5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Dec 25, 2009 | 12:10 PM
  #9801
The6spdMax's Avatar
Originally Posted by jrich7720
Hello! Just wondering if anyone could help me identify these wheels. I found them on rockauto.com, listed under both the 2002 and 2003 VQ35DEs. Just need to know what trim level they can be found on, as rockauto is selling them for $171/each(!!). They are 17x7 7-spoke wheels.
Backround: I own a 1999 Altima that will be undergoing a 5-lug conversion that involves swapping out the hubs with Maxima hubs(3rd gen SOHC fronts, and 3rd(?) or 4th gen rears). I'll need 5-lug wheels, obviously.
Those are the GLE 7 spokes stock rim.
Old Dec 25, 2009 | 12:30 PM
  #9802
jrich7720's Avatar
Excellent, thank you. I love the simple look and the finish of these wheels.
Old Dec 27, 2009 | 10:47 AM
  #9803
homeyclaus's Avatar
Originally Posted by vinnie999
I bought a 2000 with blown headgaskets. I disassembled it, had the heads surfaced, crack and vacuum checked and put it back together. It started immediately but is weak, I didnt drive it before buying it due to the head gaskets so this may have been an existing condition. When cold it will start, run ok for a few seconds and die. After warming up it will stay running and barely drive but is very weak. It's not missing or throwing any codes. I pulled the front cover back off and double checked the cam timing and it was good. I thought the converters could be clogged so I left the nuts loose and started it for a few seconds. No difference just louder. I cleaned the MAF, no change. I read through the posts about relearning and resetting the ecm but can't find the proceedure. It acts like severly retarded timing. I have my scanner hooked up to it and cant get any codes. Any help would be greatly appreciated.
Vinnie,
You sound like you've done this before, so I'll assume you've checked for vacuum leaks and made sure that's all kosher, right?
No need to worry about the ECM - it will have reset when you had the battery out to do the head gaskets.
Spending $20 on a Haynes manual might be the right thing to do at this time, if you haven't got one already.
If the timing is retarded (there is still a way to check with a newer strobe light, and my 2001 still has the markings) I'd check to make sure the camshaft position sensor and crankshaft position/TDC sensors are in place, connected, and working first. I'd then check the manual and see if there is anything specific to your model year series that could also be used as timing-related input to your ECM so it times the engine right.
In the worst case, everything but the spot a sensor fires on on the camshaft sprocket was not lined up - and the ECM will get conflicting signals since when the TDC fires the cam signal isn't where it expects it to be.
If you do figure it out, be sure to post an update!
Old Dec 27, 2009 | 02:58 PM
  #9804
novamike's Avatar
00 max thottle position sensor/switch adjustment
I have a 2000 maxima and the throttle position switch to my understanding is suppost to be pins 1 and 2 shorted at idle and then pins 2 and 3 shorted at wot.
Mine will never short the idle part of the circuit due to the way it is bolted on, becauase of this I am having a small feels like miss fire at idle.
I have loosened the bolts and tried to spin it so that the idle indication will be sent to the ecu but there is not enough play to make that adjustment.
Has the butterfly slipped on my throttle body?
there is another set of holes to line up the TPS with but they are not threaded, I put a bolt in there anyway to hold it in place and becasue of the still miss allighnment now in the other direction it sends the idle signal too long and unless I slam on the gas at start it hickups and nearly stalls before it jumps into gear.
I have looks at the TPS module and it looks and tests great... also there is no adustment inside it.
HELP!!!!
Old Dec 27, 2009 | 07:53 PM
  #9805
homeyclaus's Avatar
HELP!!!!
What was the problem you're trying to fix?
Old Dec 27, 2009 | 09:40 PM
  #9806
novamike's Avatar
What was the problem I originaly tried to fix.
"What was the problem you originaly tried to fix?"
My IACV was suspected of being a problem... I replaced it. And following mitchell od5 instructions I needed to check and adjust the TPS to spec. That is when I noticed the TPS will NOT adjust correctly. Right now the car drives very bad from 0 to 10mph but does not thow an SES light after 12 miles. So I am still having trouble adjusting the TPS but I am going to try and smog it now that the light is off.
PLEASE need advise.!
