5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Apr 6, 2009 | 10:35 AM
  #8201
pmohr's Avatar
No more Maximas...
Originally Posted by capframe
Thanks pmohr, that's so awesome that you found a picture of it, nice! there it is!!
but what is LIM and UIM? IIRC? I'm a newbie when it comes to working on my car so I don't know.
and is KS replacement something a newbie like me can do? I did replace the fuel filter on my own, based on that ability do you think I can do the KS or will I need special tools and microscopic hands to get in there for this one?
LIM - Lower Intake Manifold.
UIM - Upper Intake Manifold.
IIRC - If I Recall Correctly.
There's a sticky that explains acronyms, BTW.
You don't need small hands if you do the job the proper way, removing the intake manifolds.
Old Apr 6, 2009 | 11:52 AM
  #8202
Craftyanp's Avatar
I have a 2002 Maxima 3.5 6 speed that is in desperate need of a passenger side CV axle. I have bought two and had to return them both due to both axles being around 3 inches too short. I finally took it to a shop where they spent a couple of days going through the same problem I had. They eventually sent it out for a rebuild and it sounds worse now then before. Have any of you had this problem before? What is the correct part number for this axle. Thanks.
Old Apr 6, 2009 | 01:40 PM
  #8203
showgun9's Avatar
Originally Posted by Teddie18
I know with the PAC ROEM-NIS2 you can attenuate (adjust) the electrical flow to the speakers. So you can adjust the overall volume. I used one when I installed my AVIC D2 and it works just fine.
In regards to the fitment issue, there is a gap around the AVIC between it and the GXE trim piece. The reason why is because the AVIC trim piece piece is too big; it won't fit inside the opening of the GXE. There is also a problem with fitment at the bottom of the GXE where it mates up against the HVAC controls. It doesn't clip together well at the bottom, causing a gap.
To eliminate the gap around the AVIC I carefully cut down and then filed down the sides of the AVIC trim piece so that it fit through and flush with the opening of the GXE trim piece.
Procedure
1. Tape a piece of paper to the front of GXE unit and from the inside trace the size of the opening of the GXE onto the paper.
2. Tape the tracing to the AIVC trim piece that goes around the AVIC headunit, making sure that the tracing is centered on the trim piece.
3. Using a utility or exacto knife, trace/etch the outside dimension of the tracing onto the AVIC trim piece.
4. Cut away and file down the sides of the trim piece until it fits inside and flush with the face of the GXE unit. File lightly when you get close to the etched line because as soon as you go beyond the etched line you're toast.
5. Once the filing and sanding was done I attached the trim piece to the GXE unit with epoxy.
Now you have a custom fit piece that eliminates the big gap and is as pretty close to factory fitment as you're going to get anywhere.
Thanks for your help and detailed instructions. I really appreciate it. You cleared up the major issues I was having installing the AVIC.
Old Apr 6, 2009 | 02:02 PM
  #8204
atxking27's Avatar
Anybody?
I need the PR intake template. Ive found some for the 4th gens(THE TEMPLATE) and not sure if it will work on the 5th gen.(can someone confirm) Ive found the instructions on the install process and it shows where the template goes but not an actual full size pic where i can copy and print out my own. Where can I find one? I bought the intake used and asked the seller of it but he doesnt have it either, and Im not gonna just cut into the car.
Old Apr 6, 2009 | 05:27 PM
  #8205
1stMax2K3SE's Avatar
Originally Posted by pmohr
Where the wheels straight when you took them off, or where they turned?
With some force you should be able to move it back into place. Checked the axle?
after hours of playing around with the axle... i took the inner boot off only ito find out one of the bearings had popped off the knuckle that fits into the transmission causing the binding preventing the wheel assembly from mounting correctly.... the bearring grease was milk chocolate and not thick as grease
my question now becomes, do i replace the axle ***. and does a new assembly come with the bearings mounted?
thanks,
john
Old Apr 6, 2009 | 05:42 PM
  #8206
pmohr's Avatar
No more Maximas...
Yes, search around. You're getting the passenger side axle for the 4AT, not the 6MT.
I can get you the part number, but you realize it's going to be $500+ from Nissan, and they'll most likely get it from Raxles.
Call Raxles, see if they have any. They're a rather difficult item to find, unless you buy used or find a 6MT in a junkyard.
