an extra 20 or so HP and give a deeper more robust exhaust note. Be prepared that the installation can be time consuming and/or expensive (6-8 hrs on average).
Old Mar 5, 2011 | 06:46 PM
  #12606
dodgensince74's Avatar
a/c clutch interchangeability?
I have a 2000 Max that is making noise in the a/c clutch assembly so I want to replace it. The problem I'm having is find just the clutch assembly so I was going to just buy a used compressor and swap the parts. The problem I'm having is that the prices for 2000-01 compressors are very high while 99's down and 02's up are lower priced.
My question is, Will the clutch assemblies from any of these other years interchange with the 2000-01's?
Old Mar 5, 2011 | 09:03 PM
  #12607
Hydronnner's Avatar
Yea ill prolly go with the obx since its half the price and i found a diy guide for it too. But hopefully its not too hard for me to pull off. Thanks for the info dude.
O and 1 more thing. How much of a sound difference will this make? I dont want the cheap honda tuner sound like i heard others say. And the only ones i heard on youtube had catback exhausts plus the y pipes/headers, none with juss y pipe/headers. And hows cabin noise? Just need a heads up before i put money on this and the person im doin it for complains.
Old Mar 5, 2011 | 09:38 PM
  #12608
twistedone's Avatar
My 2002 Maxima SE seems to have problems fogging up whenever it is raining. If it is raining out and I'm driving, the windshield will slowly fog up unless I have the front defrost on. I've changed the in cabin microfilter and cleaned my windows but it still seems to be doing it. Anyone have any idea what could be causing it?
Old Mar 6, 2011 | 03:15 AM
  #12609
95VQ30's Avatar
chalk it up to sh1tty glass- I think it's the norm for us.
Old Mar 6, 2011 | 08:01 AM
  #12610
Vadesign's Avatar
Bank 2 (front) pre-cat question
I have the famous P0430 (bank 2 cat converter efficiency error) and have concluded from all that I've read that the front after pre-cat sensor probably isn't kidding (or malfunctioning), I need a new bank 2/front pre cat.
I have nothing stamped on my door that says Cali, nor to my knowledge has the car ever been anywhere but Virginia. Still what to buy as the front pre cat is pretty confusing.
All of the front piece only (single elbow) pre-cats seem to be designated for the california emmissions. Only Catco appears to sell a "federal" precat, and it is the whole shooting match coming off both front and back.
However, when I get under my car, I did a bolt on front precat (5 bolts on top, 3 on the bottom with the red wire 02 sensor plugged into the slug that is sending out the P0430.
Why can't I use an (Eastern, or other) Cali spec front pre-cat on my car? Has anyone who doesn't have a specifically designated Cali-emissions used these with success.
The Cali emissions seem to differ further down stream than this. Anyway, if someone could help me out - I'd sure appreciate it. Thanks.
Old Mar 6, 2011 | 08:36 AM
  #12611
stugotz's Avatar
Also new
Just purchased a '02 maxima se with 6 spd. Looking for websites for ordering new parts on line at best discount prices. If any sites have the diagrams of the parts would be as big help. Please notify, and appreciate any/all responses.
Originally Posted by larryg
OK, I'm a n00b here but I've been around a bit. However, I didn't have much luck doing a search. Anyway, I recently purchased a 2003 Maxima 6spd with about 46K miles on it. I had the oil changed at a Jiffy Lube (about 2K miles ago) and lately I've noticed the oil light gives a quick flicker and I hear a little rattle when I start the car. I remember issues with other manufacturers where the OEM oil filter had a check valve in it but the aftermarket ones did not. The check valve kept oil from draining back when the engine was off. Am I dealing with a similar situation here or do I need to look elsewhere.
Thanks,
Larry
Old Mar 6, 2011 | 11:57 AM
  #12612
anyone have any idea?
Old Mar 6, 2011 | 04:13 PM
  #12613
Hydronnner's Avatar
Is it true that headers/y pipes from 95- 03 are all the same?
Old Mar 6, 2011 | 04:17 PM
  #12614
Nissan2000Maxima's Avatar
I have a stock 2000 Nissan Maxim SE with the OEM rims which are 17"s. I currently have 225/50/17's on them, I was wondering if 235/45/17's will fit?????????? Why or why not?
Thanks in advance!!!
Better yet:
What are all the possible tire sizes that will fit on a 2000 Nissan Maxima SE with the stock/oem 17" rims?? Currently have 225/50/17's.
