*NOOBIES* The "I am new here,but have a question" thread..(post your questions here)
Old Feb 15, 2008 | 06:30 AM
  #361
BenStoked's Avatar
Jesus was a Zombie.
Originally Posted by Greeny
Your cat is fine, you most likely have a vacuum leak somewhere.
thus sayeth the Master.
Old Feb 15, 2008 | 07:17 AM
  #362
internetautomar's Avatar
mod or sell?
vac leak or IAC issue
Old Feb 15, 2008 | 08:33 AM
  #363
Kingkerb7's Avatar
ima check the the vac hoses/ had the car for over a year now and its been doing this idle thing/ a mechanic did tell me it could be a vac leak. whats IAC? anyone know or have a MSD kit for thier VG i heard it really adds power.
Old Feb 15, 2008 | 09:06 AM
  #364
Wiking's Avatar
Originally Posted by Kingkerb7
... whats IAC? ...
IACV = idle air/adj ctrl valve
One difference to a leak: ECU uses IACV when trying to adjust rpm to a pre-fixed level. When IACV -steppermotor jams, it is always kinda 'late', cranking idle down as it shoul be driving up etc... causing fluctuating idle - especially after rpm's drop down.
Typical a leak is constant. Exceptions exist.
- this page sucks = why no pics allowed?
Old Feb 15, 2008 | 10:29 AM
  #365
Kingkerb7's Avatar
wiking can you explain what IAC is /(what it stands for) how would I know that this is my problem and not a Vac Leak? MSD kits? Anyone?
Old Feb 15, 2008 | 01:50 PM
  #366
mod or sell?
IAC = Idle Air Control
stop thinking about upgrades until you have the car running perfectly.
you check for vacuum leaks first and then once they are all found you start playing with other things via the instructions in the Factory Service Manual
Old Feb 15, 2008 | 03:18 PM
  #367
coolsun's Avatar
how do u find vacum leaks? i think i hear a lil
is there an easy way to test for it
Old Feb 15, 2008 | 04:49 PM
  #368
BenStoked's Avatar
Jesus was a Zombie.
look for unhooked vacuum lines, check all vacuum lines for cracks.
Old Feb 15, 2008 | 06:46 PM
  #369
Thanatos's Avatar
i have seen some of these trunk lids and realy like the look. are they custom jobs?
Old Feb 15, 2008 | 06:49 PM
  #370
Greeny's Avatar
¯\(°_o)/¯
Originally Posted by Thanatos
i have seen some of these trunk lids and realy like the look. are they custom jobs? [IMG]http://i185.photobucket.com/albums/x132/slinkyjoe/8.jpg[IMG]
Yes, completely custom..
Old Feb 15, 2008 | 07:01 PM
  #371
Thanatos's Avatar
this will be one of the first mods i will have to do.
Old Feb 15, 2008 | 08:27 PM
  #372
buck2100's Avatar
vacum line help
I have a 90se with 5 spd. Need to know where the vacum line at the end of the top fuel rail goes.This is the small line at the end where there is a round object attached to the fuel rail with two screws.Don't know what this round object is called cant find it in my repair manual.I am changing fuel injectors and did not notice where it was connected or if it was connected some where.
Old Feb 15, 2008 | 11:21 PM
  #373
Uberhass's Avatar
Hey are the 92-94se front grills interchangeable with the older 89-91 se grills?
Old Feb 16, 2008 | 01:38 PM
  #374
BenStoked's Avatar
Jesus was a Zombie.
should be. I think the only difference may be the design.
Old Feb 16, 2008 | 06:17 PM
  #375
mod or sell?
yes there is.
take some propane in a little bottle with a hose and wand. open the valve on the propane and wave the wand around in a careful and methodical fashion. If at any point the engine RPM raises you have found the location of your vacuum leak. You may have to stick the wand under the plenum to find the leak.
Old Feb 16, 2008 | 06:19 PM
  #376
Greeny's Avatar
¯\(°_o)/¯
yes there is.
Or you could realize you have a 14 year old car and just replace all the vacuum lines...For under $20..
But thats just me..
Old Feb 16, 2008 | 06:23 PM
  #377
mod or sell?
But thats just me..
you realize that if you teach a man to fish he will leave you alone, if you give him the fish he'll drive you nuts forever wanting more
Old Feb 16, 2008 | 06:24 PM
  #378
mod or sell?
oh, and not all vacuum leaks come from rubber lines.
Old Feb 16, 2008 | 06:26 PM
  #379
Greeny's Avatar
¯\(°_o)/¯
And here we are talking about this in the noobie thread..
Old Feb 16, 2008 | 06:36 PM
  #380
mod or sell?
not
noobie needs rod
Old Feb 16, 2008 | 06:41 PM
  #381
Greeny's Avatar
¯\(°_o)/¯
[IMG]http://www.mybambino.com/media/fishingrod.jpg[IMG] not
[IMG]http://i26.tinypic.com/11sh994.jpg[IMG]
noobie needs rod
My suggestion and your suggestion will both fix a vacuum leak,but mine is faster, safer,and longer lasting..
