5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Well the only thing the OBDII scanner is going to do is read your stored codes if your SES light is on. Usually the codes are relevant to mechanical related issues, like a misfire, exhaust, MAF, etc. I don't believe there are any P0xxx codes for charging system issues.
Sounds good.
Just did a quick google search for "p0 codes" - nothing in the standard lists about battery/alternator.
Heres a quick key to deciphering codes.
http://www.kbmsystems.net/obd_fault_codes_ref.htm
Hello.
I'm new to the forums, purchased a 2001 maxima, manual, love it.
Problem is, the high pressure hose for the power steering is leaking slightly where the connection between rubber and metal is. So, went to the dealer, they will sell me one for $195.
Well, advanced auto parts selling it for $165.
So, is there a difference, does anyone have any experience with aftermarket high pressure hoses? Which one should i go for? Is the price premium worth it for the OEM part?
Second, O2 sensor after the CAT has failed. P0140 code..
Anyway, should i get the OEM one for $130 or bosh universal for $50?
Any input is appreciated.
Thanks.
Thanks.
Hello.
I'd go with an OE replacement, but not an OEM sensor. I wouldn't touch a universal for a replacement, but that's just me.
Is there a switch somewhere to disable airbags? Maybe i should check the fuses...
PS: This is the sensor id need for my P0140 code, right? Link
The thing is that there are no other codes beside P0140...
You're speaking of engine codes, the SRS system is entirely different. If the light is on, there's a code stored (or was). No, there's no switch.
Again, why go with an OEM part? That's quite an expense, you can likely find OE style aftermarket parts for well under that price. But yes, that's the correct part.
What did you use to pull codes, a scanner or a code reader? If a scanner, does it have SRS capabilities?
Guess il have to pay a visit to my dealer to get this checked.
Thanks.
You can pull the codes yourself, or most any shop that does more than just oil changes should be able to read them as well. The ability to read SRS codes(especially on an older car like this) is commonplace.
Ive heard that the dealers cover any SRS related issues.
Is this true?
New to the forums etc etc etc.
Here goes it
5.5 gen
The front rotors on the car are currently warped pretty bad and like with most car enthusiasts I would prefer to upgrade. Not sure on the conditions of the pads but they will also be replaced.
What seems to be the most popular upgrade is installing the 6th gen brakes up front (not sure about the rear) and then your done. However I am not really in a position to accomplish this.
Im currently looking at aftermarket rotors that are slotted with stock calipers and either metallic or ceramic pads. I would also like to get some SS braided lines too.
Is the 6th gen kit better or would better rotors, pads and lines work better?
A case of which is best I guess.
By the way all four corners will be replaced not just the front.
Here goes it
5.5 gen
i did all that already but when I go to edit avatar, where do I put it? theres nowhere for me to insert the code or upload to here
need help
can i change the back right side light by myself? i busted it the other day running into the mail box. is it expensive or do i have to take it to dealer.
also can a 7in dvd double din player been installed?
Yes, it can.
I want to think that is true, obviously if it hasn't been tampered with. But even if it's not true, the SRS system most likely carries a very long 'warranty'.
Here goes it
5.5 gen
Here goes it
5.5 gen
The other way you want to go will help, but not as much. Many of the better pads are pretty noisy as well, which some people really hate.
Hi folks! I recently got a service engine soon code p0340 for the camshaft postion sensor.. '02 maxima. i've been doing some research and i'm getting mixed info on the location of this sensor. to my understanding this sensor is on the passenger side.. or is it the one under the air intake to the rear on the drivers side? thanks in advance for your help.
(edit: thanks, Brett.)There was a TSB back around 2004 for dealers to replace the CPS because of a faulty design in the production parts. If yours are original, it's possible you got one of the bad ones. Then again, 9 years is a good run, eh?
Here, you might find this entertaining and/or informative:
http://forums.maxima.org/5th-generat...y-5th-gen.html
Hello.
