5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Jan 16, 2012 | 09:32 PM
  #14841
smokin5s's Avatar
Anyone have any idea on how to get my fuel economy up? my car's computer is telling me I'm getting 27mpg, but I would like to see it higher if I could.
Old Jan 16, 2012 | 10:00 PM
  #14842
Amerikaner83's Avatar
tune up, and learn to drive like your gramma
but damn, 27MPG, mix of city and highway? That's better than my GrandAm. Seems to be a good number from what I read on here.
Old Jan 16, 2012 | 10:06 PM
  #14843
smokin5s's Avatar
ya, I'm going to give it a tune up this weekend when I tackle the rear valve covers. my last car got 31mpg, so I might just have wishful thinking... I do alot of freeway driving.
Another question, does anyone steering wheel controls light up? Mine don't and that just seems odd to me.
Old Jan 17, 2012 | 01:11 AM
  #14844
arkangelgabriel's Avatar
Smokin5s on the tail light harness it conected right in. Now the problem was with the hosing. The hole for the brake light was to small. Meaning that particular hole will be to big for your brake light giving your 5.5 uses a different bulb there (smaller than 5th gen). I thought about doing what pmohr said and exchange the housings with the original tail lights but it felt like i was gonna brake it. So like i said i riged it with some electrical tape. And on the steering wheel deal mine dont light up either. Didnt think much of it till now. thought it was normal.
Old Jan 18, 2012 | 02:24 PM
  #14845
iclandicmaxima's Avatar
TCS and Slip light issues
Sorry if this is a repost when i start my car the odd time it will run funny and the tcs and slip light will be on... I will drive my car a few blocks then it will run fine again... any help would be appreciated it seems either tcs sensor might be wacky or its running on only some of the cylinders???
Thanks peeps
Old Jan 18, 2012 | 07:19 PM
  #14846
smokin5s's Avatar
my car came with 1 key and 1 remote... if I purchase a new remote online, how do I program the car to work with it?
Old Jan 18, 2012 | 08:00 PM
  #14847
MuscleEater's Avatar
Hello all. I am a new member and have owned and love my 03 Max for a year now. Hope to gain knowledge as much as I can about the 5 gen from all of you guys.
Future plan is to do a complete header to catback via Cattman. Just wanted to know other options that may be better than this one.
Old Jan 19, 2012 | 06:38 AM
  #14848
homeyclaus's Avatar
Thanks peeps
There is no TCS sensor, TCS uses the ABS sensors to detect wheel spin.
Get a code reader, pull the codes. I don't remember if you need the nissan-specific reader to get the ABS/TCS system codes.
Also, check whether your battery indicator bulb on the dash works. If the battery, tcs, and slip lights come on all at once it's an indication of a failing alternator. I know, it's not obvious.
Old Jan 19, 2012 | 07:39 AM
  #14849
DennisMik's Avatar
If you learn to use the search function, you will have your answers much faster. Here is a link to your answer that I got from searching for "program remote".
http://forums.maxima.org/5th-generat...tructions.html
Old Jan 19, 2012 | 12:57 PM
  #14850
originalhandy's Avatar
I have a 2000 Nissan Maxima SE and it has low profiles on it.
I would like some more air and rubber between me and the road for a smoother ride and I get conflicting sizes online. What is the stock size rim and tyre that I should be looking at ?
Thanks in advance.
Old Jan 19, 2012 | 01:39 PM
  #14851
djfrestyl's Avatar
Suspension Yoda
What size do you have now?
Old Jan 19, 2012 | 02:41 PM
  #14852
cjandura's Avatar
Thanks in advance.
Inside the center console lid list the OE size your car came with.white sticker with green writing.
Old Jan 21, 2012 | 03:47 PM
  #14853
MustangSlayer's Avatar
2000 Nissan Maxima Heavy Duty Clutch Master Cylinder
I have 00' Max SE with a ACT Stage 3 Heavy Duty Clutch kit and I need recommendations on heavy duty master cylinder like crazy. Ive gone through 3 in 2 months. Please help! Thank you!
Old Jan 21, 2012 | 08:01 PM
  #14854
smokin5s's Avatar
I found it thanks!
honestly, I suck at the search function, I remember a post talking about replacing the oil pan, but I can't find it anywhere with part numbers... I replaced my rear valve cover tonight as well as the HP Power steering line, and I noticed my oil pan is rusted to hell and it develops dripping oil from just sitting... I went to rock auto but can't find a oil pan for the 6 speeds.
Edit, Autozone has one for $70 plus gaskets... anyone online that would be cheaper? I typically use Rock Auto, but like I said, no luck with finding the part.
Old Jan 21, 2012 | 08:25 PM
  #14855
pmohr's Avatar
No more Maximas...