IVE SEARCHED, NOTHING CONCLUSIVE YET!!!
Old Mar 6, 2011 | 06:31 PM
  #12615
djfrestyl's Avatar
Suspension Yoda
Better yet:
You're going to be a bit off...
http://www.miata.net/garage/tirecalc.html
Old Mar 6, 2011 | 07:24 PM
  #12616
efanatic's Avatar
Originally Posted by Unclejunebug
What's the process like and what tools are necessary? Is there an easy way to determine which coil is bad? I'd like to avoid replacing all six if possible.
As an update, last weekend I pulled out of my driveway and the engine sounded and felt like it was misfiring. It stayed like this for maybe 1/4 mile and SEL light started flashing. After the 1/4 mile the engine went back to normal and SEL light stopped and has stayed off since. From what I've seen on the internet and on this forum a flashing SEL means bad ignition coils.
Would a bad ignition coil go in and out? I always thought that it one was bad it was bad.
Hex key to take off engine cover
10mm socket with extention to undo the bolts holding the each coil
plug socket with extention.
Thats it!
I replaced all mine. My SES light was doing the same (it would come on and go off. It would flash at me when I got on it hard when the SES light was on. All kinds of weird stuff.
Old Mar 6, 2011 | 07:36 PM
  #12617
hillbilly4u's Avatar
02 Maxima, auto tranny
Have been lurking and searching. Have fixed most of the problems with some help from here. 1 is still giving me trouble. Its the passenger side clunk over bumps. Have replaced all 4 struts and strut mounts. Replaced sway bar end links and bushings and alignment. Clunk is still there. The guy that did all the work comes with a good rep for his work. He and I checked motor mounts and they look good. Any Ideas??
Old Mar 6, 2011 | 07:38 PM
  #12618
djfrestyl's Avatar
Suspension Yoda
^^ Just because they look good doesn't mean they are. Pretty common, new transverse mount fixes it right up.
Old Mar 6, 2011 | 08:32 PM
  #12619
Thanks for the reply. The mounts are all thats left, and I have read that alot replaced them. Also ran into a guy selling subframe collars in the classifieds. Think these would help on a stock ride?
Old Mar 7, 2011 | 05:15 AM
  #12620
djfrestyl's Avatar
Suspension Yoda
Ya sure, subframe collars make a nice difference in the ride, doesn't matter if you're stock.
Old Mar 7, 2011 | 05:38 AM
  #12621
What will this cause? Safety hazzard or not really? What is the worst that can happen. Care is for my mom, and I'd like to be as accurate as possible.. (cause 250/50/17 is hard to find atm)
Old Mar 7, 2011 | 06:01 AM
  #12622
djfrestyl's Avatar
Suspension Yoda
Keep it at stock tire size, keep it simple.
Old Mar 7, 2011 | 08:15 AM
  #12623
cj32's Avatar
I would also take a look at your wheel bearings and Hub I have the same issue and the stealership told me it was a bad hub and bearing assy
Old Mar 7, 2011 | 03:32 PM
  #12624
Its hard to find tire sizes 225/50/17 here... thats my issue. And my tire on the passenger front is balder than a .......bald guyy
Old Mar 7, 2011 | 06:03 PM
  #12625
djfrestyl's Avatar
Suspension Yoda
Where are you located that you can't find tires??
www.tirerack.com.
Old Mar 7, 2011 | 06:32 PM
  #12626
^ Toronto ontario. And its not that I cant find tires, its just that I'm not about to spend $6oo-$11oo on tires. Thats as much as the car is worth basically.
Old Mar 7, 2011 | 07:20 PM
  #12627
randalk's Avatar
225 45 17?
just bought an 03, was wondering if anyone ever put 225 45s on a gle with stock rims and suspension. wondering if its going to make it look stupid.
Old Mar 7, 2011 | 08:40 PM
  #12628
shaks's Avatar
you can always check junk yards, they usually sell unnecessary tires, even on rims, prices won't be that bad either. Here in NY they go for 35-50 a piece, but sometimes even stores ask for 75 (I asked why and they said - it's 17'', no difference for width, just 17''...)
Old Mar 8, 2011 | 08:41 AM
  #12629
Scottwax's Avatar
That's Mr. Detail to you
225/45/17s will look a touch small with a stock suspension.
Old Mar 8, 2011 | 09:32 AM
  #12630
crayzs's Avatar
Another noob question....
