5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Apr 26, 2008 | 10:00 AM
  #5801
foodmanry's Avatar
Da Roller Coaster!
Originally Posted by GigEmAgs07
so today i heard this pretty nice little squeak coming from under the hood. I noticed that it only made the noise when the a/c is on. It sounds like it's comin from the radiator fans in the very front of the engine right behind the grill. What are my options? it's still spinning well, so could i just wd40 it? any suggestions?
You can try to regrease it, but I wouldn't use WD40, try white lithium grease. The fan motor will ultimately fail though as it sounds like the bearings on the fan motor are on the way out. I had to replace mine. The fan motor is about $120 and it very easy to change out yourself. Do not go OEM as the price is almost twice that amount.
Old Apr 26, 2008 | 10:02 AM
  #5802
foodmanry's Avatar
Da Roller Coaster!
Originally Posted by NmexMAX
You need coils. Also, TCS / SLIP perhaps might be an ABS sensor.
He also needs a MAF sensor as well since the RPM's won't go over 2K at times.
I think the ABS sensor has its own light. I remember damaging my ABS line and the ABS light popped up, or the brake light. But, then again, I don't have TCS on my Max.
Old Apr 26, 2008 | 11:13 AM
  #5803
NmexMAX's Avatar
dot dot dot ...
on the MAF part. Also, if the wheel sensor is in working order, BUT senses slip, it will light w/o the ABS light, so on that too. I must have been drinking last night.
Old Apr 27, 2008 | 12:40 AM
  #5804
netstorm64's Avatar
Thanks for the reply.
I have been experiencing my cars mpg going down, is this most likely caused by the MAF since it regulates flow?
Old Apr 27, 2008 | 02:58 AM
  #5805
sunstream453's Avatar
what factors affect cruise control? im a 6-speed and my cruise control doesnt work. the front right ABS sensor isnt working and is tripping the ABS light and i am under the impression that is why the cruise control doesnt work. would that cause the cruise control to not work?
Old Apr 27, 2008 | 12:25 PM
  #5806
atlridin's Avatar
I agree, get the Berk. I have an Apexi filter with mine.
Old Apr 27, 2008 | 04:06 PM
  #5807
mkogz's Avatar
Just bought a 2000 max and ran into a little problem. When driving, my hazards sometime turn on for no apparent reason. sometimes it will happen and other nights it will not happen. I first had it happen to me and it lasted just a split second. lately, I will be driving and they will turn on then off and on and off then on for a little bit then finally turn off. I have no idea what it could be. Relay? Fuse? Input would be great appreciate.
Old Apr 27, 2008 | 04:20 PM
  #5808
njk4o5's Avatar
are the 00-01 bumpers really different than the 02-03 bumpers? im looking for a stillen lip wondering if one made for the 00 will fit my 02
Old Apr 27, 2008 | 07:30 PM
  #5809
SoonerFan's Avatar
Cletus
yes
no
Old Apr 27, 2008 | 09:58 PM
  #5810
foodmanry's Avatar
Da Roller Coaster!
Yes. Change out the MAF and monitor your MPG. It should be more consistent after a MAF change.
Old Apr 27, 2008 | 10:40 PM
  #5811
majesticmaxima's Avatar
i dont think the abs light will effect the cruise control. My abs light has been on for 6 months or so and the CC still works. However my light came on for the right rear sensor. The circuit is open. I'd say the two are unrelated.
Old Apr 27, 2008 | 11:55 PM
  #5812
maxima703's Avatar
Hey guys I'm new to this forum. I recently purchased a 2000 Nissan Maxima GLE about a month ago and I'm happy to say that it's an all around great car. I do have one question though since I'm not into specifics of cars as much as others. I want to change my headlight bulbs but I'm not quite sure which type I'm supposed to get. I assumed it was the H4. If I'm wrong It'd be great if someone could help me out. Thanks.
Old Apr 28, 2008 | 04:43 AM
  #5813
vball_max's Avatar
http://www.moodym.com/maxima/tech/maxbulbchart.html
add to your favorites
Old Apr 28, 2008 | 06:07 AM
  #5814
NmexMAX's Avatar
dot dot dot ...
Non reacted. Check your fuses (Cruise Control)
Check your fuses (Hazards fuse)
Old Apr 28, 2008 | 06:26 AM
  #5815
Jay5487's Avatar
I have a 2000 maxima and last week i noticed it start to idle a little high (1000-1250) when not in gear. Over the weekend it started to rev itself when not in gear from like 1000 up 1500 then back down and just kept repeating about every 2 sec..... I plan on taking it into a shop because im not very good with cars but I just want a guess at what the problem is so I dont get ripped off....
The car has 63000 miles on it... I recently replaced....
Battery
Starter
Alternator
Oil Change
Any help is greatly appreciated...
Old Apr 28, 2008 | 06:38 AM
  #5816
maxdriver10's Avatar
i'm pretty sure that you're ABS faulting has nothing to do with cruise control...the cruise control could simply be a faulty wiring job, but i'm not 100% sure
Old Apr 28, 2008 | 06:42 AM
  #5817
NmexMAX's Avatar
dot dot dot ...
Battery
Starter
Alternator
Oil Change
Sounds like an IACV issue. Got a SES light? if so, my guess would be P0505
Old Apr 28, 2008 | 06:47 AM
  #5818
Jay5487's Avatar
Yeah, I do... Thanks for the response
Would this be something that would normally happen out of the blue... I just got an oil change about a week ago when the problem started, would it be something they might have done?