Old Apr 6, 2009 | 05:45 PM
  #8207
pmohr's Avatar
No more Maximas...
thanks,
john
Are you 6MT or 4AT? Don't recall if you've mentioned it already. That'll make the decision on whether or not you can even get a new one in a timely manner.
With a new axle, you don't have to do anything to it other than install it.
Old Apr 6, 2009 | 05:57 PM
  #8208
4 spd auto... make a difference?
Old Apr 6, 2009 | 06:00 PM
  #8209
pmohr's Avatar
No more Maximas...
Yes, it's a PITA to find a 6MT axle at most any auto parts store. You should have no problem getting one, though.
Old Apr 6, 2009 | 06:05 PM
  #8210
so.. i guess that means replace it? any old replacement part from the autoparts store, dealer, or some other brand?
Thanks pmohr
Old Apr 6, 2009 | 06:08 PM
  #8211
pmohr's Avatar
No more Maximas...
Thanks pmohr
Well you could put it back together, if you didn't destroy the boot all you'd need is another clamp for it. If you want to replace the whole axle, you could just get it from whatever auto parts store, really.
Old Apr 6, 2009 | 06:15 PM
  #8212
Here's a couple pics. The boot seems in to be in good shape per eye inspection, but the color of the grease leads me to believe there's water leak.
http://www2.snapfish.com/thumbnailsh...0/t_=164402292
Old Apr 6, 2009 | 06:30 PM
  #8213
pmohr's Avatar
No more Maximas...
Requires a login to view the album.
You could always get a new boot and clamps, and a tube of axle grease. Spray everything down, then put it all back together.
Old Apr 6, 2009 | 06:44 PM
  #8214
I think i am just going to play it safe and replace it being it's tore apart, and i've had an issue with the wheel bearring about a yr ago.
Old Apr 6, 2009 | 06:45 PM
  #8215
this link work?
http://www2.snapfish.com/slideshow/A...2/t_=164402292
Old Apr 6, 2009 | 09:47 PM
  #8216
RiDe DaH MaX's Avatar
im planning to buy a ecu for my 2001 GLE ...will a ecu from a 2001 se work on my car ???
Old Apr 7, 2009 | 09:46 AM
  #8217
mbarbasch's Avatar
03 shocks & bra for sale...please post in Classifieds
I sold my 03 Max but have some parts that people on this forum might be interested in.
Brand New KYB Shocks/Struts Front and rear
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
Nose Mask
http://cgi.ebay.com/ebaymotors/ws/eB...m=290308193404
Thanks,
Old Apr 8, 2009 | 07:31 AM
  #8218
maxima415's Avatar
hi everyone. i am looking for a catback exhaust. i was thinking about tsudo n1. does anyone have any suggestions
Old Apr 8, 2009 | 08:05 AM
  #8219
Orgullo's Avatar
$$ Ballin on a Budget $$
Originally Posted by atxking27
Anybody?
This may help you out. I posted it here too but it wasn't stickied for some reason.
http://forums.nycmaximas.org/showthread.php?t=25714
Like the other person said you can replace just the boot and clamps no problem. However, if you do decide to replace it, assuming you are lowered in any way, go with "Raxles." If you can find one at the parts store most offer a lifetime warranty so any issues just take it back.
Yes...
Nose Mask
Thanks,
Wrong place my man.
Strictly choice. All of them give a great sound. It's just a matter of what you want the tip to look like.
1) Cattman
2) Custom
3) Megan
4) Greddy EvoII
5) N1
Old Apr 8, 2009 | 01:11 PM
  #8220
TheOnlyMax88's Avatar
ok so i just figured out how to use the search correctly thanks pmohr, and iv been looking through cat back threads and i even found out what it ment lol man im dumb anyways i think im gonna go custom same place that put on my flow 40 im gettin warp Y first then the whole system my question, which is the B-pipe in the pic ?just out of curiosity, thats not what im gettin but it looks nice but i dont need the muffler
Old Apr 8, 2009 | 01:14 PM
  #8221
pmohr's Avatar
No more Maximas...
That has a two piece B-pipe, it's the top two.
The B-pipe goes in between the converter and the muffler.
Old Apr 8, 2009 | 01:24 PM
  #8222
ok so most of the cat back is the b-pipe, but i also thought the y-pipe was before the cat also, so where does the y fit in if the b is from cat to muffler?