And IMHO..Using propane on a vg (POSSIBLE OLD PLUG WIRES LEAKING SPARK) is a big...BIG nono..
Old Feb 16, 2008 | 07:07 PM
  #382
mod or sell?
actually it is quite safe to use, use it at the shop all the time with no issues.
Old Feb 17, 2008 | 06:31 AM
  #383
buck2100's Avatar
Anybody have any info on this?
Old Feb 17, 2008 | 07:11 AM
  #384
BenStoked's Avatar
Jesus was a Zombie.
the thing is the Power Valve Actuator
see http://www.cardomain.com/ride/748507/3 for more info.
Old Feb 17, 2008 | 05:29 PM
  #385
coolsun's Avatar
has any one don a GAB (ghetto air box) mod like those 4th gen cheap a** did?
http://www.youtube.com/watch?v=T2vTI...eature=related
Old Feb 17, 2008 | 10:29 PM
  #386
Kingkerb7's Avatar
My car shakes as if it needs a tune up when the rpm is going back down when I am at a full stop.When the rpm goes down to normal (800) the shaking stops.The shaking is Almost like when you start to lift you foot off the clutch without giving it enough gas. Could this also be due to a vac leak?
Old Feb 17, 2008 | 10:38 PM
  #387
BenStoked's Avatar
Jesus was a Zombie.
not exactly sure what they did there... did they cut a hole on the filter box? I did see a 3rd gen page a while back about cleaning up the intake, including cutting holes in the box(pre filter, of course. I modified that by only taking out the piping between the filter box and the headlight. better sound, and a little better pickup. may not be as good as a CAI, but its cheaper.
Old Feb 18, 2008 | 10:10 AM
  #388
coolsun's Avatar
i think wat they did was remove the other end of the air box tubing leavin the top end and strapping it tightly to the side where the air goes into
like a pop charger but not round using only the stock filter
Old Feb 18, 2008 | 03:40 PM
  #389
timstover's Avatar
Engine swap injector difference 94 to 91
I am swapping a 91 vg30e into my 94 gxe. The 91 was totaled but had a great running engine. My 94 engine has a rod knocking and had severe blow by. With the 91 engine on the ground I am replacing the front and rear crank seals, cam seals, timing components, water pump and thermostat. All is going well except the injectors have different connectors. I have read much, by searching, about the different injectors. However, I simply would like to swap the fuel rails, with injectors, from my original engine to the replacement engine. The injectors on the original engine ran great and didn't leak. Will this work? My concern relates to an engine swap in did in my 91 300zx ( I know the motor is different). On my 300zx the newer injectors required a different fuel rail which required a different intake. I was hoping this would not be the case on the vg30e. Thanks for any help. Tim Stover
Old Feb 18, 2008 | 03:43 PM
  #390
Greeny's Avatar
¯\(°_o)/¯
Yup, they will swap into your replacement engine with no problem.
Old Feb 18, 2008 | 04:24 PM
  #391
mod or sell?
Don't forget to swap over all the sensors, and replace the coolant temp sensor.
Old Feb 19, 2008 | 06:34 PM
  #392
buck2100's Avatar
The vacum line I'm talking about is under the plemum.It is at the end of the top fuel rail.It has a larger rubber line coming in from the fire wall side that is to the right of the fuel line coming from fuel filter.This line connects to a round metal piece that is connected to fuel rail. This round piece also has a small rubber line at the opposite end of the the larger one.This is the line I can not find a place for it to connect to. I assume this is a vacum line. I have looked at these pics before but could not find what I was looking for.It might be there I just dont see it. Thanks for your help.
Old Feb 19, 2008 | 06:38 PM
  #393
Greeny's Avatar
¯\(°_o)/¯
Sounds like the fuel pressure regulator vacuum line.
I will get you a picture of where the vacuum line goes to either tonight, or in the morning..
Old Feb 20, 2008 | 07:00 AM
  #394
Greeny's Avatar
¯\(°_o)/¯
Here ya go..
Old Feb 20, 2008 | 06:18 PM
  #395
benz-tech's Avatar
VG30 goodness
Alright, Moderators, I am post-whoring. This 15 post thing is getting old and I would like to share some beautiful pics of my professionally ported VG heads. Here's a teaser...oh wait, I can't even put a picture up. Am I missing something?
Old Feb 20, 2008 | 06:23 PM
  #396
Greeny's Avatar
¯\(°_o)/¯
Not in here..
Go here---> http://forums.maxima.org/forumdisplay.php?f=65 post a few nice comments about a few cars..
Then read this sticky---> http://forums.maxima.org/showthread.php?t=377037
Old Feb 20, 2008 | 06:39 PM
  #397
benz-tech's Avatar
Will do. And thank you. I'll take it easy on the rants in the future.
Old Feb 20, 2008 | 08:47 PM
  #398
G3Karl's Avatar
why cant I post new topics?
Old Feb 20, 2008 | 08:48 PM
  #399
Greeny's Avatar
¯\(°_o)/¯
--->http://forums.maxima.org/faq.php
Old Feb 20, 2008 | 09:04 PM
  #400
G3Karl's Avatar
thanks