I found it thanks!
The oil pans are the same, regardless of trans type.
There is no lower oil pan gasket, it's just RTV.
$70 from AZ, or $78 from the dealer (http://www.courtesyparts.com/11110a-...3-p-52507.html)...hell, Dave B probably has a better price than that.
Old Jan 21, 2012 | 10:21 PM
  #14856
Amber7301's Avatar
Problem after ECM reprogram
Originally Posted by phenryiv1
Credit to SEmy2K2go & phenryiv1:
This thread is for the new members so that they are able to post a question. It can be ANYTHING that is 5th generation related. If we think it is important, we will either answer or make it into its own thread. If not, we will delete it.
This is only for LEGIT 5th Gen questions that may be specific to one user.
This is for noobs only and will be open only as long as we feel like maintaining it. SPAM WILL NOT BE TOLERATED.
This idea was brought to my attention by phenryiv1 in the I30(35) section
ALL MEMBER RESPONSES MUST BA A QUOTE OF THE ORIGINAL QUESTION! New questions, obviously, need not have any quotes.
____________________________________________
5th gen FAQs (READ ME! PLEASE! READ ME!):
http://forums.maxima.org/showthread.php?t=36867
Modification and other HOW-Tos (tells you how to do common things done to 5th Gens):
http://forums.maxima.org/showthread.php?t=33563
ECU Fault codes or Check Engine light diagnostics (5th Gen):
http://forums.maxima.org/showthread.php?t=374481
THIS IS NOT A SUBSTITUTE FOR SEARCH!!!
How do I search? http://forums.maxima.org/showthread.php?t=378748
Even if you are new and have no search privileges, you can read the Stickies (which we are working on to update), use the Google search method, or scan through the forum pages using the Find function on the browser (what I did when I first joined), or any other methods of research you may prefer, prior to just blurting out a question that has probably been asked before.
Please refrain from postwhoring in this thread. Since this thread is meant to help those who still cannot start their own threads, postwhoring just to reach 15 posts is inexcusable.
Hey everyone!
I posted a few weeks ago about a problem I was having and while I was able to fix part of it, I now have another issue. I'm just about to give up on my car because I don't know what to do.
Originally the idle was out of wack ... changed air sensor and IAV, that didn't do anything as I ultimately needed to change the ECM. I took it to the dealer to have it reprogrammed, that fixed the up and down idling and the car no longer dies and starts up just fine. The problem that I have now that I DID NOT have before it went into the dealer is this ... which is kind of hard to explain. When I am in 1st gear and take off at a slower speed right around 1500 rpm it's like it gets stuck and then if I step on the pedal and give it more gas the car jumps, as if I am releasing the clutch when the car is in gear, that's the exact feeling it gives. If I take off with a little more acceleration it won't do it it also does not do it if the car is cold. I don't know if I'm making sense the way I'm explaining it but I can't describe it any other way. I took a video of the rpm when I have the car in neutral, below. I was also looking under the hood and there is a little hose that has a small crack in it, connected to this black box, which I'm not sure what it is (pic attached). Can this affect the car and give me the problem I am having? I called the dealer and told them my issue and told them it was after they reprogrammed the ECM and they said it was my throttle body but before I changed the ECM I had put in another throttle body and that did not make any difference so I opted to put the original one back in, do you think that could still be the problem? I've spent over $2,000 the past couples months and I can't afford to put any more into it and I can't keep playing the guessing game with this car. Any help or advice would be greatly appreciated.
It's a 2001 Maxima with 134, 000 miles 5 speed manual.
http://i32.photobucket.com/albums/d4...121_205810.jpg
http://s32.photobucket.com/albums/d4...121_205151.mp4
Old Jan 22, 2012 | 05:18 AM
  #14857
sandra123's Avatar
shocks/struts on 02 maxima se
I purchased Grabriel ultra shocks/struts and strut mounts for my car and after one day of driving I notice a lot of squeaking among other noises that sounded like something is loose. And it's still rides rough and much more noiser than before the job was done. My mechanic told me after taking it back in to him three times that there was nothing he could do because I bought cheap shocks/struts from Auto Zone and that he is sure he installed them correctly. I am a female that does not know too much about cars and don't know if something was installed correctly or not. Can someone help me as to what the problem maybe. My mechanic told me to buy better quality shocks/struts for him to reinstall in which I will need to pay him again. I don't have money to waste.
Old Jan 22, 2012 | 11:39 AM
  #14858
Sandra your squeak noices are most probably coming from the strut mounts. If the car didnt make squeak noises before you can put the old mounts back (if they still good) and itll solve the squeaking issue. I changed my struts about 6 months ago and i only changed the struts. My strut mounts where still good. I used kyb struts althou i dont recommend them for you since you looking for confort. kyb are stiff struts.