Old Apr 8, 2009 | 01:28 PM
  #8223
pmohr's Avatar
No more Maximas...
The Y is before the converter. It goes exhaust manifolds, Y, catalytic converter, B, muffler.
Old Apr 8, 2009 | 02:23 PM
  #8224
lol ok gotcha, iv really never seen the under side while its on a lift before thats a must, thanks man
Old Apr 8, 2009 | 04:01 PM
  #8225
peteyturbo's Avatar
I need advice on exhaust components for my sisters Maxima. It is an auto 2003 GLE.
The rear section was rusted out about 8 months ago so I replaced that with the HKS rear section. The pipe I bolted the rear section to (b-pipe?) did appear to be on it's last leg as well.
Recently she had taken the car for service and she was told the "front pipe with flex tube" was leaking. I am guessing that this is the "Y" pipe.
So I would like to install some stainless piping to get rid of this factory system that is rusting out. The problem is that I have searched and cannot find anyone that sells these peices for the 03.
She does not want the car to be much louder so the cats must stay along with any resonaters. Can anyone point me in the right direction for any of these products?
Cattman has nothing on his site for this year, and I have searched and came up empty.
Will I be better off doing a custom pipe?? The Y-pipe looks like it will not be much fun to make without a jig
Old Apr 8, 2009 | 04:11 PM
  #8226
pmohr's Avatar
No more Maximas...
Did you call Brian Catts? He may not have them listed on his site, but IME his site isn't updated very often.
Warpspeed has one, too.
FWIW I searched 'y pipe' in the 5th gen forum, here was the very first result:
http://forums.maxima.org/5th-generat...highlight=pipe
Old Apr 8, 2009 | 04:25 PM
  #8227
peteyturbo's Avatar
Thanks man, I guess I should have left out the "2003" when I was searching
I was under the impression that the 03's were a bit different and it looks to be for an 02 for the warpspeed one.
Old Apr 9, 2009 | 03:59 PM
  #8228
Kevin Trout's Avatar
I just had a new 2004 6 speed manual transmission w/hlsd along with a new clutch installed into my 2003 maxima today. I had the transmission shop use half redline mt-90 and half mtl transmission fluids. I also had them install my short shifter (2 piece unit) as well.
The first test drive left me pretty unimpressed. The shifting action is extremely notchy, and several gears are difficult to engage. Should I be worried about this, or is this normal with a new transmission, and will ease up after a break-in period? Should I have waited to install the short shifter after a break-in period?
Old Apr 9, 2009 | 04:03 PM
  #8229
pmohr's Avatar
No more Maximas...
First thing to do is remove the short shifter kit. You shouldn't do several mods at once purely because of this, diagnosis gets harder. Especially when they're within the same category, as the trans and shifting equipment.
Remove the STS adapters, see if it gets any better.
FWIW it shouldn't be extremely notchy, but it definitely shouldn't be hard to get in gear. Which gears? 1/2/R?
It's possible they didn't adjust the clutch pedal correctly. What type of clutch?
Old Apr 9, 2009 | 04:35 PM
  #8230
I found that 1st gear is difficult to shift into from a dead start, 4th gear is very notchy, and shifting down from 4th to 3rd was very notchy as well.
I'm not sure what type of clutch they installed, it's just one that the transmission shop happened to have on the shelf. They called me up when they took the transmission out to let me know the clutch had alot less than 50% remaining. The only thing I noticed with the new clutch is that it has a lighter required pedal effort to engage.
Old Apr 9, 2009 | 10:27 PM
  #8231
d.sull's Avatar
So I took my max into the dealer to get a diagnostics run on it. The service guy told me I needed some kind of induction cleaning that would cost me about $150. He said the car would drive like a whole new car. Sounds kinda like bullsh!t to me but I thought I'd get someone else's opinion. Any suggestions?
Old Apr 10, 2009 | 04:33 AM
  #8232
Progress's Avatar
It's business time.
Ask him if the car had any codes stored. Those induction cleanings are how dealers make money.
Old Apr 10, 2009 | 07:26 AM
  #8233
Just a quick update on the car, I took it out for another drive last night and it already seemed to shift much better than on the initial drive. I'll have to keep an eye on it over the next while, and really take it easy when it comes to acceleration and speed of the shifts until the clutch wears in properly. The transmission already seems to be "loosening up" for lack of better terminology.