Old Apr 28, 2008 | 10:10 AM
  #5819
maxima703's Avatar
Originally Posted by kgallerie
Bulb Cross Reference
9003 = HB2 = H4
9004 = HB1
9005 = HB3
9006 = HB4
9007 = HB5
Since my car is a 00' and the headlight bulb type listed is 9003, I guess it's safe to say H4 bulbs fit in. Thanks kgallerie
Old Apr 28, 2008 | 11:08 AM
  #5820
JonHasAMaxima's Avatar
1) when i turn the dials for turning on the ac or heat the fan doesnt turn on. All positions it stays off. It just happened all of a sudden really, before that it was working perfectly. Anyone know what could be wrong?
2) My left side steering wheel controls dont work. The volume, and all the ones on the left side of the steering wheel dont work, i have an aftermarket head unit so i dont expect the volume to work, but id like the mode thing to work so i could see the mpg and dte etc. The right side (cruise control) works perfectly. Anyone know what could be wrong here?
Old Apr 28, 2008 | 12:21 PM
  #5821
kieljon's Avatar
another noobie question (about window switches)
Hey guys...
I can't find any rear window switches for sale on the web... anywhere! The junkyards around here don't have any either. Anyone know where I can order two?
History: my rear windows (both sides) increasingly began not to roll up. When I took the car in for a rotation/balance and to have the rotors turned, I asked the shop to take a look. They rolled the window 1/2 down, then told me it was indeed broken. (Brilliant!!) They also told me it was probably a regulator and would cost $400 to fix. After trusting they knew what they were doing (another mistake) and purchasing 2 new regulators for both rear windows, I took the door panel off only to find the regulators working perfectly. I recently tested both rear switches. One works perfectly and the other is very spastic (not rolling up well). Both switches performed exactly the same on 2 different motors, so I assume the issue is with the switches.
So, the short of it, I need 2 new window switches. Unfortunately, I cannot find where to buy them. Any suggestions?!
Thanks!
Old Apr 28, 2008 | 01:22 PM
  #5822
foodmanry's Avatar
Da Roller Coaster!
Battery
Starter
Alternator
Oil Change
Hmm...I wonder if that is part of the fuel cutoff TSB. There is one out for the 2k and 2k1 manual maximas. Check that out, if it falls under that then it should be under a warranty I would think.
Old Apr 28, 2008 | 05:08 PM
  #5823
Grand_hustle17's Avatar
5th gen and 5.5th gen headlights
well since everyone ignored me in the noob thread.
QUESTION: ive got HID's in my 2k, i want to go with the 5.5th gen headlights i know it fits but are the bulbs different therefore i have to do different HID's???
Old Apr 28, 2008 | 05:27 PM
  #5824
BoominChu's Avatar
SHIFT_OUTTA DA MAX
you have to get ds2 bulbs... they aready have HID's... you just have to change the bulb.... you current HID kit will then be useless
  #5825
Scottwax's Avatar
That's Mr. Detail to you
Check the fuse for the blower motor first.
You should be able to find it in the FAQ thread, but there is a wire near the HU (brown, I believe) that you have to ground to get the trip computer to work. There is also a wiring adapter that will allow you to retain the use of the steering wheel controls.
Old Apr 28, 2008 | 05:42 PM
  #5826
SoonerFan's Avatar
Cletus
if you buy 02-03 HIDs, they come with everything you need including the bulbs
Old Apr 28, 2008 | 06:00 PM
  #5827
Majestic's Avatar
Yahhhhhhh
Yeah. It was a little weird replacing my HID bulbs last week. It can be kind of a pain since there's little space.
BTW if you need to buy some cheap D2R HID bulbs I got mine from this guy on ebay for $30 shipped. And before others bash me about cheap HID bulbs I bought some from this same guy for my old car and they lasted almost 2 years before I took them out and got new housings. They also heat up fast and don't change color.
Old Apr 28, 2008 | 06:09 PM
  #5828
User 12822's Avatar
About how much horse would I gain on a 2000 max with high quality headers and full exhuast?
Old Apr 28, 2008 | 06:12 PM
  #5829
DrunkieTheBear's Avatar
Turbo'd Saab
on auto 15-20whp with proper tune
on manual 20-25whp with proper tune
Old Apr 28, 2008 | 06:16 PM
  #5830
SoonerFan's Avatar
Cletus
more than the hood scoop
Old Apr 28, 2008 | 06:32 PM
  #5831
irish44j's Avatar
retired moderator
that's because:
1. That thread is for introductions, not asking about headlights
2. You're not a noob.
Old Apr 28, 2008 | 06:35 PM
  #5832
aw89maxSE's Avatar
I'm not a noob, but I have a noob question for those that have 2k2/2k3 or have done the 2k2 HID swap onto a 5th gen and I don't need to start a new thread for it.
In the fuse box by the battery and the air filter, do you guys have fuses in the drivers side and passengers side headlight sockets....I think they are 20A fuses.
Old Apr 28, 2008 | 06:37 PM
  #5833
User 12822's Avatar
lol i took it off yo
Old Apr 28, 2008 | 06:42 PM
  #5834
well can i use the 8000k harness with the DR2, im really not trying to get rid of my HID's they're only like 2 months old... can they fit in the dual halo projectors?
Old Apr 28, 2008 | 06:48 PM
  #5835
SoonerFan's Avatar
Cletus
buy the proper setup and sell your other one
Old Apr 28, 2008 | 06:51 PM
  #5836
SoonerFan's Avatar
Cletus
THANK GOD...now change your sig pic
  #5837
not that pressed, ill just get some new headlights
Old Apr 28, 2008 | 07:00 PM
  #5838
User 12822's Avatar
im too lazy
Old Apr 28, 2008 | 08:59 PM
  #5839
Majestic's Avatar
Yahhhhhhh
Old Apr 28, 2008 | 09:00 PM
  #5840
freshv6power's Avatar
Can you use the old setup as foglights?