Can someone tell me what the issues are when buying an aftermarket precat for a cali emissions vehicle? I am not in CA anymore and want to get rid of a 0430 code.
Just got confused by a salesperson who said there are different parts for the CA pre-cat and what they sell wouldn't pass. He may actually have said they don't fit either which...
Thanks.
Old Mar 8, 2011 | 09:52 AM
  #12631
IDKABOUTTHIS?'s Avatar
VIAS SOLENOID CONTROL VALVE
That's the correct part number...I went to the dealership to get my car repaired for this exact same problem and that's is the part and part number they used!
Originally Posted by ridinwitha35
Question, how did you know that the VIAS Solenoid Control Valve is part number 14955-8J10A? I call around to different dealers and no one seems to know what I'm talking about.
Old Mar 8, 2011 | 01:30 PM
  #12632
VQP0WER's Avatar
Thanks.
Just get a Eastern precat. (p/n 40387). It's about $175
Old Mar 8, 2011 | 03:03 PM
  #12633
crayzs's Avatar
that's the part number I was live chatting about. maybe it was a robot.
thanks.
Old Mar 9, 2011 | 08:49 AM
  #12634
Nunya's Avatar
New
Hi everybody..
I have a question regarding a 2003 Maxima GLE I recently acquired. It has a bose system and built in navigation with controls on the steering wheel, but I would like to replace the stereo only to one that is ipod compatible. I was wondering if changing the stereo would affect the navigation and the steering controls or anything else other than the unit i am replacing.
Thanks, and cool site.
Old Mar 9, 2011 | 08:55 AM
  #12635
djfrestyl's Avatar
Suspension Yoda
OEM navi is tied to the HVAC controls. It CANNOT be easily replaced with an aftermarket radio unit.
Your only option is an aux interface kit or FM modulator.
Originally Posted by Nunya
Hi everybody..
Old Mar 9, 2011 | 08:59 AM
  #12636
Nunya's Avatar
Thanks djfrestyl for the quick reply.
That's what i was afraid of, any recommendations on the interface kit? the fm modulator is out of the question.
EDIT: I found this on icarkits http://www.icarkits.com/cars/NISSAN_...003/PODNISV215 is that worth a try?
Old Mar 9, 2011 | 01:19 PM
  #12637
TMoney_87's Avatar
Got a Problem... Driving a 2003 maxima SE
Lately my cars being idleing pretty bad for the last couple of months, only when its cold, runs great when the engines warm no complaints. It will also stall some times(when engines cold), usually when I have it in drive and come to a stop.
Anyways for the longest time I wasn't getting any engine codes, but last weekend I get P0113(Intake Air Temperature Sensor), P0152(O2 bank 2, sensor 1), P0138(O2 Bank 1 sensor 2). Would these codes affect the idle?
Not to mention 2 days ago my exhaust cracked(I saw this coming, did a temp fix but it was -25 C outside, so it wasn't the greatest), right behind the rear passenger wheel. The exhaust line broke, so I'll fix that this weekend, since its going to be warm. Is this a coincidence or could the codes have been triggered by the exhaust brake(O2's maybe, but P0113)?
Old Mar 9, 2011 | 01:52 PM
  #12638
djfrestyl's Avatar
Suspension Yoda
I've had good luck with the USA-Spec and PAC products. Never used the one above. Price on yours is a bit high.
Old Mar 9, 2011 | 05:56 PM
  #12639
95VQ30's Avatar
One way to find out, fix your exhaust and replace the O2's. Or fix the exhaust and drive it for a few days and see if you still get O2 codes.
Old Mar 10, 2011 | 08:25 AM
  #12640
wiseguy55's Avatar
2002 Maxima GLE Auto, Same Problem here
I have the exact same problem! I have taken the car to a mechanic and he told me that it was the front struts, but I kind of dont believe him only because I dont bounce around on the street or highway. Correct me if I'm wrong, but isnt that how you can tell if your struts are bad?
I have also pushed on each strut putting my weight on the car and making it bounce, it does not bounce more than 1.5 times after I stop putting force to it. That's normal correct?
Anyways, my problem is exactly as hillbilly4u. I have a clunk in the front passenger side when I drive over bumps and cracks on the road. It is also a little noticable on the driver side too, but really noticable on the passenger side. I really want to narrow it down and order the correct parts for replacement.
Any ideas or suggestions?