Old Jan 22, 2012 | 01:00 PM
  #14859
kevin84's Avatar
AC Bypass belt rubbing on itself under idler pulley...
Hey all. I just did the ac bypass with a 37 inch 6 rib belt and noticed that the belt is rubbing on itself under the idler pulley. I'm assuming this is bad...and don't want to drive it until it's fixed. Couldn't find any information on this particular issue, and I've read of plenty of people with 2000 max's who use that exact belt...should I just loosen the idler pulley a little? It really looks like something must be different than from pics and diagrams I've seen...because it doesn't even look that close to being clear...any help would be much appreciated!
Old Jan 22, 2012 | 02:25 PM
  #14860
DennisMik's Avatar
If the belt is rubbing, then the belt is too big. You will have to get a smaller one. The bypass belt should be 920mm, or 36.2 inches. I suspect that the belt you have was mis-labeled and is bigger than 37 inches.
Old Jan 22, 2012 | 05:38 PM
  #14861
ryan3417's Avatar
Sorry to resurrect this oooold thread.
Originally Posted by BENMAX03
Okay, I have searched all over this forum about this hesitation issue, and I only find on here info on the problem with the manual transmissions. I however have an auto 2k3, and it hesitates under load/hard acceleration. Let me explain, that I have not had this car for the past 8 months, and I'm sure that 87 octane gas has been used most often. Now I have this car back, I've changed plugs, cleaned maf, cleand throttle body, used fuel treatment and nothing but 93 octane or better. Would my hesitation issues be for something the same as the manual transmissions? Like a ecu reflash needed? Anyone else with an auto have this hesitation?
I'm having the same issue on my 2k3 auto...110k miles. Seriously bogs down/hesitates on hard acceleration. I've been looking at every hesitation thread i could find on here.
Can anyone tell me if the issue that started this thread was ever resolved and what the root cause was? It's exactly what i'm experiencing.
Many thanks!
Old Jan 22, 2012 | 05:47 PM
  #14862
ShocknAwe's Avatar
Many thanks!
The stock A/T just isnt good, plane and simple. Warm your engine up before you drive to allow the tranny fluid to warm up, that will help a little bit. You might also have a leak somewhere. A tranmission controller module from JWT will transform the stock transmission into what you could call "good" performance. Expensive option though
Old Jan 22, 2012 | 05:58 PM
  #14863
vijay101's Avatar
Hi, I am new here and have a question regarding wheel fitment. I would appreciate if someone could let me know if the following wheels and size would fit on my car without problem. I got a 2003 Maxima GLE
TSW Donington 18 x 8 +20 offset 5x114.3
Thank you
Old Jan 22, 2012 | 06:22 PM
  #14864
kurt1's Avatar
Hay guys I'm going to be buying a 5.5 gen Australian spec maxima 3.5l 4sp auto. My concern is the tranny and how realiable is the 4sp autos.? I've heard good and bad and even some people saying there really strong. My question is the australian maxima is it the same gearbox and engine as the American. I had a look at one yesterday and compared an American spec model. Looks exactly the same. Only reason I'm comparing is because I wanna buy some parts from America like exhaust cattman. Nwp block of plates ect. Is the exhaust compatible to the American model? It's got twins at the back stock. Looks very restrictive.
Old Jan 22, 2012 | 06:48 PM
  #14865
ryan3417's Avatar
yeah i dont think it's the tranny. It does this when the engine has been running for awhile. It's when passing on the highway and you really punch the gas that it boggs down.
Old Jan 22, 2012 | 06:56 PM
  #14866
ShocknAwe's Avatar
Does it downshift and still feel bogged when you press the gas down furthur? Try turning the OD off and see if it still seems sluggish when you try to pass at highway speeds. I dont use the OD unless im going on a long HWY trip because when you try to pass with the OD on you almost have to press it to the floor to downshift
Old Jan 22, 2012 | 07:12 PM
  #14867
ryan3417's Avatar
i actually feel the bog when it downshifts. for example: when i'm entering the highway or passing someone and i give it alot of gas, nothing happens for a few seconds then the RPM's start to increase alittle and then a few seconds later it really pulls like it's supposed to...its not downshifting/changing gears when it's supposed to... I remember when i would mash the pedal, the car would really jump, but no more...
  #14868
amixamse's Avatar
ask for a 01 maf at napa they have the iat sensor in them and for half the price of a 03 maf.