Old Dec 28, 2009 | 10:13 AM
  #9807
vinnie999's Avatar
Thanks for the reply. I have a factory service manual and have used it for the repair. I've read of similar problems (though not as severe) in the posts. The general consensus in those posts was the MAF. I tried cleaning mine but it didnt change anything so I bought a new one on Ebay and am waiting for it to arrive. I've never been one for part changing and am a little concerned that I'm not getting any failure codes. This would normally lead me to believe that it's an ecm problem but the MAF sensor was only $50.00 on Ebay so it's worth a try. I'll post the results. Thanks Again
Old Dec 28, 2009 | 12:34 PM
  #9808
mandyfig's Avatar
Did you get an original MAF sensor for $50? Where in fleabay? Did you just get the sensor and not the whole housing unit, typical in OEM?
Old Dec 28, 2009 | 12:35 PM
  #9809
mandyfig's Avatar
I have been trying to locate a MAF cleaner, Advance Auto is always out and have been tempted to get the Electronics Cleaner instead. Before I buy a new MAF. My mileage is 18 mpg, combination city and hiway, that sucks.
Old Dec 28, 2009 | 02:24 PM
  #9810
VQP0WER's Avatar
You think it's supposed to be better then that?
Old Dec 28, 2009 | 04:49 PM
  #9811
bc06psd's Avatar
Originally Posted by bc06psd
I just bought a 2000 maxima for my kid. It has a few issues but for the price of 2k, I think I got a pretty good deal. I need help finding parts for it now.
I need to get all new trim pieces for the interior. The ones in it are chalky and look terrible. Wheres the best place to get new ones?
The radio and the clock above the radio don't come on. I suspect they are on the same fuse. Correct or should I look for another issue?
I need a passenger side mirror painted ocean gray. Where can I get a mirror already painted?
The CV joint assemblies need to be replaced. I've changed them on other cars before but never a nissan. Is it a pretty difficult job and how long should it take?
Thanks for all of your help guys.
So the only response I got to my question was "junkyard". I assume the poster was refering to the trim piece question, but since he only said junkyard I'm just assuming. Actually I want "new" trim pieces so that can't be right either, dunno. Would anyone else care to share a bit of knowledge. Btw I changed the cv's this weekend. I had to use a cutting torch to get the spindle nuts off. Once I got the spindle nuts off it took all of 45 minutes to finish the job.
Old Dec 28, 2009 | 05:09 PM
  #9812
VQP0WER's Avatar
Ok, new trim pieces are not gonna be cheap, but here ya go:
http://www.courtesyparts.com/maxima-...1956_1957.html
Old Dec 28, 2009 | 05:39 PM
  #9813
bc06psd's Avatar
Perfect! Thanks for helping the newb.
Old Dec 29, 2009 | 06:19 PM
  #9814
vinnie999's Avatar
It's just the sensor, my housing is fine. It was $62.00 including shipping.
Old Dec 30, 2009 | 08:04 AM
  #9815
T.Bear70's Avatar
5.5 Wheel Fitment
Hey people i'm new here and i dont kno if this queston was answered yet but whatstock wheels from any other nissans fit a 5gen maxima? i seen a thread on it awhile back but now i cant find it
Old Dec 30, 2009 | 08:12 AM
  #9816
Nelsito65's Avatar
This sub-forum should give you a good starting point:
http://forums.maxima.org/tires-wheels-53/
Old Dec 30, 2009 | 08:32 AM
  #9817
T.Bear70's Avatar
i jus wanna kno if the nissan murano rims will fit? i seen pics of 4-5th gen maxs wit all srts of nissan rims on here ahile back but now i cant find that thread
Old Dec 30, 2009 | 08:39 AM
  #9818
Nelsito65's Avatar
They do.
Old Dec 30, 2009 | 08:45 AM
  #9819
T.Bear70's Avatar
ok thanx
Old Dec 30, 2009 | 11:05 AM
  #9820
homeyclaus's Avatar
I realize the Mitchell book says that, but generally "adjust" translates to "verify it's not visibly broken, test drive and adjust if needed". So what happens when you set it back to where it was?
On many Nissans (I don't know your model year or engine type) you don't really have to touch any of the throttle body controls when you mess with the valve unless they're in the way.
On many others, as long as it picks up "closed" correctly and the car runs fine, it's fine.
Old Dec 31, 2009 | 02:16 PM
  #9821
vinnie999's Avatar
The sensor was made by Bosch and cured the problem instantly.
Old Jan 1, 2010 | 06:24 AM
  #9822
chrisl67's Avatar
2000 Maxima 124k California Emissions P0135 Woes
Long story short.
Last year car was running poorly, check engine light was on P0135. Won't pass inspection.
My regular mechanic replaced the O2 sensor, light was still on.
Took it to the dealer. Diagnosed with bad Bank1 (firewall side) Pre-Cat
quoted 1300 to replace.
I decided to replace both sides myself the logic being if one was bad the other wouldn't be far behind.