Will the oil pan from a 4th gen maxima fit a 5th gen maxima?
My oil pan is somewhat bent and it might choke the oil pump and my gasket leaks, so going to solve 2 problems at once.
Thanks.
Thanks.
New member here. If all goes well I hope to be picking up an 02 Maxima from the local Honda dealership. Clean car, test drove it last night. Just introducing myself, because I'll probably have some questions lol.
Thanks,
-Will
Thanks,
-Will
They should be interswapable. Question is...why? Do you just happen to have a spare 4th gen oil pan laying around?
So I am going to install an amp to my double din within the next couple of days. I know how to hook it up its just I am unsure of how to get through the firewall. I know there is a grommet that leads above the wheel well. There are a lot of posts on it but they all have dead pics on them. Any help?
Battery or alternator
I searched and couldnt find the answer, I was driving last night and i noticed my lights on the inside were going dim (speedometer, dash lights) and it also looked like my headlights were dimming too and a few minutes later while i was driving all the lights like the brake light, air bag light, tcs light all popped on, and all of my door speakers stopped working all i could hear were my subs in the back, i parked the car and it wouldnt crank back up but i left it sitting and it started back up, could anyone tell me what caused this?
any help is appreciated thanks
i have an 01 ae btw
oh yea one more thing everytime i turn my car off it makes a noise like 4 or 5 times and when i turned it off last night it still made the noise but it was realll slow
i have an 01 ae btw
i have an 01 ae btw
i have an 01 ae btw
Did that on my last car. Worked just fine.
Hello.
Does anyone on these forums have any experience with clifford alarms? I bough the car that was fitted with clifford, the previous owner did not include any clifford related items, manuals or information.
I recently disconnected the battery, now the alarm basically chirps 4 times randomly when the car doors are unlocked, or the car is running under 40 miles an hour or so. Is finding a clifford dealer my only hope?
Hello.
Crawl up under the drivers side foot area. Look up and see where they mounted the alarm brain. It will be a black looking box. Typically they zip tie it to the main wiring harness. There should be a label on it with the model #. If you can get that, then you should be able to download the manual.
No model number in sight, il look more tomorrow when i have the time and when its not dark...
whats going on. im having an issue, i have a 2001 nissan maxima se 20th anni, it has all original parts under the hood, motor is completely stock came with 56k now has 58k, bought it like 2months ago out of a dealership. now since ive had the car every things been fine, runs great, but recently ive been noticing the head has some sort of clicking, feels like to me it could be the valves that need adjusting but im new the the nissan game so i no nothing on how to deal with this issue and how much it will cost me, how long do i have till it goes out on me and will i need to also do a timing chain aswell? now i am currently using mobile 1 fully synthetic motor oil just did an oil change yesterday ( is there any possible way it could be the oil i am using? ) and nothings changed but its been tiking for about 1 month and half, now if any body can please help me with this issue i will be very great full l and thanks in advance.
I have an unusual issue which has not disabled my 2002 Maxima, but has me wondering. On a recent trip into a city, there was a flashing of two dash lights, one on the left, and one on the right. It was so brief I don't know what they were. I left it at a garage for two days. They checked the alternator and did other voltage tests three different times over the 2 day span and it always tested fine. They suggested a new belt and I had it installed.
On the return trip, while leaving the city, at around the same region on a dual lane highway, the warning lights again flicked on briefly. They never came on again for the rest of the 100+ KM journey, nor in subsequent days. When the lights briefly appear, it has no effect on the operation of
the car. The check engine light is not lit afterward.
This is going to sound strange, but it is the only theory I can come up with. I suspect there is a strong source of radio or similar energy in that highway location which causes a problem in some borderline electronic part. The stereo is stock original and I don't have anything extra patched into the car like a CB radio.
Anyone ever see two dash lights flick on and off like this while driving?
I need to start posting more newbie questions.