Old Jan 22, 2012 | 07:15 PM
  #14869
ryan3417's Avatar
oh and my gas mileage is pretty crappy too. was 17mpg city a few weeks ago. i had cleaned the MAF (i know it's useless on a 2k3 but i was desperate). MPG are now at 21/22 city. not bad but they used to be at 27 consistently since 2003. there's just a general lack of power anymore.
here's what i'm thinking:
1. knock sensor - temporarily replace with a 570k resistor - see if that helps
2. Get a new MAF (car is not throwing any codes)
Old Jan 22, 2012 | 07:59 PM
  #14870
Amave's Avatar
Originally Posted by Amber7301
Hey everyone!
yeah i could see how a loss in vacuum might screw things up . Try replacing that hose and see how it reacts under the same conditions as you were having your problem.
It is very possible your old ECM had adjusted the settings to compensate for the loss of vacumm , and since you have a new ECM in there it, doesn't know what to do with the extra positive pressure.
Its worth a shot and it looks like you can buy some cheap bulk hose form like Home Depot and replace it .
Otherwise i would say it might be IACV related
Old Jan 22, 2012 | 08:06 PM
  #14871
Amave's Avatar
i installed GR-2's and they are not stiff at all... i love them
Old Jan 22, 2012 | 08:07 PM
  #14872
Amave's Avatar
Originally Posted by Kendu34
I just purchased the car and realized the speedometer is not workin correctly. The gauge moves but doesn't give correct speed any idea what it is?
tires correct size?
Old Jan 22, 2012 | 08:10 PM
  #14873
Amave's Avatar
Would you happen to know the part number for the speedometer cable? I can't find it.
this might be due to our cars using an electric speedo ...
cable does not exist, therefore you cannot find it ...sounds like your needle/gauge might be fukked up
Old Jan 22, 2012 | 08:47 PM
  #14874
Wow nice know that!!! I was wayyy off
Old Jan 22, 2012 | 09:05 PM
  #14875
Hey everyone!
Srry to hear you having such a problem with your car. It does sound like maybe a vacum problem but before you change that hose you can just tape it good with some electrical tape and drive to see if that fixes the problem. That way you get that checked out of possible things causing the problem.
Its hard to beleive your car has given you so much problems. All i got with mine was a bad maf senso. 190k still going as new
Old Jan 23, 2012 | 02:36 AM
  #14876
DennisMik's Avatar
this might be due to our cars using an electric speedo ... cable does not exist, therefore you cannot find it ...
Exactly right. Started with the 3rd gen models introduced in 1989.
Old Jan 23, 2012 | 08:23 AM
  #14877
C56spd's Avatar
New 2003 SE owner
My wife and I have owned two Maxima's in the past 96 & 2000 and just bought a 2003 SE auto fully loaded for my son. I have spent a few hours reading/searching on this forum and have found it very informative & educational.
Here is a little bit about the car: Silver/black int, leather, bose, heated seats/steering wheel, (comes in handy in Green Bay!),HID, 150,000 well maintained miles. We haven't driven it many miles yet but haven't discovered any major issues. It did come with brand new winter tires on stock rims. It also has summer tires (225/50/17's) that are in ~70-80%.
We just had the muffler flange cut off and sleeved ($42) to cut down on the noise. I also had the headlights buffed out last night and they look great.
I am looking to do two purchases and would appreciate input:
1) Need to buy new summer rims. Found these Tire Rack:http://www.tirerack.com/wheels/Wheel...All&sort=Price
They also have the MSW Type 14 rim for only $79 each which is really good.
2) I am also considering putting coil overs on the car. Will coil overs be a bad idea with crappy Wisconsin winters? I have read a ton on this but wondered how I choose a local installer if going with Tein or BC Racing. Also, where is the best place to buy the coil overs? Are there any group buys?
I don't want to dump too much money into the car but want it to handle well.
Thanks for all the great info!
Old Jan 23, 2012 | 10:04 AM
  #14878
There you go. I wanted stiffness thou but without knowing i put kyb. Im glad thou! plus moog front end parts to
Old Jan 23, 2012 | 11:52 AM
  #14879
cjandura's Avatar
Good start on the car.i would get coilovers but keep in mind it is a good ideal to swap them out in the winter time.i currently run BC in the summer and tokico Blues in the winter.
Old Jan 23, 2012 | 01:54 PM
  #14880
Amber7301's Avatar
FINALLY Fixed!!
Thank you to all who gave their advice on this post and my previous post. I decided to give it one more shot today and took it into a little shop near my house ... I am DONE with the dealer!! Turns out that the TPS voltage was low and all they had to do was readjust it and then do a relearn procedure...they said that should have been done at the dealer when they reprogrammed the ECM but apparently I threw that $300 down the drain because their job was incomplete. Thankfully this place diagnosed the problem and fixed it for $90. This has been a nightmare and $2600 hundred dollars later my car now runs like it should, I'm thankful to have come across the RARE and HONEST mechanic that I did!