Finally finished the work last month. Car was running better, but still hesitating. Replaced MAF with Napa part. Reset Computer. Car ran like it was brand new.
However, after one drive cycle. (clear codes,drive car, shut off car and allow to cool. Within about 3 seconds of starting the cold car, P0135 back again. Took it back to my mechanic, who checked the wiring all the way from the O2 sensor to the ECU and found nothing wrong.
Took car to the dealer on this past Tuesday. They called up to tell me there were at least 20 things wrong with the car, even though I told them to troubleshoot the light. They found a broken bolt in the mid-pipe flange to the manifold (I knew it was there, the dealer had broken it off when they did the original troubleshooting and didn't tell me). They said there was an exhaust leak, and that was causing the code. So they fixed the broken bolt, and called me to tell me it was fixed($538 labor).
Went to dealer, and sure enough as soon as I turned the key, the P0135 code is back yet again. The dealer told me to call them if the light came back on, which I'll do on Monday.
So I'm left to ponder this issue over the weekend. Admittedly I've never changed the plugs, but the car is running fantastic, and not having any misfires. This seems like a dealer scam, as I've read about 2000 maxima's having recurring O2 sensor issues, but this seems like they know what the problem is, but want to milk me dry before they actually fix it.
I have pictures and details on doing a R&R on the pre-cats if anyone is interested in the details I'll post it in another area once I'm allowed to.
Any suggestions appreciated, because if this continues much longer I'm going to end up driving a Toyota Camry as my next car if my wife has anything to say about it... A fate worse than death...
-Chris
Old Jan 1, 2010 | 01:06 PM
  #9823
vinnie999's Avatar
Vinnie,
NEW DEVELOPMENT
Ok, the MAF sensor cured my problem instantly, for about 20 miles. Now after driving for awhile it's running rich (like black smoke rich) and cutting off at an idle. It's intermittent, but gets worse the longer that it is driven. Still no codes though. I unplugged the o2 sensors while it was running and nothing changed. Anybody got any ideas?
Old Jan 1, 2010 | 09:17 PM
  #9824
BurntRubber1976's Avatar
Maxima Y2K1 20TH Anniversary Engine Starting Issue
May I ask you something and I hope someone has a valid response...
Yesterday being a pretty cold day and night(the temperature was -20C during the day and -24C at night) I tried to start my 2001 Maxima 20th Anniversary which didn't seem to go so well. When I tried to start the car the engine turned over 1.5 turns but too slow to catch so I plugged in the block heater and 3 hours later when I went to start it the engine fired up with no real issues.
Today I attempted to start the engine and it was completely dead, the battery is not even 2 months old(bought at Canadian Tire and it's a Eliminator series with 850 Crank Amps) and I know that it's completely fine seeing as my lights all work without dimming, my interior light stays bright when I crank the Bose stereo however when I advance the key in the ignition to start the car I get nothing. The car ran yesterday fine and today won't take a jump start from my brothers truck, I pulled the battery, brought it inside to warm up and proceeded to charge it. An hour ago I went outside to try to start it and same ordeal took place...everything works, the fuel pump engages along with everything else that prompts on engine start up however the starter didn't even click over. What I'm trying to understand is how from yesterday until today the engine has seemed to fail at firing up. The block heater has been plugged in all day and the battery has been inside the house and charging so what really is left? Solenoids? Ignition Coils? Has anyone had that issue before and if so what did you do to fix it?
Old Jan 2, 2010 | 05:56 AM
  #9825
kknobl's Avatar
Bear with me, folks. New this forum and have never owned a Nissan (been a GM guy) but am considering a Maxima for my next car.
I'm sure they have timing belts, so my question is at what mileage intervals to they need to be replaced? And how much $$ are we talking.
Thanks for any input.
Old Jan 2, 2010 | 09:49 AM
  #9826
mandyfig's Avatar
I think the MAX has a timing chain.
Old Jan 2, 2010 | 11:04 AM
  #9827
Ghost_54's Avatar
You just have to love winter time in Canada. Given the temp. that you have mentioned most batteries would struggle a bit with that bitter cold. Couple of questions is the car parked outside or in the garage? if parked outside any chance that you have it parked facing into the wind, (and is windy throughout the evening)? Even though you say the battery is reasonable new our winter conditions can leave it a bit weak first thing on a very cold morning, but after a few hours and the day time temp rises a bit you are able to start up without an issue. Lights and the internal lighting even with a very weak battery will still function to some degree. I might suggest taking the car back to CT and have them check that battery (as it would still be under warranty) and also check that your alternator is putting out the correct amp. to charge the system properly.