Old Apr 10, 2009 | 08:09 AM
  #8234
baronvf's Avatar
Looks like I am going to need a full catback repair as well.
as pictures show everything from my rear-cat out to my muffler(some bastard sold me that piece of crap like 2 years ago)
Needs replacing.
I kind of need of need to bring this one in with out selling a kidney.
Was thinking of ordering everything from warpspeed.
Repair guy says he can save the cat that is rear of the flex tube, but I figure it would be better to just get a new one with the y-pipe.
But the flex tube snapped off the cat, so I need to replace that converter too.
So my question is, is warpspeed decent for a one-stop solution? Or am I better just going to them for the y-pipe?
Is it worth trying to salvage the cat rear of the flex-tube
2000 Maxima California Spec (Does not need to pass cali emissions, I am in vermont)
Looks like I'll need:
Rear-cat
Flex tube back
(cat behind flex tube might be salvagable)
New Muffler
Would like the car to not get ridiculously louder, so I am guessing I need a resonator in the new muffler
Gah.
as always, any help would be appreciated!
1.) How much is this going to run?
2.) Warpspeed or dave B.?
3.) Worth saving the cat rear of the flex-tube?
4.) Where to go for muffler?
5.) The love of a maxima is priceless, right?
Old Apr 10, 2009 | 09:05 AM
  #8235
d.sull's Avatar
Yea, it had the P140 or whatever it is code stored. He wanted me to pay him $700+ to put in three O2 sensors and a MAF. I just bought the MAF and put it in myself and the codes are gone.
Anyway, you're saying the induction cleaning thing is bullsh*t too, correct? He said it would clean the carbon or something from the motor and make it run a lot better. If that's the truth then I'm down for doing it but it sounds sketch. Thanks for the info, Progress.
Old Apr 10, 2009 | 09:09 AM
  #8236
d.sull's Avatar
Originally Posted by baronvf
Gah.
I've heard a lot of good things about Warpspeed. I'm looking to put one of their Y-pipes on my car soon. I'd go ahead and replace everything if you're going to take the time and money to do it. Otherwise you'll probably have to replace it later.
As far as the love of a Maxima being priceless, that's what I keep telling myself.
Old Apr 10, 2009 | 09:13 AM
  #8237
baronvf's Avatar
Thanks, ya gotta tell yourself that.
I called up warpspeed and the owner is going to call me back in a bit to see if he has everything in stock.
Otherwise I guess I will have to go cattman and their complete system, which I hope includes the 2nd converter. (I guess only the front most converter is still intact. )
So this is this piece that I am unsure of what I should be ordering. Is this included in the "catback" exhaust?
I was getting p0430 codes before all this happened with the muffler.
Dallas from Warpspeed said he'll send me some stock stuff he has lying around if he can find all the pieces, I am just a little nervous I am not going to get everything I need.
he also said that his 99 kit could fit but there needed to be an additional bend to get the pipe over the axle. Not sure if the shop I am at now could do it, so I am looking for something that will work without hassle. That being said I don't want to put replacement parts on that will need to be replaced again in a couple years
See pics for the questions:
So where the circle is is the 2nd cat that was connected to flex tube. I have a cali spec vehicle, but OBD inspection for emissions.
Old Apr 10, 2009 | 02:41 PM
  #8238
maxima415's Avatar
im thinking about getting a zex wet kit, and im wondering if i can do a 75 shot safely. or do i need other upgrades before i do this
Old Apr 10, 2009 | 02:47 PM
  #8239
pmohr's Avatar
No more Maximas...
Did you search at all? Look at the Nitrous forum? Look at the stickies?
http://forums.maxima.org/nitrous-40/
http://forums.maxima.org/nitrous/123...rous-faqs.html
Old Apr 10, 2009 | 05:30 PM
  #8240
dcnded's Avatar
Quickie STS
i did the quickie STS today on my 6-spd. for sure an improvement, shortens the throw a full inch , also makes the shifts alot firmer, however do to the loss of leverage at the lever it translates to a "stiffer" feel across the board. Just wanted to drop my 2 cents ...great mod thanks again!!! to Maxima.org