Old Jan 2, 2010 | 04:35 PM
  #9828
pmohr's Avatar
No more Maximas...
How are you 'sure' that they have belts? The VQ has a timing chain (well, 3 of them). There is no maintenance interval for the chain.
Old Jan 2, 2010 | 05:45 PM
  #9829
kaimaxx's Avatar
Hey,
So I'm looking at buying a used 2002 Max. It has everything I want, plus more that I'll probably take out. And the mileage is around 56k, which is good since i travel a lot.
My question is, it has a history of theft. I do plan on taking my mechanic to see it before i buy it. But do you think it's worth the risk? And he's asking 8900 is that fair???
you can check it out here.
http://cgi.ebay.com/ebaymotors/Nissa...item4a9d7a43d2
Old Jan 2, 2010 | 06:20 PM
  #9830
Ghost_54's Avatar
Looks like a nice car, and I feel it is over priced however the mileage is quit good ... personally for 8900 bucks I would have expected it to be completely certified, safety and emission certified.
Old Jan 2, 2010 | 06:47 PM
  #9831
kaimaxx's Avatar
I wanna try to negotiate. Even though he says he won't go any less than 8500. What do you think is a more fair price???
Old Jan 2, 2010 | 07:22 PM
  #9832
Ghost_54's Avatar
Not being able to see the car is going to make my opinion a tad bit bias, the car has very good mileage but I would want to see all service records if any as well I would want my mechanic to review the car for any hidden issues ... but for even 8500 I would want it emission certified and safety certified. My reasons for insisting this from the seller is because the car has low mileage he should have no issue in accommodating the request failure to do so implies there may be hidden issues that he is disclosing.
edit: had to go back and check that mileage as you said 56k well I am in Canada and our cars are in kilometers not miles so if I convert this car to KM it would be just over 90,000km which would put his asking price between 1500-2000 bucks to high and being sold as is, I would have walked away at that point.
If you truly have 8 thousand to spent you can do much much better
Old Jan 2, 2010 | 07:33 PM
  #9833
kknobl's Avatar
Just an assumption on my part, as I kind of always thought the Japanese automakers tended to use belts because of the quieter operation that they provide.
Again, I have about zero experience with foreign cars, so I'm glad to hear the Max's have chains.
Old Jan 2, 2010 | 08:04 PM
  #9834
vrdublu's Avatar
Can someone tell me what are the largest 18" wheels that can fit on the 03 maxima se 8" or 8.5" without rubbing? Not lowered currently, but will probably go with a tein coilover package in the summer.
Old Jan 3, 2010 | 11:36 AM
  #9835
fonz's Avatar
good tips guys,nissan max has the timing chains
Old Jan 3, 2010 | 05:24 PM
  #9836
Jasjeet's Avatar
Xenon Headlights
What do you guys think about replacing the Xenon bulbs in my 03 se.
I want to have 6000K bulbs.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Will thee work with the stock balasts?
thanks
Old Jan 4, 2010 | 08:01 PM
  #9837
graydona's Avatar
Is my timing off?
Hi All,
I'm a newbie to this site and I have a newbie question...
I just bought an '01 Maxima SE, automatic
I check the iginition timing yesterday. I hooked up my timing light to that little check loop next to the transmission dipstick (as directed by AllData).
This is what I see:
Looks like the timing is at least 25 degrees BTDC. I hooked up my laptop and checked the OBD timing and it says 15 BTDC. Shouldn't they be the same? What am I missing here? Is the ECU retarding the timing that much?
Thanks,
Graydon
Old Jan 5, 2010 | 06:02 AM
  #9838
Nelsito65's Avatar
Originally Posted by graydona
Hi All,
This is what I see:
Thanks,
Graydon
I thought no timing adjusting was necessary on these cars. What kind of issues are you having?
Old Jan 5, 2010 | 08:56 AM
  #9839
graydona's Avatar
I'm not having any issues. Car runs great. I just want to understand why my timing light reads 25 degrees and the OBD software reads 15 degrees.
Old Jan 5, 2010 | 11:49 AM
  #9840
homeyclaus's Avatar
Looks like 15 degrees on the harmonic balancer/pulley/whatever there to me.
The computer controls that - it'll retard and advance the timing as needed - at idle in park it's probably trying to save fuel, so it leans out the mixture and retards it to the point that it runs smooth and the mix lights right based on what the knock sensors and O2 sensors say.
Under load it would advance the timing until the knock sensor signaled. That would give you the most efficient power for the fuel you're burning at your air density.
Just a thought.
